MrEngman
Re: (UPDATE) Drivers for TL-WN725N V2 - 3.6.11+ -> 4.1.xx+
Tue Nov 03, 2015 9:03 pm
luisnetbeast wrote:Hi! I'm trying to install the driver for 4.1.7-v7+ #817, so, I've downloaded 8188eu-v7-20150914.tar.gz. However, when I try to do insmod I get this message:
"insmod: ERROR: could not insert module /lib/modules/4.1.7-v7+/kernel/drivers/net/wireless/8188eu.ko: Invalid module format"
What can I do?
Thank you in advance!
If you are using raspbian 4.1.7-v7+ #817 and have downloaded that driver file I would not expect that error, possibly " Unknown symbol in module" but not "Invalid module format".
The drivers I compile are for raspbian and will not work with other OS's. What OS are you using? What is the complete output of command uname -a.
As you say you are using 4.1.7-v7+ #817 I would expect it may include the built in r8188eu driver so you should not need to install the driver I compile to get your wifi working.
Check the built in driver and the necessary firmware files are included with the commands
ls /lib/modules/4.1.7-v7+/kernel/drivers/staging/rtl8188eu/r8188eu.ko
ls /lib/firmware/rtlwifi/rtl8188eufw.bin
If the firmware is not included install it using command
sudo wget https://github.com/lwfinger/rtl8188eu/raw/master/rtl8188eufw.bin -O /lib/firmware/rtlwifi/rtl8188eufw.bin
MrEngman
Dimonira
Wed Nov 04, 2015 7:44 am
Raspbian Jessie 4.1.7-v7+ #817 already has a built-in driver.
So it is not necessary to install the driver and when you upgrade the system, too.
luisnetbeast
Wed Nov 04, 2015 8:54 am
What can I do?
MrEngman
Nice! I think this is already running. I was a problem of Hostapd application that doesn't work properly.
Thank you!
johnirak
Fri Nov 20, 2015 12:46 am
I installed grblweb/reprapweb on a Raspberry 2.
This command:
uname -a
returned this:
Linux xyzbots 3.18.0-trunk-rpi2 #1 SMP PREEMPT Debian 3.18.5-1~exp1.co1 (2015-02-02) armv7l GNU/Linux
so I tried to install drivers for 3.18.5-v7. I changed "3.18.5-v7" to "3.18.0-trunk-rpi2" in install.sh and installed it with ./install.sh
I ran "dmesg" and I saw that:
8188eu: disagrees about version of symbol module_layout
I think I should compile the driver specifically for my OS. How could I do this? Is there any chance to find a compiled driver?
berrybunker79
Mon Dec 07, 2015 10:42 pm
Hey,
Thanks for the amazingly informative post. However, I wanted to ask for some guidance, as my new RPi2 says the firmware version is 3.19.3 and I am unable to trace the correct driver to install for this. If anyone has any leads, I would be very grateful. Thanks!
diederik
Tue Dec 08, 2015 11:48 am
berrybunker79 wrote:firmware version is 3.19.3
Can you post the output of 'uname -a' ?
Kas Ali
Tue Dec 08, 2015 9:57 pm
Hi
I have purchased a Rpi with firmware 4.1.13-v7+ #826 and a TL-WN725n v2.1. When i follow the instructions it says the drivers have been installed but still wont pick up any or connect to my wifi.
Any ideas on what it can be?
berrybunker79
Wed Dec 09, 2015 10:52 am
Hey,
My rpi2 is loaded with recalbox. I managed to fix it with the invaluable help of Mr. Engman, who advised me to install the following driver:-
3.18.16+ #796       - 8188eu-20150619.tar.gz
However, that itself didnt fix the issue. After installing the drivers, I ran the following commands:-
wget -O /lib/firmware/rtlwifi/rtl8188eufw.bin https://github.com/lwfinger/rtl8188eu/raw/master/rtl8188eufw.bin
on the basis of this forum post:- http://blog.recalbox.com/forums/topic/t ... tl-wn725n/
Thereafter, a quick reboot had the wifi card up and running!
Thanks all!
sdhip
Tue Dec 22, 2015 7:09 pm
Hi
Running Raspbian Jessie 4.1.13-v7+ #826 on a Pi 2 Model B and a Pi Zero.
Wifi adapter: 0bda:0179 Realtek Semiconductor Corp.
Nothing else plugged in.
2 amp power supply.
Accessed by ssh.
I can confirm that the built in driver (r8188eu) is flaky and dropping packets on both the above Pis.
It seems to be much worse on the Pi Zero.
The driver 8188eu listed here is as solid as a rock on both.
