Page 46 of 60
Re: (UPDATE) Drivers for TL-WN725N V2 - 3.6.11+ -> 4.1.xx+
Posted: Fri Jul 15, 2016 8:46 pm
by marek.janac
But why its not working after usb is plugged in? In RasPlex wifi worked immediately on Raspberry Zero.
Posted: Sun Jul 17, 2016 8:27 am
by WHiDRaSL
Hi! I'm using TL-WN725N V2 dongle, trying direct connection to my phone (Yotaphone2 or LG Nexus 5), I can see phone, can connect to it. But if I try another way (connect to dongle from phone), phone unable to find any p2p device around it (using iwpriv wlan0 p2p_set enable=1). Can you help me? Also I want to make working piracast, my phone doesn't see Piracast device (phone can see it only if I emulate connecting by editing python scripts, but can't connect).
RT PREEMPT
Posted: Sat Aug 13, 2016 3:19 pm
by ppoirier
I am currently running on a PREEMPT 4.4.9 (
http://www.frank-durr.de/?p=203) , how can I get the 8812au driver installed ?
Best Regards
Posted: Fri Aug 26, 2016 10:44 am
by KirkmanJ
hello.
having issues finding
wget
https://dl.dropboxusercontent.com/u/802 ... ifi.tar.gz tar xzf install-wifi.tar.gz.
using a B+ and it can not locate.
Posted: Fri Aug 26, 2016 11:06 am
by KirkmanJ
Ignore last post,
Not 100% sure but i dont think that was the issue.
I am running 4.4.17+ #904 , on a Pi B+
Need to create a Wifi access point, i have managed to get the AP to show up on my phone, and it prompts for Password, but then gets stuck in a loop and wont connect.
Any help would be appreciated , not sure what the problem is or what the solution would be.
Posted: Fri Sep 09, 2016 9:42 pm
by luckybenni
Hi MrEngman,
I'm involved in a Open Source Copter project where we use a RaspPi Zero as basis for the flight control communication between a Smartphone application and the flight controller in the Copter. The Zero is setting up an AP where the user logs in with his Smartphone and then steers the Copter via an Android App.
One safety feature in the app is a constant analysis of the signal strength of the respective user - if it drops below a certain quality level the Copter stops automatically. Currently the signal strength is analyzed via the iw command, which unfortunately does not support non kernel drivers.
Do you happen to know alternative commands to iw that can be used to read the signal strength of devices connected to the WLAN stick acting as an AP and that are working with your driver?
Thanks a ton for your immense work.
Greetings, Benjamin
Posted: Fri Sep 09, 2016 11:24 pm
by MrEngman
luckybenni wrote:Hi MrEngman,
Greetings, Benjamin
There's command
iwconfig but don't know if that gives you the info you need. And maybe
sudo iwlist wlano scan. Not sure as you are running your wifi as an AP if these will give the info you want.
MrEngman
Posted: Sun Sep 11, 2016 9:44 pm
by ppoirier
Hello MrEngman
http://www.frank-durr.de/?p=203) , do you have a 8812au driver builded for this kernel?
Best Regards
Posted: Sun Sep 11, 2016 10:48 pm
by MrEngman
ppoirier wrote:Hello MrEngman
Best Regards
Sorry, no.
MrEngman
Posted: Tue Sep 13, 2016 8:30 pm
by st3fyx
I've updated kernel, but i can't find right driver.
This is the message:
./install-wifi -c 8812au rpi-update
Your current kernel revision = 4.4.20+
Your current kernel build = #908
Please wait ... checking the kernel revision and build you will have after running command 'sudo rpi-update'.
Running command 'sudo rpi-update' will load:
kernel build = #909
Checking for a new 8812au wifi driver module if you run command 'sudo rpi-update'.
A driver does not yet exist for this update.
Regards
S.
Posted: Tue Sep 13, 2016 9:43 pm
by MrEngman
st3fyx wrote:Hi,
kernel build = #909
Regards
S.
Try again.
MrEngman
Posted: Thu Sep 15, 2016 5:24 am
by st3fyx
I've an error:
./install-wifi
Checking for a wifi module to determine the driver to install.
Your wifi module is Bus 001 Device 004: ID 0bda:8179 Realtek Semiconductor Corp.
And it uses the 8188eu driver.
Checking for a new 8188eu wifi driver module for your current kernel.
There is a driver module available for this kernel revision.
Downloading the 8188eu driver.
Installing the 8188eu driver.
Error: could not insert module 8188eu.ko: Unknown symbol in module
Posted: Thu Sep 15, 2016 10:17 am
by MrEngman
st3fyx wrote:I've an error:
./install-wifi
You will need to reboot your Pi. The driver you downloaded and installed requires some additional modules being loaded and these will be loaded when you reboot.
