jcptapar05
Re: (UPDATE) Drivers for TL-WN725N V2 - 3.6.11+ -> 4.xx.xx+
Wed Oct 23, 2019 9:04 am
Hi Everyone I have realtek 8188etv(I used 8188eu/4.19.79-v7.1273 driver) I followed the instructions but I can't enter to monitor mode? I tried sudo airmon-ng start wlan0 o ifconfig wlan0 mode monitor still the same mode(manage or auto). Please help me. I am using rpi 3b with 8188etv usb stick. How to enter to monitor mode? I installed the driver and after running airmon-ng it tells me operation not supported(-95)
bmichaelb
Sun Oct 27, 2019 1:41 am
MrEngman
I have the TL-WN725N v3, and bought it because it was on a list from Microsoft, supposedly guaranteed to work with WiFi Direct. I've even come across a video on Youtube, showing it working to connect to an Android phone, and I've come across threads saying it works as a p2p-device...but with a driver from 2014, no longer hosted on dropbox. It doesn't matter if I install using your script, or build from scratch, I can never get the '* P2P-device' listed under supported interfaces using 'iw list', and using a 'WiFi_Direct_User_Interface' P2P set up script from one of the threads I came across, it says,
Interface doesn't accept private ioctl...
p2p_set (8BF0): Operation not permitted
Does something need to be enabled in the driver while compiling, or is my device just not capable of being a p2p-device?
i@raspberrypi:~ $ iw list
Wiphy phy0
	max # scan SSIDs: 9
	max scan IEs length: 2304 bytes
	max # sched scan SSIDs: 0
	max # match sets: 0
	max # scan plans: 1
	max scan plan interval: -1
	max scan plan iterations: 0
	Retry short limit: 7
	Retry long limit: 4
	Coverage class: 0 (up to 0m)
	Supported Ciphers:
		* WEP40 (00-0f-ac:1)
		* WEP104 (00-0f-ac:5)
		* TKIP (00-0f-ac:2)
		* CCMP-128 (00-0f-ac:4)
	Available Antennas: TX 0 RX 0
	Supported interface modes:
		 * IBSS
		 * managed
		 * AP
		 * P2P-client
		 * P2P-GO
https://www.raspberrypi.org/forums/view ... hp?t=91891
https://docs.microsoft.com/en-us/window ... wifidirect
https://docs.microsoft.com/en-us/window ... compatlist
https://www.amazon.ca/gp/product/B008IFXQFU
IntrudersPi
Mon Nov 04, 2019 3:43 pm
Dears,
[EDIT] I've let the subject and bough a Ralink RT5370 - it work without any problem.
I come form this topic :
https://www.raspberrypi.org/forums/view ... p?t=220596
And followed that tutorial :
http://downloads.fars-robotics.net/
But I don't know how to do the last mile
I've put all the code below for debug purposes.
pi@raspberrypi:~ $ sudo apt update
Get:1 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB]
Hit:2 http://archive.raspberrypi.org/debian buster InRelease
Fetched 15.0 kB in 1s (18.8 kB/s)
Reading package lists... Done
Building dependency tree
All packages are up to date.
pi@raspberrypi:~ $ sudo apt full-upgrade
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
pi@raspberrypi:~ $ uname -a
Linux raspberrypi 4.19.75-v7l+ #1270 SMP Tue Sep 24 18:51:41 BST 2019 armv7l GNU/Linux
pi@raspberrypi:~ $ lsusb
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 005: ID 0bda:8179 Realtek Semiconductor Corp. RTL8188EUS 802.11n Wireless Network Adapter
Bus 001 Device 004: ID 03f0:134a HP, Inc Optical Mouse
Bus 001 Device 003: ID 03f0:0024 HP, Inc KU-0316 Keyboard
Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
At this point TL-WN725N(EU) v3.0 is connected but not installed
Wireless interfaces check :
pi@raspberrypi:~ $ iwconfig
wlan0     IEEE 802.11  ESSID:"WIFI_VISITORS"
          Mode:Managed  Frequency:5.24 GHz  Access Point: 2C:3E:CF:60:C0:BF
          Bit Rate=108 Mb/s   Tx-Power=31 dBm
          Retry short limit:7   RTS thr:off   Fragment thr:off
          Power Management:on
          Link Quality=42/70  Signal level=-68 dBm
          Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0
          Tx excessive retries:0  Invalid misc:0   Missed beacon:0
eth0      no wireless extensions.
lo        no wireless extensions.
wlan1     unassociated  ESSID:""  Nickname:"<WIFI@REALTEK>"
          Mode:Auto  Frequency=2.412 GHz  Access Point: Not-Associated
          Sensitivity:0/0
          Retry:off   RTS thr:off   Fragment thr:off
          Power Management:off
          Link Quality:0  Signal level:0  Noise level:0
Driver download :
pi@raspberrypi:~ $ wget http://downloads.fars-robotics.net/wifi-drivers/8188eu-drivers/8188eu-4.19.75-v7l-1270.tar.gz
--2019-11-04 16:29:08--  http://downloads.fars-robotics.net/wifi-drivers/8188eu-drivers/8188eu-4.19.75-v7l-1270.tar.gz
Resolving downloads.fars-robotics.net (downloads.fars-robotics.net)... 82.68.133.179
Connecting to downloads.fars-robotics.net (downloads.fars-robotics.net)|82.68.133.179|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 681881 (666K) [application/x-gzip]
Saving to: ‘8188eu-4.19.75-v7l-1270.tar.gz’
8188eu-4.19.75-v7l-1270.tar.gz                              100%[=========================================================================================================================================>] 665.90K  44.3KB/s    in 15s
2019-11-04 16:29:23 (44.4 KB/s) - ‘8188eu-4.19.75-v7l-1270.tar.gz’ saved [681881/681881]
pi@raspberrypi:~ $ tar -zxvf 8188eu-4.19.75-v7l-1270.tar.gz
8188eu.ko
8188eu.conf
install.sh
Driver install :
pi@raspberrypi:~ $ sudo install -p -m 644 8188eu.ko /lib/modules/$(uname -r)/kernel/drivers/net/wireless
pi@raspberrypi:~ $ sudo insmod /lib/modules/$(uname -r)/kernel/drivers/net/wireless/8188eu.ko
pi@raspberrypi:~ $ sudo depmod -a
          Bit Rate=135 Mb/s   Tx-Power=31 dBm
          Power Management:on
          Link Quality=43/70  Signal level=-67 dBm
          Tx excessive retries:11  Invalid misc:0   Missed beacon:0
          Sensitivity:0/0
Last command played is a sudo reboot and then another interfaces check
wlan0     unassociated  ESSID:""  Nickname:"<WIFI@REALTEK>"
          Sensitivity:0/0
wlan1     IEEE 802.11  ESSID:"WIFI_VISITORS"
          Bit Rate=150 Mb/s   Tx-Power=31 dBm
          Power Management:on
          Link Quality=46/70  Signal level=-64 dBm
Now, can someone be kind enough and tell me how to activate my wlan0 in a monitor mode ?
I'm stuck at this step for one week :cry:
Thanks in advance
Doub
Mon Nov 25, 2019 2:40 am
The install script linked in the top post doesn't seem to support the Pi compute modules. Is that on purpose?
I have a CM3+ and a TP-Link RTL8188EUS-based Wifi dongle I'd like to use together. I had to add the following section to get the Pi detected:
# check for Pi CM3+
    elif cat Pirevno | grep -i 'a02100' ; then
        echo "You have a Pi CM3+ v1.0"
        Pi=2
I've only run the (modified) script in check mode so far, as I have the dongle working in STA/Managed mode with default Raspbian drivers, and I don't want to break that.
But I'd like to enable mixed mode STA+AP, and I think the default driver won't let me do that. Would the driver installed by this script be capable of running as a client and access point at the same time?
MrEngman
Fri Nov 29, 2019 11:21 am
No. I just don't have any CM modules. However, I will update the script to handle CM's.
# check for Pi CM3+
        Pi=2
I don't know whether it will work as client and AP at the same time but doubt it will.
MrEngman
travelmate630
Thu Dec 12, 2019 1:00 am
what can I do if I'm making my own kernel? I had cooked a new kernel based on 4.19.86+, after a successful compiling, I installed the 4.19.86+ driver (I am compiling kernel for pi Zero), but the driver (8188eu.ko) failed to load, it just said Invalid module format. I think the build number of the kernel that the driver was built is surely different from mine. What can I do to resolve the situation?
MrEngman
Thu Dec 12, 2019 5:58 am
If you compiled your own version of the kernel you will need to compile your own version of the driver as well.
MrEngman
MrAmir
Tue Dec 17, 2019 7:37 pm
Hello MrEngman,
I've got TL-WN725N V3. As you know V3 support monitor mode, unlike V2.
Unfortunately I was not able to independently understand how to install the driver on the Raspberry PI by TP-Link Installation Guide. https://static.tp-link.com/2018/201805/ ... 7_beta.zip
However, the driver that is installed according to your tutorial does not support monitor mode, as it was developed for version 2, I think.
After reading this forum thread, I found that other people faced a similar problem.
If it's possible, could you help me and the others by compiling the necessary driver?
uname -r: 4.19.75+ #1270
lsusb: Bus 001 Device 002: ID 0bda:8179 Realtek Semiconductor Corp. RTL8188EUS 802.11n Wireless Network Adapter
Thank you in advance!
And sorry for my english...
MrEngman
Wed Dec 18, 2019 10:35 am
Hello MrEngman,
Don't know how you figured out that. I have never tried monitor mode on any wifi adapter.
I had a look through the source for the wifi driver and found a line referring to monitor which was set to no. I changed it to yes and compiled the driver for my kernel version and it appears to now run in monitor mode. My wifi dongle is an early version of the TL-WN725N, and as far as I'm aware it's not a v3.
I am compiling a series of 8188eu drivers with monitor enabled and will let you know when the compiling is finish, in about 2 1/2 hours.
MrEngman
MrEngman
Wed Dec 18, 2019 10:36 am
Hello MrEngman,
MrEngman
MrAmir
Wed Dec 18, 2019 1:59 pm
I found this information from the box and the official TP-Link website. You can see next screenshots.
MrEngman
This is very good news for me, because the compilation had problems due to various changes in the new Linux kernels and the lack of updating a number of commands in the source code.
Thank you very much!
Amir
MrAmir
Thu Dec 19, 2019 6:25 pm
Hello! I was pleased to find that you updated the driver. Even the "iw list" shows the presence of a monitor mode.
But in practice, nothing happened. Most likely, this function is generally not implemented in the driver or implemented in part, because of what has been disabled.
It seems I still have to deal with drivers from tp-link web-site.
MrAmir
Sat Dec 21, 2019 5:28 am
Hello MrEngman,
By installing a large number of patches, I was able to compile the V3 driver from TP-Link site. But unfortunately they are not installed in the system. The insmod throws such an error.
I can’t even imagine what to do with it.
MrEngman
Sun Dec 22, 2019 2:04 am
Hi MrAmir,
Sorry for the delay in responding.
I've found this newer version of the 8188eu driver, v5.3.9, specifically configured to be able to use monitor mode. https://github.com/aircrack-ng/rtl8188eus
It compiles for kernel 4.19.xx without needing any changes and supports your wifi module. I have not tried it myself but thought you might find it is what you are looking for.
MrEngman
Pearl.852
Sun Jan 12, 2020 1:19 pm
Hi MrEngman,
I am looking for TP-Link Archer-T1U driver for RPi-1B. I have tried search for it at http://downloads.fars-robotics.net/wifi ... 0-drivers/, but the latest version is upto Kernel 4.19.19-1198 only. Could you help, please?
