djscoutmaster
Camera Module / Motion / UV4L Problems
Mon Nov 25, 2013 3:20 am
i installed the uv4l drivers for the pi camera module from herr http://www.linux-projects.org/modules/s ... e&artid=14
then i installed motion and config from here http://www.linux-projects.org/modules/s ... e&artid=16
no in my logs i get the below output. It keeps retrying to connect but cant.. and i dont understand what "Nov 24 21:11:00 raspberrypi motion: [1] ioctl (VIDIOCGCAP): Invalid argument" means
Nov 24 21:11:00 raspberrypi motion: [1] cap.driver: "raspicam"
Nov 24 21:11:00 raspberrypi motion: [1] cap.card: "Camera Board OV5647"
Nov 24 21:11:00 raspberrypi motion: [1] cap.bus_info: "CSI"
Nov 24 21:11:00 raspberrypi motion: [1] cap.capabilities=0x01000001
Nov 24 21:11:00 raspberrypi motion: [1] - VIDEO_CAPTURE
Nov 24 21:11:00 raspberrypi motion: [1] - READWRITE
Nov 24 21:11:00 raspberrypi motion: [1] Test palette YU12 (640x480)
Nov 24 21:11:00 raspberrypi motion: [1] Using palette YU12 (640x480) bytesperlines 960 sizeimage 460800 colorspace 00000000
Nov 24 21:11:00 raspberrypi motion: [1] found control 0x00980900, "brightness", range 0,100
Nov 24 21:11:00 raspberrypi motion: [1] #011"brightness", default 50, current 50
Nov 24 21:11:00 raspberrypi motion: [1] found control 0x00980901, "contrast", range -100,100
Nov 24 21:11:00 raspberrypi motion: [1] #011"contrast", default 0, current 0
Nov 24 21:11:00 raspberrypi motion: [1] found control 0x00980902, "saturation", range -100,100
Nov 24 21:11:00 raspberrypi motion: [1] #011"saturation", default 0, current 0
Nov 24 21:11:00 raspberrypi motion: [1] found control 0x00980913, "iso", range 100,800
Nov 24 21:11:00 raspberrypi motion: [1] #011"iso", default 400, current 400
Nov 24 21:11:00 raspberrypi motion: [1] found control 0x08000000, "shutter speed", range 0,1000
Nov 24 21:11:00 raspberrypi motion: [1] #011"shutter speed", default 0, current 0
Nov 24 21:11:00 raspberrypi motion: [1] found control 0x08000001, "zoom factor", range 1,8
Nov 24 21:11:00 raspberrypi motion: [1] #011"zoom factor", default 0, current 1
Nov 24 21:11:10 raspberrypi motion: [1] Retrying until successful connection with camera
im running the noIR camera module trying to get the motion server/software up and running. used it tons of times with a usb. previous to all this i did enable the camera in the raspi-config and could get successful pictures and video.
help please
djscoutmaster
Update
Tue Nov 26, 2013 1:46 am
Installed everything and started over. Now when i install and start motion i get the following:
Processing triggers for man-db ...
Setting up motion (3.2.12-3.4) ...
insserv: warning: script 'uv4l_uvc' missing LSB tags and overrides
[ ok ] Starting motion detection daemon: motion.
The camera module seem to blink every so often as it keep re-trying to connect but is not succesfull..
anyone ever seen this "missing LSB tag overrides" issue?
diegocarrera
Re: Camera Module / Motion / UV4L Problems
Wed Nov 27, 2013 9:38 pm
I got same error like @djscoutmaster
So, I apply 'rpi-update', but it didn't help.
kif
Sun Mar 02, 2014 5:11 pm
@djscoutmaster @diegocarrera
I had trouble getting linux-projects solution to work.
A friend recommended using mmal instead:
http://rbnrpi.wordpress.com/project-lis ... etect-cam/
hope that helps
Cancelor
Thu May 05, 2016 6:58 am
I'm seeing the same
Is this the best place to get support for uv4l? Registration at linux-projects.org isn't currently working.
Can't find the thread you want? Try googling : YourSearchHere site:raspberrypi.org
Return to “Camera board”
