ShortCircuit217
Re: (UPDATE) Drivers for TL-WN725N V2 - 3.6.11+ -> 4.xx.xx+
Sat Jan 14, 2017 2:48 pm
MrEngman wrote: Applying random commands is just going to mess things up. I would suggest you try and install the right driver - mt7610 - for the T1U then you might get it working. Searching the forum for "T1U" might help.
MrEngman
After researching more I was able to get your automatic script to install the driver!
However my device cannot resolve outbound connections and seems to only be seeing 5GHz networks. The wifi logo is also greyed out even though it's saying it's associated to a network. I've tried changing the WLAN number to 1 in the config file, with the same result.
aa777888
Mon Jan 23, 2017 4:31 pm
aa777888 wrote:
MrEngman wrote:
aa777888 wrote:MrEngman,
I updated Raspian, downloaded and installed the new, latest install-wifi tool, checked that a driver was available for the latest kernel, updated the kernel and driver according to the built in help, and...
I am still getting the same kernel error and attendant behavior as shown in my post above.
Is there anything I can do to fix this? Should I obtain something other than the DWA-171?
Thanks,
aa
I've been using this driver for a long time now and have never seen anything like this before or on any other Pi's I run. Searching the internet would appear to indicate it is a shortage of virtual memory e.g. viewtopic.php?p=136644#p136644 during heavy usage. It's a really old post but could provide a clue to a solution, just need to sort out how to do this with the current kernel version to provide a similar solution.
Maybe posting a new thread referencing the error you're getting "Unable to handle kernel paging request at virtual address" may get you a better response.
Sorry I could not provide a better answer.
MrEngman
Thanks for the response, MrEngman!
Actually I had posted a separate threat first with almost that exact title, however nobody responded to it for several days. Hence, in some desperation, I posted in this thread which seemed to be active and had your attention.
I followed up on the previous thread you provided, but increasing the vm.min_free_kbytes did not improve the situation.
At this point it would seem wisest to try another 802.11ac adapter, perhaps one that uses a different driver.
All: I would appreciate one or two recommendations in that area, please.
Thanks,
aa
Since the definition of insanity is to continue to do the same thing and expect different results, I obtained an Edimax AC600 adapter, updated the driver using your fantastic installation tool (really, it is a fabulous tool and we are all indebted to you!) and obtained exactly the same results as with the D-Link--great performance until the kernel exception :-(
[ 1095.364354] RTL871X: rtw_set_802_11_connect(wlan0)  fw_state=0x00000009
[ 1095.382756] Unable to handle kernel paging request at virtual address bc471062
[ 1095.382780] pgd = 80004000
[ 1095.382791] [bc471062] *pgd=36b63811, *pte=00000000, *ppte=00000000
[ 1095.382817] Internal error: Oops: 7 [#1] SMP ARM
[ 1095.382828] Modules linked in: bnep hci_uart btbcm bluetooth 8812au(O) cfg80211 rfkill snd_usb_audio snd_hwdep snd_usbmidi_lib snd_rawmidi snd_seq_device snd_bcm2835 snd_pcm snd_timer snd bcm2835_wdt bcm2835_gpiomem evdev joydev uio_pdrv_genirq rpi_ft5406 rpi_backlight uio i2c_dev fuse ipv6
[ 1095.382951] CPU: 1 PID: 421 Comm: RTW_CMD_THREAD Tainted: G           O    4.4.38-v7+ #938