Index of /wifi-drivers/mt7610-drivers
[ICO]	Name	Last modified	Size	Description
[PARENTDIR]	Parent Directory	 	-
[   ]	mt7610-3.18.3-739.tar.gz	2018-04-21 00:58	444K
[   ]	mt7610-3.18.3-740.tar.gz	2018-04-21 01:00	444K
[   ]	mt7610-3.18.3-741.tar.gz	2018-04-21 01:03	444K
[   ]	mt7610-3.18.3-742.tar.gz	2018-04-21 01:05	444K
[   ]	mt7610-3.18.5-744.tar.gz	2018-04-21 01:08	444K
[   ]	mt7610-3.18.5-746.tar.gz	2018-04-21 01:11	444K
[   ]	mt7610-3.18.5-748.tar.gz	2018-04-21 01:15	444K
[   ]	mt7610-3.18.5-v7-746.tar.gz	2018-04-21 01:13	471K
[   ]	mt7610-3.18.5-v7-748.tar.gz	2018-04-21 01:17	471K
[   ]	mt7610-3.18.6-1.tar.gz	2018-04-21 01:20	444K
[   ]	mt7610-3.18.6-753.tar.gz	2018-04-21 01:25	444K
[   ]	mt7610-3.18.6-754.tar.gz	2018-04-21 01:30	444K
[   ]	mt7610-3.18.6-v7-749.tar.gz	2018-04-21 01:22	471K
[   ]	mt7610-3.18.6-v7-753.tar.gz	2018-04-21 01:27	471K
[   ]	mt7610-3.18.6-v7-754.tar.gz	2018-04-21 01:32	471K
[   ]	mt7610-3.18.7-755.tar.gz	2018-04-21 01:34	444K
[   ]	mt7610-3.18.7-756.tar.gz	2018-04-21 01:39	444K
[   ]	mt7610-3.18.7-757.tar.gz	2018-04-21 01:44	444K
[   ]	mt7610-3.18.7-758.tar.gz	2018-04-21 01:49	444K
[   ]	mt7610-3.18.7-759.tar.gz	2018-04-21 01:53	444K
[   ]	mt7610-3.18.7-v7-755.tar.gz	2018-04-21 01:36	471K
[   ]	mt7610-3.18.7-v7-756.tar.gz	2018-04-21 01:41	471K
[   ]	mt7610-3.18.7-v7-757.tar.gz	2018-04-21 01:46	471K
[   ]	mt7610-3.18.7-v7-758.tar.gz	2018-04-21 01:51	470K
[   ]	mt7610-3.18.7-v7-759.tar.gz	2018-04-21 01:55	470K
[   ]	mt7610-3.18.8-761.tar.gz	2018-04-21 01:58	444K
[   ]	mt7610-3.18.8-763.tar.gz	2018-04-21 02:03	444K
[   ]	mt7610-3.18.8-764.tar.gz	2018-04-21 02:07	444K
[   ]	mt7610-3.18.8-765.tar.gz	2018-04-21 02:12	444K
[   ]	mt7610-3.18.8-v7-761.tar.gz	2018-04-21 02:00	470K
[   ]	mt7610-3.18.8-v7-763.tar.gz	2018-04-21 02:05	470K
[   ]	mt7610-3.18.8-v7-764.tar.gz	2018-04-21 02:09	470K
[   ]	mt7610-3.18.8-v7-765.tar.gz	2018-04-21 02:14	470K
[   ]	mt7610-3.18.9-767.tar.gz	2018-04-21 02:17	444K
[   ]	mt7610-3.18.9-768.tar.gz	2018-04-21 02:21	444K
[   ]	mt7610-3.18.9-772.tar.gz	2018-04-21 02:26	444K
[   ]	mt7610-3.18.9-v7-767.tar.gz	2018-04-21 02:19	470K
[   ]	mt7610-3.18.9-v7-768.tar.gz	2018-04-21 02:23	470K
[   ]	mt7610-3.18.9-v7-772.tar.gz	2018-04-21 02:28	470K
[   ]	mt7610-3.18.10-774.tar.gz	2018-04-21 02:31	444K
[   ]	mt7610-3.18.10-775.tar.gz	2018-04-21 02:36	444K
[   ]	mt7610-3.18.10-v7-774.tar.gz	2018-04-21 02:33	470K
[   ]	mt7610-3.18.10-v7-775.tar.gz	2018-04-21 02:38	470K
[   ]	mt7610-3.18.11-776.tar.gz	2018-04-21 02:40	444K
[   ]	mt7610-3.18.11-777.tar.gz	2018-04-21 02:45	444K
[   ]	mt7610-3.18.11-780.tar.gz	2018-04-21 02:50	444K
[   ]	mt7610-3.18.11-781.tar.gz	2018-04-21 02:54	444K
[   ]	mt7610-3.18.11-v7-776.tar.gz	2018-04-21 02:42	470K
[   ]	mt7610-3.18.11-v7-777.tar.gz	2018-04-21 02:47	470K
[   ]	mt7610-3.18.11-v7-780.tar.gz	2018-04-21 02:52	470K
[   ]	mt7610-3.18.11-v7-781.tar.gz	2018-04-21 02:56	470K
[   ]	mt7610-3.18.12-782.tar.gz	2018-04-21 02:59	444K
[   ]	mt7610-3.18.12-783.tar.gz	2018-04-21 03:04	444K
[   ]	mt7610-3.18.12-v7-782.tar.gz	2018-04-21 03:01	470K
[   ]	mt7610-3.18.12-v7-783.tar.gz	2018-04-21 03:06	470K
[   ]	mt7610-3.18.13-784.tar.gz	2018-04-21 03:08	444K
[   ]	mt7610-3.18.13-785.tar.gz	2018-04-21 03:13	444K
[   ]	mt7610-3.18.13-v7-784.tar.gz	2018-04-21 03:10	470K
[   ]	mt7610-3.18.13-v7-785.tar.gz	2018-04-21 03:15	470K
[   ]	mt7610-3.18.14-792.tar.gz	2018-04-21 03:18	444K
[   ]	mt7610-3.18.14-793.tar.gz	2018-04-21 03:23	444K
[   ]	mt7610-3.18.14-794.tar.gz	2018-04-21 03:27	444K
[   ]	mt7610-3.18.14-v7-792.tar.gz	2018-04-21 03:20	470K
[   ]	mt7610-3.18.14-v7-793.tar.gz	2018-04-21 03:25	470K
[   ]	mt7610-3.18.14-v7-794.tar.gz	2018-04-21 03:30	470K
[   ]	mt7610-3.18.16-795.tar.gz	2018-04-21 03:32	444K
[   ]	mt7610-3.18.16-796.tar.gz	2018-04-21 03:37	444K
[   ]	mt7610-3.18.16-v7-795.tar.gz	2018-04-21 03:34	470K
[   ]	mt7610-3.18.16-v7-796.tar.gz	2018-04-21 03:39	470K
[   ]	mt7610-4.0.5-797.tar.gz	2018-04-21 03:43	427K
[   ]	mt7610-4.0.5-v7-797.tar.gz	2018-04-21 03:45	447K
[   ]	mt7610-4.0.6-798.tar.gz	2018-04-21 03:48	427K
[   ]	mt7610-4.0.6-799.tar.gz	2018-04-21 03:52	427K
[   ]	mt7610-4.0.6-v7-798.tar.gz	2018-04-21 03:50	447K
[   ]	mt7610-4.0.6-v7-799.tar.gz	2018-04-21 03:54	447K
[   ]	mt7610-4.0.7-801.tar.gz	2018-04-21 03:57	427K
[   ]	mt7610-4.0.7-802.tar.gz	2018-04-21 04:01	427K
[   ]	mt7610-4.0.7-v7-801.tar.gz	2018-04-21 03:59	447K
[   ]	mt7610-4.0.7-v7-802.tar.gz	2018-04-21 04:03	447K
[   ]	mt7610-4.0.8-803.tar.gz	2018-04-21 04:06	427K
[   ]	mt7610-4.0.8-804.tar.gz	2018-04-21 04:10	427K
[   ]	mt7610-4.0.8-805.tar.gz	2018-04-21 04:15	427K
[   ]	mt7610-4.0.8-v7-803.tar.gz	2018-04-21 04:08	447K
[   ]	mt7610-4.0.8-v7-804.tar.gz	2018-04-21 04:12	447K
[   ]	mt7610-4.0.8-v7-805.tar.gz	2018-04-21 04:17	447K
[   ]	mt7610-4.0.9-807.tar.gz	2018-04-21 04:19	427K
[   ]	mt7610-4.0.9-v7-807.tar.gz	2018-04-21 04:21	447K
[   ]	mt7610-4.1.4-808.tar.gz	2018-04-21 04:25	427K
[   ]	mt7610-4.1.4-v7-808.tar.gz	2018-04-21 04:27	447K
[   ]	mt7610-4.1.5-809.tar.gz	2018-04-21 04:30	427K
[   ]	mt7610-4.1.5-v7-809.tar.gz	2018-04-21 04:32	447K
[   ]	mt7610-4.1.6-810.tar.gz	2018-04-21 04:34	427K
[   ]	mt7610-4.1.6-811.tar.gz	2018-04-21 04:39	427K
[   ]	mt7610-4.1.6-812.tar.gz	2018-04-21 04:44	427K
[   ]	mt7610-4.1.6-v7-810.tar.gz	2018-04-21 04:36	447K
[   ]	mt7610-4.1.6-v7-811.tar.gz	2018-04-21 04:41	447K
[   ]	mt7610-4.1.6-v7-812.tar.gz	2018-04-21 04:46	447K
[   ]	mt7610-4.1.7-813.tar.gz	2018-04-21 04:48	427K
[   ]	mt7610-4.1.7-815.tar.gz	2018-04-21 04:53	427K
[   ]	mt7610-4.1.7-817.tar.gz	2018-04-21 04:57	427K
[   ]	mt7610-4.1.7-v7-813.tar.gz	2018-04-21 04:50	447K
[   ]	mt7610-4.1.7-v7-815.tar.gz	2018-04-21 04:55	447K
[   ]	mt7610-4.1.7-v7-817.tar.gz	2018-04-21 04:59	447K
[   ]	mt7610-4.1.8-818.tar.gz	2018-04-21 05:02	427K
[   ]	mt7610-4.1.8-v7-818.tar.gz	2018-04-21 05:04	447K
[   ]	mt7610-4.1.9-819.tar.gz	2018-04-21 05:06	427K
[   ]	mt7610-4.1.9-v7-819.tar.gz	2018-04-21 05:08	447K
[   ]	mt7610-4.1.10-820.tar.gz	2018-04-21 05:11	427K
[   ]	mt7610-4.1.10-821.tar.gz	2018-04-21 05:16	427K
[   ]	mt7610-4.1.10-v7-820.tar.gz	2018-04-21 05:13	447K
[   ]	mt7610-4.1.10-v7-821.tar.gz	2018-04-21 05:18	447K
[   ]	mt7610-4.1.11-822.tar.gz	2018-04-21 05:20	427K
[   ]	mt7610-4.1.11-v7-822.tar.gz	2018-04-21 05:22	447K
[   ]	mt7610-4.1.12-824.tar.gz	2018-04-21 05:25	427K
[   ]	mt7610-4.1.12-825.tar.gz	2018-04-21 05:30	427K
[   ]	mt7610-4.1.12-v7-824.tar.gz	2018-04-21 05:27	447K
[   ]	mt7610-4.1.12-v7-825.tar.gz	2018-04-21 05:32	447K
[   ]	mt7610-4.1.13-826.tar.gz	2018-04-21 05:34	427K
[   ]	mt7610-4.1.13-827.tar.gz	2018-04-21 05:39	427K
[   ]	mt7610-4.1.13-v7-826.tar.gz	2018-04-21 05:36	447K
[   ]	mt7610-4.1.13-v7-827.tar.gz	2018-04-21 05:41	447K
[   ]	mt7610-4.1.14-828.tar.gz	2018-04-21 05:43	427K
[   ]	mt7610-4.1.14-v7-828.tar.gz	2018-04-21 05:45	447K
[   ]	mt7610-4.1.15-829.tar.gz	2018-04-21 05:48	427K
[   ]	mt7610-4.1.15-830.tar.gz	2018-04-21 05:52	427K
[   ]	mt7610-4.1.15-831.tar.gz	2018-04-21 05:57	427K
