Relax, XBMC will restart shortly. (not)
Posted: Wed Dec 18, 2013 4:02 am
by kristisdad
My Raspbmc goes through all the setup, updates, then starts an endless loop of Relax, XBMC will restart shortly, but it doesn't… What's wrong??
Re: Relax, XBMC will restart shortly. (not)
Posted: Sun Dec 22, 2013 2:59 pm
by mombasa123
Yup - I am getting this too. Was fine last weekend. Googled it and saw similar issues in the past but none of the solutions then work now,
Also did fresh reinstalls etc but no luck. Deffo stuck :(
Posted: Sun Dec 22, 2013 4:44 pm
by kristisdad
I don't know what happened, maybe the SD card got corrupted (I'm not a techie), so I reflashed a new card with Raspbmc and started from scratch, restarted and Voila!, all is fine.
Posted: Wed Dec 25, 2013 12:26 am
by AIR802
I have a new unit. It goes through the various stages, the latter stages being:
*Updating service management
*downloading new XBMC build
*Extracting XBMC
*Relax, XBMC will restart shortly
Press ESC key for a command line
However, like the others are reporting it never moves from this stage. I tried "recovery" but it goes through all the motions and right back here to the same spot. What do I need to do? Do I need to download a new image onto the same SD card?
Posted: Wed Dec 25, 2013 2:13 am
by hcarreathers
I had the same problem. But I can't seem to get it to read a new image. What download did you use?
Posted: Wed Dec 25, 2013 2:25 am
by kristisdad
I used a new Kingston 8GB Class 10 SD and download from: http://www.mattcardle.co.uk/how-to-inst ... mc-on-usb/
No muss, no fuss, started right up.
Hope this helps.
Posted: Wed Dec 25, 2013 6:28 am
by hcarreathers
That worked! Thanks!
Posted: Wed Jan 15, 2014 3:20 pm
by Dr. Theamat
I had the exact same problem... It's in this post http://www.raspberrypi.org/forum/viewto ... op#p473212 . It looks like the only solution is to format the NOOBs card and reinstall another image...
No one else has a better solution for this? In what format should I format the SD?
Posted: Wed Sep 17, 2014 3:51 pm
by capecape
I have solved this issue following [url]http://sørenj.dk/?p=506[/url]
Connect via ssh, stop xbmc service, rename directory ~pi/.xmbc/ and reboot
BR
Posted: Tue Sep 23, 2014 12:47 am
by Pinoob1234
Hi
Just got my Raspberry Pi B+ in the mail today, I downloaded the RaspBMC An XBMC Media Centre thing and loaded it to the micro 8 gig SD card, hooked up the Pi to the TV and ran it let it do all the updating and rebooting etc. now I am at the Relax, XBMC will restart shortly loop thing.
I hit escape and it takes me to a login screen I log in then it takes me to a command prompt thing, I am command prompt stupid, I am black screen have to type in commands stupid if it does not have a GUI I will need detailed step by step instructions if you leave out a space or make one little typo in your instructions I will never get it to work.
Looks like this problem has been going on for a really long time what is the fix for this problem?
Suggestions?
I bough the Rasberry Pi to use as a media player I was under the impression its a proven design and the software is proven and has a GUI? IS their another software I should be using ?
Thanks in advance.
Posted: Tue Sep 23, 2014 12:19 pm
by DirkS
When and from where did you download the Raspbmc image?
Posted: Tue Sep 23, 2014 12:30 pm
by kusti8
Use openelec or xbian, they are faster and are easier to use. No command line if you don't want to.
Posted: Tue Sep 23, 2014 12:52 pm
by DirkS
kusti8 wrote:No command line if you don't want to.
That's also the case with Raspbmc.
In this case it only showed up because of user actions when the problem dialog showed. Effectively the user 'wanted to'...
Posted: Tue Sep 23, 2014 6:29 pm
by Pinoob1234
DirkS wrote:When and from where did you download the Raspbmc image?
First time was a week or so ago off the Raspberry site go here http://www.raspberrypi.org/downloads/ RaspBMC
An XBMC Media Centre download it followed the instructions using the installer thing in the tuorial when that failed on 3 different memory cards formatting and reloading each card 3 times (9 tries) I gave up and downloaded the Raspbian
Debian Wheezy and installed it then added the RaspBMC off the menu same results cycle of Relax, XBMC will restart shortly and it does it never stops restarting.
Formatted the card AGAIN and installed the Raspbian Debian Wheezy then picked OpenELEC An XBMC Media Centre it works life is good.
After searching the web found out the Relax, XBMC will restart shortly is a common problem thats been going on for like 9 months, once they resolved that problem please reply here I will try it again, since its a known problem I will not waste any more of my time trying.
Hope they resolve the problem.
ALL of my downloads and instructions to install came from the official site http://www.raspberrypi.org/downloads/
Thanks for the help.
Posted: Wed Sep 24, 2014 12:39 am
by DirkS
What problem is that? I have used Raspbmc since the start (2 years ago?) and never had it myself.
BTW: I don't understand
and downloaded the Raspbian Debian Wheezy and installed it then added the RaspBMC off the menu same results cycle of Relax, XBMC will restart shortly and it does it never stops restarting.
How did you add Raspbmc to a Raspbian Wheezy install? Both are separate distros...
Just to go back to basics: is the power supply sufficient (is the red power led always on?). Any USB peripherals plugged in?
Gr.
Dirk.
Posted: Wed Sep 24, 2014 1:18 am
by Pinoob1234
Gr.
Dirk.
What problem?
Get some time to do some reading its a common problem https://www.google.com/#q=relax+xbmc+wi ... mmand+line
I cured the problem I installed Openelec .
Thanks again.
Posted: Fri Mar 13, 2015 6:07 pm
by twoDarkMessiah
FIX:
Connect to Shell via SSH or Local:
Login with your 'pi' user...
enter following commands:
sudo apt-get update
sudo apt-get dist-upgrade
sudo service stop kodi
echo 'SUBSYSTEM=="vchiq",GROUP="video",MODE="0660"' > /etc/udev/rules.d/10-vchiq-permissions.rules
sudo usermod -a -G video pi
sudo reboot
Now you Raspbmc should start normally. :!:
