bonaccia
Re: (UPDATE) Drivers for TL-WN725N V2 - 3.6.11+ -> 4.1.xx+
Wed Nov 02, 2016 11:20 am
I have a AC600 wifi dongle from Easynic (amazon link).
do I need these drivers to use it in a RPi 3 ? what is the file to download ?
lsusb
Bus 001 Device 004: ID 0e8d:7610 MediaTek Inc.
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp.
uname -a
Linux [name] 4.4.21-v7+ #911 SMP Thu Sep 15 14:22:38 BST 2016 armv7l GNU/Linux
thank you
bonaccia
MrEngman
Wed Nov 02, 2016 12:53 pm
bonaccia wrote:Hello,
lsusb
uname -a
thank you
bonaccia
You can install a driver using the commands
wget https://dl.dropboxusercontent.com/u/80256631/mt7610-4.4.21-v7-911.tar.gz
tar xzf mt7610-4.4.21-v7-911.tar.gz
./install.sh
There is also a script that will automatically install the driver. You can download and install the script using commands
wget https://dl.dropboxusercontent.com/u/80256631/install-wifi.tar.gz
tar xzf install-wifi.tar.gz
Run command ./install-wifi -h to see information on using the script.
After installing the mt7610 driver you will then have two wifi modules enabled, the AC600 and the Broadcom wifi built into the Pi 3B. You can disable the Broadcom wifi by make the file /etc/modprobe.d/brcmfmac.conf and adding the line blacklist brcmfmac. This will stop the Broadcom driver loading and disable the Broadcom wifi.
MrEngman
bonaccia
Thu Nov 03, 2016 11:21 am
Magic! It worked!
thank you.
pshotton
Re: (UPDATE) Drivers for TL-WN725N V2 - 3.6.11+ -> 4.xx.xx+
Sat Dec 31, 2016 4:23 pm
Hi
I've followed your updated instructions - my kernel version is 4.4.38+ #938
I downloaded the appropriate gz file, installed it. The kernel module installs fine.
However my Pi still says 'No wireless interfaces found'
lsusb shows the wifi dongle with a code 0bda:8179
ifconfig shows a wlan2 connection up.
Hovering over the network widget shows: "wlan2: not associated"
Any help much appreciated.
Thanks for your continuing support of this chipset
Phil
MrEngman
Sat Dec 31, 2016 5:08 pm
pshotton wrote:Hi
Phil
Does the file /etc/network/interfaces have an entry for wlan2? If not you will need to edit file /etc/network/interfaces and add another wifi entry for wlan2.
Like this, which also has a couple of additional entries wlan3 and ra0, which is used on one of my Pi's that is running Raspbian Jessie and I use for checking out wifi drivers.
# Please note that this file is written to be used with dhcpcd.
# For static IP, consult /etc/dhcpcd.conf and 'man dhcpcd.conf'.
auto lo
iface lo inet loopback
auto eth0
allow-hotplug eth0
iface eth0 inet manual
auto wlan0
allow-hotplug wlan0
iface wlan0 inet manual
wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
auto wlan1
allow-hotplug wlan1
iface wlan1 inet manual
auto wlan2
allow-hotplug wlan2
iface wlan2 inet manual
auto wlan3
allow-hotplug wlan3
iface wlan3 inet manual
auto ra0
allow-hotplug ra0
iface ra0 inet manual
FYI ra0 is the name used by some Ralink drivers, older versions of mt7601 and mt7610 drivers.
MrEngman
tjs000
Wed Jan 04, 2017 1:47 am
Good evening MrEngan,
I am looking for a driver for the 7610u chipset for kernel version 4.4.22-3. As far as I can tell, this doesn't exist in your dropbox, so I can only assume that the kernel is too recent for it to have been compiled so far. Or perhaps it is too obscure, i wouldn't be surprised if it was proprietary. If it would be possible to get hold of a driver for this kernel version then that would be great, or at least one that is compatible. I can't change my kernel as it has some modifications that allow a realtime drone flight controller to run properly. My /lib/modules/ folder contains:
4.4.22+ and 3.3.20-v7+
and uname -a gives:
Linux erle-brain-2 4.4.22+ #3 PREEMPT Wed Oct 12 16:55:25 CEST 2016 armv6l GNU/Linux
Please let me know if you need any more information! Thanks again!
T
MrEngman
Wed Jan 04, 2017 9:17 am
tjs000 wrote:Good evening MrEngan,
and uname -a gives:
T
Unfortunately the drivers I compile are for Raspbian and I expect you are using some other operating system or have compiled your own version. What operating system are you using? If you have modified the kernel yourself you would probably need to compile your own driver.
MrEngman
tjs000
Wed Jan 04, 2017 11:32 am
I believe I am running a version of Raspbian. I only know that the kernel has been modified, and not by me. I am happy to try to compile the driver myself, but to be honest I wouldn't know where to start. I am not completely new to the idea so I should be able to make do with some rough instructions. I don't think have access to the kernel source unless it's included in a normal install.
lsb_release -a gives:
No LSB modules are available.
Distributor ID: Raspbian
Description: Raspbian GNU/Linux 8.0 (jessie)
Release: 8.0
Codename: jessie
I don't believe that the wireless drivers are different from a normal Linux install.
Thanks for your help, and I am sorry for getting your name wrong in the first post... :/
T
MrEngman
Wed Jan 04, 2017 12:06 pm
tjs000 wrote:I believe I am running a version of Raspbian. I only know that the kernel has been modified, and not by me. I am happy to try to compile the driver myself, but to be honest I wouldn't know where to start. I am not completely new to the idea so I should be able to make do with some rough instructions. I don't think have access to the kernel source unless it's included in a normal install.
Release: 8.0
Codename: jessie
T
If it's based on Raspbian it may be relatively easy to compile a suitable driver. Is an image available somewhere on the internet so I can download it and take a look at it.
MrEngman
aa777888
Wed Jan 04, 2017 3:15 pm
MrEngman--I'm very much hoping that you can help me.
Access point is a Ubiquiti UAP LC AR. Addressing is static.
Hardware is a Pi3 and DWA-171.
uname -a returns:
Linux radiopi 4.4.34-v7+ #930 SMP Wed Nov 23 15:20:41 GMT 2016 armv7l GNU/Linux
I initially used this link to install:
When I had the problems described below, I reinstalled using this link:
wget https://dl.dropboxusercontent.com/u/80256631/8812au-4.4.34-v7-930.tar.gz
However in both cases I get the same behavior.
