SD card format problems
Posted: Sun Dec 08, 2013 10:49 am
i cant get my Micro SD card to format back to 8gb so i can put NOOB on it any help?
A small, affordable computer with free resources to help people learn, make things, and have fun
https://www.raspberrypi.org/forums/
https://www.raspberrypi.org/forums/viewtopic.php?f=28&t=62825
i cant get my Micro SD card to format back to 8gb so i can put NOOB on it mikerr wrote:Click options, format size adjustment = ON
MrEngman wrote:Read page 3 of the Raspberry Pi Quick Start guide.
http://www.raspberrypi.org/wp-content/u ... e-v2_1.pdf
MrEngman
MrEngman
You don't need to define "Volume Label" and "Quick Format" should also be OK but just in case you can try "Format Type -next342 wrote:MrEngman wrote:Read page 3 of the Raspberry Pi Quick Start guide.
MrEngman
it still says 58mb is that alright and do i put anything in the "Volume Label" and it is set to "Quick Format"
MrEngman wrote:You don't need to define "Volume Label" and "Quick Format" should also be OK but just in case you can try "Format Type -next342 wrote:MrEngman wrote:Read page 3 of the Raspberry Pi Quick Start guide.
MrEngman
Full Overwrite" but it will take much longer.
After formatting it should show the full size of the card. What machine are you formatting it on? Do you use a built in card reader or an external USB interfaced card reader? Using a built in card reader can be an issue. Presumably you have tried Option with format size adjustment = ON, haven't you?
MrEngman