[ 1095.382961] Hardware name: BCM2709
[ 1095.382973] task: b914b3c0 ti: b6848000 task.ti: b6848000
[ 1095.383385] PC is at join_cmd_hdl+0x168/0x370 [8812au]
[ 1095.383397] LR is at 0x0
[ 1095.383410] pc : [<7f24e14c>]    lr : [<00000000>]    psr: 80000113
sp : b6849ed8  ip : 00000000  fp : b6849f14
[ 1095.383424] r10: 00000001  r9 : 7f32baf4  r8 : bc46f40c
[ 1095.383435] r7 : bc46d0fe  r6 : bc471062  r5 : 00003eec  r4 : bc46c000
[ 1095.383446] r3 : 00003f64  r2 : 00000001  r1 : bc46d1b2  r0 : 00000001
[ 1095.383459] Flags: Nzcv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment kernel
[ 1095.383471] Control: 10c5383d  Table: 2c4c006a  DAC: 00000055
[ 1095.383484] Process RTW_CMD_THREAD (pid: 421, stack limit = 0xb6848210)
[ 1095.383495] Stack: (0xb6849ed8 to 0xb684a000)
[ 1095.383508] 9ec0:                                                       805bbb2c 800d989c
[ 1095.383525] 9ee0: b84cd11c b84cd100 b6849f14 b84cd100 bc46c000 bc46d958 bc46d978 000136ae
[ 1095.383542] 9f00: bc46d958 000048a4 b6849f5c b6849f18 7f22fb5c 7f24dff0 00000000 b914b3c0
[ 1095.383559] 9f20: 00000000 bc46d968 bc46d9a4 b6b7b200 00000000 00000000 b5cf1940 bc46c000
[ 1095.383575] 9f40: 7f22f8cc 00000000 00000000 00000000 b6849fac b6849f60 80042860 7f22f8d8
[ 1095.383593] 9f60: 3972d000 00000000 b6849f94 bc46c000 00000000 00000000 b6849f78 b6849f78
[ 1095.383609] 9f80: 00000000 00000000 b6849f88 b6849f88 b5cf1940 80042774 00000000 00000000
[ 1095.383626] 9fa0: 00000000 b6849fb0 8000fbc8 80042780 00000000 00000000 00000000 00000000
[ 1095.383641] 9fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1095.383658] 9fe0: 00000000 00000000 00000000 00000000 00000013 00000000 e3530000 0a00003c
[ 1095.384383] [<7f24e14c>] (join_cmd_hdl [8812au]) from [<7f22fb5c>] (rtw_cmd_thread+0x290/0x3ec [8812au])
[ 1095.384745] [<7f22fb5c>] (rtw_cmd_thread [8812au]) from [<80042860>] (kthread+0xec/0x104)
[ 1095.384768] [<80042860>] (kthread) from [<8000fbc8>] (ret_from_fork+0x14/0x2c)
[ 1095.384786] Code: e0888005 e59f9208 e2853078 e0876003 (e7d73003)
[ 1095.384858] ---[ end trace 6894181658c0e520 ]---
[ 1109.999027] RTL871X: rtw_set_802_11_connect(wlan0)  fw_state=0x00000008
Although the kernel exception does appear a little different in form.
Suggestions are welcome!
Thanks,
aa
daltoncurtin
Sun Feb 05, 2017 8:20 pm
I've been using the driver for my tplink AC450 wireless dongle for a bit now and it's fairly stable but I have an issue that I haven't been able to find else where. At least not related directly to the pi and this type of dongle.
When I move my pi (still powered) to another access point that it is configured for, it will not reconnect to the new access point.
I believe it did reconnect once, but I tested it several times and in the majority it would not reconnect no matter how long I left it.
This is frustrating since It may fail to reconnect to even the same ap if it were to some how lose connection which is troublesome for the project I'm working on.
If the pi is power cycled it will reconnect automatically at reboot or I can manually reconnect via terminal after plugging in the hdmi without power cycling
I can post kernel ver and log scrypts when I get back but I was curious if this was a known issue. Appreciate any help!
by the way using wicd-curses with dhcp-client in preference. I remember having to disable a dhcp service or something to that affect to get wicd to work.