The DWA-171 will come up at boot time no problem. iwconfig reports:
wlan0     IEEE 802.11AC  ESSID:"noneofyourbusiness"  Nickname:"<WIFI@REALTEK>"
          Mode:Managed  Frequency:5.745 GHz  Access Point: 82:2A:A8:85:83:4A
          Bit Rate:434 Mb/s   Sensitivity:0/0
          Retry:off   RTS thr:off   Fragment thr:off
          Power Management:off
          Link Quality=75/100  Signal level=90/100  Noise level=0/100
          Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0
          Tx excessive retries:0  Invalid misc:0   Missed beacon:0
iperf3 gives good results, usually in the 15 to 18Mbyte/s range.
However, after random periods, sometimes many hours, other times 30 seconds, the WiFi will go down. Sometimes it seems traffic dependent, i.e. if the Pi is just sitting there doing nothing it'll be OK, but start moving traffic (e.g. iperf3 testing) it will go down. Other times I can run iperf3 for hours and it is fine.
dmesg reports the following
[   77.636093] RTL871X: rtw_set_802_11_connect(wlan0)  fw_state=0x00000009
[   77.651879] Unable to handle kernel paging request at virtual address bc4a301f
[   77.651907] pgd = 80004000
[   77.651918] [bc4a301f] *pgd=36b4c811, *pte=00000000, *ppte=00000000
[   77.651948] Internal error: Oops: 7 [#1] SMP ARM
[   77.651960] Modules linked in: bnep hci_uart btbcm bluetooth 8812au(O) cfg80211 rfkill snd_usb_audio snd_hwdep snd_usbmidi_lib snd_rawmidi snd_seq_device snd_bcm2835 snd_pcm snd_timer snd bcm2835_wdt bcm2835_gpiomem evdev joydev uio_pdrv_genirq uio rpi_backlight rpi_ft5406 i2c_dev fuse ipv6
[   77.652133] CPU: 2 PID: 425 Comm: RTW_CMD_THREAD Tainted: G           O    4.4.34-v7+ #930
[   77.652148] Hardware name: BCM2709
[   77.652170] task: b93a0b80 ti: b8a38000 task.ti: b8a38000
[   77.652697] PC is at join_cmd_hdl+0x168/0x370 [8812au]
[   77.652710] LR is at 0x0
[   77.652723] pc : [<7f26a004>]    lr : [<00000000>]    psr: 80000013
sp : b8a39ed8  ip : 00000000  fp : b8a39f14
[   77.652737] r10: 00000001  r9 : 7f34d130  r8 : bc4a140c
[   77.652747] r7 : bc49f0fe  r6 : bc4a301f  r5 : 00003ea9  r4 : bc49e000
[   77.652758] r3 : 00003f21  r2 : 00000001  r1 : bc49f1b2  r0 : 00000001
[   77.652771] Flags: Nzcv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment kernel
[   77.652782] Control: 10c5383d  Table: 391d406a  DAC: 00000055
[   77.652794] Process RTW_CMD_THREAD (pid: 425, stack limit = 0xb8a38210)
[   77.652806] Stack: (0xb8a39ed8 to 0xb8a3a000)
[   77.652818] 9ec0:                                                       805bba64 800d989c
[   77.652835] 9ee0: afe74a9c afe74a80 b8a39f14 afe74a80 bc49e000 bc49f958 bc49f978 ffffa922
[   77.652852] 9f00: bc49f958 000048a4 b8a39f5c b8a39f18 7f246b5c 7f269ea8 b8a39f3c b8a38000
[   77.652869] 9f20: b684ca00 bc49f968 bc49f9a4 b8af4a00 00000000 00000000 b684ca00 bc49e000
[   77.652885] 9f40: 7f2468cc 00000000 00000000 00000000 b8a39fac b8a39f60 80042860 7f2468d8
[   77.652902] 9f60: 39713000 00000000 b8a39f94 bc49e000 00000000 00000000 b8a39f78 b8a39f78
[   77.652919] 9f80: 00000000 00000000 b8a39f88 b8a39f88 b684ca00 80042774 00000000 00000000
[   77.652935] 9fa0: 00000000 b8a39fb0 8000fbc8 80042780 00000000 00000000 00000000 00000000
[   77.652951] 9fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   77.652967] 9fe0: 00000000 00000000 00000000 00000000 00000013 00000000 124b002c 10802006
[   77.653821] [<7f26a004>] (join_cmd_hdl [8812au]) from [<7f246b5c>] (rtw_cmd_thread+0x290/0x3ec [8812au])
[   77.654247] [<7f246b5c>] (rtw_cmd_thread [8812au]) from [<80042860>] (kthread+0xec/0x104)
[   77.654273] [<80042860>] (kthread) from [<8000fbc8>] (ret_from_fork+0x14/0x2c)
[   77.654291] Code: e0888005 e59f9208 e2853078 e0876003 (e7d73003)
[   77.654307] ---[ end trace a355fcd6d086b7c1 ]---
[   92.272130] RTL871X: rtw_set_802_11_connect(wlan0)  fw_state=0x00000008
I feel like I am very close to having this working reliably. I have searched extensively on the forum and elsewhere but have found no useful links to a solution for this problem. What am I missing? Would I be more successful with an different 802.11ac WiFi adapter?
Thanks,
aa
Matc
Fri Jan 06, 2017 10:38 am
Hi, i'm getting this errors, can someone help me with this ?
mv: cannot stat ‘*.bin’: No such file or directory
sudo install -p -m 644 mt7610u.ko /lib/modules/4.4.38-v7+/kernel/drivers/net/wireless
install: cannot stat ‘mt7610u.ko’: No such file or directory
sudo depmod 4.4.38-v7+
rm: cannot remove ‘mt7610u.ko’: No such file or directory
MrEngman
Fri Jan 06, 2017 1:10 pm
Matc wrote:Hi, i'm getting this errors, can someone help me with this ?
It would help if you tell us what are you doing when you get those errors.
What driver are you trying to install, mt7610 I guess?
If you are using my install-wifi script there have been changes to the kernel format and also to the mt7610 driver which has required a change. There is a new script which can be downloaded and installed using commands
sudo wget https://dl.dropboxusercontent.com/u/80256631/install-wifi -O /usr/bin/install-wifi
chmod +x /usr/bin/install-wifi
You will need to run the new script using sudo - e.g. sudo install-wifi ....
For details on using the script use command
sudo install-wifi -h
MrEngman
Matc
Fri Jan 06, 2017 4:25 pm
Thanks, it worked !
aa777888
Sat Jan 07, 2017 3:43 am
MrEngman,
I updated Raspian, downloaded and installed the new, latest install-wifi tool, checked that a driver was available for the latest kernel, updated the kernel and driver according to the built in help, and...
