MrEngman
Re: (UPDATE) Drivers for TL-WN725N V2 - 3.6.11+ -> 3.12.19+
Sat May 10, 2014 12:06 pm
lorigio wrote:Hi thanks for your work :D
However how can i update the drivers for every new firmware before reboot?
Now i must plug my pc keyboard on the pi to update the firmware because ssh is no longer accessible after firmware update.
If you look about 12 posts back here I describe how you can update the drivers after doing rpi-update but before rebooting to load the new kernel.
The description uses 3.12.18+ #677 and other items referencing that version as an example. You will of course need to use the ones relevant to the version you are updating to.
I really should add this to the original post with all the other install details.
MrEngman
shailu178
Fri May 16, 2014 4:28 am
hi
i already downloaded the script as suggested by @LaFambe but if you can help me how to run it
sorry i m very new to raspberry pi
thank you for help
MrEngman
Fri May 16, 2014 8:31 am
shailu178 wrote:hi
thank you for help
Hi, I've just tried running the script to check if its still OK and it doesn't appear to be working. Possibly my fault as I've changed the format of the post it gets the driver information from, sorry.
Looks like you are going to have to follow the installation instructions here. There is further information on configuring the wifi connection here
MrEngman
MrEngman
Fri May 16, 2014 10:17 am
Hi shailu178,
OK, I've figure out what the problem is. Seems like a change to the forum addressing, due to a recent update to the Raspberry Pi web site, is causing the script to fail.
I have fixed the script available from dropbox. You can download, install and run it using the following set of commands.
wget https://dl.dropboxusercontent.com/u/80256631/install-8188eu.tgz -O install-8188eu.tgz
tar -xzvf install-8188eu.tgz
chmod 755 install-8188eu.sh
./install-8188eu.sh
Providing you are using a raspbian linux image this should install the driver you need.
MrEngman
piboy123
Sun May 18, 2014 7:45 pm
Is there any news on whether the necessary changes will be in the next release of Rasbian directly?
And if so, when the next release might be?
MrEngman
Sun May 18, 2014 7:56 pm
piboy123 wrote:Hello,
I presume you mean when will the driver be included in the code, right?
I've no idea, and don't particularly care as I use a different version of code. The one that's going to be included requires a driver file and a separate firmware file. The firmware was stripped out of the normal source and made into a separate file for some unknown reason. Not at all helpful in my view.
MrEngman
MrEngman
Re: (UPDATE) Drivers for TL-WN725N V2 - 3.6.11+ -> 3.12.20+
Mon Jun 02, 2014 10:37 am
WARNING: The latest apt-get update/upgrade for Raspbian installs kernel 3.12.20+ #687.
After running command sudo apt-get update you will need to update the wifi driver for 8188eu devices, before rebooting your Pi, using the following commands otherwise you may fnd your wifi no longer works.
wget https://dl.dropboxusercontent.com/u/80256631/8188eu-20140509.tar.gz
tar -zxvf 8188eu-20140509.tar.gz
sudo install -p -m 644 8188eu.ko /lib/modules/3.12.20+/kernel/drivers/net/wireless
sudo depmod 3.12.20+
MrEngman
reizaaditra
Wed Jun 04, 2014 3:27 am
MrEngman wrote:WARNING: The latest apt-get update/upgrade for Raspbian installs kernel 3.12.20+ #687.
MrEngman
Hello MArEngmang
I've previously installed kernel driver when 3.10.25 + and when I updated to kernel 3.12.20 + and follow the tutorial as you still can not
do i have to delete the previous driver or not?
Terima Kasih
MrEngman
Wed Jun 04, 2014 8:38 am
reizaaditra wrote: Hello MArEngmang
Terima Kasih
You do not have to delete the previous driver.
However, you can save some space on your SD card by deleting the old module directories. If you use command ls /lib/modules it will show the modules directories. You can delete the old ones as you do not need them.
On my PI which I have updated from 3.10.37+ to 3.12.18+ then to 3.12.19+ and now to 3.12.20+ I type command ls /lib/modules and it shows me
[email protected] ~ $ ls /lib/modules
3.10.37+  3.12.18+  3.12.19+  3.12.20+
It shows old module directories 3.10.37+, 3.12.18+ and 3.12.19+ and and the new directory 3.12.20+. The old directories are not used and I can make more free space on my SD card if I delete these old directories. To delete the directories I need to use the command sudo rm -r 3.10.37+ (or 3.12.18+ or 3.12.19+)
On your Pi command ls /lib/modules will probably show a different list of directories, possibly just 3.10.25+ and 3.12.20+. You can delete directory 3.10.25+ but be careful and DO NOT DELETE 3.12.20+.