Update: I sort of fixed the issue with a cron job + script that forced wicd to disconnect and reconnect but i've been getting kernel issues (big explosive ones) that I believe are related to the dongle. Need to investigate some more. Might post parts of log if I feel it's actually related.
cattell
Mon Feb 20, 2017 4:24 am
I am having problems at the stage where 'dropboxusercontent' starts to be accessed. My log of the last few commands that failed is below. Can anyone tell me what is wrong? Peter
MrEngman
Tue Feb 21, 2017 2:27 am
cattell wrote:I am having problems at the stage where 'dropboxusercontent' starts to be accessed. My log of the last few commands that failed is below. Can anyone tell me what is wrong? Peter
Would help if you did post the log output.
Don't know which version of the script you are using but there is a newer version. Look at the MAJOR UDATE section in the first post viewtopic.php?p=462982#p462982
MrEngman
cattell
Tue Feb 21, 2017 6:56 am
Sorry, I thought I had posted the log in in previous post. Here it is,
Peter
pi@raspberrypi:~ $ uname -a
Linux raspberrypi 4.4.21+ #911 Thu Sep 15 14:17:52 BST 2016 armv6l GNU/Linux
pi@raspberrypi:~ $ wget https://dl.dropboxusercontent.com/u/802 ... 991.tar.gz
--2017-02-20 13:54:46-- https://dl.dropboxusercontent.com/u/802 ... 991.tar.gz
Resolving dl.dropboxusercontent.com (dl.dropboxusercontent.com)... failed: Name or service not known.
wget: unable to resolve host address ‘dl.dropboxusercontent.com’
--2017-02-20 13:55:20-- https://dl.dropboxusercontent.com/u/802 ... 991.tar.gz
pi@raspberrypi:~ $ sudo wget https://dl.dropboxusercontent.com/u/802 ... stall-wifi -O /usr/bin/install-wifi
--2017-02-20 14:01:58-- https://dl.dropboxusercontent.com/u/802 ... stall-wifi
pi@raspberrypi:~ $
MrEngman
Tue Feb 21, 2017 12:31 pm
cattell wrote:Sorry, I thought I had posted the log in in previous post. Here it is,
Peter
pi@raspberrypi:~ $
The link you are using is wrong Try this
wget https://dl.dropboxusercontent.com/u/80256631/8188eu-4.4.21-911.tar.gz
- 911 not 991.
As you are also having problems downloading the wifi install script does your Pi have a working internet connection?
MrEngman
cattell
Tue Feb 21, 2017 10:52 pm
Yes my Pi does have a working ethernet link. I'll try the suggestion you make later today Many thanks for your help Peter
cattell
Wed Feb 22, 2017 1:30 am
OK, finally got it working via the following commands. Many thanks once again,
Peter
wget https://dl.dropboxusercontent.com/u/802 ... 911.tar.gz
tar xzf 8188eu-4.4.21-911.tar.gz
./install.sh
MrEngman
Wed Feb 22, 2017 1:37 am
cattell wrote:OK, finally got it working via the following commands. Many thanks once again,
Peter
./install.sh
Good, glad to be able to help
MrEngman
macmpi
Wed Feb 22, 2017 9:41 am
Dear MrEngman,
Thanks for all the work and support on these drivers.
install-wifi script has really become an extremely powerful all-in-one tool. Thought it's made to install, it would be nice if it could have an option to revert or uninstall these drivers: any chance you may add such option?
Thanks for consideration.
MrEngman
Thu Feb 23, 2017 9:04 pm
macmpi wrote:Dear MrEngman,
Not sure what the point is in uninstalling the drivers. The script can already be use to revert to a different version if you change the kernel version.
Not sure what version of the script you are currently using but I would suggest you install the new version, details in the first post here. viewtopic.php?p=462982#p462982 in the MAJOR UPDATE:- section as there has been a change in the format of the kernel that stops the older version working.
MrEngman
macmpi
Fri Feb 24, 2017 7:02 am
MrEngman wrote:Not sure what the point is in uninstalling the drivers. The script can already be use to revert to a different version if you change the kernel version.
Well, like with any software, particular setup may have issues with the driver: one may detect a bug, report here, and needs to restore operations with kernel's baseline driver until this is resolved. Or user may try it and determine it does not fully fulfill it's needs in a particular case, etc...