I am still getting the same kernel error and attendant behavior as shown in my post above.
Is there anything I can do to fix this? Should I obtain something other than the DWA-171?
Thanks,
aa
MrEngman
Sat Jan 07, 2017 10:00 am
aa777888 wrote:MrEngman,
Thanks,
aa
I've been using this driver for a long time now and have never seen anything like this before or on any other Pi's I run. Searching the internet would appear to indicate it is a shortage of virtual memory e.g. viewtopic.php?p=136644#p136644 during heavy usage. It's a really old post but could provide a clue to a solution, just need to sort out how to do this with the current kernel version to provide a similar solution.
Maybe posting a new thread referencing the error you're getting "Unable to handle kernel paging request at virtual address" may get you a better response.
Sorry I could not provide a better answer.
MrEngman
GammaScorpii
Sun Jan 08, 2017 9:08 am
I am very close to getting this working, but there are still issues.
I have a TP-Link T1U AC450 USB adapter, so from what I've read on here I should be installing
mt7610-4.4.38-v7-938.tar.gz
on
4.4.38-v7+ #938 SMP Thu Dec 15 15:22:21 GMT 2016 armv7l GNU/Linux
Which installs fine and when I reboot I can see my open 5GHz network with a scan.
wpa_supplicant however refuses to connect to it. But when I run
iwconfig wlan0 essid 5GNETWORK
it connects, but my router for some reason does not assign an IP address and the packets sent are very very low. The MAC address of the adapter shows up on the network, and the adapter lights up but only when I force with iwconfig.
What is the problem here?
lsmod:
Module                  Size  Used by
xfs                   836865  1
mt7610u               680445  1
8192cu                560049  0
cfg80211              428431  2 mt7610u,8192cu
rfkill                 16037  3 cfg80211
snd_bcm2835            20447  0
snd_pcm                75762  1 snd_bcm2835
snd_timer              19288  1 snd_pcm
snd                    51908  3 snd_bcm2835,snd_timer,snd_pcm
bcm2835_wdt             3225  0
bcm2835_gpiomem         3040  0
uio_pdrv_genirq         3164  0
uio                     8000  1 uio_pdrv_genirq
i2c_dev                 5859  0
fuse                   84037  1
ipv6                  347594  39
lsusb:
Bus 001 Device 004: ID 2357:0105
MrEngman
Sun Jan 08, 2017 12:16 pm
GammaScorpii wrote:I am very close to getting this working, but there are still issues.
on
lsmod:
Module                  Size  Used by
xfs                   836865  1
mt7610u               680445  1
8192cu                560049  0
snd_bcm2835            20447  0
bcm2835_wdt             3225  0
i2c_dev                 5859  0
fuse                   84037  1
ipv6                  347594  39
lsusb:
I use a TP-Link Archer T2U wifi and I have no problem connecting to my network using wpa_supplicant.conf using the format
country=GB
update_config=1
network={
        ssid="network-name"
        psk="network-password"
however I find using the mt7610 drive is not very reliable. Although the wifi stays connected data transfer is not very reliable and can be slow even when connected to a 5GHz AP with 434Mb/s bitrate.
Sounds like your wpa_supplicant.conf file has a problem. Make sure you do not have any spaces around the "=" signs for a start and the network name and password are OK. Also set "country=" to the country where you are.
Your lsmod shows the mt7610 driver and also the 8192cu wifi driver but lsusb only shows the mt7610 wifi module. Have you set up your Pi to force the 8192cu driver to be loaded or did you have an 8192cu wifi module installed and then unplugged it?
MrEngman
aa777888
Sun Jan 08, 2017 4:13 pm
Thanks,
aa
MrEngman
Thanks for the response, MrEngman!
Actually I had posted a separate threat first with almost that exact title, however nobody responded to it for several days. Hence, in some desperation, I posted in this thread which seemed to be active and had your attention.
I followed up on the previous thread you provided, but increasing the vm.min_free_kbytes did not improve the situation.
At this point it would seem wisest to try another 802.11ac adapter, perhaps one that uses a different driver.
All: I would appreciate one or two recommendations in that area, please.
Thanks,
aa
GammaScorpii
Mon Jan 09, 2017 12:36 pm
Thanks MrEngman.
I have another 300Mbps 802.11n dongle which I've been using for quite a while. I don't recall ever modifying the pi in regards to WiFi drivers. This one worked straight away. Although I might have wait for LAN before boot enabled? This adapter was also plugged in when I was trying to connect the other 5GHz dongle. I have tried it without the other dongle plugged in.
I just tried forcing the iwconfig connection twice in a row, and I finally have an IP! Any idea why it couldn't do this straight away? Before, from the router page, it appeared that the pi was not sending any packets, but as soon as I ran the command twice they started appearing.
Have just been testing it under ssh and seemed stable until I ran a wifi scan, then it immediately dropped out and never came back. Is this just a problem with the driver being unstable?
turing
Tue Jan 10, 2017 6:47 pm
Is there a new version for kernel 4.4.34-v7+ out there? I've tried to install 8188eu-4.4.8-v7-881 but it does not work. Now the 725 is not recognized anymore as an interface (ifconfig), only via lsusb.
MrEngman
Wed Jan 11, 2017 10:49 am
turing wrote:Is there a new version for kernel 4.4.34-v7+ out there? I've tried to install 8188eu-4.4.8-v7-881 but it does not work. Now the 725 is not recognized anymore as an interface (ifconfig), only via lsusb.
Yes, if you are using Rasbian Jessie or Jessie Lite.
https://dl.dropboxusercontent.com/u/802 ... 929.tar.gz or
https://dl.dropboxusercontent.com/u/802 ... 930.tar.gz
Why don't you download the install-wifi script which will automatically find and install the driver for you. Look at the first post in this thread viewtopic.php?p=462982#p462982 and read the MAJOR UPDATE:- section. Just before the end of that section it show how to download and install the script.
MrEngman
vik__
Fri Jan 13, 2017 11:15 am
I am struggling to get a similar USB wifi adapter working. I have already updated the driver (matching with my Raspbian version), but it does not appear to be working. I see the wlan0, but I am unable to scan any access points and I am obviously unable to connect to any. Any help would be highly appreciated. Thank you.