You were trying to load the 8812au module originally. Why were you trying to load that driver? Do you have more than one wifi connected to your Pi?
Raspbian already has a driver for the 8188eu wifi modules so now my 8188eu driver is loaded it will disable the driver included with the OS. To use the driver included with raspbian you will need to delete my driver using commands
sudo rm /lib/modules/4.4.20+/kernel/drivers/net/wireless/8188eu.ko
sudo depmod -a
and edit the file /etc/modprobe.d/8188eu.conf and comment out the line
blacklist r8188eu to re-enable the built in driver and then reboot.
If you do need to install the 8812au driver you can use the command
./install-wifi 8812au. This may give the error
Error: could not insert module 8812au.ko: Unknown symbol in module
. You should then reboot as the wifi driver will need extra modules being loaded.
I have just updated the script to avoid the error you were seeing "
Unknown symbol in module" so if the driver relies on additional modules running they will be loaded. You can download the new version using
wget https://dl.dropboxusercontent.com/u/80256631/install-wifi.tar.gz
MrEngman
Posted: Sun Sep 18, 2016 6:28 pm
by st3fyx
Thanks a lot,
all works fine!
regards
S.
Posted: Fri Sep 30, 2016 12:53 pm
by mauricabrera
Working really good on the lastest version of PIXEL.
Thanks a lot for the new installer!
Linux raspberrypi 4.4.21-v7+ #911 SMP Thu Sep 15 14:22:38 BST 2016 armv7l GNU/Linux
Posted: Tue Oct 04, 2016 9:38 pm
by Shepard-N7
Anything new for 4.4.21+ (the new Pixel)? the 4.4.8 doesn't work unfortunately.
Posted: Wed Oct 05, 2016 12:25 am
by MrEngman
Read the previous post.
MrEngman
Posted: Tue Oct 11, 2016 9:20 am
by macmpi
I have an issue to get 8188eu driver working on a rpi0 with latest Raspian Jessy lite image.
My setup works with kernel's r8188eu driver, but wanted to give 8188eu a shot for various reasons.
So I just installed 8188eu using latest install-wifi script on the working setup.
pi@raspberrypi:~ $ uname -a
Linux raspberrypi 4.4.23+ #913 Tue Oct 4 13:56:56 BST 2016 armv6l GNU/Linux
pi@raspberrypi:~ $ lsmod
Module Size Used by
8188eu 931354 0
cfg80211 499234 1 8188eu
rfkill 21397 2 cfg80211
pi@raspberrypi:~ $ cat /etc/network/interfaces
auto lo
iface lo inet loopback
iface eth0 inet dhcp
allow-hotplug wlan0
iface wlan0 inet manual
wpa-roam /etc/wpa_supplicant/wpa_supplicant.conf
iface default inet dhcp
and wpa_supplicant.conf with proper SSID/pass (working with base driver)
result with 8188eu:
pi@raspberrypi:~ $ iwconfig
wlan0 unassociated Nickname:"<WIFI@REALTEK>"
Mode:Managed Frequency=2.412 GHz Access Point: Not-Associated
Sensitivity:0/0
Retry:off RTS thr:off Fragment thr:off
Power Management:off
Link Quality:0 Signal level:0 Noise level:0
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:0 Missed beacon:0
pi@raspberrypi:~ $ sudo iwlist wlan0 scan
wlan0 No scan results
rpi0 device has not been moved from the network conditions it was in with original driver (detected 5 SSID)
Going back, soleley removing 8188eu driver:
sudo rm /lib/modules/4.4.23+/kernel/drivers/net/wireless/8188eu.ko
sudo depmod -a
sudo rm /etc/modprobe.d/8188eu.conf
and reboot restores normal wifi operation.
Thanks for any help/suggestion to get 8188eu up and running.
Posted: Tue Oct 11, 2016 3:55 pm
by MrEngman
Hi macmpi,
I'm running the 8188eu driver and TP-Link WN725n wifi on my Pi Zero with Raspbian jessie lite 4.4.23+ #913. No problems at all.
I created a new SD card using the 2016-09-23-raspbian-jessie-lite image. I then copied the file /etc/wpa_supplicant/wpa_supplicant.conf from another Pi to the new card using a USB to SD card reader to configure the wifi and then booted the new card on the Pi Zero. The wifi was running OK using the built in r8188eu driver with kernel version 4.4.21+ #911.
I then installed rpi-update and updated the kernel to 4.4.23+ #913 and then rebooted and then downloaded the wifi install script and installed the 8188eu driver, rebooted again and it is running without any problems.