MrEngman
Tmgiewont
Re: (UPDATE) Drivers for TL-WN725N V2 - 3.6.11+ -> 3.12.21+
Thu Jun 12, 2014 8:48 pm
I tried to do this all but whenever I try to enter in the URL of the Dropbox thing it says error unable to reslove host address what do I do!?
MrEngman
Fri Jun 13, 2014 12:16 am
Do you have access to the internet from your Raspberry Pi via a wired ethernet connection, eth0? If you do then you shouldn't have a problem. If not you can download the driver on another machine and copy it to the SD card used by the Pi. The install instructions detail how you can do that.
MrEngman
Tmgiewont
Fri Jun 13, 2014 1:16 am
I put the program on the SD card now when I put in the code with the drop box thing it does say that it saved index.html.1 but then is says that the URL of the drop box is no file or directory not sure what I did wrong help?
MrEngman
Fri Jun 13, 2014 2:05 am
Please answer the question I asked. Does your Pi have a connection to the internet with network cable?
The file you say you download is index.html. This is not right. You are not downloading the file correctly. The file should have a name like 8188eu-20131219.tar.gz.
If you look here http://www.raspberrypi.org/forums/viewt ... 28&t=62371 there are instructions to install the driver if you have an internet connection. There are also instructions to install the driver if you do not have an internet connection to your Pi.
What operating system have you installed? NOOBS and raspbian or just the raspbian image?
What is the output from commands uname -a and ifconfig -a.
If you answer all the questions I can tell you the right instructions.
MrEngman
Tmgiewont
Sat Jun 14, 2014 5:27 pm
I don't have interent connection
I have NOOBS and raspian the desktop is up and fully running when I log in
Uname -a: Linux raspberry 3.10.25 #622 PREEMPT fri Jan 3 18:41:00 GMT 2014 armv61 GNU/Linux
Ifconfig -a
Etho Link encap:Ethernet HWaddr b8:27:eb:87:80:89
UP BROADCAST MULTICAST
MTU:1500 Metric:1
RX packets: 1309 errors:0 dropped:0 overruns:0 frame:0 Tx packets: 108 errors: 0 dropped: 0 overruns:0 carrier:0 collisions:0 txqueuelen:1000
RX bytes:88204 (86.1 KiB). TX bytes:9866 (9.6 KiB)
lo Link encap:local loop back
Inet addr:127.0.0.1 Mask: 255.0.0.0
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:0 errors:0 drooped:0 overuns:0 framed:0
TX Packets:0 errors:0 dropped:0 overruns:0 carrier:0
Collisions:0 txqueuelen:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
Tmgiewont
Sat Jun 14, 2014 5:30 pm
Wait I may actually have interent connection because I have a TRENDNET.
TEW-647GA (that I use to get wifi for my xbox) and when I plug that into the pi via Ethernet a yellow light comes on so I'm not sure what that means
MrEngman
Sat Jun 14, 2014 7:37 pm
I don't know either, perhaps you have an internet connection?
To install the driver you do not need an internet connection to your Pi but you need another machine with an internet connection to download the driver file.
If you have a Windows machine download the driver from here https://dl.dropboxusercontent.com/u/802 ... 219.tar.gz to you windows machine. Then take the SD card from your Pi, plug it into a card reader on your Windows machine and copy the file to your SD card.
Plug the Sd card back in your Pi and boot raspbian. Now look at the instructions for installing the driver on an SD card that uses NOOBS and raspbian. I put the like in my previous post. They look like this
# copy driver file from NOOBS boot directory to your home directory
# mount the NOOBS boot directory
sudo mount /dev/mmcblk0p1 /mnt
# copy the file to your home directory - note there is a period(full-stop .) at the end of the command
sudo mv /mnt/8188eu-20131219.tar.gz .
# unmount NOOBS boot directory
sudo umount /dev/mmcblk0p1
# untar the file
tar -zxvf 8188eu-20131219.tar.gz
# install the driver
sudo install -p -m 644 8188eu.ko /lib/modules/$(uname -r)/kernel/drivers/net/wireless
# register the driver
sudo depmod $(uname -r)
# load the driver
sudo insmod /lib/modules/$(uname -r)/kernel/drivers/net/wireless/8188eu.ko
Hope that helps
MrEngman
Richy_T
Re: (UPDATE) Drivers for TL-WN725N V2 - 3.6.11+ -> 3.12.22+
Wed Jun 18, 2014 12:45 am
hi guys, i just got my RPI today and have been trying to set it up for a few hours but am running into some problems
after loading a raspbian image running rpi-update & apt-get update
the TL-WN752N was installed properly using the helpful script on this page, i configured it in /etc/network/interfaces and it was working.
then i installed debs for PiTFT screen (tried using both beta & normal deb)
https://learn.adafruit.com/adafruit-pit ... stallation
it gets the display working but breaks the wifi for me, the kernel changes to 3.10.32+ #6 (on beta deb, on the other deb it also changes to some other number)
i tried reinstalling TPlink after installing PiTFT debs using the install script but get a "cannot match kernel" error message.
reinstalling with -k for closest kernel build doesnt do anything either...