Outputs for ifconfig, iwconfig, lsusb, lsmod:
pi@raspberrypi:~ $ ifconfig
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:448 errors:0 dropped:0 overruns:0 frame:0
          TX packets:448 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1
          RX bytes:36288 (35.4 KiB)  TX bytes:36288 (35.4 KiB)
wlan0     Link encap:Ethernet  HWaddr 00:c6:93:64:11:59
          inet6 addr: fe80::f78a:3890:f505:f2fa/64 Scope:Link
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
pi@raspberrypi:~ $ iwconfig
wlan0     unassociated  Nickname:"<WIFI@REALTEK>"
          Mode:Managed  Frequency=2.412 GHz  Access Point: Not-Associated
          Sensitivity:0/0
          Link Quality:0  Signal level:0  Noise level:0
lo        no wireless extensions.
pi@raspberrypi:~ $ lsmod
Module                  Size  Used by
bnep                   11853  2
bluetooth             365780  5 bnep
8188eu                931354  0
cfg80211              499234  1 8188eu
rfkill                 21397  4 cfg80211,bluetooth
joydev                  9194  0
evdev                  11650  4
hid_logitech_hidpp     11560  0
sg                     20799  0
snd_bcm2835            23131  1
snd_pcm                95473  1 snd_bcm2835
snd_timer              22556  1 snd_pcm
snd                    68400  5 snd_bcm2835,snd_timer,snd_pcm
bcm2835_gpiomem         3823  0
bcm2835_wdt             4133  0
uio_pdrv_genirq         3718  0
uio                    10230  1 uio_pdrv_genirq
hid_logitech_dj        11567  0
i2c_dev                 6578  0
fuse                   90504  3
ipv6                  367671  28
pi@raspberrypi:~ $ lsusb
Bus 001 Device 005: ID 1908:0226 GEMBIRD
Bus 001 Device 004: ID 046d:c52b Logitech, Inc. Unifying Receiver
Bus 001 Device 006: ID 0bda:0179 Realtek Semiconductor Corp.
Bus 001 Device 003: ID 1a40:0101 Terminus Technology Inc. 4-Port HUB
Output for dmesg:
pi@raspberrypi:~ $ dmesg
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 4.4.34+ (dc4@dc4-XPS13-9333) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611) ) #930 Wed Nov 23 15:12:30 GMT 2016
[    0.000000] CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
[    0.000000] Machine model: Raspberry Pi Zero Rev 1.3
[    0.000000] cma: Reserved 8 MiB at 0x1b400000
[    0.000000] Memory policy: Data cache writeback
[    0.000000] On node 0 totalpages: 114688
[    0.000000] free_area_init_node: node 0, pgdat c08843cc, node_mem_map db010000
[    0.000000]   Normal zone: 1008 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 114688 pages, LIFO batch:31
[    0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[    0.000000] pcpu-alloc: [0] 0
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 113680
[    0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=1824 bcm2708_fb.fbheight=984 bcm2708.boardrev=0x900093 bcm2708.serial=0xf4bea2fd smsc95xx.macaddr=B8:27:EB:BE:A2:FD bcm2708_fb.fbswap=1 bcm2708.uart_clock=48000000 bcm2708.disk_led_gpio=47 vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000  dwc_otg.lpm_enable=0 console=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
[    0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.000000] Memory: 436516K/458752K available (6059K kernel code, 437K rwdata, 1844K rodata, 380K init, 726K bss, 14044K reserved, 8192K cma-reserved)
[    0.000000] Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
    vmalloc : 0xdc800000 - 0xff800000   ( 560 MB)
    lowmem  : 0xc0000000 - 0xdc000000   ( 448 MB)
    modules : 0xbf000000 - 0xc0000000   (  16 MB)
      .text : 0xc0008000 - 0xc07c0008   (7905 kB)
      .init : 0xc07c1000 - 0xc0820000   ( 380 kB)
      .data : 0xc0820000 - 0xc088d490   ( 438 kB)
       .bss : 0xc088d490 - 0xc0943050   ( 727 kB)
[    0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] NR_IRQS:16 nr_irqs:16 16
[    0.000028] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
[    0.000072] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
[    0.000173] bcm2835: system timer (irq = 27)
[    0.000488] Console: colour dummy device 80x30
[    0.000725] console [tty1] enabled
[    0.000754] Calibrating delay loop... 697.95 BogoMIPS (lpj=3489792)
[    0.060312] pid_max: default: 32768 minimum: 301
[    0.060692] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.060721] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.061715] Disabling cpuset control group subsystem
[    0.061767] Initializing cgroup subsys io
[    0.061805] Initializing cgroup subsys memory
[    0.061866] Initializing cgroup subsys devices
[    0.061899] Initializing cgroup subsys freezer
[    0.061930] Initializing cgroup subsys net_cls
[    0.062014] CPU: Testing write buffer coherency: ok
[    0.062092] ftrace: allocating 20645 entries in 61 pages
[    0.172591] Setting up static identity map for 0x81c0 - 0x81f8
[    0.174437] devtmpfs: initialized
[    0.183890] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
[    0.184418] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.186209] pinctrl core: initialized pinctrl subsystem
[    0.187082] NET: Registered protocol family 16
[    0.192814] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[    0.201299] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
[    0.201329] hw-breakpoint: maximum watchpoint size is 4 bytes.
[    0.201506] Serial: AMBA PL011 UART driver
[    0.201916] 20201000.uart: ttyAMA0 at MMIO 0x20201000 (irq = 81, base_baud = 0) is a PL011 rev2
[    0.202400] console [ttyAMA0] enabled
[    0.203176] bcm2835-mbox 2000b880.mailbox: mailbox enabled
[    0.247176] bcm2835-dma 20007000.dma: DMA legacy API manager at f2007000, dmachans=0x1
[    0.248050] SCSI subsystem initialized
[    0.248384] usbcore: registered new interface driver usbfs
[    0.248519] usbcore: registered new interface driver hub
[    0.248728] usbcore: registered new device driver usb
[    0.252509] raspberrypi-firmware soc:firmware: Attached to firmware from 2016-11-25 16:03
[    0.280349] clocksource: Switched to clocksource timer
[    0.333091] FS-Cache: Loaded
[    0.333525] CacheFiles: Loaded
[    0.352842] NET: Registered protocol family 2
[    0.354201] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[    0.354307] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
[    0.354410] TCP: Hash tables configured (established 4096 bind 4096)
[    0.354523] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    0.354563] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    0.354908] NET: Registered protocol family 1
[    0.355506] RPC: Registered named UNIX socket transport module.
[    0.355533] RPC: Registered udp transport module.
[    0.355546] RPC: Registered tcp transport module.