Many thanks
Stephen
hotter
Sat Dec 26, 2015 12:11 am
Hi, my linux is:
root@MusicBox:~# uname -a
Linux MusicBox 3.18.7-v7+ #755 SMP PREEMPT Thu Feb 12 17:20:48 GMT 2015 armv7l GNU/Linux
and I have the problem when trying to install drivers:
root@MusicBox:~# wget https://dl.dropboxusercontent.com/u/80256631/8188eu-v7-20150212.tar.gz
--2015-12-26 00:04:35--  https://dl.dropboxusercontent.com/u/80256631/8188eu-v7-20150212.tar.gz
Resolving dl.dropboxusercontent.com (dl.dropboxusercontent.com)... 45.58.74.5
Connecting to dl.dropboxusercontent.com (dl.dropboxusercontent.com)|45.58.74.5|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 401971 (393K) [application/octet-stream]
Saving to: `8188eu-v7-20150212.tar.gz.1'
100%[======================================>] 401,971      405K/s   in 1.0s
2015-12-26 00:04:41 (405 KB/s) - `8188eu-v7-20150212.tar.gz.1' saved [401971/401971]
root@MusicBox:~# tar -zxvf 8188eu-v7-20150212.tar.gz
8188eu.ko
8188eu.conf
install.sh
root@MusicBox:~# sudo install -p -m 644 8188eu.ko /lib/modules/$(uname -r)/kernel/drivers/net/wireless
root@MusicBox:~# sudo insmod /lib/modules/$(uname -r)/kernel/drivers/net/wireless/8188eu.ko
Error: could not insert module /lib/modules/3.18.7-v7+/kernel/drivers/net/wireless/8188eu.ko: Unknown symbol in module
Can anyone help me?
hotter
Sat Dec 26, 2015 12:13 am
Hi, my linux is:
8188eu.ko
8188eu.conf
install.sh
Can anyone help me?
MrEngman
Sat Dec 26, 2015 3:04 am
hotter wrote:Hi, my linux is:
8188eu.ko
8188eu.conf
install.sh
Can anyone help me?
To install the drivers I compile you should run the commands
tar xzf 8188eu-v7-20150212.tar.gz
./install.sh
to install it correctly. This is explained in the instructions in the first post in this thread. You should then reboot the Pi.
The error you see "Unknown symbol in module" is because the driver requires other modules to be loaded and they are not loaded until the driver is installed correctly and you reboot the Pi.
NOTE: There is an 8188eu driver that is now included in the Raspbian image but you may have to load firmware to use it. To use the built in driver you will need to uninstall my driver and update the realtek firmware. You can delete my driver and update the built in realtek firmware using the commands
sudo rm /lib/modules/$(uname -r)/kernel/drivers/net/wireless/8188eu.ko
sudo rm /etc/modprobe.d/8188eu.conf
sudo depmod $(uname -r)
sudo apt-get update
sudo apt-get install firmware-realtek
Which version of the driver you use is up to you but there are some people who prefer to use the driver I compile as they say it is more reliable, but if you do use my driver you will need to update it every time you update your kernel. Using the built in driver you do not need to update it as this is done automatically whenever you update the kernel.
MrEngman
elmo61
Mon Dec 28, 2015 11:05 am
My Version Required: 4.1.15-v7+ #830
I'm a complete beginner trying to set up my raspberry pi for first time, I am currently looking for drivers for the following version? They don't seem to be available yet, should I use 4.1.14-v7+ #830 instead?
longhorn
Mon Dec 28, 2015 11:49 am
8188eu-20151215.tar.gz (build #830) returns 404 error. Can't install the driver after last raspberry update :(
MrEngman
Mon Dec 28, 2015 2:45 pm
longhorn wrote:8188eu-20151215.tar.gz (build #830) returns 404 error. Can't install the driver after last raspberry update :(
Sorry, my fault. Try again. Should be OK now.
MrEngman
Wed Dec 30, 2015 12:05 am
Hi Mr Engman,
Are you going to build your drivers for the experimental 4.4.0-rc7 (BRANCH=next rpi-update) kernel? Only I'm reluctant to run that on my RPi2B until I can get a known good 8188eu driver (because wiring it to the network is pain).
MrEngman
Wed Dec 30, 2015 2:38 am
DougieLawson wrote:Hi Mr Engman,
Hi Dougie,
OK, just tried to compile it and it fails with a huge number of warnings and errors so I think you are out of luck unless someone can suggest a fix.
