mse_68870
Re: (UPDATE) Drivers for TL-WN725N V2 - 3.6.11+ -> 4.1.xx+
Wed Sep 02, 2015 6:07 am
I am using the WN725 as AP without issues, thanks to this thread's contributors.
I am now trying to reduce the transmit power of the device, but am failing to do so, as shown below.
Am i doing something wrong or is this simply not supported ?
pi@n014 ~ $ uname -a
Linux n014 3.18.7+ #758 PREEMPT Mon Feb 23 19:27:03 GMT 2015 armv6l GNU/Linux
pi@n014 ~ $ sudo iwconfig wlan0
wlan0     IEEE 802.11bgn  ESSID:"NB14"  Nickname:"<WIFI@REALTEK>"
          Mode:Master  Frequency:2.437 GHz  Access Point: C4:6E:1F:1B:9E:D2
          Sensitivity:0/0
          Retry:off   RTS thr:off   Fragment thr:off
          Encryption key:off
          Power Management:off
          Link Quality:0  Signal level:0  Noise level:0
          Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0
          Tx excessive retries:0  Invalid misc:0   Missed beacon:0
pi@n014 ~ $ sudo iwconfig wlan0 txpower 10
Error for wireless request "Set Tx Power" (8B26) :
    SET failed on device wlan0 ; Operation not permitted.
pi@n014 ~ $ lsusb
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp.
Bus 001 Device 004: ID 0bda:8179 Realtek Semiconductor Corp.
kavierkoo
Sun Sep 06, 2015 5:21 pm
Hi! I am a newbie in Raspbian,recently I bought a Raspberry Pi 2 with TL-WN727N Dongle but my Pi was unable to detect it so
I tried to follow the instruction for installing the TL-WN725N, however it turned out to be not working.
Below are details I think it would help Sir to understand more about my situation.
Thanks for your help.
This is the code I use for downloading
wget https://dl.dropboxusercontent.com/u/80256631/8188eu-v7-20150406.tar.gz
tar xzf 8188eu-v7-20150406.tar.gz
./install.sh
pi@kavierpi ~ $ uname -a
Linux kavierpi 3.18.11-v7+ #781 SMP PREEMPT Tue Apr 21 18:07:59 BST 2015 armv7l GNU/Linux
pi@kavierpi ~ $ lsusb
Bus 001 Device 004: ID 148f:7601 Ralink Technology, Corp.
pi@kavierpi ~ $ dmesg | grep usb
[    1.309834] usbcore: registered new interface driver usbfs
[    1.315537] usbcore: registered new interface driver hub
[    1.321006] usbcore: registered new device driver usb
[    1.686048] usbcore: registered new interface driver smsc95xx
[    2.209087] dwc_otg bcm2708_usb: DWC OTG Controller
[    2.215576] dwc_otg bcm2708_usb: new USB bus registered, assigned bus number 1
[    2.224464] dwc_otg bcm2708_usb: irq 32, io mem 0x00000000
[    2.242082] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    2.250489] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.259311] usb usb1: Product: DWC OTG Controller
[    2.265560] usb usb1: Manufacturer: Linux 3.18.11-v7+ dwc_otg_hcd
[    2.273229] usb usb1: SerialNumber: bcm2708_usb
[    2.291890] usbcore: registered new interface driver usb-storage
[    2.402371] usbcore: registered new interface driver usbhid
[    2.409624] usbhid: USB HID core driver
[    2.698064] usb 1-1: new high-speed USB device number 2 using dwc_otg
[    2.908377] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[    2.916947] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    3.218265] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[    3.328418] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[    3.337285] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    3.412584] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:7e:51:11
[    3.528223] usb 1-1.3: new high-speed USB device number 4 using dwc_otg
[    3.649453] usb 1-1.3: New USB device found, idVendor=148f, idProduct=7601
[    3.658371] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    3.667567] usb 1-1.3: Product: 802.11 n WLAN
[    3.674045] usb 1-1.3: Manufacturer: MediaTek
[    3.680407] usb 1-1.3: SerialNumber: 1.0
pi@kavierpi ~ $ lsmod
Module                  Size  Used by
cfg80211              386508  0
rfkill                 16651  1 cfg80211
snd_bcm2835            18649  0
snd_pcm                73475  1 snd_bcm2835
snd_seq                53078  0
snd_seq_device          5628  1 snd_seq
snd_timer              17784  2 snd_pcm,snd_seq
snd                    51038  5 snd_bcm2835,snd_timer,snd_pcm,snd_seq,snd_seq_device
uio_pdrv_genirq         2958  0
uio                     8119  1 uio_pdrv_genirq
pi@kavierpi ~ $ cat /etc/network/interfaces
auto lo
iface lo inet loopback
auto eth0
allow-hotplug eth0
iface eth0 inet manual
auto wlan0
allow-hotplug wlan0
iface wlan0 inet manual
wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
auto wlan1
allow-hotplug wlan1
iface wlan1 inet manual
pi@kavierpi ~ $ sudo cat /etc/wpa_supplicant/wpa_supplicant.conf
update_config=1
network={
    ssid="Not-Appropriate-To-Show-Here-Sorry"
    psk="Not-Appropriate-To-Show-Here-Sorry"
Once again thanks for the help.
