RaspberryPi Won't start at all(first time)
Posted: Thu Nov 28, 2013 6:23 pm
by theastamana
Hello everybody,
I just got my raspberryPi today. Excited to try it, plugged it into the case and try to boot it up, but without succes.
What happens when entering the power a red and a green light light up. After that the green light will go off and start flashing almost invisble.
Nothing happens after that. I have already put new NOOBS software on it, but no succes.
Its a raspberryPi model B.
Thanks in advance,
Paul
Re: RaspberryPi Won't start at all(first time)
Posted: Thu Nov 28, 2013 7:07 pm
by DeeJay
Posted: Thu Nov 28, 2013 7:09 pm
by bubbl
try flashing anything other than NOOBS. if that fails, try another SD card. after that, contact the supplier.
Posted: Thu Nov 28, 2013 8:24 pm
by theastamana
bubbl wrote:try flashing anything other than NOOBS. if that fails, try another SD card. after that, contact the supplier.
I have tried another sd card and it worked. Shame the 8gb card is not compatible with raspberrypi.
Posted: Fri Nov 29, 2013 7:22 am
by gsh
What is the make / model of the SD card you used?
There is no reason for any SD card not to work...
Gordon
