poogle
RTL8188EUS cannot setup access point
Tue Nov 26, 2013 8:58 am
Hi
I'm having troubles getting my TL-WN725N v2 setup as an access point.
pi@raspberrypi ~ $ uname -a
Linux raspberrypi 3.10.19+ #600 PREEMPT Sat Nov 16 20:34:43 GMT 2013 armv6l GNU/Linux
I have installed the drivers and firmware provided by MrEngman in this post: http://www.raspberrypi.org/phpBB3/viewt ... man+%23600
The dongle seems to be found found during startup:
[    3.223976] usb 1-1.2: new high-speed USB device number 4 using dwc_otg
[    3.354710] usb 1-1.2: New USB device found, idVendor=0bda, idProduct=8179
[    3.363319] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    3.374492] usb 1-1.2: Product: 802.11n NIC
[    3.380349] usb 1-1.2: Manufacturer: Realtek
[    3.386272] usb 1-1.2: SerialNumber: 00E04C0001
[    3.974739] udevd[156]: starting version 175
[    5.910015] Chip Version Info: CHIP_8188E_Normal_Chip_TSMC_A_CUT_1T1R_RomVer(0)
[    6.254969] usbcore: registered new interface driver r8188eu
[   18.867721] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[   18.887162] r8188eu: Firmware Version 11, SubVersion 1, Signature 0x88e1
[   19.394657] r8188eu: MAC Address = 64:66:b3:07:23:f1
I have downloaded and compiled the modified hostapd from Realtek for chipset RTL8188CUS (could not find any version for the RTL8188EUS chipset) from http://www.realtek.com.tw/downloads/dow ... loads=true and modified the hostapd.conf as follows:
interface=wlan0
ssid=RPiAp
channel=1
macaddr_acl=0
auth_algs=1
ignore_broadcast_ssid=0
wpa=3
wpa_passphrase=<removed>
wpa_key_mgmt=WPA-PSK
wpa_pairwise=TKIP
rsn_pairwise=CCMP
driver=rtl871xdrv
ieee80211n=1
hw_mode=g
device_name=RTL8188EU
manufacturer=Realtek
But when running
sudo /usr/sbin/hostapd -dd /etc/hostapd/hostapd.conf
I get the following output:
random: Trying to read entropy from /dev/random
Configuration file: /etc/hostapd/hostapd.conf
drv->ifindex=3
l2_sock_recv==l2_sock_xmit=0x0x12c648
BSS count 1, BSSID mask 00:00:00:00:00:00 (0 bits)
Allowed channel: mode=1 chan=1 freq=2412 MHz max_tx_power=0 dBm
Allowed channel: mode=2 chan=165 freq=5825 MHz max_tx_power=0 dBm
Completing interface initialization
Mode: IEEE 802.11g  Channel: 1  Frequency: 2412 MHz
RATE[0] rate=10 flags=0x1
RATE[11] rate=540 flags=0x0
Flushing old station entries
ioctl[RTL_IOCTL_HOSTAPD]: Operation not supported
Could not connect to kernel driver.
Deauthenticate all stations
+rtl871x_sta_deauth_ops, ff:ff:ff:ff:ff:ff is deauth, reason=2
rtl871x_set_key_ops
Failed to set encryption.
Failed to clear default encryption keys (ifname=wlan0 keyidx=0)
rtl871x_set_key_ops
Failed to clear default encryption keys (ifname=wlan0 keyidx=1)
rtl871x_set_key_ops
Failed to clear default encryption keys (ifname=wlan0 keyidx=2)
rtl871x_set_key_ops
Failed to clear default encryption keys (ifname=wlan0 keyidx=3)
Using interface wlan0 with hwaddr 64:66:b3:07:23:f1 and ssid 'RPiAp'
Deriving WPA PSK based on passphrase
SSID - hexdump_ascii(len=5):
     52 50 69 41 70                                    RPiAp
PSK (ASCII passphrase) - hexdump_ascii(len=8): [REMOVED]
PSK (from passphrase) - hexdump(len=32): [REMOVED]
rtl871x_set_wps_assoc_resp_ie
random: Got 20/20 bytes from /dev/random
Get randomness: len=32 entropy=0
GMK - hexdump(len=32): [REMOVED]
Key Counter - hexdump(len=32): [REMOVED]
WPA: group state machine entering state GTK_INIT (VLAN-ID 0)
Get randomness: len=16 entropy=0
GTK - hexdump(len=32): [REMOVED]
WPA: group state machine entering state SETKEYSDONE (VLAN-ID 0)
rtl871x_set_key_ops
rtl871x_set_beacon_ops
rtl871x_set_hidden_ssid_ops
Failed to set beacon head/tail or DTIM period
wlan0: Setup of interface done.