MrEngman
Sun Sep 06, 2015 11:55 pm
kavierkoo wrote:Hi! I am a newbie in Raspbian,recently I bought a Raspberry Pi 2 with TL-WN727N Dongle but my Pi was unable to detect it so
The TL-WN727N uses the mt7601 driver which is not installed in the version of raspbian you have. You can download and install the driver with the following commands
wget https://dl.dropboxusercontent.com/u/80256631/mt7601-3.18.11-v7-781.tar.gz
tar xzf mt7601-3.18.11-v7-781.tar.gz
./install.sh
Your set up in /etc/network/interfaces and /etc/wpa_supplicant/wpa_supplicant.conf looks OK so after installing the driver reboot and hopefully you should find your wifi works.
MrEngman
blachanc
Re: (UPDATE) Drivers for TL-WN725N V2 - 3.6.11+ -> 3.18.xx+
Mon Sep 07, 2015 6:38 am
5 Months later, And one upgrade later.. Thanks Again
Thanks to your Drivers, once again, My wifi was back in 5 minutes.
pi@raspberrypi ~ $ uname -a
Linux raspberrypi 4.1.6-v7+ #810 SMP PREEMPT Tue Aug 18 15:32:12 BST 2015 armv7l GNU/Linux
wget https://dl.dropboxusercontent.com/u/80256631/8188eu-v7-20150818.tar.gz
pi@raspberrypi ~ $ tar xvf ./8188eu-v7-20150818.tar.gz
./install.sh
sudo cp 8188eu.conf /etc/modprobe.d/.
sudo install -p -m 644 8188eu.ko /lib/modules/4.1.6-v7+/kernel/drivers/net/wireless
sudo depmod 4.1.6-v7+
Reboot to run the driver.
blachanc wrote: Wed Apr 08, 2015 12:10 pm
many Thanks,
I was starting to regret my EBAY purchase:
EBAY NEW-Realtek-RTL8188cus
and of course... NO it was not a RTL8188cus chipset but a RTL8188eu
I hope the RTL8188eu chip gets supported OOB in raspian soon.
Ben
Ben
Autism/Asperger syndrome: what is your score on this quiz?
http://www.raspberrypi.org/forums/viewtopic.php?f=62&t=70191
kavierkoo
Mon Sep 07, 2015 10:17 am
./install
MrEngman
Thanks for the help but during ./install, it says No such file or directory
pi@kavierpi ~ $ wget https://dl.dropboxusercontent.com/u/80256631/mt7601-3.18.11-v7-781.tar.gz
--2015-09-07 10:15:52--  https://dl.dropboxusercontent.com/u/80256631/mt7601-3.18.11-v7-781.tar.gz
Resolving dl.dropboxusercontent.com (dl.dropboxusercontent.com)... 174.129.255.187, 54.243.70.174, 54.243.159.171, ...
Connecting to dl.dropboxusercontent.com (dl.dropboxusercontent.com)|174.129.255.187|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 335534 (328K) [application/octet-stream]
Saving to: `mt7601-3.18.11-v7-781.tar.gz.1'
100%[======================================>] 335,534     74.4K/s   in 4.4s
2015-09-07 10:16:02 (74.4 KB/s) - `mt7601-3.18.11-v7-781.tar.gz.1' saved [335534/335534]
pi@kavierpi ~ $ tar xzf mt7601-3.18.11-v7-781.tar.gz
pi@kavierpi ~ $ ./install
-bash: ./install: No such file or directory
MrEngman
Mon Sep 07, 2015 10:24 am
./install.sh
MrEngman
Sorry my mistake, the command to install the drive should be ./install.sh, not ./install.
MrEngman
kavierkoo
Mon Sep 07, 2015 10:31 am
MrEngman
Wow, It works!!! thanksss MrEngMan!
polioman
Mon Sep 07, 2015 12:29 pm
mse_68870 wrote:Hello,
Did you made a special hostapd config file?
I want to try it out.
kavierkoo
Thu Sep 10, 2015 10:09 am
MrEngman
Im really sorry that i might need to bother you again >,<
I accidentally updated my firmware and now its 4.1.6-v7+ #811 but in the list there's no driver for it, what should I do?
really sorry for the inconveniences caused and thank you
MrEngman
Thu Sep 10, 2015 11:16 am
kavierkoo wrote:
MrEngman
This thread is for the TL-WN725N and other drivers using the 8188eu driver, not for the TL-WN727N using the mt7601 driver, so you will not find the driver you need listed.
There is a driver now included in the raspbian image but it needs firmware loading. You can do that with the command
sudo wget https://github.com/porjo/mt7601/raw/master/src/mcu/bin/MT7601.bin -O /lib/firmware/mt7601u.bin
Reboot after loading the firmware and the wifi should work.