[   ]	mt7610-4.1.15-v7-829.tar.gz	2018-04-21 05:50	447K
[   ]	mt7610-4.1.15-v7-830.tar.gz	2018-04-21 05:54	447K
[   ]	mt7610-4.1.15-v7-831.tar.gz	2018-04-21 05:59	447K
[   ]	mt7610-4.1.16-832.tar.gz	2018-04-21 06:02	427K
[   ]	mt7610-4.1.16-833.tar.gz	2018-04-21 06:06	427K
[   ]	mt7610-4.1.16-v7-832.tar.gz	2018-04-21 06:03	447K
[   ]	mt7610-4.1.16-v7-833.tar.gz	2018-04-21 06:08	447K
[   ]	mt7610-4.1.17-834.tar.gz	2018-04-21 06:11	427K
[   ]	mt7610-4.1.17-838.tar.gz	2018-04-21 06:15	427K
[   ]	mt7610-4.1.17-840.tar.gz	2018-04-21 06:20	427K
[   ]	mt7610-4.1.17-841.tar.gz	2018-04-21 06:24	427K
[   ]	mt7610-4.1.17-842.tar.gz	2018-04-21 06:29	427K
[   ]	mt7610-4.1.17-843.tar.gz	2018-04-21 06:33	427K
[   ]	mt7610-4.1.17-v7-834.tar.gz	2018-04-21 06:13	447K
[   ]	mt7610-4.1.17-v7-838.tar.gz	2018-04-21 06:17	447K
[   ]	mt7610-4.1.17-v7-840.tar.gz	2018-04-21 06:22	447K
[   ]	mt7610-4.1.17-v7-841.tar.gz	2018-04-21 06:26	447K
[   ]	mt7610-4.1.17-v7-842.tar.gz	2018-04-21 06:30	447K
[   ]	mt7610-4.1.17-v7-843.tar.gz	2018-04-21 06:35	447K
[   ]	mt7610-4.1.18-845.tar.gz	2018-04-21 06:38	427K
[   ]	mt7610-4.1.18-848.tar.gz	2018-04-21 06:42	427K
[   ]	mt7610-4.1.18-v7-845.tar.gz	2018-04-21 06:40	447K
[   ]	mt7610-4.1.18-v7-848.tar.gz	2018-04-21 06:44	447K
[   ]	mt7610-4.1.19-851.tar.gz	2018-04-21 06:47	427K
[   ]	mt7610-4.1.19-852.tar.gz	2018-04-21 06:51	427K
[   ]	mt7610-4.1.19-853.tar.gz	2018-04-21 06:56	427K
[   ]	mt7610-4.1.19-858.tar.gz	2018-04-21 07:01	427K
[   ]	mt7610-4.1.19-v7-851.tar.gz	2018-04-21 06:49	447K
[   ]	mt7610-4.1.19-v7-852.tar.gz	2018-04-21 06:53	447K
[   ]	mt7610-4.1.19-v7-853.tar.gz	2018-04-21 06:58	447K
[   ]	mt7610-4.1.19-v7-858.tar.gz	2018-04-21 07:03	447K
[   ]	mt7610-4.1.20-862.tar.gz	2018-04-21 07:05	427K
[   ]	mt7610-4.1.20-865.tar.gz	2018-04-21 07:10	427K
[   ]	mt7610-4.1.20-867.tar.gz	2018-04-21 07:15	427K
[   ]	mt7610-4.1.20-v7-862.tar.gz	2018-04-21 07:07	447K
[   ]	mt7610-4.1.20-v7-865.tar.gz	2018-04-21 07:12	447K
[   ]	mt7610-4.1.20-v7-867.tar.gz	2018-04-21 07:16	447K
[   ]	mt7610-4.1.21-872.tar.gz	2018-04-21 07:19	427K
[   ]	mt7610-4.1.21-873.tar.gz	2018-04-21 07:24	427K
[   ]	mt7610-4.1.21-v7-872.tar.gz	2018-04-21 07:21	447K
[   ]	mt7610-4.1.21-v7-873.tar.gz	2018-04-21 07:26	447K
[   ]	mt7610-4.4.6-874.tar.gz	2018-04-21 07:30	427K
[   ]	mt7610-4.4.6-875.tar.gz	2018-04-21 07:35	427K
[   ]	mt7610-4.4.6-v7-874.tar.gz	2018-04-21 07:32	447K
[   ]	mt7610-4.4.6-v7-875.tar.gz	2018-04-21 07:37	447K
[   ]	mt7610-4.4.7-876.tar.gz	2018-04-21 07:40	427K
[   ]	mt7610-4.4.7-877.tar.gz	2018-04-21 07:44	427K
[   ]	mt7610-4.4.7-878.tar.gz	2018-04-21 07:49	427K
[   ]	mt7610-4.4.7-879.tar.gz	2018-04-21 07:54	427K
[   ]	mt7610-4.4.7-v7-876.tar.gz	2018-04-21 07:42	447K
[   ]	mt7610-4.4.7-v7-877.tar.gz	2018-04-21 07:46	447K
[   ]	mt7610-4.4.7-v7-878.tar.gz	2018-04-21 07:51	447K
[   ]	mt7610-4.4.7-v7-879.tar.gz	2018-04-21 07:56	447K
[   ]	mt7610-4.4.8-880.tar.gz	2018-04-21 07:58	427K
[   ]	mt7610-4.4.8-881.tar.gz	2018-04-21 08:03	427K
[   ]	mt7610-4.4.8-v7-880.tar.gz	2018-04-21 08:00	448K
[   ]	mt7610-4.4.8-v7-881.tar.gz	2018-04-21 08:05	448K
[   ]	mt7610-4.4.9-883.tar.gz	2018-04-21 08:08	427K
[   ]	mt7610-4.4.9-884.tar.gz	2018-04-21 08:12	427K
[   ]	mt7610-4.4.9-v7-883.tar.gz	2018-04-21 08:10	447K
[   ]	mt7610-4.4.9-v7-884.tar.gz	2018-04-21 08:14	447K
[   ]	mt7610-4.4.10-885.tar.gz	2018-04-21 08:17	427K
[   ]	mt7610-4.4.10-v7-885.tar.gz	2018-04-21 08:19	447K
[   ]	mt7610-4.4.11-886.tar.gz	2018-04-21 08:21	427K
[   ]	mt7610-4.4.11-887.tar.gz	2018-04-21 08:26	427K
[   ]	mt7610-4.4.11-888.tar.gz	2018-04-21 08:31	427K
[   ]	mt7610-4.4.11-891.tar.gz	2018-04-21 08:35	427K
[   ]	mt7610-4.4.11-v7-886.tar.gz	2018-04-21 08:23	447K
[   ]	mt7610-4.4.11-v7-887.tar.gz	2018-04-21 08:28	447K
[   ]	mt7610-4.4.11-v7-888.tar.gz	2018-04-21 08:33	447K
[   ]	mt7610-4.4.11-v7-891.tar.gz	2018-04-21 08:37	447K
[   ]	mt7610-4.4.12-892.tar.gz	2018-04-21 08:40	427K
[   ]	mt7610-4.4.12-v7-892.tar.gz	2018-04-21 08:42	447K
[   ]	mt7610-4.4.13-893.tar.gz	2018-04-21 08:45	427K
[   ]	mt7610-4.4.13-894.tar.gz	2018-04-21 08:49	427K
[   ]	mt7610-4.4.13-v7-893.tar.gz	2018-04-21 08:47	447K
[   ]	mt7610-4.4.13-v7-894.tar.gz	2018-04-21 08:51	447K
[   ]	mt7610-4.4.14-895.tar.gz	2018-04-21 08:54	427K
[   ]	mt7610-4.4.14-896.tar.gz	2018-04-21 08:59	427K
[   ]	mt7610-4.4.14-v7-895.tar.gz	2018-04-21 08:56	447K
[   ]	mt7610-4.4.14-v7-896.tar.gz	2018-04-21 09:01	447K
[   ]	mt7610-4.4.15-897.tar.gz	2018-04-21 09:03	427K
[   ]	mt7610-4.4.15-898.tar.gz	2018-04-21 09:08	427K
[   ]	mt7610-4.4.15-v7-897.tar.gz	2018-04-21 09:05	447K
[   ]	mt7610-4.4.15-v7-898.tar.gz	2018-04-21 09:10	447K
[   ]	mt7610-4.4.16-899.tar.gz	2018-04-21 09:13	427K
[   ]	mt7610-4.4.16-900.tar.gz	2018-04-21 09:17	427K
[   ]	mt7610-4.4.16-v7-899.tar.gz	2018-04-21 09:15	447K
[   ]	mt7610-4.4.16-v7-900.tar.gz	2018-04-21 09:19	447K
[   ]	mt7610-4.4.17-901.tar.gz	2018-04-21 09:22	427K
[   ]	mt7610-4.4.17-902.tar.gz	2018-04-21 09:27	427K
[   ]	mt7610-4.4.17-904.tar.gz	2018-04-21 09:32	427K
[   ]	mt7610-4.4.17-v7-901.tar.gz	2018-04-21 09:24	447K
[   ]	mt7610-4.4.17-v7-902.tar.gz	2018-04-21 09:29	447K
[   ]	mt7610-4.4.17-v7-904.tar.gz	2018-04-21 09:34	447K
[   ]	mt7610-4.4.18-905.tar.gz	2018-04-21 09:36	427K
[   ]	mt7610-4.4.18-v7-905.tar.gz	2018-04-21 09:39	447K
[   ]	mt7610-4.4.19-906.tar.gz	2018-04-21 09:41	427K
[   ]	mt7610-4.4.19-907.tar.gz	2018-04-21 09:46	427K
[   ]	mt7610-4.4.19-v7-906.tar.gz	2018-04-21 09:43	447K
[   ]	mt7610-4.4.19-v7-907.tar.gz	2018-04-21 09:48	447K
[   ]	mt7610-4.4.20-908.tar.gz	2018-04-21 09:51	427K
[   ]	mt7610-4.4.20-909.tar.gz	2018-04-21 09:55	427K
[   ]	mt7610-4.4.20-910.tar.gz	2018-04-21 10:00	427K
[   ]	mt7610-4.4.20-v7-908.tar.gz	2018-04-21 09:53	448K
[   ]	mt7610-4.4.20-v7-909.tar.gz	2018-04-21 09:57	447K
[   ]	mt7610-4.4.20-v7-910.tar.gz	2018-04-21 10:02	447K
[   ]	mt7610-4.4.21-911.tar.gz	2018-04-21 10:04	427K
[   ]	mt7610-4.4.21-v7-911.tar.gz	2018-04-21 10:06	447K
[   ]	mt7610-4.4.22-912.tar.gz	2018-04-21 10:09	427K
[   ]	mt7610-4.4.22-v7-912.tar.gz	2018-04-21 10:11	447K
[   ]	mt7610-4.4.23-913.tar.gz	2018-04-21 10:14	427K
[   ]	mt7610-4.4.23-v7-913.tar.gz	2018-04-21 10:16	447K
[   ]	mt7610-4.4.25-914.tar.gz	2018-04-21 10:18	427K
[   ]	mt7610-4.4.25-v7-914.tar.gz	2018-04-21 10:20	447K
[   ]	mt7610-4.4.26-915.tar.gz	2018-04-21 10:23	427K
[   ]	mt7610-4.4.26-916.tar.gz	2018-04-21 10:27	427K
[   ]	mt7610-4.4.26-v7-915.tar.gz	2018-04-21 10:25	447K
[   ]	mt7610-4.4.26-v7-916.tar.gz	2018-04-21 10:29	447K
[   ]	mt7610-4.4.27-917.tar.gz	2018-04-21 10:32	427K
[   ]	mt7610-4.4.27-918.tar.gz	2018-04-21 10:37	427K
[   ]	mt7610-4.4.27-v7-917.tar.gz	2018-04-21 10:34	447K
[   ]	mt7610-4.4.27-v7-918.tar.gz	2018-04-21 10:39	447K
[   ]	mt7610-4.4.30-919.tar.gz	2018-04-21 10:41	427K
[   ]	mt7610-4.4.30-920.tar.gz	2018-04-21 10:46	427K
[   ]	mt7610-4.4.30-v7-919.tar.gz	2018-04-21 10:43	447K
[   ]	mt7610-4.4.30-v7-920.tar.gz	2018-04-21 10:48	448K