This is the first file with the warnings
  CC [M]  /home/richard/src/rtl8188eus_linux_v4.3.0.8_13968.20150417/core/rtw_ioctl_set.o
In file included from /home/richard/src/rtl8188eus_linux_v4.3.0.8_13968.20150417/include/drv_types.h:64:0,
                 from /home/richard/src/rtl8188eus_linux_v4.3.0.8_13968.20150417/core/rtw_debug.c:22:
/home/richard/src/rtl8188eus_linux_v4.3.0.8_13968.20150417/core/rtw_debug.c: In function ‘dump_drv_version’:
/home/richard/src/rtl8188eus_linux_v4.3.0.8_13968.20150417/include/rtw_debug.h:187:19: error: void value not ignored as it ought to be
  #define _seqdump seq_printf
/home/richard/src/rtl8188eus_linux_v4.3.0.8_13968.20150417/include/rtw_debug.h:240:7: note: in expansion of macro ‘_seqdump’
    if(_seqdump(sel, fmt, ##arg)) /*rtw_warn_on(1)*/; \
/home/richard/src/rtl8188eus_linux_v4.3.0.8_13968.20150417/core/rtw_debug.c:65:2: note: in expansion of macro ‘DBG_871X_SEL_NL’
  DBG_871X_SEL_NL(sel, "%s %s\n", DRV_NAME, DRIVERVERSION);
/home/richard/src/rtl8188eus_linux_v4.3.0.8_13968.20150417/core/rtw_debug.c:66:2: note: in expansion of macro ‘DBG_871X_SEL_NL’
  DBG_871X_SEL_NL(sel, "build time: %s %s\n", __DATE__, __TIME__);
There are a large number of very similar warnings in other files. My knowledge of C is almost non-existent but the warnings are so consistent in the various files it probably only needs a minor update to fix.
I shall have a hunt around the internet but if anyone's got any suggestions? I can supply the source to look at if someone would care to take a look at it.
MrEngman
Wed Dec 30, 2015 10:24 am
Where can I get the source package? So I can give it a go on one of my 4.4.0 systems.
MrEngman
Wed Dec 30, 2015 12:09 pm
DougieLawson wrote:Where can I get the source package? So I can give it a go on one of my 4.4.0 systems.
You can find it here. I Cross-compile on a PC running Ubuntu. Compiles without any errors or warnings on 3,12, 3.18, 4.0 and 4.1 using tools/arm-bcm2708/gcc-linaro-arm-linux-gnueabihf-raspbian from the tools repo.
Tried this update but the compile still fails on 4.4 with a huge number of warnings/errors.
MrEngman
MrEngman
Fri Jan 01, 2016 4:58 pm
The driver for 4.4.0-rc7 looks OK now I fixed the initial patch I screwed up applying. Been up now about 40hrs with the updated driver and no sign of any problems. I've been running some real data transfer tests on my Pi 2B transferring a 3GB file back and forth between my Pi and W7 laptop using pscp from putty and it's running fine with transfer rates between 900-1250kB/s, currently fairly solid at around about 1150kB/s from the Pi to the W7.
MrEngman
stryktips
Fri Jan 01, 2016 5:35 pm
I've got a Raspberry pi 2 B, 4.1.13-v7+ #826, and I've downloaded the specified driver from the beginning of this thread, and was able to use it as a client, connecting to my home wifi. However, I'd like to use it as a AP, so I've compiled hostapd from https://github.com/jenssegers/RTL8188-h ... 2.0.tar.gz. I'm able to see the ssid, but when I try to connect it just wont, and I get the following line in dmesg:
[17849.883039] RTL871X: OnDisassoc(wlan0) reason=8, ta=30:75:12:a1:c8:8a
This line seems to come from the driver part, and not from hostapd itself, right? So, I though i'd ask here what it means, and what I might do to resolve the issue.
/Janne
Fri Jan 01, 2016 7:07 pm
I've not had a chance to try it, been too busy staying up until 03:00 this morning watching the low order digit of the calendar year increment (year++;). I've got my 2B wired at the moment.
MrEngman
Fri Jan 01, 2016 8:54 pm
stryktips wrote:Hi,
/Janne
I've tried setting up a Pi as an AP a few times just to see if it works using http://www.daveconroy.com/turn-your-ras ... s-chipset/ and I was able use it without problems with a TL-WN725N as well as the EW-7811Un, although I haven't tried it for quite a while now.
Found this http://forums.dlink.com/index.php?topic=7498.0 on the internet which appears to indicate the error you're seeing is due to an issue with defining the security mode in the AP.
MrEngman
stryktips
Sat Jan 02, 2016 1:45 pm
MrEngman wrote:
stryktips wrote:Hi,
/Janne
MrEngman
Thanks for the the link. The thing is though, that I get the same error even if I configure it as an unsecure network, but I will try different combinations to see whether that changes anything.
skp
Tue Jan 05, 2016 5:40 pm
Not working for me. I downloaded the file for my version, which is 4.1.13-v7+ #826.
I get as far as
$ sudo insmod /lib/modules/$(uname -r)/kernel/drivers/net/wireless/8188eu.ko
But the response is:
Error: could not insert module /lib/modules/4.1.13-v7+/kernel/drivers/net/wireless/8188eu.ko: Invalid module format
Any suggestions?
