A have a PI running 24/7 on a remote location only with SSH access and a good friend who can unplug and plug the power cable...
From time to time it appears that the Ethernet connection on the Pi dies and maybe also the USB.
A have a big psu connected with more than enough amps and the cpu usage is very low ( around 0.05 ).
The system was running stable for the first 14 days, but after a power outage the errors began to show up.
Since I'm not much a hardware guy I would like to hear in which log to look for some hints on what actually goes down ( if it's the bus, the Ethernet connection or the Pi ) and also what to look for in the log ?
Thank you in advance.
BooX
