Hoximor
DHCP server can't start for AP
Sun Dec 01, 2013 8:01 am
Hi
I just bought a Raspberry Pi (Model B) with this WiFi dongle : http://tellu.re/IntmE6
I wanted to create a WiFi access point with them, so I followed this tutorial : http://tellu.re/1afLfe9
This was the first time a tutorial for this was good (I had read other but there was always an error somewhere).
I finished doing everything written in it, and I could see the Pi_AP on my Windows Phone and Galaxy Tab, but couldn't connect.
So I rebooted and then, I saw the DHCP service could not start, and I would like some help over here because I don't know where the problem is, I followed exactly the tutorial :roll:
Here is my error message :
[ ok ] Starting ISC DHCP server: dhcpd[....] Starting OpenBSD Secure Shell server: sshd
[FAIL] check syslog for diagnostics. ... failed!
 failed!
[FAIL] startpar: service(s) returned failure: isc-dhcp-server ... failed!
And then it asks me to log in.
I searched on Google but nothing helped me.
If you have any idea...
Note : when I try to connect from my Galaxy Tab, the status stays at "Getting IP adress" (or something like that, it is in french)
MattF
Re: DHCP server can't start for AP
Tue Dec 03, 2013 12:05 am
Make sure that the leases database directory specified in the configuration file actually exists.
saj27
Wed Mar 11, 2015 12:27 pm
Hi, same problem on boot [FAIL] startpar : service(s) returned failure: isc-dhcp-server...failure.
is that a driver problem or smth with isc-dhcp?
also if i put command :cat /var/log/syslog
about dhcp i got:
Mar 11 11:52:09 raspberrypi dhcpd: /etc/dhcp/dhcpd.conf line 111: unknown option dhcp.broadcast-adress
Mar 11 11:52:09 raspberrypi dhcpd: option broadcast-adress 192.
Mar 11 11:52:09 raspberrypi dhcpd: ^
Mar 11 11:52:09 raspberrypi dhcpd: Configuration file errors encountered -- exiting
Mar 11 11:52:09 raspberrypi dhcpd: Internet Systems Consortium DHCP Server 4.2.2
Mar 11 11:52:09 raspberrypi dhcpd: Copyright 2004-2011 Internet Systems Consortium.
Mar 11 11:52:09 raspberrypi dhcpd: All rights reserved.
Mar 11 11:52:09 raspberrypi dhcpd: For info, please visit https://www.isc.org/software/dhcp/
Mar 11 11:52:10 raspberrypi dhcpd: /etc/dhcp/dhcpd.conf line 111: unknown option dhcp.broadcast-adress
Mar 11 11:52:10 raspberrypi dhcpd: option broadcast-adress 192.
Mar 11 11:52:10 raspberrypi dhcpd: ^
Mar 11 11:52:10 raspberrypi dhcpd: Configuration file errors encountered -- exiting
i serch file by sudo nano /etc/dhcp/dhcpd.conf
and linne 111 is in
subnet 192.168.42.0 netmask 255.255.255.0 {
range 192.168.42.10 192.168.42.50;
line 111>>option broadcast-adress 192.168.42.255;
option routers 192.168.42.1;
default-lease-time 600;
max-lease-time 7200;
option domain-name "local";
option domain-name-servers 8.8.8.8, 8.8.4.4;
Aydan
Wed Mar 11, 2015 2:28 pm
saj27 wrote:Hi, same problem on boot [FAIL] startpar : service(s) returned failure: isc-dhcp-server...failure.
about dhcp i got:
and linne 111 is in
It's spelling it out what is wrong:
unknown option, I suspect you have a typo.
Regards
Aydan
Aydan
Wed Mar 11, 2015 2:30 pm
Hoximor wrote:Hi
 failed!
Did you look into syslog for dhcpd errors?
Regards
Aydan
saj27
Thu Mar 12, 2015 11:30 am
What a noobish mistake! Sorry for taking your time, now all is fine and work well, thanks a lot!
Added 13/3/2015
After connecting typo and go through tutorial RPi worked as AP, all was ok. But today i go that on boot:
[FAIL] Starting ISC DHCP server : dhcpd[....] check syslog for diagnostics ... failed!
failed!
My IP is 10.10.1.4
That's odd, I'm pretty sure i rebooted RPi yesterday and there was no problems.
I hope it's not something silly like last time.
Thanks a lot!
saj27
Fri Mar 13, 2015 10:11 am
from cat /var/log/syslog i got:
Mar 12 12:06:45 raspberrypi dhcpd: Internet Systems Consortium DHCP Server 4.2.2
Mar 12 12:06:45 raspberrypi dhcpd: Copyright 2004-2011 Internet Systems Consortium.
Mar 12 12:06:45 raspberrypi dhcpd: All rights reserved.
Mar 12 12:06:45 raspberrypi dhcpd: For info, please visit https://www.isc.org/software/dhcp/
Mar 12 12:06:45 raspberrypi dhcpd: Wrote 3 leases to leases file.
Mar 12 12:06:45 raspberrypi dhcpd: No subnet declaration for wlan0 (no IPv4 addresses).
Mar 12 12:06:45 raspberrypi dhcpd: ** Ignoring requests on wlan0. If this is not what
Mar 12 12:06:45 raspberrypi dhcpd: you want, please write a subnet declaration
Mar 12 12:06:45 raspberrypi dhcpd: in your dhcpd.conf file for the network segment
Mar 12 12:06:45 raspberrypi dhcpd: to which interface wlan0 is attached. **
Mar 12 12:06:45 raspberrypi dhcpd: Not configured to listen on any interfaces!