[    0.355558] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.356938] hw perfevents: enabled with armv6_1176 PMU driver, 3 counters available
[    0.358356] futex hash table entries: 256 (order: -1, 3072 bytes)
[    0.375030] VFS: Disk quotas dquot_6.6.0
[    0.375452] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.378164] FS-Cache: Netfs 'nfs' registered for caching
[    0.379536] NFS: Registering the id_resolver key type
[    0.379659] Key type id_resolver registered
[    0.379678] Key type id_legacy registered
[    0.384144] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[    0.384578] io scheduler noop registered
[    0.384619] io scheduler deadline registered (default)
[    0.385016] io scheduler cfq registered
[    0.387752] BCM2708FB: allocated DMA memory 5b800000
[    0.387827] BCM2708FB: allocated DMA channel 0 @ f2007000
[    0.433185] Console: switching to colour frame buffer device 228x61
[    1.360824] bcm2835-rng 20104000.rng: hwrng registered
[    1.361174] vc-cma: Videocore CMA driver
[    1.361201] vc-cma: vc_cma_base      = 0x00000000
[    1.361216] vc-cma: vc_cma_size      = 0x00000000 (0 MiB)
[    1.361231] vc-cma: vc_cma_initial   = 0x00000000 (0 MiB)
[    1.361704] vc-mem: phys_addr:0x00000000 mem_base=0x1ec00000 mem_size:0x20000000(512 MiB)
[    1.389570] brd: module loaded
[    1.403277] loop: module loaded
[    1.404579] vchiq: vchiq_init_state: slot_zero = 0xdb880000, is_master = 0
[    1.407305] Loading iSCSI transport class v2.0-870.
[    1.408796] usbcore: registered new interface driver smsc95xx
[    1.408925] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    1.609845] Core Release: 2.80a
[    1.609888] Setting default values for core params
[    1.609945] Finished setting default values for core params
[    1.810466] Using Buffer DMA mode
[    1.810500] Periodic Transfer Interrupt Enhancement - disabled
[    1.810515] Multiprocessor Interrupt Enhancement - disabled
[    1.810534] OTG VER PARAM: 0, OTG VER FLAG: 0
[    1.810647] Dedicated Tx FIFOs mode
[    1.811306] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xdb814000 dma = 0x5b814000 len=9024
[    1.811351] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
Interrupt/Control Split Transaction hack enabled
[    1.811394] dwc_otg: Microframe scheduler enabled
[    1.811484] WARN::hcd_init_fiq:413: FIQ on core 0 at 0xc0409938
[    1.811511] WARN::hcd_init_fiq:414: FIQ ASM at 0xc0409c14 length 36
[    1.811547] WARN::hcd_init_fiq:439: MPHI regs_base at 0xdc898000
[    1.811636] dwc_otg 20980000.usb: DWC OTG Controller
[    1.811715] dwc_otg 20980000.usb: new USB bus registered, assigned bus number 1
[    1.811802] dwc_otg 20980000.usb: irq 56, io mem 0x00000000
[    1.811873] Init: Port Power? op_state=1
[    1.811889] Init: Power Port (0)
[    1.812316] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    1.812348] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.812372] usb usb1: Product: DWC OTG Controller
[    1.812393] usb usb1: Manufacturer: Linux 4.4.34+ dwc_otg_hcd
[    1.812414] usb usb1: SerialNumber: 20980000.usb
[    1.813754] hub 1-0:1.0: USB hub found
[    1.813873] hub 1-0:1.0: 1 port detected
[    1.814923] dwc_otg: FIQ enabled
[    1.814948] dwc_otg: NAK holdoff enabled
[    1.814963] dwc_otg: FIQ split-transaction FSM enabled
[    1.815029] Module dwc_common_port init
[    1.815654] usbcore: registered new interface driver usb-storage
[    1.816285] mousedev: PS/2 mouse device common for all mice
[    1.817511] bcm2835-cpufreq: min=700000 max=1000000
[    1.817941] sdhci: Secure Digital Host Controller Interface driver
[    1.817961] sdhci: Copyright(c) Pierre Ossman
[    1.818462] sdhost: log_buf @ db813000 (5b813000)
[    1.870445] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[    1.871107] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.872120] ledtrig-cpu: registered to indicate activity on CPUs
[    1.872481] hidraw: raw HID events driver (C) Jiri Kosina
[    1.872845] usbcore: registered new interface driver usbhid
[    1.872866] usbhid: USB HID core driver
[    1.894034] Initializing XFRM netlink socket
[    1.894142] NET: Registered protocol family 17
[    1.894389] Key type dns_resolver registered
[    1.896729] registered taskstats version 1
[    1.897118] vc-sm: Videocore shared memory driver
[    1.897156] [vc_sm_connected_init]: start
[    1.898346] [vc_sm_connected_init]: end - returning 0
[    1.899091] of_cfs_init
[    1.899276] of_cfs_init: OK
[    1.900858] Waiting for root device /dev/mmcblk0p2...
[    1.937902] mmc0: host does not support reading read-only switch, assuming write-enable
[    1.940035] mmc0: new high speed SDHC card at address 59b4
[    1.941300] mmcblk0: mmc0:59b4 USDU1 15.0 GiB
[    1.943314]  mmcblk0: p1 p2
[    2.011204] Indeed it is in host mode hprt0 = 00021501
[    2.074746] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
[    2.074781] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
[    3.099248] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
[    3.101654] EXT4-fs (mmcblk0p2): 13 orphan inodes deleted
[    3.101686] EXT4-fs (mmcblk0p2): recovery complete
[    3.211467] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    3.211588] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[    3.214903] devtmpfs: mounted
[    3.216309] Freeing unused kernel memory: 380K (c07c1000 - c0820000)
[    3.507403] random: systemd: uninitialized urandom read (16 bytes read, 17 bits of entropy available)
[    3.515195] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR)
[    3.515893] systemd[1]: Detected architecture 'arm'.
[    3.654468] NET: Registered protocol family 10
[    3.656587] systemd[1]: Inserted module 'ipv6'
[    3.659609] systemd[1]: Set hostname to <raspberrypi>.