It may be difficult to figure-out how to reverse the changes for many users (same users who need simple installs), so such an uninstall option is probably desirable to avoid hassle of re-installing a whole SD to clear-out the changes.
Makes sense?
chekitsch
Wed Mar 08, 2017 8:19 am
Could somebody please help, I'm running kernel 4.4.5-v7 #970, which i downloaded from right here:
https://www.raspberrypi.org/downloads/raspbian/
I can't seem to find a driver for this version...
Many thanks....
MrEngman
Wed Mar 08, 2017 9:50 am
chekitsch wrote:Hello,
Many thanks....
Maybe you should try kernel 4.4.50-v7+ #970.
MrEngman
dnaranjor
Wed Mar 08, 2017 2:43 pm
I have a RPi 1 Model B about 3 years old, crippled since the Ethernet port died about a year ago. Now my only option is to connect it to the network via WiFi.
Long story short, I 've successfully installed the drivers for TL-WN725N V2 on my RPi and now I'm able to scan the nearby WiFi networks without problems.
My issue is that I'm not able to connect to my desired WiFi network, due to a wpa_supplicant daemon failed to start error.
Any suggestions?
MrEngman
Wed Mar 08, 2017 8:14 pm
dnaranjor wrote:I have a RPi 1 Model B about 3 years old, crippled since the Ethernet port died about a year ago. Now my only option is to connect it to the network via WiFi.
Any suggestions?
I presume you are using Raspbian. Can you post the output of commands
cat /etc/os-release
cat /etc/network/interfaces
sudo cat /etc.wpa_supplicant/wpa_supplicant.conf
so I can see how your wifi is set up. Don't forget to hide the password in wpa_supplicant.conf.
MrEngman
wonx
Wed Mar 15, 2017 9:06 pm
Help! I successfully updated the driver several times, but now I can't download the new driver. I have kernel 4.4.50-v7 #970 so I guess I have to download the following file:
https://dl.dropboxusercontent.com/u/80256631/8188eu-4.4.50-v7-970.tar.gz
However, I get a 404 error. Is the "server" down or the files have been removed?
MrEngman
Wed Mar 15, 2017 9:24 pm
wonx wrote:Help! I successfully updated the driver several times, but now I can't download the new driver. I have kernel 4.4.50-v7 #970 so I guess I have to download the following file:
Sorry, seems like there's been a major change to Dropbox and I'm trying to find out how to get round the problem. It's really screwed things up and I'm not at all happy about it.
MrEngman
wonx
Wed Mar 15, 2017 9:37 pm
I see. Is there any way I could get that specific file from another link?
MrEngman
Wed Mar 15, 2017 9:59 pm
wonx wrote:I see. Is there any way I could get that specific file from another link?
I'm looking at doing that at the moment. I'll get back when I've sorted it out.
MrEngman
MrEngman
Wed Mar 15, 2017 10:04 pm
Think I've sorted out the specific file you need. Try this
wget http://fars-robotics.net/8188eu-4.4.50-v7-970.tar.gz
tar xzf 8188eu-4.4.50-v7-970.tar.gz
./install.sh
MrEngman
wonx
Wed Mar 15, 2017 10:06 pm
Thanks a lot!!
MrEngman
Thu Mar 16, 2017 12:48 am
Hi to everyone,
Dropbox have changed their web site setup which has screwed up the scripts to download and install the wifi drivers.
If you use my script please download the new version and install using commands
sudo wget http://www.fars-robotics.net/install-wifi -O /usr/bin/install-wifi
sudo chmod +x /usr/bin/install-wifi
See the first post in this thread for a few more details.
MrEngman
macmpi
Thu Mar 16, 2017 8:34 am
Dear MrEngman,
Ouch...quite radical impact of Dropbox policy change indeed.
The list of drivers available is limited but should cover 4.4.35 - 4.4.50 and 4.9.xx
Any chance you can make earlier drivers available too (4.4.9 #884 series in particular)?
Is that just a matter of time to copy them all over?
Thanks!