I too am having the same issue. If anyone has got this module together and would upload it somewhere (or put it in the install script), it would be much appreciated.
Given that adafruit sells the tft and from the shots of their network adapter in their store, it is this one, it is surprising that this is not smoother.
MrEngman
Thu Jun 19, 2014 3:41 pm
Hi Richy_T,
I've been looking at trying to get a working driver for you and it's proving a real pain. I've tried loading the linux source and then loading AdaFruits patches to be able to compile the source but the patches fail to load. Typical tutorial which only half explains things. Why don't they say what kernel version their patches work with. I presume an early version of 3.10 but it could be a late 3.6 version looking at the file dates. Not much good I think for 3.10 from mid March.
Anyway I decided to try something different. I downloaded their image from here http://adafruit-download.s3.amazonaws.c ... -pitft.zip and installed it on an SD card. Command uname -a shows
Linux raspberrypi 3.10.34+ #1 PREEMPT Fri Mar 28 20:10:54 CET 2014 armv6l GNU/Linux
so I downloaded the 8188eu driver for 3.10.34+ I compiled for raspbian without PiFTB and it loads without problems. The same driver works for 3.10.32+ so may be OK for you.
Just one thing. I don't have an PiTFT. I have my Pi with the PiTFT image connected to the ethernet and an HDMI display. When I power on it boots and shows a few lines of very small text and then I presume initialises, or tries to initialise the TFT which there isn't one and no more text appears on the HDMI display. I then tried to connect using SSH and it works, and so appears to have booted OK, so I can do what I need without a working display connected directly to the Pi. So as I said I downloaded the 8188eu driver and used command insmod to load it and it loads without problems so should work fine for this kernel version.
Is the script you are trying to use the one from @LaFambe. If it is it will not work as kernel version and build are not supported in the list of those that are valid.
I would suggest loading the driver manually. Worked for me so I don't see why it will not work for you, unless the image loaded using the deb files is incompatible.
If you have a wired internet connection you can install the driver using the following commands
# download and untar the driver
wget https://dl.dropboxusercontent.com/u/80256631/8188eu-20140117.tar.gz
tar -zxvf 8188eu-20140117.tar.gz
# now check it will load Ok so will work
sudo insmod 8188eu.ko
# if you do not get any error message it will work and you can continue to install the driver
sudo rmmod 8188eu
If you don't have a wired internet connection to download the driver take a look at the original post with the install instructions with details how to load the driver using a different machine and then copying it to the SD card.
Whether it will work for you I don't know but it looks like it could so well worth a try.
MrEngman
raspiuser22
Thu Jun 19, 2014 9:39 pm
Hi All,
I bought a Raspi 5 days ago with a TL WN725N V2.
I tried almost every tuto i found on the internet and it still doesn't work.
I run raspbmc =>
Linux raspbmc 3.12.21 #2 PREEMPT Wed Jun 11 04:53:06 UTC 2014 armv6l GNU/Linux
[email protected]:~$ wget https://dl.dropboxusercontent.com/u/802 ... 509.tar.gz
--2014-06-19 23:06:49-- https://dl.dropboxusercontent.com/u/802 ... 509.tar.gz
Resolving dl.dropboxusercontent.com (dl.dropboxusercontent.com)... 54.243.255.237, 23.23.200.116, 54.225.188.65, ...
Connecting to dl.dropboxusercontent.com (dl.dropboxusercontent.com)|54.243.255.237|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 300268 (293K) [application/octet-stream]
Saving to: `8188eu-20140509.tar.gz'
100%[===========================================================================>] 300,268 457K/s in 0.6s
2014-06-19 23:06:56 (457 KB/s) - `8188eu-20140509.tar.gz' saved [300268/300268]
[email protected]:~$ tar -zxvf 8188eu-20140509.tar.gz
8188eu.ko
[email protected]:~$ sudo install -p -m 644 8188eu.ko /lib/modules/3.12.21/kernel/drivers/net/wireless/
[email protected]:~$ sudo insmod /lib/modules/3.12.21/kernel/drivers/net/wireless/8188eu.ko
Error: could not insert module /lib/modules/3.12.21/kernel/drivers/net/wireless/8188eu.ko: Invalid module format
I tried :
sudo wget http://raspberry-at-home.com/files/8188eu.ko -O /lib/modules/`uname -r`/kernel/drivers/net/wireless/8188eu.ko
--2014-06-18 23:56:40-- http://raspberry-at-home.com/files/8188eu.ko
Resolving raspberry-at-home.com (raspberry-at-home.com)... 188.128.169.103
Connecting to raspberry-at-home.com (raspberry-at-home.com)|188.128.169.103|:80... connected.