[   ]	mt7610-4.4.31-921.tar.gz	2018-04-21 10:50	427K
[   ]	mt7610-4.4.31-922.tar.gz	2018-04-21 10:55	427K
[   ]	mt7610-4.4.31-923.tar.gz	2018-04-21 11:00	427K
[   ]	mt7610-4.4.31-v7-921.tar.gz	2018-04-21 10:52	447K
[   ]	mt7610-4.4.31-v7-922.tar.gz	2018-04-21 10:57	447K
[   ]	mt7610-4.4.31-v7-923.tar.gz	2018-04-21 11:02	447K
[   ]	mt7610-4.4.32-924.tar.gz	2018-04-21 11:04	427K
[   ]	mt7610-4.4.32-925.tar.gz	2018-04-21 11:09	427K
[   ]	mt7610-4.4.32-926.tar.gz	2018-04-21 11:13	427K
[   ]	mt7610-4.4.32-v7-924.tar.gz	2018-04-21 11:06	447K
[   ]	mt7610-4.4.32-v7-925.tar.gz	2018-04-21 11:11	447K
[   ]	mt7610-4.4.32-v7-926.tar.gz	2018-04-21 11:15	447K
[   ]	mt7610-4.4.33-927.tar.gz	2018-04-21 11:18	427K
[   ]	mt7610-4.4.33-928.tar.gz	2018-04-21 11:22	427K
[   ]	mt7610-4.4.33-v7-927.tar.gz	2018-04-21 11:20	447K
[   ]	mt7610-4.4.33-v7-928.tar.gz	2018-04-21 11:24	447K
[   ]	mt7610-4.4.34-929.tar.gz	2018-04-21 11:27	427K
[   ]	mt7610-4.4.34-930.tar.gz	2018-04-21 11:32	427K
[   ]	mt7610-4.4.34-v7-929.tar.gz	2018-04-21 11:29	447K
[   ]	mt7610-4.4.34-v7-930.tar.gz	2018-04-21 11:34	447K
[   ]	mt7610-4.4.35-931.tar.gz	2018-04-21 11:36	427K
[   ]	mt7610-4.4.35-932.tar.gz	2018-04-21 11:41	427K
[   ]	mt7610-4.4.35-v7-931.tar.gz	2018-04-21 11:38	447K
[   ]	mt7610-4.4.35-v7-932.tar.gz	2018-04-21 11:43	447K
[   ]	mt7610-4.4.36-933.tar.gz	2018-04-21 11:46	427K
[   ]	mt7610-4.4.36-v7-933.tar.gz	2018-04-21 11:48	447K
[   ]	mt7610-4.4.37-936.tar.gz	2018-04-21 11:50	427K
[   ]	mt7610-4.4.37-v7-936.tar.gz	2018-04-21 11:52	448K
[   ]	mt7610-4.4.38-938.tar.gz	2018-04-21 11:55	427K
[   ]	mt7610-4.4.38-v7-938.tar.gz	2018-04-21 11:57	447K
[   ]	mt7610-4.4.41-942.tar.gz	2018-04-21 12:00	427K
[   ]	mt7610-4.4.41-v7-942.tar.gz	2018-04-21 12:02	447K
[   ]	mt7610-4.4.42-946.tar.gz	2018-04-21 12:04	427K
[   ]	mt7610-4.4.42-v7-946.tar.gz	2018-04-21 12:06	447K
[   ]	mt7610-4.4.43-948.tar.gz	2018-04-21 12:09	427K
[   ]	mt7610-4.4.43-v7-948.tar.gz	2018-04-21 12:11	447K
[   ]	mt7610-4.4.44-950.tar.gz	2018-04-21 12:13	427K
[   ]	mt7610-4.4.44-v7-950.tar.gz	2018-04-21 12:15	447K
[   ]	mt7610-4.4.45-954.tar.gz	2018-04-21 12:18	427K
[   ]	mt7610-4.4.45-v7-954.tar.gz	2018-04-21 12:20	447K
[   ]	mt7610-4.4.46-957.tar.gz	2018-04-21 12:22	427K
[   ]	mt7610-4.4.46-959.tar.gz	2018-04-21 12:26	427K
[   ]	mt7610-4.4.46-v7-957.tar.gz	2018-04-21 12:24	447K
[   ]	mt7610-4.4.46-v7-959.tar.gz	2018-04-21 12:28	447K
[   ]	mt7610-4.4.47-961.tar.gz	2018-04-21 12:31	427K
[   ]	mt7610-4.4.47-v7-961.tar.gz	2018-04-21 12:33	447K
[   ]	mt7610-4.4.48-962.tar.gz	2018-04-21 12:35	427K
[   ]	mt7610-4.4.48-964.tar.gz	2018-04-21 12:40	427K
[   ]	mt7610-4.4.48-v7-962.tar.gz	2018-04-21 12:37	447K
[   ]	mt7610-4.4.48-v7-964.tar.gz	2018-04-21 12:42	447K
[   ]	mt7610-4.4.49-968.tar.gz	2018-04-21 12:44	427K
[   ]	mt7610-4.4.49-v7-968.tar.gz	2018-04-21 12:46	447K
[   ]	mt7610-4.4.50-970.tar.gz	2018-04-21 12:48	427K
[   ]	mt7610-4.4.50-v7-970.tar.gz	2018-04-21 12:50	447K
[   ]	mt7610-4.9.11-971.tar.gz	2018-04-21 12:55	428K
[   ]	mt7610-4.9.11-v7-971.tar.gz	2018-04-21 12:57	447K
[   ]	mt7610-4.9.13-972.tar.gz	2018-04-21 13:00	428K
[   ]	mt7610-4.9.13-974.tar.gz	2018-04-21 13:05	428K
[   ]	mt7610-4.9.13-v7-972.tar.gz	2018-04-21 13:02	447K
[   ]	mt7610-4.9.13-v7-974.tar.gz	2018-04-21 13:07	447K
[   ]	mt7610-4.9.14-977.tar.gz	2018-04-21 13:09	427K
[   ]	mt7610-4.9.14-v7-977.tar.gz	2018-04-21 13:12	447K
[   ]	mt7610-4.9.16-978.tar.gz	2018-04-21 13:14	428K
[   ]	mt7610-4.9.16-v7-978.tar.gz	2018-04-21 13:17	447K
[   ]	mt7610-4.9.17-981.tar.gz	2018-04-21 13:19	428K
[   ]	mt7610-4.9.17-v7-981.tar.gz	2018-04-21 13:21	447K
[   ]	mt7610-4.9.19-983.tar.gz	2018-04-21 13:24	428K
[   ]	mt7610-4.9.19-v7-983.tar.gz	2018-04-21 13:26	447K
[   ]	mt7610-4.9.20-985.tar.gz	2018-04-21 13:29	428K
[   ]	mt7610-4.9.20-v7-985.tar.gz	2018-04-21 13:31	447K
[   ]	mt7610-4.9.21-986.tar.gz	2018-04-21 13:34	428K
[   ]	mt7610-4.9.21-v7-986.tar.gz	2018-04-21 13:36	447K
[   ]	mt7610-4.9.22-987.tar.gz	2018-04-21 13:39	428K
[   ]	mt7610-4.9.22-v7-987.tar.gz	2018-04-21 13:41	447K
[   ]	mt7610-4.9.23-989.tar.gz	2018-04-21 13:43	428K
[   ]	mt7610-4.9.23-v7-989.tar.gz	2018-04-21 13:46	447K
[   ]	mt7610-4.9.24-991.tar.gz	2018-04-21 13:48	428K
[   ]	mt7610-4.9.24-992.tar.gz	2018-04-21 13:53	428K
[   ]	mt7610-4.9.24-993.tar.gz	2018-04-21 13:58	428K
[   ]	mt7610-4.9.24-v7-991.tar.gz	2018-04-21 13:51	447K
[   ]	mt7610-4.9.24-v7-992.tar.gz	2018-04-21 13:55	447K
[   ]	mt7610-4.9.24-v7-993.tar.gz	2018-04-21 14:00	447K
[   ]	mt7610-4.9.25-994.tar.gz	2018-04-21 14:03	428K
[   ]	mt7610-4.9.25-995.tar.gz	2018-04-21 14:08	428K
[   ]	mt7610-4.9.25-v7-994.tar.gz	2018-04-21 14:05	447K
[   ]	mt7610-4.9.25-v7-995.tar.gz	2018-04-21 14:10	447K
[   ]	mt7610-4.9.26-996.tar.gz	2018-04-21 14:13	428K
[   ]	mt7610-4.9.26-v7-996.tar.gz	2018-04-21 14:15	447K
[   ]	mt7610-4.9.27-997.tar.gz	2018-04-21 14:18	428K
[   ]	mt7610-4.9.27-v7-997.tar.gz	2018-04-21 14:20	447K
[   ]	mt7610-4.9.28-998.tar.gz	2018-04-21 14:23	428K
[   ]	mt7610-4.9.28-999.tar.gz	2018-04-21 14:27	428K
[   ]	mt7610-4.9.28-v7-998.tar.gz	2018-04-21 14:25	447K
[   ]	mt7610-4.9.28-v7-999.tar.gz	2018-04-21 14:30	447K
[   ]	mt7610-4.9.29-1000.tar.gz	2018-04-21 14:32	428K
[   ]	mt7610-4.9.29-v7-1000.tar.gz	2018-04-21 14:35	447K
[   ]	mt7610-4.9.30-1001.tar.gz	2018-04-21 14:37	428K
[   ]	mt7610-4.9.30-v7-1001.tar.gz	2018-04-21 14:39	447K
[   ]	mt7610-4.9.31-1005.tar.gz	2018-04-21 14:42	428K
[   ]	mt7610-4.9.31-1007.tar.gz	2018-04-21 14:47	428K
[   ]	mt7610-4.9.31-v7-1005.tar.gz	2018-04-21 14:44	447K
[   ]	mt7610-4.9.31-v7-1007.tar.gz	2018-04-21 14:49	447K
[   ]	mt7610-4.9.32-1008.tar.gz	2018-04-21 14:52	427K
[   ]	mt7610-4.9.32-1009.tar.gz	2018-04-21 14:57	428K
[   ]	mt7610-4.9.32-v7-1008.tar.gz	2018-04-21 14:54	447K
[   ]	mt7610-4.9.32-v7-1009.tar.gz	2018-04-21 14:59	447K
[   ]	mt7610-4.9.33-1010.tar.gz	2018-04-21 15:01	428K
[   ]	mt7610-4.9.33-1012.tar.gz	2018-04-21 15:06	428K
[   ]	mt7610-4.9.33-v7-1010.tar.gz	2018-04-21 15:04	447K
[   ]	mt7610-4.9.33-v7-1012.tar.gz	2018-04-21 15:09	447K
[   ]	mt7610-4.9.34-1013.tar.gz	2018-04-21 15:11	427K
[   ]	mt7610-4.9.34-v7-1013.tar.gz	2018-04-21 15:13	447K
[   ]	mt7610-4.9.35-1014.tar.gz	2018-04-21 15:16	427K
[   ]	mt7610-4.9.35-v7-1014.tar.gz	2018-04-21 15:18	447K
[   ]	mt7610-4.9.36-1015.tar.gz	2018-04-21 15:21	427K
[   ]	mt7610-4.9.36-v7-1015.tar.gz	2018-04-21 15:23	447K
[   ]	mt7610-4.9.37-1017.tar.gz	2018-04-21 15:26	428K
[   ]	mt7610-4.9.37-v7-1017.tar.gz	2018-04-21 15:28	447K
[   ]	mt7610-4.9.39-1018.tar.gz	2018-04-21 15:31	427K
[   ]	mt7610-4.9.39-1020.tar.gz	2018-04-21 15:36	428K
[   ]	mt7610-4.9.39-1021.tar.gz	2018-04-21 15:40	428K
[   ]	mt7610-4.9.39-v7-1018.tar.gz	2018-04-21 15:33	447K
[   ]	mt7610-4.9.39-v7-1020.tar.gz	2018-04-21 15:38	447K
[   ]	mt7610-4.9.39-v7-1021.tar.gz	2018-04-21 15:43	447K
[   ]	mt7610-4.9.40-1022.tar.gz	2018-04-21 15:45	427K
[   ]	mt7610-4.9.40-v7-1022.tar.gz	2018-04-21 15:48	447K
[   ]	mt7610-4.9.41-1023.tar.gz	2018-04-21 15:50	428K