[    3.878083] uart-pl011 20201000.uart: no DMA platform data
[    3.894278] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 20 bits of entropy available)
[    4.030635] Indeed it is in host mode hprt0 = 00021501
[    4.133542] random: systemd: uninitialized urandom read (16 bytes read, 22 bits of entropy available)
[    4.135755] random: systemd: uninitialized urandom read (16 bytes read, 22 bits of entropy available)
[    4.138562] random: systemd: uninitialized urandom read (16 bytes read, 22 bits of entropy available)
[    4.172650] random: systemd: uninitialized urandom read (16 bytes read, 23 bits of entropy available)
[    4.174726] random: systemd: uninitialized urandom read (16 bytes read, 23 bits of entropy available)
[    4.175230] random: systemd: uninitialized urandom read (16 bytes read, 23 bits of entropy available)
[    4.210530] usb 1-1: new full-speed USB device number 3 using dwc_otg
[    4.210921] Indeed it is in host mode hprt0 = 00021501
[    4.322391] random: systemd: uninitialized urandom read (16 bytes read, 25 bits of entropy available)
[    4.322702] random: systemd: uninitialized urandom read (16 bytes read, 25 bits of entropy available)
[    4.411034] usb 1-1: not running at top speed; connect to a high speed hub
[    4.411980] usb 1-1: New USB device found, idVendor=1a40, idProduct=0101
[    4.412042] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    4.412067] usb 1-1: Product: USB 2.0 Hub [Safe]
[    4.413466] hub 1-1:1.0: USB hub found
[    4.413759] hub 1-1:1.0: 4 ports detected
[    4.585360] systemd[1]: Cannot add dependency job for unit regenerate_ssh_host_keys.service, ignoring: Unit regenerate_ssh_host_keys.service failed to load: No such file or directory.
[    4.593178] systemd[1]: Expecting device dev-ttyAMA0.device...
[    4.594160] systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
[    4.594808] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    4.595121] systemd[1]: Starting Remote File Systems (Pre).
[    4.595347] systemd[1]: Reached target Remote File Systems (Pre).
[    4.595789] systemd[1]: Starting Arbitrary Executable File Formats File System Automount Point.
[    4.597148] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    4.597491] systemd[1]: Starting Encrypted Volumes.
[    4.597712] systemd[1]: Reached target Encrypted Volumes.
[    4.597927] systemd[1]: Starting Swap.
[    4.598172] systemd[1]: Reached target Swap.
[    4.598393] systemd[1]: Expecting device dev-mmcblk0p1.device...
[    4.598607] systemd[1]: Starting Root Slice.
[    4.598992] systemd[1]: Created slice Root Slice.
[    4.599262] systemd[1]: Starting User and Session Slice.
[    4.599900] systemd[1]: Created slice User and Session Slice.
[    4.600147] systemd[1]: Starting Delayed Shutdown Socket.
[    4.600716] systemd[1]: Listening on Delayed Shutdown Socket.
[    4.600936] systemd[1]: Starting /dev/initctl Compatibility Named Pipe.
[    4.601452] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[    4.601660] systemd[1]: Starting Journal Socket (/dev/log).
[    4.602245] systemd[1]: Listening on Journal Socket (/dev/log).
[    4.602561] systemd[1]: Starting udev Control Socket.
[    4.603118] systemd[1]: Listening on udev Control Socket.
[    4.603417] systemd[1]: Starting udev Kernel Socket.
[    4.603850] systemd[1]: Listening on udev Kernel Socket.
[    4.604187] systemd[1]: Starting Journal Socket.
[    4.604807] systemd[1]: Listening on Journal Socket.
[    4.605298] systemd[1]: Starting System Slice.
[    4.605978] systemd[1]: Created slice System Slice.
[    4.606439] systemd[1]: Starting File System Check on Root Device...
[    4.613943] systemd[1]: Starting system-systemd\x2dfsck.slice.
[    4.615053] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[    4.615492] systemd[1]: Starting system-autologin.slice.
[    4.616369] systemd[1]: Created slice system-autologin.slice.
[    4.616643] systemd[1]: Starting system-serial\x2dgetty.slice.
[    4.617364] systemd[1]: Created slice system-serial\x2dgetty.slice.
[    4.617871] systemd[1]: Starting Increase datagram queue length...
[    4.635315] systemd[1]: Starting Restore / save the current clock...
[    4.663684] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[    4.696485] usb 1-1.2: new full-speed USB device number 4 using dwc_otg
[    4.723569] systemd[1]: Mounting POSIX Message Queue File System...
[    4.744860] systemd[1]: Mounting Debug File System...
[    4.795081] usb 1-1.2: New USB device found, idVendor=046d, idProduct=c52b
[    4.795126] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    4.795150] usb 1-1.2: Product: USB Receiver
[    4.795170] usb 1-1.2: Manufacturer: Logitech
[    4.816263] systemd[1]: Started Set Up Additional Binary Formats.
[    4.845282] systemd[1]: Mounted Huge Pages File System.
[    4.845632] systemd[1]: Starting udev Coldplug all Devices...
[    4.900511] usb 1-1.4: new full-speed USB device number 5 using dwc_otg
[    5.000927] usb 1-1.4: not running at top speed; connect to a high speed hub
[    5.001424] usb 1-1.4: New USB device found, idVendor=1908, idProduct=0226
[    5.001452] usb 1-1.4: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    5.003095] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[    5.020570] scsi host0: usb-storage 1-1.4:1.0
[    5.036558] systemd[1]: Starting Load Kernel Modules...
[    5.124383] systemd[1]: Starting Slices.
[    5.124647] systemd[1]: Reached target Slices.
[    5.165522] systemd[1]: Mounted Debug File System.
[    5.169482] systemd[1]: Mounted POSIX Message Queue File System.
[    5.183889] systemd[1]: Started Increase datagram queue length.
[    5.239052] systemd[1]: Started File System Check on Root Device.
[    5.242715] systemd[1]: Started Restore / save the current clock.
[    5.245609] systemd[1]: Started Create list of required static device nodes for the current kernel.
[    5.288091] fuse init (API version 7.23)
[    5.306075] systemd[1]: Time has been changed
[    5.319146] i2c /dev entries driver
[    5.355363] systemd[1]: Started Load Kernel Modules.
[    5.524310] systemd[1]: Started udev Coldplug all Devices.
[    5.714208] systemd[1]: Starting Apply Kernel Variables...
[    5.722598] systemd[1]: Mounting Configuration File System...
[    5.728915] systemd[1]: Mounting FUSE Control File System...
[    5.765147] systemd[1]: Starting Create Static Device Nodes in /dev...
[    5.822124] systemd[1]: Starting Syslog Socket.
[    5.822840] systemd[1]: Listening on Syslog Socket.
[    5.823248] systemd[1]: Starting Journal Service...
[    5.873278] systemd[1]: Started Journal Service.