When scanning for wireless networks from other devices the RPiAP does not appear. Anyone got any clues as to why this is not working? I guess the lines ioctl[RTL_IOCTL_HOSTAPD]: Operation not supported has something to do with it? :)
/Patrik
ITBungler
Re: RTL8188EUS cannot setup access point
Sat Dec 14, 2013 11:09 pm
Same here, guess the root cause is:
But no idea what cause this...
the Driver or the hostapd, but as this hostapd
with the old driver I assume the driver.....
my2cents
ITBungler
matakapo
Sun Jan 05, 2014 5:48 pm
I have exactly the same problem as poogle and I find no solution on the forum, any idea?
I use the driver rtl8188eu drivers for 03.10.25 + provided by MrEngman
http://www.raspberrypi.org/phpBB3/viewt ... 82#p462982
The dongle works well as a client but I can not run in AP
pi@raspberrybob ~ $ uname -a
Linux raspberrybob 3.10.25+ #622 PREEMPT Fri Jan 3 18:41:00 GMT 2014 armv6l GNU/Linux
When running
pi@raspberrybob ~/scripts $ sudo hostapd -dd /etc/hostapd/hostapd.conf
I get this output, and i can't see any wifi ssid on my other devices.
drv->ifindex=3
l2_sock_recv==l2_sock_xmit=0x0xac3648
Allowed channel: mode=1 chan=2 freq=2417 MHz max_tx_power=0 dBm
Allowed channel: mode=1 chan=3 freq=2422 MHz max_tx_power=0 dBm
Allowed channel: mode=1 chan=4 freq=2427 MHz max_tx_power=0 dBm
Allowed channel: mode=1 chan=5 freq=2432 MHz max_tx_power=0 dBm
Allowed channel: mode=1 chan=6 freq=2437 MHz max_tx_power=0 dBm
Allowed channel: mode=1 chan=7 freq=2442 MHz max_tx_power=0 dBm
Allowed channel: mode=1 chan=8 freq=2447 MHz max_tx_power=0 dBm
Allowed channel: mode=1 chan=9 freq=2452 MHz max_tx_power=0 dBm
Allowed channel: mode=1 chan=10 freq=2457 MHz max_tx_power=0 dBm
Allowed channel: mode=1 chan=11 freq=2462 MHz max_tx_power=0 dBm
Allowed channel: mode=1 chan=12 freq=2467 MHz max_tx_power=0 dBm
Allowed channel: mode=1 chan=13 freq=2472 MHz max_tx_power=0 dBm
Allowed channel: mode=0 chan=1 freq=2412 MHz max_tx_power=0 dBm
Allowed channel: mode=0 chan=2 freq=2417 MHz max_tx_power=0 dBm
Allowed channel: mode=0 chan=3 freq=2422 MHz max_tx_power=0 dBm
Allowed channel: mode=0 chan=4 freq=2427 MHz max_tx_power=0 dBm
Allowed channel: mode=0 chan=5 freq=2432 MHz max_tx_power=0 dBm
Allowed channel: mode=0 chan=6 freq=2437 MHz max_tx_power=0 dBm
Allowed channel: mode=0 chan=7 freq=2442 MHz max_tx_power=0 dBm
Allowed channel: mode=0 chan=8 freq=2447 MHz max_tx_power=0 dBm
Allowed channel: mode=0 chan=9 freq=2452 MHz max_tx_power=0 dBm
Allowed channel: mode=0 chan=10 freq=2457 MHz max_tx_power=0 dBm
Allowed channel: mode=0 chan=11 freq=2462 MHz max_tx_power=0 dBm
Allowed channel: mode=2 chan=36 freq=5180 MHz max_tx_power=0 dBm
Allowed channel: mode=2 chan=40 freq=5200 MHz max_tx_power=0 dBm
