Rasbian not reading NTSF?
Posted: Sun Dec 01, 2013 10:02 pm
by The Russian
I have Raspbian and I have an External 3,5" cabbinet witha SATA disk that is full of Flac files,and when I try to copy one of the I get input/output error,I that an indication that it can´t read NTFS or what?
Re: Rasbian not reading NTSF?
Posted: Sun Dec 01, 2013 11:40 pm
by DougieLawson
You can read (or write) NTFS.
Posted: Sun Dec 01, 2013 11:45 pm
by gkreidl
sudo apt-get install ntfs-3g
If that does not help, you may have a power problem.
Posted: Mon Dec 02, 2013 1:29 am
by Nr90
Reading should work, writing might nog out of the box.
You would need to add the ntfs-3g package. The previous poster missed a word in the command to enter:
Posted: Mon Dec 02, 2013 7:06 am
by smithg400
I expect you already have the ntfs-3g package installed as you say the problem occurs when you go to copy a file (and you wouldn't be able to 'see' files without the package). So the problem is one of two things:
- There is insufficient power to the hard drive - a hard drive must be powered from it's own supply or from a powered USB hub - the Raspberry Pi won't provide enough power itself
- You have a physical error on the disk
If you can copy the file OK on another machine then the disk is probably OK and then I'd definitely look at the power supply.
Posted: Mon Dec 02, 2013 2:36 pm
by The Russian
I installed the 3g but no difference.
The HDD does have it´s own powersupply.
From Windows I can read and write to the disk.
I have another drive with it´s own powersupply,and from that the raspbian can read and copy OK.
So I suspect theres sommething wrong with the cabinett or the drive,just seems funny it works in windows..
Posted: Mon Dec 02, 2013 4:17 pm
by gkreidl
Many newer "self powered" usb HDs are not completely self powered at all; they take the 12 V from the power supply and the 5 V from usb. I fell into the same trap when buying a new HD. Only a powered usb hub will help in this case.
Posted: Mon Dec 02, 2013 4:54 pm
by The Russian
Yes,I have a powered USB hubb and I connected it to the disk and now its working to copy files with rasbian.
Thanks for the answers!!
Posted: Thu Dec 05, 2013 7:33 pm
by The Russian
But now there is another problem..when I unplugg the power plugg to the Pi it doesn´t stop it keeps going...it must be getting the power trhough the USB cable from the hubb,is this how it should be?I mean I have a bipolar PSU to power the Pi and the PSU to the hubb is switched.... :roll:
Posted: Thu Dec 05, 2013 7:59 pm
by FTrevorGowen
The Russian wrote:But now there is another problem..when I unplugg the power plugg to the Pi it doesn´t stop it keeps going...it must be getting the power trhough the USB cable from the hubb,is this how it should be?I mean I have a bipolar PSU to power the Pi and the PSU to the hubb is switched.... :roll:
About half of all "low-to-medium-cost" USB hubs "back-power" AFAICT (see here: http://www.cpmspectrepi.webspace.virgin ... esChk.html for those I've tested). Some folks use this "feature" (strictly, it's not allowed by the USB specs.) to power their Pi's and accept the risks associated with having by-passed the Pi's own protection circuitry (polyfuse etc.).
Trev.
Posted: Thu Dec 05, 2013 8:35 pm
by The Russian
Ok,it is a cheap generic 7 port hub,what can I do,open it (I am used to DIY soldering)and break the traces(the power traces) to the port going to the Pi?
Posted: Fri Dec 06, 2013 11:10 am
by jdb
Or cut the "red wire" inside the cable from the Hub to the Pi.
Posted: Fri Dec 06, 2013 7:04 pm
by The Russian
I cut the trace,and now it´s working like it should.