[    6.031704] scsi 0:0:0:0: Direct-Access     Generic  Mass-Storage     1.11 PQ: 0 ANSI: 2
[    6.301505] sd 0:0:0:0: [sda] Attached SCSI removable disk
[    6.350808] systemd-udevd[122]: starting version 215
[    7.843795] logitech-djreceiver 0003:046D:C52B.0003: hiddev0,hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-20980000.usb-1.2/input2
[    8.527693] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[    8.641055] bcm2835-wdt 20100000.watchdog: Broadcom BCM2835 watchdog timer
[    8.897692] gpiomem-bcm2835 20200000.gpiomem: Initialised: Registers at 0x20200000
[   11.223348] systemd-journald[115]: Received request to flush runtime journal from PID 1
[   11.984981] sd 0:0:0:0: Attached scsi generic sg0 type 0
[   12.211043] input: Logitech M215 2nd Gen as /devices/platform/soc/20980000.usb/usb1/1-1/1-1.2/1-1.2:1.2/0003:046D:C52B.0003/0003:046D:401B.0004/input/input0
[   12.215457] logitech-hidpp-device 0003:046D:401B.0004: input,hidraw1: USB HID v1.11 Mouse [Logitech M215 2nd Gen] on usb-20980000.usb-1.2:1
[   12.331656] input: Logitech K330 as /devices/platform/soc/20980000.usb/usb1/1-1/1-1.2/1-1.2:1.2/0003:046D:C52B.0003/0003:046D:4016.0005/input/input1
[   12.378729] logitech-hidpp-device 0003:046D:4016.0005: input,hidraw2: USB HID v1.11 Keyboard [Logitech K330] on usb-20980000.usb-1.2:2
[   12.396258] random: nonblocking pool is initialized
[   17.747983] Adding 102396k swap on /var/swap.  Priority:-1 extents:3 across:208896k SSFS
[   25.980515] usb 1-1.1: new full-speed USB device number 6 using dwc_otg
[   26.080780] usb 1-1.1: not running at top speed; connect to a high speed hub
[   26.081830] usb 1-1.1: New USB device found, idVendor=0bda, idProduct=0179
[   26.081854] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[   26.081870] usb 1-1.1: Product: 802.11n NIC
[   26.081884] usb 1-1.1: Manufacturer: Realtek
[   26.081898] usb 1-1.1: SerialNumber: 00C693641159
[   28.792770] RTL871X: module init start
[   28.792804] RTL871X: rtl8188eu v4.3.0.8_13968.20150417
[   28.792817] RTL871X: build time: Nov 25 2016 19:31:42
[   28.799528] bFWReady == _FALSE call reset 8051...
[   28.829394] RTL871X: rtw_ndev_init(wlan0)
[   28.838486] usbcore: registered new interface driver rtl8188eu
[   28.838566] RTL871X: module init ret=0
[   29.437792] cfg80211: World regulatory domain updated:
[   29.437829] cfg80211:  DFS Master region: unset
[   29.437843] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[   29.437863] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[   29.437878] cfg80211:   (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[   29.437892] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[   29.437908] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[   29.437923] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[   29.437937] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[   29.437951] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[   29.437963] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[   31.251205] ==> rtl8188e_iol_efuse_patch
[   31.721242] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   31.778247] cfg80211: Regulatory domain changed to country: SA
[   31.778284] cfg80211:  DFS Master region: ETSI
[   31.778297] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[   31.778316] cfg80211:   (2402000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[   31.778333] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[   31.778349] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[   31.778363] cfg80211:   (5490000 KHz - 5710000 KHz @ 160000 KHz), (N/A, 2700 mBm), (0 s)
[   33.720483] RTL871X: nolinked power save enter
[   41.459055] Bluetooth: Core ver 2.21
[   41.459233] NET: Registered protocol family 31
[   41.459249] Bluetooth: HCI device and connection manager initialized
[   41.459280] Bluetooth: HCI socket layer initialized
[   41.459305] Bluetooth: L2CAP socket layer initialized
[   41.459353] Bluetooth: SCO socket layer initialized
[   41.528234] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   41.528266] Bluetooth: BNEP filters: protocol multicast
[   41.528304] Bluetooth: BNEP socket layer initialized
[  108.181278] ==> rtl8188e_iol_efuse_patch
[  108.647330] RTL871X: nolinked power save leave
[  110.111657] RTL871X: nolinked power save enter
[  168.231238] ==> rtl8188e_iol_efuse_patch
[  168.683766] RTL871X: nolinked power save leave
[  170.151058] RTL871X: nolinked power save enter
[  228.161311] ==> rtl8188e_iol_efuse_patch
[  228.601052] RTL871X: nolinked power save leave
[  230.069802] RTL871X: nolinked power save enter
[  288.205559] ==> rtl8188e_iol_efuse_patch
[  288.697117] RTL871X: nolinked power save leave
[  290.160862] RTL871X: nolinked power save enter
[  348.181225] ==> rtl8188e_iol_efuse_patch
[  348.637568] RTL871X: nolinked power save leave
[  350.100909] RTL871X: nolinked power save enter
[  408.171221] ==> rtl8188e_iol_efuse_patch
[  408.731140] RTL871X: nolinked power save leave
[  410.201426] RTL871X: nolinked power save enter
[  468.171224] ==> rtl8188e_iol_efuse_patch
[  468.641093] RTL871X: nolinked power save leave
[  470.111060] RTL871X: nolinked power save enter
[  528.171235] ==> rtl8188e_iol_efuse_patch
[  528.773806] RTL871X: nolinked power save leave
[  530.469002] RTL871X: nolinked power save enter
[  588.181219] ==> rtl8188e_iol_efuse_patch
[  588.646634] RTL871X: nolinked power save leave
[  590.111358] RTL871X: nolinked power save enter
[  648.151233] ==> rtl8188e_iol_efuse_patch
[  648.616895] RTL871X: nolinked power save leave
[  650.080518] RTL871X: nolinked power save enter
[  708.311279] ==> rtl8188e_iol_efuse_patch
[  708.752825] RTL871X: nolinked power save leave
[  710.221040] RTL871X: nolinked power save enter
