andrewstillie
installing isc-dhcp-server
Thu Dec 05, 2013 10:41 pm
I am following a tutorial at http://www.penguin tutor/news/raspberrypi/wireless a hot spot
At the Add access point and DHCP server software stage I get the following error......
[email protected] / $ sudo apt-get install hostapd isc-dhcp-server
Reading package lists... Done
Building dependency tree
hostapd is already the newest version.
The following extra packages will be installed:
isc-dhcp-client isc-dhcp-common
Suggested packages:
resolvconf avahi-autoipd isc-dhcp-server-ldap
The following NEW packages will be installed:
isc-dhcp-server
The following packages will be upgraded:
2 upgraded, 1 newly installed, 0 to remove and 125 not upgraded.
Need to get 2,433 kB of archives.
After this operation, 1,876 kB of additional disk space will be used.
Do you want to continue [Y/n]? y
Err http://mirrordirector.raspbian.org/raspbian/ wheezy/main isc-dhcp-client armhf 4.2.2.dfsg.1-5+deb70u3
404 Not Found
Err http://mirrordirector.raspbian.org/raspbian/ wheezy/main isc-dhcp-common armhf 4.2.2.dfsg.1-5+deb70u3
404 Not Found
Err http://mirrordirector.raspbian.org/raspbian/ wheezy/main isc-dhcp-server armhf 4.2.2.dfsg.1-5+deb70u3
404 Not Found
Failed to fetch http://mirrordirector.raspbian.org/rasp ... _armhf.deb 404 Not Found
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
Re: installing isc-dhcp-server
Thu Dec 05, 2013 10:49 pm
Your RPi isn't connected to your WiFi (and therefore isn't connected to the public Internet).
Or your subnet mask is incorrect.
Or your gateway / routing table is incorrect.
Your WiFi adapter has gone into power saving mode.
Or you cable isn't connected to a live port on your router/switch.
This is a doctor free zone.
andrewstillie
Thu Dec 05, 2013 11:05 pm
Ok. I will check again tomorrow.
Could it be something to do with the changes made in the previous step in the interfaces file?
Thanks for you help!
Thu Dec 05, 2013 11:16 pm
andrewstillie wrote: Could it be something to do with the changes made in the previous step in the interfaces file?
Here's my working sample /etc/network/interfaces
auto lo
auto eth0
auto wlan0
iface lo inet loopback
iface eth0 inet dhcp
allow-hotplug wlan0
iface wlan0 inet dhcp
wpa_roam  /etc/wpa_supplicant/wpa_supplicant.conf
And /etc/wpa_supplicant/wpa_supplicant.conf
network={
  ssid="NETWORKID"
  scan_ssid=1
  psk="redactedpassword"
# proto=RSN
# key_mgmt=WPA-PSK
# pairwise=CCMP TKIP
# group=CCMP TKIP
Fri Dec 06, 2013 7:03 am
Did you do a
sudo apt-get update
before running the install command?
I suspect not, as the current isc-dhcp-client is 4.2.2.dfsg.1-5+deb70u6, not 4.2.2.dfsg.1-5+deb70u3.
The old one possibly doesn't exist on the server anymore, which is why you get a 404 Not Found error.
andrewstillie
Fri Dec 06, 2013 12:45 pm
Hi Dougie,
Is this the setup that you have for using your Pi as a Wifi-Hotspot or is this the config I need when connecting to my home wifi network.
Cheers
auto lo
auto eth0
auto wlan0
allow-hotplug wlan0
network={
  ssid="NETWORKID"
  scan_ssid=1
# proto=RSN
# key_mgmt=WPA-PSK
# group=CCMP TKIP
andrewstillie
Fri Dec 06, 2013 12:47 pm
I did a "sudo apt-get update" at the start of the process.
it appears that it went wrong when I issued the
command.
rpdom wrote:Did you do a
sudo apt-get update
Fri Dec 06, 2013 3:14 pm
andrewstillie wrote:Hi Dougie,
Cheers
That's the home network version. My experiments to get my Pi running as an access point are on hold.
auto lo
iface eth0 inet static
address 192.168.xxx.7
gateway 192.168.xxx.1
netmask 255.255.255.0
hostapd /etc/hostapd/hostapd.conf
auto br0
iface br0 inet static
address 192.168.xxx.8
bridge_ports eth0 wlan0
iface eth0 inet6 static
address 2001:xxxx:xxxx:xxxx:ba27:ebff:fe00:069e
netmask 64
iface wlan0 inet6 static
address 2001:xxxx:xxxx:xxxx:821f:2ff:fe68:c6af
netmask 64