Allowed channel: mode=2 chan=44 freq=5220 MHz max_tx_power=0 dBm
Allowed channel: mode=2 chan=48 freq=5240 MHz max_tx_power=0 dBm
Allowed channel: mode=2 chan=52 freq=5260 MHz max_tx_power=0 dBm
Allowed channel: mode=2 chan=56 freq=5280 MHz max_tx_power=0 dBm
Allowed channel: mode=2 chan=60 freq=5300 MHz max_tx_power=0 dBm
Allowed channel: mode=2 chan=64 freq=5320 MHz max_tx_power=0 dBm
Allowed channel: mode=2 chan=100 freq=5500 MHz max_tx_power=0 dBm
Allowed channel: mode=2 chan=104 freq=5520 MHz max_tx_power=0 dBm
Allowed channel: mode=2 chan=108 freq=5540 MHz max_tx_power=0 dBm
Allowed channel: mode=2 chan=112 freq=5560 MHz max_tx_power=0 dBm
Allowed channel: mode=2 chan=116 freq=5580 MHz max_tx_power=0 dBm
Allowed channel: mode=2 chan=120 freq=5600 MHz max_tx_power=0 dBm
Allowed channel: mode=2 chan=124 freq=5620 MHz max_tx_power=0 dBm
Allowed channel: mode=2 chan=128 freq=5640 MHz max_tx_power=0 dBm
Allowed channel: mode=2 chan=132 freq=5660 MHz max_tx_power=0 dBm
Allowed channel: mode=2 chan=136 freq=5680 MHz max_tx_power=0 dBm
Allowed channel: mode=2 chan=140 freq=5700 MHz max_tx_power=0 dBm
Allowed channel: mode=2 chan=149 freq=5745 MHz max_tx_power=0 dBm
Allowed channel: mode=2 chan=153 freq=5765 MHz max_tx_power=0 dBm
Allowed channel: mode=2 chan=157 freq=5785 MHz max_tx_power=0 dBm
Allowed channel: mode=2 chan=161 freq=5805 MHz max_tx_power=0 dBm
RATE[1] rate=20 flags=0x1
RATE[2] rate=55 flags=0x1
RATE[3] rate=110 flags=0x1
RATE[4] rate=60 flags=0x0
RATE[5] rate=90 flags=0x0
RATE[6] rate=120 flags=0x0
RATE[7] rate=180 flags=0x0
RATE[8] rate=240 flags=0x0
RATE[9] rate=360 flags=0x0
RATE[10] rate=480 flags=0x0
rtl871x_set_key_ops
rtl871x_set_key_ops
rtl871x_set_key_ops
rtl871x_set_key_ops
Using interface wlan0 with hwaddr 64:66:b3:25:9e:29 and ssid 'bystoufly'
SSID - hexdump_ascii(len=9):
     62 79 73 74 6f 75 66 6c 79                        bystoufly
PSK (ASCII passphrase) - hexdump_ascii(len=10): [REMOVED]
GTK - hexdump(len=16): [REMOVED]
rtl871x_set_key_ops
^CSignal 2 received - terminating
ELOOP: remaining socket: sock=6 eloop_data=0xac36b8 user_data=(nil) handler=0x29df0
Hove
Sun Jan 05, 2014 7:26 pm
You may need to update your hostapd (assuming the EUS chipset supports soft AP like the CUS chipset does) - see here:
http://www.daveconroy.com/turn-your-ras ... s-chipset/
www.pistuffing.co.uk - Raspberry Pi and other stuffing!
matakapo
Mon Jan 06, 2014 8:05 am
Hi, thanks for your reply.
I tried with the updated hostapd but it doesn´t work either. I get exactly the same error message :(
Hove
Mon Jan 06, 2014 9:00 am
Then it may well be that the RTL8188EUS chipset doesn't support soft AP. Certainly the CUS version does as Dave Conroy's blog describes. See if you can find the spec. of the chipset and see if it mentions soft AP support.