[   ]	mt7610-4.9.41-v7-1023.tar.gz	2018-04-21 15:52	447K
[   ]	mt7610-4.9.43-1026.tar.gz	2018-04-21 15:55	428K
[   ]	mt7610-4.9.43-1028.tar.gz	2018-04-21 16:00	428K
[   ]	mt7610-4.9.43-v7-1026.tar.gz	2018-04-21 15:57	448K
[   ]	mt7610-4.9.43-v7-1028.tar.gz	2018-04-21 16:02	447K
[   ]	mt7610-4.9.44-1029.tar.gz	2018-04-21 16:05	428K
[   ]	mt7610-4.9.44-v7-1029.tar.gz	2018-04-21 16:07	448K
[   ]	mt7610-4.9.45-1031.tar.gz	2018-04-21 16:10	428K
[   ]	mt7610-4.9.45-v7-1031.tar.gz	2018-04-21 16:12	447K
[   ]	mt7610-4.9.46-1032.tar.gz	2018-04-21 16:15	428K
[   ]	mt7610-4.9.46-v7-1032.tar.gz	2018-04-21 16:17	447K
[   ]	mt7610-4.9.47-1033.tar.gz	2018-04-21 16:19	428K
[   ]	mt7610-4.9.47-v7-1033.tar.gz	2018-04-21 16:22	447K
[   ]	mt7610-4.9.48-1034.tar.gz	2018-04-21 16:24	428K
[   ]	mt7610-4.9.48-v7-1034.tar.gz	2018-04-21 16:26	447K
[   ]	mt7610-4.9.50-1035.tar.gz	2018-04-21 16:29	428K
[   ]	mt7610-4.9.50-v7-1035.tar.gz	2018-04-21 16:31	447K
[   ]	mt7610-4.9.51-1036.tar.gz	2018-04-21 16:34	428K
[   ]	mt7610-4.9.51-v7-1036.tar.gz	2018-04-21 16:36	448K
[   ]	mt7610-4.9.52-1038.tar.gz	2018-04-21 16:39	428K
[   ]	mt7610-4.9.52-v7-1038.tar.gz	2018-04-21 16:41	447K
[   ]	mt7610-4.9.53-1040.tar.gz	2018-04-21 16:44	428K
[   ]	mt7610-4.9.53-v7-1040.tar.gz	2018-04-21 16:46	447K
[   ]	mt7610-4.9.54-1041.tar.gz	2018-04-21 16:49	428K
[   ]	mt7610-4.9.54-1042.tar.gz	2018-04-21 16:53	428K
[   ]	mt7610-4.9.54-v7-1041.tar.gz	2018-04-21 16:51	447K
[   ]	mt7610-4.9.54-v7-1042.tar.gz	2018-04-21 16:56	447K
[   ]	mt7610-4.9.56-1044.tar.gz	2018-04-21 16:58	428K
[   ]	mt7610-4.9.56-v7-1044.tar.gz	2018-04-21 17:00	447K
[   ]	mt7610-4.9.57-1045.tar.gz	2018-04-21 17:03	428K
[   ]	mt7610-4.9.57-v7-1045.tar.gz	2018-04-21 17:05	447K
[   ]	mt7610-4.9.58-1046.tar.gz	2018-04-21 17:08	428K
[   ]	mt7610-4.9.58-v7-1046.tar.gz	2018-04-21 17:10	447K
[   ]	mt7610-4.9.59-1047.tar.gz	2018-04-21 17:13	428K
[   ]	mt7610-4.9.59-v7-1047.tar.gz	2018-04-21 17:15	447K
[   ]	mt7610-4.9.60-1048.tar.gz	2018-04-21 17:18	428K
[   ]	mt7610-4.9.60-v7-1048.tar.gz	2018-04-21 17:20	447K
[   ]	mt7610-4.9.61-1049.tar.gz	2018-04-21 17:23	428K
[   ]	mt7610-4.9.61-v7-1049.tar.gz	2018-04-21 17:25	447K
[   ]	mt7610-4.9.62-1051.tar.gz	2018-04-21 17:27	428K
[   ]	mt7610-4.9.62-v7-1051.tar.gz	2018-04-21 17:30	447K
[   ]	mt7610-4.9.63-1052.tar.gz	2018-04-21 17:32	428K
[   ]	mt7610-4.9.63-v7-1052.tar.gz	2018-04-21 17:34	447K
[   ]	mt7610-4.9.64-1053.tar.gz	2018-04-21 17:37	428K
[   ]	mt7610-4.9.64-v7-1053.tar.gz	2018-04-21 17:39	447K
[   ]	mt7610-4.9.65-1056.tar.gz	2018-04-21 17:42	428K
[   ]	mt7610-4.9.65-v7-1056.tar.gz	2018-04-21 17:44	448K
[   ]	mt7610-4.9.66-1059.tar.gz	2018-04-21 17:47	428K
[   ]	mt7610-4.9.66-v7-1059.tar.gz	2018-04-21 17:49	448K
[   ]	mt7610-4.9.67-1061.tar.gz	2018-04-21 17:52	428K
[   ]	mt7610-4.9.67-v7-1061.tar.gz	2018-04-21 17:54	447K
[   ]	mt7610-4.9.68-1064.tar.gz	2018-04-21 17:57	428K
[   ]	mt7610-4.9.68-v7-1064.tar.gz	2018-04-21 17:59	447K
[   ]	mt7610-4.9.69-1065.tar.gz	2018-04-21 18:01	428K
[   ]	mt7610-4.9.69-v7-1065.tar.gz	2018-04-21 18:04	447K
[   ]	mt7610-4.9.70-1068.tar.gz	2018-04-21 18:06	428K
[   ]	mt7610-4.9.70-v7-1068.tar.gz	2018-04-21 18:08	447K
[   ]	mt7610-4.9.72-1069.tar.gz	2018-04-21 18:11	428K
[   ]	mt7610-4.9.72-v7-1069.tar.gz	2018-04-21 18:13	447K
[   ]	mt7610-4.9.73-1072.tar.gz	2018-04-21 18:16	428K
[   ]	mt7610-4.9.73-v7-1072.tar.gz	2018-04-21 18:18	447K
[   ]	mt7610-4.9.75-1074.tar.gz	2018-04-21 18:21	428K
[   ]	mt7610-4.9.75-v7-1074.tar.gz	2018-04-21 18:23	447K
[   ]	mt7610-4.9.76-1076.tar.gz	2018-04-21 18:26	428K
[   ]	mt7610-4.9.76-v7-1076.tar.gz	2018-04-21 18:28	447K
[   ]	mt7610-4.9.77-1081.tar.gz	2018-04-21 18:30	428K
[   ]	mt7610-4.9.77-v7-1081.tar.gz	2018-04-21 18:33	448K
[   ]	mt7610-4.9.78-1084.tar.gz	2018-04-21 18:35	428K
[   ]	mt7610-4.9.78-v7-1084.tar.gz	2018-04-21 18:38	448K
[   ]	mt7610-4.9.79-1086.tar.gz	2018-04-21 18:40	428K
[   ]	mt7610-4.9.79-1091.tar.gz	2018-04-21 18:45	428K
[   ]	mt7610-4.9.79-v7-1086.tar.gz	2018-04-21 18:42	447K
[   ]	mt7610-4.9.79-v7-1091.tar.gz	2018-04-21 18:47	447K
[   ]	mt7610-4.9.80-1092.tar.gz	2018-04-21 18:50	428K
[   ]	mt7610-4.9.80-1098.tar.gz	2018-04-21 18:55	428K
[   ]	mt7610-4.9.80-v7-1092.tar.gz	2018-04-21 18:52	447K
[   ]	mt7610-4.9.80-v7-1098.tar.gz	2018-04-21 18:57	447K
[   ]	mt7610-4.14.18-1093.tar.gz	2018-04-21 19:07	428K
[   ]	mt7610-4.14.18-v7-1093.tar.gz	2018-04-21 19:10	447K
[   ]	mt7610-4.14.20-1094.tar.gz	2018-04-21 19:12	428K
[   ]	mt7610-4.14.20-v7-1094.tar.gz	2018-04-21 19:15	447K
[   ]	mt7610-4.14.21-1095.tar.gz	2018-04-21 19:17	428K
[   ]	mt7610-4.14.21-v7-1095.tar.gz	2018-04-21 19:20	447K
[   ]	mt7610-4.14.22-1096.tar.gz	2018-04-21 19:22	428K
[   ]	mt7610-4.14.22-v7-1096.tar.gz	2018-04-21 19:25	447K
[   ]	mt7610-4.14.24-1097.tar.gz	2018-04-21 19:27	428K
[   ]	mt7610-4.14.24-v7-1097.tar.gz	2018-04-21 19:30	447K
[   ]	mt7610-4.14.26-1099.tar.gz	2018-04-21 19:32	428K
[   ]	mt7610-4.14.26-v7-1099.tar.gz	2018-04-21 19:35	447K
[   ]	mt7610-4.14.27-1100.tar.gz	2018-04-21 19:37	428K
[   ]	mt7610-4.14.27-v7-1100.tar.gz	2018-04-21 19:40	447K
[   ]	mt7610-4.14.29-1101.tar.gz	2018-04-21 19:42	428K
[   ]	mt7610-4.14.29-v7-1101.tar.gz	2018-04-21 19:45	447K
[   ]	mt7610-4.14.30-1102.tar.gz	2018-04-21 19:47	428K
[   ]	mt7610-4.14.30-1103.tar.gz	2018-04-21 19:52	428K
[   ]	mt7610-4.14.30-v7-1102.tar.gz	2018-04-21 19:50	447K
[   ]	mt7610-4.14.30-v7-1103.tar.gz	2018-04-21 19:55	447K
[   ]	mt7610-4.14.31-1104.tar.gz	2018-04-21 19:57	428K
[   ]	mt7610-4.14.31-v7-1104.tar.gz	2018-04-21 20:00	447K
[   ]	mt7610-4.14.32-1105.tar.gz	2018-04-21 20:02	428K
[   ]	mt7610-4.14.32-1106.tar.gz	2018-04-21 20:07	428K
[   ]	mt7610-4.14.32-1107.tar.gz	2018-04-21 20:12	428K
[   ]	mt7610-4.14.32-v7-1105.tar.gz	2018-04-21 20:04	447K
[   ]	mt7610-4.14.32-v7-1106.tar.gz	2018-04-21 20:10	447K
[   ]	mt7610-4.14.32-v7-1107.tar.gz	2018-04-21 20:14	447K
[   ]	mt7610-4.14.33-1108.tar.gz	2018-04-21 20:17	428K
[   ]	mt7610-4.14.33-1109.tar.gz	2018-04-21 20:22	428K
[   ]	mt7610-4.14.33-v7-1108.tar.gz	2018-04-21 20:19	447K
[   ]	mt7610-4.14.33-v7-1109.tar.gz	2018-04-21 20:24	447K
[   ]	mt7610-4.14.34-1110.tar.gz	2018-04-21 20:27	428K
[   ]	mt7610-4.14.34-v7-1110.tar.gz	2018-04-21 20:29	447K
[   ]	mt7610-4.14.37-1111.tar.gz	2018-04-26 23:57	428K
[   ]	mt7610-4.14.37-v7-1111.tar.gz	2018-04-27 00:07	447K
[   ]	mt7610-4.14.39-1112.tar.gz	2018-05-05 23:46	428K
[   ]	mt7610-4.14.39-v7-1112.tar.gz	2018-05-05 23:56	447K
[   ]	mt7610-4.14.41-1113.tar.gz	2018-05-18 18:45	428K
[   ]	mt7610-4.14.41-v7-1113.tar.gz	2018-05-18 18:55	447K
[   ]	mt7610-4.14.42-1114.tar.gz	2018-05-21 18:36	428K
[   ]	mt7610-4.14.42-v7-1114.tar.gz	2018-05-21 18:45	447K
[   ]	mt7610-4.14.43-1115.tar.gz	2018-05-25 18:32	428K
[   ]	mt7610-4.14.43-v7-1115.tar.gz	2018-05-25 18:42	447K
[   ]	mt7610-4.14.44-1117.tar.gz	2018-05-31 20:05	428K
[   ]	mt7610-4.14.44-v7-1117.tar.gz	2018-05-31 20:15	447K
[   ]	mt7610-4.14.48-1118.tar.gz	2018-06-07 22:05	428K
