thieron
Pesky Black Bars
Sat Nov 23, 2013 10:47 pm
I've worked through the wiki and got the side black bars to go away but the top and bottom bars remaine...
I'm using a TV and HDMI cable. It seems like the screen resolution is off. It's cutting the image off at the top and the bottom. Using overscan_top and overscan_bottom pushes the text under the black bars. It doesn't move the bar up or down.
Settings I've uncommented:
hdmi_group=1
hdmi_mode=4
disable_overscan=1
overscan_left=50
overscan_right=50
overscan_top=-50
overscan_bottom=-50
I've spent hours on this and can get the top and bottom bars to go away, any ideas?
Phill Rymer
Re: Pesky Black Bars
Sun Nov 24, 2013 3:49 am
check tv settings for video in/output i had this problem tv was set to a resolution of 16-10 i tried all the different options and its fine now may be you have same issues