[  768.181282] ==> rtl8188e_iol_efuse_patch
[  768.608648] RTL871X: nolinked power save leave
[  770.071179] RTL871X: nolinked power save enter
[  828.182133] ==> rtl8188e_iol_efuse_patch
[  828.699480] RTL871X: nolinked power save leave
[  830.169666] RTL871X: nolinked power save enter
[  888.191291] ==> rtl8188e_iol_efuse_patch
[  888.668913] RTL871X: nolinked power save leave
[  890.131401] RTL871X: nolinked power save enter
[  948.181287] ==> rtl8188e_iol_efuse_patch
[  948.687160] RTL871X: nolinked power save leave
[  950.151286] RTL871X: nolinked power save enter
[ 1008.181214] ==> rtl8188e_iol_efuse_patch
[ 1008.619782] RTL871X: nolinked power save leave
[ 1010.089885] RTL871X: nolinked power save enter
[ 1068.191236] ==> rtl8188e_iol_efuse_patch
[ 1068.632287] RTL871X: nolinked power save leave
[ 1070.100986] RTL871X: nolinked power save enter
[ 1128.241228] ==> rtl8188e_iol_efuse_patch
[ 1128.682245] RTL871X: nolinked power save leave
[ 1130.151335] RTL871X: nolinked power save enter
[ 1188.191233] ==> rtl8188e_iol_efuse_patch
[ 1188.657405] RTL871X: nolinked power save leave
[ 1190.120986] RTL871X: nolinked power save enter
[ 1248.211141] ==> rtl8188e_iol_efuse_patch
[ 1248.641580] RTL871X: nolinked power save leave
[ 1250.108059] RTL871X: nolinked power save enter
[ 1308.181181] ==> rtl8188e_iol_efuse_patch
[ 1308.662243] RTL871X: nolinked power save leave
[ 1310.128835] RTL871X: nolinked power save enter
[ 1368.191114] ==> rtl8188e_iol_efuse_patch
[ 1368.744502] RTL871X: nolinked power save leave
[ 1370.208987] RTL871X: nolinked power save enter
[ 1428.191126] ==> rtl8188e_iol_efuse_patch
[ 1428.626657] RTL871X: nolinked power save leave
[ 1430.088379] RTL871X: nolinked power save enter
[ 1488.181149] ==> rtl8188e_iol_efuse_patch
[ 1488.614983] RTL871X: nolinked power save leave
[ 1490.078975] RTL871X: nolinked power save enter
[ 1548.181167] ==> rtl8188e_iol_efuse_patch
[ 1548.651589] RTL871X: nolinked power save leave
[ 1550.120427] RTL871X: nolinked power save enter
[ 1608.191171] ==> rtl8188e_iol_efuse_patch
[ 1608.614998] RTL871X: nolinked power save leave
[ 1610.078982] RTL871X: nolinked power save enter
[ 1668.311215] ==> rtl8188e_iol_efuse_patch
[ 1668.770755] RTL871X: nolinked power save leave
[ 1670.238859] RTL871X: nolinked power save enter
[ 1728.201194] ==> rtl8188e_iol_efuse_patch
[ 1728.682861] RTL871X: nolinked power save leave
[ 1730.148870] RTL871X: nolinked power save enter
[ 1788.192001] ==> rtl8188e_iol_efuse_patch
[ 1788.651642] RTL871X: nolinked power save leave
[ 1790.118884] RTL871X: nolinked power save enter
[ 1848.191144] ==> rtl8188e_iol_efuse_patch
[ 1848.765231] RTL871X: nolinked power save leave
[ 1850.456977] RTL871X: nolinked power save enter
[ 1908.201140] ==> rtl8188e_iol_efuse_patch
[ 1908.718482] RTL871X: nolinked power save leave
[ 1910.179032] RTL871X: nolinked power save enter
[ 1968.201108] ==> rtl8188e_iol_efuse_patch
[ 1968.664335] RTL871X: nolinked power save leave
[ 1970.129046] RTL871X: nolinked power save enter
[ 2028.201286] ==> rtl8188e_iol_efuse_patch
[ 2028.650465] RTL871X: nolinked power save leave
[ 2030.121369] RTL871X: nolinked power save enter
[ 2088.251250] ==> rtl8188e_iol_efuse_patch
[ 2088.692710] RTL871X: nolinked power save leave
[ 2090.161313] RTL871X: nolinked power save enter
[ 2148.211271] ==> rtl8188e_iol_efuse_patch
[ 2148.648365] RTL871X: nolinked power save leave
[ 2150.111067] RTL871X: nolinked power save enter
[ 2208.261310] ==> rtl8188e_iol_efuse_patch
[ 2208.883707] RTL871X: nolinked power save leave
[ 2210.350486] RTL871X: nolinked power save enter
pi@raspberrypi:~ $
MrEngman
Fri Jan 13, 2017 5:19 pm
vik__ wrote:Hi,
          Sensitivity:0/0
Module                  Size  Used by
bnep                   11853  2
8188eu                931354  0
joydev                  9194  0
evdev                  11650  4
sg                     20799  0
snd_bcm2835            23131  1
bcm2835_wdt             4133  0
i2c_dev                 6578  0
fuse                   90504  3
ipv6                  367671  28
Output for dmesg:
pi@raspberrypi:~ $
From the info you posted it appears you are using a Pi Zero with a hub connected to it. Does the hub have it's own power supply? If not this could be part of the problem.
How do you scan for wifi APs. I use command sudo iwconfig wlan0 scan. If you scan with this command what result do you get.
In dmesg there is the line "[ 31.778247] cfg80211: Regulatory domain changed to country: SA" which may indicate you need to change you wifi setup.
I set up my wifi by editing file /etc/wpa_supplicant/wpa_supplicant.conf like this
country=GB
update_config=1
network={
        ssid="network-name"
Change country=GB to set the country where you are and ssid and psk using the settings for your network.
MrEngman
ShortCircuit217
Sat Jan 14, 2017 8:25 am
Hello everyone,
I seem to be at an impasse. I'm trying my best to understand what I'm supposed to be doing to get these T1U drivers working but unfortunately I can't seem to make any of the scripts work and receive either child errors or path errors. I'm running 4.4.9 on build 884
The last command I stumbled upon was
wget https://dl.dropboxusercontent.com/u/802 ... 884.tar.gz
tar xzf 8188eu-4.4.9-884.tar.gz
sudo install -p -m 644 8188eu.ko /lib/modules/4.4.9+/kernel/drivers/net/wireless
sudo insmod /lib/modules/4.4.9+/kernel/drivers/net/wireless/8188eu.ko
sudo depmod -a
sudo reboot
MrEngman
Sat Jan 14, 2017 1:27 pm
ShortCircuit217 wrote:Hello everyone,
sudo depmod -a
sudo reboot
Applying random commands is just going to mess things up. I would suggest you try and install the right driver - mt7610 - for the T1U then you might get it working. Searching the forum for "T1U" might help.
MrEngman