[   ]	mt7610-4.14.48-v7-1118.tar.gz	2018-06-07 22:15	447K
[   ]	mt7610-4.14.49-1120.tar.gz	2018-06-14 19:31	428K
[   ]	mt7610-4.14.49-v7-1120.tar.gz	2018-06-14 19:40	447K
[   ]	mt7610-4.14.50-1121.tar.gz	2018-06-18 21:31	428K
[   ]	mt7610-4.14.50-1122.tar.gz	2018-06-27 10:46	9.0M
[   ]	mt7610-4.14.50-v7-1121.tar.gz	2018-06-18 21:40	447K
[   ]	mt7610-4.14.50-v7-1122.tar.gz	2018-06-27 10:49	9.1M
[   ]	mt7610-4.14.52-1123.tar.gz	2018-06-27 23:35	428K
[   ]	mt7610-4.14.52-v7-1123.tar.gz	2018-06-27 23:45	447K
[   ]	mt7610-4.14.54-1124.tar.gz	2018-07-09 20:59	428K
[   ]	mt7610-4.14.54-1126.tar.gz	2018-07-11 22:07	428K
[   ]	mt7610-4.14.54-v7-1124.tar.gz	2018-07-09 21:10	447K
[   ]	mt7610-4.14.54-v7-1126.tar.gz	2018-07-11 22:17	447K
[   ]	mt7610-4.14.56-1128.tar.gz	2018-07-18 14:03	428K
[   ]	mt7610-4.14.56-v7-1128.tar.gz	2018-07-18 14:13	447K
[   ]	mt7610-4.14.58-1130.tar.gz	2018-07-30 20:32	428K
[   ]	mt7610-4.14.58-v7-1130.tar.gz	2018-07-30 20:43	447K
[   ]	mt7610-4.14.59-1131.tar.gz	2018-08-03 21:02	428K
[   ]	mt7610-4.14.59-v7-1131.tar.gz	2018-08-03 21:13	447K
[   ]	mt7610-4.14.61-1132.tar.gz	2018-08-07 18:24	428K
[   ]	mt7610-4.14.61-1133.tar.gz	2018-08-10 13:11	428K
[   ]	mt7610-4.14.61-v7-1132.tar.gz	2018-08-07 18:34	447K
[   ]	mt7610-4.14.61-v7-1133.tar.gz	2018-08-10 13:21	447K
[   ]	mt7610-4.14.62-1134.tar.gz	2018-08-16 18:32	428K
[   ]	mt7610-4.14.62-v7-1134.tar.gz	2018-08-16 18:42	447K
[   ]	mt7610-4.14.66-1137.tar.gz	2018-08-24 18:59	428K
[   ]	mt7610-4.14.66-v7-1137.tar.gz	2018-08-24 19:09	447K
[   ]	mt7610-4.14.67-1139.tar.gz	2018-08-29 16:42	428K
[   ]	mt7610-4.14.67-v7-1139.tar.gz	2018-08-29 16:52	447K
[   ]	mt7610-4.14.68-1140.tar.gz	2018-09-10 21:13	425K
[   ]	mt7610-4.14.68-v7-1140.tar.gz	2018-09-10 21:15	445K
[   ]	mt7610-4.14.69-1141.tar.gz	2018-09-11 02:42	425K
[   ]	mt7610-4.14.69-1142.tar.gz	2018-09-14 23:49	425K
[   ]	mt7610-4.14.69-v7-1141.tar.gz	2018-09-11 02:53	445K
[   ]	mt7610-4.14.69-v7-1142.tar.gz	2018-09-14 23:59	445K
[   ]	mt7610-4.14.70-1143.tar.gz	2018-09-17 19:01	425K
[   ]	mt7610-4.14.70-1144.tar.gz	2018-09-18 21:26	425K
[   ]	mt7610-4.14.70-v7-1143.tar.gz	2018-09-17 19:11	445K
[   ]	mt7610-4.14.70-v7-1144.tar.gz	2018-09-18 21:36	445K
[   ]	mt7610-4.14.71-1145.tar.gz	2018-09-24 21:14	425K
[   ]	mt7610-4.14.71-v7-1145.tar.gz	2018-09-24 21:24	445K
[   ]	mt7610-4.14.72-1146.tar.gz	2018-09-26 19:19	425K
[   ]	mt7610-4.14.72-v7-1146.tar.gz	2018-09-26 19:29	445K
[   ]	mt7610-4.14.73-1148.tar.gz	2018-10-01 21:16	425K
[   ]	mt7610-4.14.73-v7-1148.tar.gz	2018-10-01 21:26	445K
[   ]	mt7610-4.14.74-1149.tar.gz	2018-10-09 16:38	425K
[   ]	mt7610-4.14.74-v7-1149.tar.gz	2018-10-09 16:48	445K
[   ]	mt7610-4.14.76-1150.tar.gz	2018-10-15 19:35	425K
[   ]	mt7610-4.14.76-v7-1150.tar.gz	2018-10-15 19:45	445K
[   ]	mt7610-4.14.77-1154.tar.gz	2018-10-19 20:37	425K
[   ]	mt7610-4.14.77-v7-1154.tar.gz	2018-10-19 20:47	445K
[   ]	mt7610-4.14.78-1156.tar.gz	2018-10-24 09:48	425K
[   ]	mt7610-4.14.78-v7-1156.tar.gz	2018-10-24 09:58	445K
[   ]	mt7610-4.14.79-1159.tar.gz	2018-11-05 11:19	425K
[   ]	mt7610-4.14.79-v7-1159.tar.gz	2018-11-05 11:29	445K
[   ]	mt7610-4.14.80-1161.tar.gz	2018-11-13 04:26	425K
[   ]	mt7610-4.14.80-v7-1161.tar.gz	2018-11-13 04:36	445K
[   ]	mt7610-4.14.81-1163.tar.gz	2018-11-19 23:31	425K
[   ]	mt7610-4.14.81-v7-1163.tar.gz	2018-11-19 23:41	445K
[   ]	mt7610-4.14.82-1165.tar.gz	2018-11-21 20:01	425K
[   ]	mt7610-4.14.82-v7-1165.tar.gz	2018-11-21 20:11	445K
[   ]	mt7610-4.14.83-1167.tar.gz	2018-11-29 11:50	425K
[   ]	mt7610-4.14.83-v7-1167.tar.gz	2018-11-29 12:02	445K
[   ]	mt7610-4.14.84-1168.tar.gz	2018-11-29 14:27	425K
[   ]	mt7610-4.14.84-1169.tar.gz	2018-11-29 17:13	425K
[   ]	mt7610-4.14.84-v7-1168.tar.gz	2018-11-29 14:38	445K
[   ]	mt7610-4.14.84-v7-1169.tar.gz	2018-11-29 17:25	445K
[   ]	mt7610-4.14.85-1173.tar.gz	2018-12-04 18:43	425K
[   ]	mt7610-4.14.85-v7-1173.tar.gz	2018-12-04 18:55	445K
[   ]	mt7610-4.14.86-1175.tar.gz	2018-12-06 19:17	425K
[   ]	mt7610-4.14.86-v7-1175.tar.gz	2018-12-06 19:28	445K
[   ]	mt7610-4.14.87-1178.tar.gz	2018-12-11 19:32	425K
[   ]	mt7610-4.14.87-v7-1178.tar.gz	2018-12-11 19:43	445K
[   ]	mt7610-4.14.89-1182.tar.gz	2018-12-18 08:40	425K
[   ]	mt7610-4.14.89-v7-1182.tar.gz	2018-12-18 08:52	445K
[   ]	mt7610-4.14.90-1183.tar.gz	2018-12-21 18:59	425K
[   ]	mt7610-4.14.90-v7-1183.tar.gz	2018-12-21 19:10	445K
[   ]	mt7610-4.14.92-1187.tar.gz	2019-01-09 21:54	425K
[   ]	mt7610-4.14.92-v7-1187.tar.gz	2019-01-09 22:05	445K
[   ]	mt7610-4.14.93-1189.tar.gz	2019-01-14 19:19	425K
[   ]	mt7610-4.14.93-1191.tar.gz	2019-01-16 13:25	425K
[   ]	mt7610-4.14.93-v7-1189.tar.gz	2019-01-14 19:30	445K
[   ]	mt7610-4.14.93-v7-1191.tar.gz	2019-01-16 13:36	445K
[   ]	mt7610-4.14.94-1193.tar.gz	2019-01-22 21:39	425K
[   ]	mt7610-4.14.94-v7-1193.tar.gz	2019-01-22 21:49	445K
[   ]	mt7610-4.14.97-1197.tar.gz	2019-02-05 19:57	425K
[   ]	mt7610-4.14.97-v7-1197.tar.gz	2019-02-05 20:08	445K
[   ]	mt7610-4.14.98-1200.tar.gz	2019-02-12 22:37	425K
[   ]	mt7610-4.14.98-v7-1200.tar.gz	2019-02-12 22:48	445K
[   ]	mt7610-4.19.1-1160.tar.gz	2018-11-15 22:20	435K
[   ]	mt7610-4.19.1-v7-1160.tar.gz	2018-11-15 22:31	457K
[   ]	mt7610-4.19.2-1162.tar.gz	2018-11-15 22:42	435K
[   ]	mt7610-4.19.2-v7-1162.tar.gz	2018-11-15 22:53	457K
[   ]	mt7610-4.19.4-1166.tar.gz	2018-11-23 20:17	435K
[   ]	mt7610-4.19.4-v7-1166.tar.gz	2018-11-23 20:30	457K
[   ]	mt7610-4.19.5-1170.tar.gz	2018-11-29 20:20	435K
[   ]	mt7610-4.19.5-v7-1170.tar.gz	2018-11-29 20:32	457K
[   ]	mt7610-4.19.6-1171.tar.gz	2018-12-04 16:17	435K
[   ]	mt7610-4.19.6-v7-1171.tar.gz	2018-12-04 16:30	457K
[   ]	mt7610-4.19.7-1176.tar.gz	2018-12-06 19:44	435K
[   ]	mt7610-4.19.7-v7-1176.tar.gz	2018-12-06 19:57	457K
[   ]	mt7610-4.19.8-1179.tar.gz	2018-12-12 09:24	435K
[   ]	mt7610-4.19.8-v7-1179.tar.gz	2018-12-12 09:37	457K
[   ]	mt7610-4.19.12-1185.tar.gz	2019-01-01 16:00	435K
[   ]	mt7610-4.19.12-v7-1185.tar.gz	2019-01-01 16:12	457K
[   ]	mt7610-4.19.13-1186.tar.gz	2019-01-02 10:34	435K
[   ]	mt7610-4.19.13-v7-1186.tar.gz	2019-01-02 10:46	457K
[   ]	mt7610-4.19.14-1188.tar.gz	2019-01-10 19:24	435K
[   ]	mt7610-4.19.14-v7-1188.tar.gz	2019-01-10 19:37	457K
[   ]	mt7610-4.19.15-1190.tar.gz	2019-01-14 22:06	435K
[   ]	mt7610-4.19.15-v7-1190.tar.gz	2019-01-14 22:18	457K
[   ]	mt7610-4.19.16-1195.tar.gz	2019-01-23 22:33	435K
[   ]	mt7610-4.19.16-v7-1195.tar.gz	2019-01-23 22:45	457K
[   ]	mt7610-4.19.17-1196.tar.gz	2019-01-24 18:23	435K
[   ]	mt7610-4.19.17-v7-1196.tar.gz	2019-01-24 18:35	457K
[   ]	mt7610-4.19.19-1198.tar.gz	2019-02-05 20:34	435K
[   ]	mt7610-4.19.19-v7-1198.tar.gz	2019-02-05 20:46	457K
Below is the info from the "uname" command,
$ uname -a
Linux rpi-1B-pihole 4.19.66+ #1253 Thu Aug 15 11:37:30 BST 2019 armv6l GNU/Linux
Sun Jan 12, 2020 1:49 pm
Hi MrEngman,
$ uname -a
MrEngman compiled drivers are only for Raspbian Operating System :?
Pearl.852
Sun Jan 12, 2020 2:36 pm
by fruitoftheloom » Sun Jan 12, 2020 9:49 pm
My system is running Raspbian stretch lite