After loading the firmware you will be able to update the kernel and not worry about having to update the driver as well as this will be done automatically when the kernel is updated.
There are several posts in the forum for the WN727N and the mt7601 driver, just search the forum for "WN727N" or "mt7601"
MrEngman
8-Block
Fri Sep 25, 2015 11:23 am
When the driver was updated for #817 because I did the rpi 2 update without looking this topic
kdand919
Wed Sep 30, 2015 8:02 pm
Last night I installed OSMC on a new raspberry pi B+ with a TP Link TL-WN725N V2.1 wifi dongle. I cannot seem to get the dongle to work at all with my raspberry pi. I have tried a few things throughout this message thread with no success. Last night I had been able to use it to connect to my network but could not download anything and it slows the pi to the point where it could not install any repo's. I tried again today and now I cannot even connect to my network using the OSMC network configure program. When I try to connect it says "failed to connect" and after a couple times trying it kills my raspberry pi and shows a sad face on the screen then reboots :(... Could someone please help me figure this out (I have another similar dongle and installed it properly on my first raspberry pi after using the above suggestions but can't seem to get this one going).
Thanks everyone!
Kyle
blachanc
Wed Sep 30, 2015 8:43 pm
Well,
this is the end for me, as Jessie supports natively the 8188eu dongle.
Thank you for your support !!
Ben
blachanc wrote:5 Months later, And one upgrade later.. Thanks Again
./install.sh
many Thanks,
Ben
Ben
Wed Sep 30, 2015 9:17 pm
blachanc wrote: this is the end for me, as Jessie supports natively the 8188eu dongle.
I've been using Mr Engman's driver on my Jessie testing machine for many months because the built-in driver is worse than useless.
blachanc
Wed Sep 30, 2015 9:44 pm
Dohhh,
Thanks for the heads up.
were you facing bad bitrate or connection drop off? I have been up with Jessie for only 1-2 hours of usage, mostly via weaved.
Thanks,
Ben
Thu Oct 01, 2015 5:36 pm
I was getting disconnections every ten minutes.
Sat Oct 03, 2015 8:33 am
Is there a 8188eu driver available for kernel revision = 4.1.9-v7+ & kernel build = #819? My Raspberry Pi2B is currently wired because the WiFi won't run.
MrEngman
Sat Oct 03, 2015 9:23 am
DougieLawson wrote:Is there a 8188eu driver available for kernel revision = 4.1.9-v7+ & kernel build = #819? My Raspberry Pi2B is currently wired because the WiFi won't run.
Should be available now, Dougie.
MrEngman
Sat Oct 03, 2015 12:09 pm
MrEngman
Thank you. That one is now running Jessie with 4.1.9-v7 #819 with all the latest updates on WiFi.
gangiar
Wed Oct 07, 2015 8:01 pm
hi
can u help me ?
osmc@osmc:~$ uname -a
Linux osmc 4.2.1-1-osmc #1 PREEMPT Wed Sep 23 20:52:02 UTC 2015 armv6l GNU/Linux
osmc@osmc:~$
tanx
MrEngman
Thu Oct 08, 2015 1:18 am
gangiar wrote:hi
can u help me ?
osmc@osmc:~$
tanx
What do you want help with? Would be useful if you tell us.
MrEngman
gangiar
Thu Oct 08, 2015 3:51 am
sorry
i need the right driver for TL-WN725N V2.1
after my dist-upgrade can't find a new working driver
MrEngman wrote:
gangiar wrote:hi
can u help me ?
osmc@osmc:~$
tanx
MrEngman
MrEngman
Thu Oct 08, 2015 12:31 pm
gangiar wrote:sorry
MrEngman wrote:
gangiar wrote:hi
can u help me ?
osmc@osmc:~$
tanx
MrEngman
I have just looked at OSMC and the driver for your wifi is now included in the image. You should be able to get it working by just configuring it.
If you have previously used my driver there may be a file installed that may stop the built in driver working. The file is /etc/modprobe.d/8188eu.conf. Check if the file is installed using command
ls /etc/modprobe.d/8188eu.conf
and if it is you will need to delete it and reboot your Pi to get the built in driver to work. Delete the file using command
sudo rm /etc/modprobe.d/8188eu.conf
and then reboot your Pi.
You should then be able get your wifi running with the built in driver.
MrEngman
gangiar
Thu Oct 08, 2015 1:35 pm
GREAT
It's working now
:D
thank you again
MrEngman[/quote]
Nevensky
Sat Oct 10, 2015 6:57 pm
Hello!
I was wondering if you could help me out with compiling the driver, I did read about the script you used to compile the kernels in the past (on the first page) but I figured it changed somewhat over time.
I need the driver for the kernel 3.18.9-rt5-v7+ #1,
its a realtime kernel variant of the usual 3.18.9-v7+ (8188eu-v7-20150307.tar.gz) which I tried to use to no avail, I've modified the install.sh script to match the realtime kernel but this didn't work out...
Thanks for your help! :)