You say you are using the jessie lite image but your file /etc/network/interfaces is of the format used with raspbian wheezy. Did you edit this file or did you update your SD card from a wheezy image? If you edited the file I would suggest you put it back to it's default state.
MrEngman
Posted: Tue Oct 11, 2016 4:48 pm
by macmpi
Hi MrEngman,
Thanks for your quick reply.
I took the same steps to build my rpi0 setup.
It's true I did edit
/etc/network/interfaces in doing several trials & errors.
I followed your suggestion and restored the original one, as below
pi@raspberrypi:~ $ cat /etc/network/interfaces.orig
# interfaces(5) file used by ifup(8) and ifdown(8)
# Please note that this file is written to be used with dhcpcd
# For static IP, consult /etc/dhcpcd.conf and 'man dhcpcd.conf'
# Include files from /etc/network/interfaces.d:
source-directory /etc/network/interfaces.d
auto lo
iface eth0 inet manual
allow-hotplug wlan0
wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
allow-hotplug wlan1
iface wlan1 inet manual
Baseline driver works, and then re-installed yours:
pi@raspberrypi:~ $ ./install-wifi
Your current kernel revision = 4.4.23+
Your current kernel build = #913
Your wifi module is Bus 001 Device 007: ID 0bda:8179 Realtek Semiconductor Corp.
A version of the driver 8188eu.ko is already loaded and running. You will need to reboot to load the new driver.
and same problem (no scan, no connection to AP).
Really puzzling...
PS: my rpi0 is first generation, in case that matters...
Posted: Tue Oct 11, 2016 4:57 pm
by macmpi
noticed that:
pi@raspberrypi:~ $ dmesg | grep RTL
[ 13.478991] RTL871X: module init start
[ 13.479026] RTL871X: rtl8188eu v4.3.0.8_13968.20150417
[ 13.479038] RTL871X: build time: Oct 4 2016 14:56:35
[ 13.548430] RTL871X: rtw_ndev_init(wlan0)
[ 13.564691] RTL871X: module init ret=0
[ 14.732888] ==> rtl8188e_iol_efuse_patch
[ 16.942281] RTL871X: rtw_cmd_thread: DriverStopped(0) SurpriseRemoved(1) break at line 478
My dongle is plugged through a powered USB hub in case that matters (this hub also has a usefull usb-ethernet adapter and keyboard to debug): again literally
same setup with base driver.
Posted: Tue Oct 11, 2016 5:56 pm
by MrEngman
I see the same in dmesg except for the last line you show. Not sure what that means.
I have the wifi module connected directly to my Pi Zero and connect to my Pi using SSH. No other devices connected to the Pi.
I have seen some strange things happen sometimes with wifi modules. I had one connected to a Pi using a hub and I could not get a connection. I then change the USB port the wifi was plugged in to and then it started working. This was a long time ago but it was very strange behaviour. I then plugged it back in to the USB port it was originally connected to when it did not work and then it continued to work OK. Really weird. I never did manage to figure out why it didn't work to start with.
Maybe change the USB port it is plugged in to and see if that makes a difference.
I have seen an issue with a hub where some of the ports had limited current capability so if a device was connected that consumed more current than the hub's port would allow it would disable the device connected to it. Doesn't explain why the wifi works with the r8188eu driver and not my 8188eu driver though.
Googling "RTL871X: rtw_cmd_thread: DriverStopped(0) SurpriseRemoved(1) break at line 478" comes up with a few similar errors but no answer why as far as I can tell.
MrEngman
Posted: Tue Oct 11, 2016 8:07 pm
by macmpi
MrEngman wrote:Maybe change the USB port it is plugged in to and see if that makes a difference.
Right on spot! Amazing, it works fine from another port on that same hub, thanks!
MrEngman wrote:Doesn't explain why the wifi works with the r8188eu driver and not my 8188eu driver though.
Indeed...looks like there's still room for magic in computing.
With that cleared, I'll move to
playing with hostapd, and check if it may work with baseline version now...
Posted: Tue Oct 11, 2016 8:17 pm
by MrEngman
macmpi wrote:MrEngman wrote:Maybe change the USB port it is plugged in to and see if that makes a difference.
Hi macmpi,
Good to hear your wifi is now working. Don't know about wifi working on PC's using Linux but on the Pi wifi can certain behave really weirdly at times.
Have fun, especially if you're going to try hostapd.
MrEngman
Posted: Wed Oct 12, 2016 1:17 pm
by macmpi
MrEngman wrote:The file I downloaded was rtl8188eus_linux_v4.3.0.8_13968.20150417.zip
That's great: since the included code is GPLv2, how about putting the code to github, so that source code is published, with reference to legit origins?
Wouldn't this ease maintenance?