$ cat /etc/os-release
PRETTY_NAME="Raspbian GNU/Linux 9 (stretch)"
NAME="Raspbian GNU/Linux"
VERSION_ID="9"
VERSION="9 (stretch)"
VERSION_CODENAME=stretch
ID=raspbian
ID_LIKE=debian
MrEngman
Sun Jan 12, 2020 4:28 pm
Hi MrEngman,
$ uname -a
Hi Pearl.852,
Your uname -a command indicates you are using Raspbian.
I stopped compiling the m7610 driver as it is now included in the Raspbian image. However there is an issue that the firmware required by the driver is not included in the Raspbian image so the driver will not work. I have tried downloading firmware using sudo apt install firmware-mediatek, sudo apt install firmware-ralink and sudo apt firmware-linux-nonfree but these did not install the necessary firmware.
To check if you have the driver installed use the command
modinfo mt76x0
Just need to find the firmware to get it working. I'm certain I found a site searching on the internet but I don't remember where.
MrEngman
Pearl.852
Sun Jan 12, 2020 6:15 pm
Hi MrEngman,
$ uname -a
Hi Pearl.852,
modinfo mt76x0
MrEngman
Thank for your reply. I've ran the command on both RPi-1B and RPi-4B with the results shown below
RPi-1B:
$ modinfo mt76x0
filename:       /lib/modules/4.19.66+/kernel/drivers/net/wireless/mediatek/mt76/mt76x0/mt76x0.ko
license:        GPL
firmware:       mediatek/mt7610u.bin
srcversion:     8834B0DF7DC60587640FF0D
alias:          usb:v0E8Dp7650d*dc*dsc*dp*icFFisc02ipFFin*
alias:          usb:v0E8Dp7630d*dc*dsc*dp*icFFisc02ipFFin*
alias:          usb:v2357p0105d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v0DF6p0079d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v7392pC711d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v20F4p806Bd*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v293Cp5702d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v057Cp8502d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v04BBp0951d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v07B8p7610d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v0586p3425d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v2001p3D02d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v2019pAB31d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v0DF6p0075d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v0B05p17DBd*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v0B05p17D1d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v148Fp760Ad*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v148Fp761Ad*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v7392pB711d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v7392pA711d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v0E8Dp7610d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v13B1p003Ed*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v148Fp7610d*dc*dsc*dp*ic*isc*ip*in*
depends:        mac80211,mt76,cfg80211
intree:         Y
vermagic:       4.19.66+ mod_unload modversions ARMv6 p2v8
RPi-4B:
$ modinfo mt76x0
filename:       /lib/modules/4.19.75-v7l+/kernel/drivers/net/wireless/mediatek/mt76/mt76x0/mt76x0.ko
license:        GPL
srcversion:     FEF17F9280F520EE1611312
intree:         Y
vermagic:       4.19.75-v7l+ SMP mod_unload modversions ARMv7 p2v8
MrEngman
Sun Jan 12, 2020 7:42 pm
Well, the driver is there. I guess you are missing the necessary firmware it needs to run the wifi module. You can check the firmware is missing using command
dmesg | less
and scroll through the data using up and down arrow keys and key q to terminate the command.
I got the error
[86262.132356] mt76x0 1-1.1:1.0: Direct firmware load for mediatek/mt7610u.bin failed with error -2
before I found the necessary firmware.
I now have a T1U wifi running on one of my Pi as I found the necessary mt7610 firmware file. I then just had to move it to where the driver expected to find it.
I've been hunting around the internet trying to find the firmware file and surprisingly I found it in a package in the Raspberry Pi package site here http://archive.raspbian.org/raspbian/po ... rig.tar.xz.
This file contains the firmware for the T1U wifi. I downloaded the file to my laptop and opened it using winzip and found the mt7610 firmware mediatek/mt7610u.bin. I extracted the firmware file and copied it to my Pi, restarted the wifi and it worked.
To install the driver you will need to make the directory /lib/firmware/mediatek using command
sudo mkdir /lib/firmware/mediatek
and then copy the driver to the mediate directory using command
sudo cp mt7610u.bin /lib/firmware/mediatek/.
Then reboot you Pi and hopefully you should find your wifi working.
MrEngman
Pearl.852
Mon Jan 13, 2020 10:05 am
sudo cp mt7610u.bin /lib/firmware/mediate/.
Thanks MrEngman, just a quick note before I reply with my results on the next post.
I've found that there is a typo shown for the target directory on your instructions. The correct one should be
MrEngman
Mon Jan 13, 2020 10:28 am
Thanks for pointing that out. I've corrected it now.
MrEngman
Pearl.852
Mon Jan 13, 2020 10:45 am
Hi, MrEngman
On RPi-1B (intented unit to use the T1U wifi adaptor), after copying the mt7610u.bin and then plug-in the T1U, the dmesg shows a lot of errors as shown below:
[  332.523406] usb 1-1.3: new high-speed USB device number 6 using dwc_otg
[  332.671025] usb 1-1.3: New USB device found, idVendor=2357, idProduct=0105, bcdDevice= 1.00
[  332.671055] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[  332.671069] usb 1-1.3: Product: WiFi
[  332.671082] usb 1-1.3: Manufacturer: MediaTek
[  332.671094] usb 1-1.3: SerialNumber: 1.0
[  332.793367] usb 1-1.3: reset high-speed USB device number 6 using dwc_otg
[  332.929710] mt76x0 1-1.3:1.0: ASIC revision: 76100002 MAC revision: 76502000
[  333.723889] BBP version f000f200
[  333.794131] mt76x0 1-1.3:1.0: EEPROM ver:02 fae:01
[  333.916966] ieee80211 phy2: Selected rate control algorithm 'minstrel_ht'
[  335.065122] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[  336.984012] mt76x0 1-1.3:1.0: Error: RX urb failed:-71
[  336.984187] mt76x0 1-1.3:1.0: Error: RX urb failed:-71
[  336.984390] mt76x0 1-1.3:1.0: Error: RX urb failed:-71
[  336.984511] mt76x0 1-1.3:1.0: Error: RX urb failed:-71
[  336.984690] mt76x0 1-1.3:1.0: Error: RX urb failed:-71
[  336.985015] mt76x0 1-1.3:1.0: Error: RX urb failed:-71
[  336.985134] mt76x0 1-1.3:1.0: Error: RX urb failed:-71
[  336.985252] mt76x0 1-1.3:1.0: Error: RX urb failed:-71
[  336.985385] mt76x0 1-1.3:1.0: Error: RX urb failed:-71
[  336.985606] mt76x0 1-1.3:1.0: Error: RX urb failed:-71
[  336.985773] mt76x0 1-1.3:1.0: Error: RX urb failed:-71
[  336.985938] mt76x0 1-1.3:1.0: Error: RX urb failed:-71
[  336.986150] mt76x0 1-1.3:1.0: Error: RX urb failed:-71
[  336.986348] mt76x0 1-1.3:1.0: Error: RX urb failed:-71
[  336.986498] mt76x0 1-1.3:1.0: Error: RX urb failed:-71
[  336.986576] mt76x0 1-1.3:1.0: Error: RX urb failed:-71
[  337.023703] mt76x0 1-1.3:1.0: Error: MCU response pre-completed!