Length: 967478 (945K) [application/octet-stream]
Saving to: `/lib/modules/3.12.21/kernel/drivers/net/wireless/8188eu.ko'
100%[===========================================================================>] 967,478 1.78M/s in 0.5s
2014-06-18 23:56:41 (1.78 MB/s) - `/lib/modules/3.12.21/kernel/drivers/net/wireless/8188eu.ko' saved [967478/967478]
[email protected]:~$ sudo depmod -a
[email protected]:~$ sudo modprobe 8188eu
ERROR: could not insert '8188eu': Exec format error
I also tried :
[email protected]:~$ sudo wget https://github.com/lwfinger/rtl8188eu/b ... 88eufw.bin -O /lib/firmware/rtlwifi/rtl8188eufw.bin
--2014-06-19 00:03:56-- https://github.com/lwfinger/rtl8188eu/b ... 88eufw.bin
Resolving github.com (github.com)... 192.30.252.130
Connecting to github.com (github.com)|192.30.252.130|:443... connected.
Length: 25277 (25K) [text/html]
Saving to: `/lib/firmware/rtlwifi/rtl8188eufw.bin'
100%[===========================================================================>] 25,277 --.-K/s in 0.1s
2014-06-19 00:04:03 (214 KB/s) - `/lib/firmware/rtlwifi/rtl8188eufw.bin' saved [25277/25277]
Any idea ... ? this wifi key is just pain when i see how many messages on forum talking about this one...
MrEngman
Fri Jun 20, 2014 7:53 am
Hi raspiuser22,
Different versions of linux usually require drivers specifically compiled to work with each different version. The driver files you've downloaded are for Raspbian, not raspBMC and so will not work with raspBMC. If you read the first post where the list of drivers I have compiled are shown with install instructions you will see it says the drivers are for Raspbian.
I am not familiar with raspBMC but have just downloaded the latest standalone image from here http://download.raspbmc.com/downloads/b ... nal.img.gz and installed it on an SD card and it seems there is a driver for the TL-WN725n V2 already installed, although different to the one I use. HOWEVER, the driver included needs a seperate firmware file and that is not included. Why it's not included I don't know, something the raspBMC people need to sort out. It was built into the driver but lwfinger mangled the driver so much and created a seperate firmware file. A real pain and totally unnecessary. I use a different version which does not need a seperate firmware file.
The driver file in raspBMC is installed here /lib/modules/3.12.21/kernel/drivers/staging/rtl8188eu/r8188eu.ko. This requires the firmware file rtl8188eufw.bin which you appear to have downloaded so the included driver should now be usable. If you boot with the wifi dongle connected and type command lsmod, this will show the modules loaded and hopefully you will see r8188eu, the driver file, in the list.
I would suggest you delete the driver files 8188eu.ko that you downloaded and installed so they don't get in the way of things.
I haven't used raspBMC but I believe it uses NetworkManager to configure the wifi, but how to use it I don't know. If you have further problems I would suggest you try the raspBMC forum for help.
Hopefully this throws some light on things and you now get your wifi working.
MrEngman
raspiuser22
Wed Jun 25, 2014 9:59 pm
Hi MrEngman, thank you for the help.
I didn't know that RaspBMC was totally different from the Raspian OS, i'm going to try something else and will post here the result.
Mou
Drivers for TL-WN725N V2 - 3.12.22+
Fri Jul 04, 2014 7:04 pm
Hello, I have a problem, I need to install the TL-WN725N v2 in version 3.12.22 + but the installation must be offline (because I have no internet access in my Raspberry B without the TL-WN725N).
Anyone have the files I need for installation? To download them and put them through pendrive.
Thanks!
M56.- :ugeek:
MrEngman
Re: (UPDATE) Drivers for TL-WN725N V2 - 3.6.11+ -> 3.12.23+
Fri Jul 04, 2014 8:39 pm
Why don't you take a look at the first post in this thread. That tells you how to install the driver without the Pi having an internet connection.
MrEngman
Mou
Sat Jul 05, 2014 6:38 pm
Sorry but, I saw the answer after making the post, maybe I hurried to ask.
The driver worked fine, thanks!, But when I upgrade (rpi-update) to version 3.12.24 + stopped working and can not find the link for that version. You got out there?
Apologies again, thanks for the prompt reply.
regards
