I already have and the latest 4.4.7-v7 #877.adr2 wrote:Hi MrEngman,
Could you please build your modules for the kernel 4.4.7-v7+ #876?
Thanks for your work.
MrEngman
Hi MrEngman,MrEngman wrote:I already have and the latest 4.4.7-v7 #877.adr2 wrote:Hi MrEngman,
MrEngman
Try thisadr2 wrote:Hi MrEngman,MrEngman wrote:I already have and the latest 4.4.7-v7 #877.adr2 wrote:Hi MrEngman,
MrEngman
Thank you for your reply, I must be missing something as the latest I see for the Pi 2 is '4.1.21-v7+ #872, #873 - 8188eu-v7-20160406.tar.gz'. I tried replacing the link with dates between 07/04/2016 and 17/04/2016 without luck.
wget https://dl.dropboxusercontent.com/u/80256631/8188eu-4.4.7-v7-876.tar.gz
tar xzf 8188eu-4.4.7-v7-876.tar.gz
./install.shCode: Select all
wget https://dl.dropboxusercontent.com/u/80256631/install-wifi.tar.gz
tar xzf install-wifi.tar.gzCode: Select all
./install-wifi -hThe filename format has changed. Use uname -a to find kernel version and build and the wifi driver filename now uses them like 8188eu-kernel-build.tar.gzjitendra43 wrote:Hi EngMan,
Could you please build your modules for the kernel 4.4.8-v7+ #881 ????
Thanks in Advnace
Jitendra Yadav
wget https://dl.dropboxusercontent.com/u/80256631/8188eu-4.4.8-v7-881.tar.gz
tar xzf 8188eu-4.4.8-v7-881.tar.gz
tar xzf install-wifi.tar.gzI assume you are trying to use the TP-Link TL-WN725N v2 wifi. You did not say which TP-Link wifi you used.jitendra43 wrote:Hi Mr.EngMan,
Hope you are well.
Need your help as soon as possible, i have updated RPI with latest firmware(4.4.8-v7+ #881) and also updated driver for the same which link got from you and now all TP Link wifi adaptor is not working with my current updated RPI but Edimax is working...so kindly help me, how can i resolved this issues which is getting with TP Link always...
Thanks in advnace
Jitendra Yadav
uname -a
lsusb
lsmod
cat /etc/network/interfaces
sudo cat /etc/wpa_supplicant/wpa_supplicant.confCode: Select all
wget https://dl.dropboxusercontent.com/u/80256631/8188eu-4.4.9-v7-883.tar.gz
tar xzf 8188eu-4.4.9-v7-883.tar.gz
wget https://dl.dropboxusercontent.com/u/80256631/8188eu-4.4.9-883.tar.gz
tar xzf 8188eu-4.4.9-883.tar.gz
./install-wifi -hHello, I had to update rpi so I can use the new camera pi v2 , then the wiffi is not working , can you post me the drivers for kernel 4.4.9-v7+ #884.Please. Thank youMrEngman wrote:If you want to use your Pi as an Access Point then take a look here.
I have it running at the moment after doing rpi-update to update to kernel 4.4.9-v7+ #884.
MrEngman
Try thismarc bcn wrote:Hello, I had to update rpi so I can use the new camera pi v2 , then the wiffi is not working , can you post me the drivers for kernel 4.4.9-v7+ #884.Please. Thank youMrEngman wrote:If you want to use your Pi as an Access Point then take a look here.
MrEngman
wget https://dl.dropboxusercontent.com/u/80256631/8188eu-4.4.9-v7-884.tar.gz
tar xzf 8188eu-4.4.9-v7-884.tar.gz
./install.shWhat do you mean "Nothing Happened", not very helpful. Does dmesg show any errors that may show what the problem is.jitendra43 wrote:Hi EngMan,
Nothing Happened.....still not connecting in our TP Link (TL-WN725N) in AP Mode once i deleted 8188eu.conf file from /etc/modprobe/ then its started connecting in AP Mode so help me....best way to resolved this issue asap...
Jitendra
OK, the driver you need is the one I suggested you download in my previous post.jitendra43 wrote:Hi EngMan,
1. What is the complete output of command uname -a?
Ans: Linux TH-1671026713(hostname) 4.4.9-v7+ #884 SMP Fri May 6 17:28:59 BST 2016 armv7l GNU/Linux
2. What Pi are you using? Also are you using Raspbian as the drive only works with Raspbian.
Ans: using Raspberry Pi 2 Model B V1.1
dear friend kindly donot hesitate to contact us if you need more information....hope we will get better solution asap.
Jitendra
wget https://dl.dropboxusercontent.com/u/80256631/hostapd
sudo mv hostapd /usr/sbin/hostapd
sudo chown root.root /usr/sbin/hostapd
sudo chmod 755 /usr/sbin/hostapdCode: Select all
Linux raspberrypi 4.4.9-v7+ #884 SMP Fri May 6 17:28:59 BST 2016 armv7l GNU/LinuxCode: Select all
Your current kernel revision = 4.4.9-v7+
Your current kernel build = #884
Checking for a wifi module to determine the driver to install.
Your wifi module is Bus 001 Device 004: ID 0bda:8179 Realtek Semiconductor Corp.
And it uses the 8188eu driver.
Checking for a new 8188eu wifi driver module for your current kernel.
There is a driver module available for this kernel revision.
Downloading the 8188eu driver.
Installing the 8188eu driver.
A version of the driver 8188eu.ko is already loaded and running. You will need to reboot to load the new driver.Code: Select all
wlan1 Link encap:Ethernet HWaddr f4:f2:6d:0c:ee:c5
inet6 addr: fe80::f797:411e:e8d7:75ec/64 Scope:Link
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)Code: Select all
# interfaces(5) file used by ifup(8) and ifdown(8)
# Please note that this file is written to be used with dhcpcd
# For static IP, consult /etc/dhcpcd.conf and 'man dhcpcd.conf'
# Include files from /etc/network/interfaces.d:
source-directory /etc/network/interfaces.d
auto lo
iface lo inet loopback
iface eth0 inet manual
allow-hotplug wlan0
iface wlan0 inet manual
wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
allow-hotplug wlan1
iface wlan1 inet manual
update_config=1
country=GB
network={
ssid="network-name"
psk="network-password"
./install-wifi -h