[  337.024065] mt76x0 1-1.3:1.0: Error: send MCU cmd failed:-71
[  337.087407] usb 1-1.3: USB disconnect, device number 6
[  337.094617] ------------[ cut here ]------------
[  337.094856] WARNING: CPU: 0 PID: 5 at drivers/net/wireless/mediatek/mt76/mt76x0/mac.c:55 mt76_mac_fill_tx_status+0x268/0x2a4 [mt76x0]
[  337.094871] Modules linked in: arc4 mt76x0 mt76 mac80211 sha256_generic cfg80211 rfkill snd_bcm2835(C) raspberrypi_hwmon hwmon snd_pcm snd_timer snd bcm2835_codec(C) bcm2835_v4l2(C) v4l2_mem2mem bcm2835_mmal_vchiq(C) v4l2_common videobuf2_dma_contig videobuf2_vmalloc videobuf2_memops videobuf2_v4l2 videobuf2_common videodev media vc_sm_cma(C) fixed uio_pdrv_genirq uio ip_tables x_tables ipv6
[  337.095043] CPU: 0 PID: 5 Comm: kworker/u2:0 Tainted: G         C        4.19.66+ #1253
[  337.095049] Hardware name: BCM2835
[  337.095168] Workqueue: mt76x0 mt76x0_tx_stat [mt76x0]
[  337.095231] [<c0017edc>] (unwind_backtrace) from [<c0014e24>] (show_stack+0x20/0x24)
[  337.095268] [<c0014e24>] (show_stack) from [<c06b9750>] (dump_stack+0x20/0x28)
[  337.095304] [<c06b9750>] (dump_stack) from [<c0024450>] (__warn+0xf4/0x11c)
[  337.095330] [<c0024450>] (__warn) from [<c00245a8>] (warn_slowpath_null+0x4c/0x58)
[  337.095457] [<c00245a8>] (warn_slowpath_null) from [<bf402030>] (mt76_mac_fill_tx_status+0x268/0x2a4 [mt76x0])
[  337.095682] [<bf402030>] (mt76_mac_fill_tx_status [mt76x0]) from [<bf402414>] (mt76x0_send_tx_status+0xac/0x1b4 [mt76x0])
[  337.095875] [<bf402414>] (mt76x0_send_tx_status [mt76x0]) from [<bf403d10>] (mt76x0_tx_stat+0x5c/0x1d0 [mt76x0])
[  337.096000] [<bf403d10>] (mt76x0_tx_stat [mt76x0]) from [<c003d248>] (process_one_work+0x130/0x3a0)
[  337.096029] [<c003d248>] (process_one_work) from [<c003d4ec>] (worker_thread+0x34/0x530)
[  337.096055] [<c003d4ec>] (worker_thread) from [<c0042ff0>] (kthread+0x11c/0x158)
[  337.096080] [<c0042ff0>] (kthread) from [<c00090ac>] (ret_from_fork+0x14/0x28)
[  337.096090] Exception stack(0xce0effb0 to 0xce0efff8)
[  337.096104] ffa0:                                     00000000 00000000 00000000 00000000
[  337.096124] ffc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[  337.096139] ffe0: 00000000 00000000 00000000 00000000 00000013 00000000
[  337.096149] ---[ end trace 576b24c8624f1c29 ]---
[  337.096347] mt76x0 1-1.3:1.0: Error: MCU response pre-completed!
[  337.096380] mt76x0 1-1.3:1.0: Error: send MCU cmd failed:-19
[  337.096413] mt76x0 1-1.3:1.0: Error: MCU response pre-completed!
[  337.096432] mt76x0 1-1.3:1.0: Error: send MCU cmd failed:-19
[  337.096467] mt76x0 1-1.3:1.0: Error: MCU response pre-completed!
[  337.096485] mt76x0 1-1.3:1.0: Error: send MCU cmd failed:-19
[  337.096514] mt76x0 1-1.3:1.0: Error: MCU response pre-completed!
[  337.096532] mt76x0 1-1.3:1.0: Error: send MCU cmd failed:-19
[  337.096556] mt76x0 1-1.3:1.0: Error: MCU response pre-completed!
[  337.096574] mt76x0 1-1.3:1.0: Error: send MCU cmd failed:-19
[  337.096599] mt76x0 1-1.3:1.0: Error: MCU response pre-completed!
[  337.096618] mt76x0 1-1.3:1.0: Error: send MCU cmd failed:-19
[  337.096644] mt76x0 1-1.3:1.0: Error: MCU response pre-completed!
[  337.096661] mt76x0 1-1.3:1.0: Error: send MCU cmd failed:-19
[  337.096691] mt76x0 1-1.3:1.0: Error: MCU response pre-completed!
[  337.096709] mt76x0 1-1.3:1.0: Error: send MCU cmd failed:-19
[  337.096734] mt76x0 1-1.3:1.0: Error: MCU response pre-completed!
[  337.096753] mt76x0 1-1.3:1.0: Error: send MCU cmd failed:-19
[  337.096781] mt76x0 1-1.3:1.0: Error: MCU response pre-completed!
[  337.096799] mt76x0 1-1.3:1.0: Error: send MCU cmd failed:-19
[  337.096824] mt76x0 1-1.3:1.0: Error: MCU response pre-completed!
[  337.096842] mt76x0 1-1.3:1.0: Error: send MCU cmd failed:-19
[  337.096872] mt76x0 1-1.3:1.0: Error: MCU response pre-completed!
[  337.096890] mt76x0 1-1.3:1.0: Error: send MCU cmd failed:-19
[  337.096915] mt76x0 1-1.3:1.0: Error: MCU response pre-completed!
[  337.096933] mt76x0 1-1.3:1.0: Error: send MCU cmd failed:-19
[  337.097154] mt76x0 1-1.3:1.0: Error: MCU response pre-completed!
[  337.097177] mt76x0 1-1.3:1.0: Error: send MCU cmd failed:-19
[  337.097449] mt76x0 1-1.3:1.0: Error: MCU response pre-completed!
[  337.097477] mt76x0 1-1.3:1.0: Error: send MCU cmd failed:-19
[  337.097507] mt76x0 1-1.3:1.0: Error: MCU response pre-completed!
[  337.097526] mt76x0 1-1.3:1.0: Error: send MCU cmd failed:-19
[  337.097551] mt76x0 1-1.3:1.0: Error: MCU response pre-completed!
[  337.097569] mt76x0 1-1.3:1.0: Error: send MCU cmd failed:-19
[  337.097593] mt76x0 1-1.3:1.0: Error: MCU response pre-completed!
[  337.097610] mt76x0 1-1.3:1.0: Error: send MCU cmd failed:-19
[  337.097638] mt76x0 1-1.3:1.0: Error: MCU response pre-completed!
[  337.097655] mt76x0 1-1.3:1.0: Error: send MCU cmd failed:-19
[  337.097680] mt76x0 1-1.3:1.0: Error: MCU response pre-completed!
[  337.097698] mt76x0 1-1.3:1.0: Error: send MCU cmd failed:-19
[  337.097720] mt76x0 1-1.3:1.0: Error: MCU response pre-completed!
[  337.097741] mt76x0 1-1.3:1.0: Error: send MCU cmd failed:-19
[  337.097766] mt76x0 1-1.3:1.0: Error: MCU response pre-completed!
[  337.097786] mt76x0 1-1.3:1.0: Error: send MCU cmd failed:-19
[  337.097807] mt76x0 1-1.3:1.0: Error: MCU response pre-completed!
[  337.097824] mt76x0 1-1.3:1.0: Error: send MCU cmd failed:-19
[  337.097848] mt76x0 1-1.3:1.0: Error: MCU response pre-completed!
[  337.097867] mt76x0 1-1.3:1.0: Error: send MCU cmd failed:-19
[  337.097904] mt76x0 1-1.3:1.0: Error: MCU response pre-completed!
[  337.097923] mt76x0 1-1.3:1.0: Error: send MCU cmd failed:-19
[  337.097953] mt76x0 1-1.3:1.0: Error: MCU response pre-completed!
[  337.097971] mt76x0 1-1.3:1.0: Error: send MCU cmd failed:-19
[  337.097996] mt76x0 1-1.3:1.0: Error: MCU response pre-completed!
[  337.098014] mt76x0 1-1.3:1.0: Error: send MCU cmd failed:-19
[  337.098170] mt76x0 1-1.3:1.0: Error: MCU response pre-completed!
[  337.098190] mt76x0 1-1.3:1.0: Error: send MCU cmd failed:-19
[  337.433690] usb 1-1.3: new high-speed USB device number 7 using dwc_otg
[  337.580807] usb 1-1.3: New USB device found, idVendor=2357, idProduct=0105, bcdDevice= 1.00
[  337.580837] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[  337.580851] usb 1-1.3: Product: WiFi
[  337.580862] usb 1-1.3: Manufacturer: MediaTek
[  337.580876] usb 1-1.3: SerialNumber: 1.0
[  337.693594] usb 1-1.3: reset high-speed USB device number 7 using dwc_otg
[  337.830166] mt76x0 1-1.3:1.0: ASIC revision: 76100002 MAC revision: 76502000
[  338.634103] BBP version f000f200
[  338.705811] mt76x0 1-1.3:1.0: EEPROM ver:02 fae:01
[  338.729885] ieee80211 phy3: Selected rate control algorithm 'minstrel_ht'
On RPi-4B, the T1U seems mounted correctly, but I haven't able to get it to connect yet. See dmesg from RPi-4B as reference below:
[23314.133237] usb 1-1.1: new high-speed USB device number 12 using xhci_hcd
[23314.278778] usb 1-1.1: New USB device found, idVendor=2357, idProduct=0105, bcdDevice= 1.00
[23314.278798] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[23314.278812] usb 1-1.1: Product: WiFi
[23314.278824] usb 1-1.1: Manufacturer: MediaTek
[23314.278835] usb 1-1.1: SerialNumber: 1.0
[23314.394152] usb 1-1.1: reset high-speed USB device number 12 using xhci_hcd
[23314.533263] mt76x0 1-1.1:1.0: ASIC revision: 76100002 MAC revision: 76502000
[23315.333497] BBP version f000f200
[23315.363459] mt76x0 1-1.1:1.0: EEPROM ver:02 fae:01
[23315.383087] ieee80211 phy6: Selected rate control algorithm 'minstrel_ht'
[23432.303242] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[23432.303259] brcmfmac: power management disabled
[23432.345584] IPv6: ADDRCONF(NETDEV_UP): wlan1: link is not ready
[23438.355550] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
Could it be the T1U firmware not compatible with the raspbian stretch running on RPi-1B? My RPi-4B is running raspbian buster. Really appreciate if you have any suggestions.
Pearl.852
Mon Jan 13, 2020 10:56 am
Thank you. Does the "." (period) at the end of the command relevant? Sorry, I am still learning Linux commands.
MrEngman
Mon Jan 13, 2020 8:24 pm
I've been checking out the mt7610 driver on various Pi. Kind of works OK although it seems it doesn't like being to far from the wifi AP.
Tried on a Pi 4, Pi 3 an old Pi B+.
Came across this old post of mine explaining why I stopped compiling the mt7610 driver. https://www.raspberrypi.org/forums/view ... 0#p1481812
The next post after that has a pointer to the firmware file needed for the mt7610 driver. Seems it is the same as the one I found in the package I found and gave you the pointer to but it's easier to access as it is directly accessible rather than having to unzip a file to access it.
MrEngman
