wlan0 down after apt-get upgrade
Posted: Mon Nov 18, 2013 10:33 pm
As I've mentioned before I've run and my wlan0 isin't working anymore - please help. The details you've may be asking me:
uname -a
lsusb
Bus 001 Device 002: ID 0424:9512 Standard Microsystems Corp.
Bus 001 Device 004: ID 05e3:0608 Genesys Logic, Inc. USB-2.0 4-Port HUB
Bus 001 Device 005: ID 148f:3070 Ralink Technology, Corp. RT2870/RT3070 Wireless Adapter
Bus 001 Device 006: ID 04fc:0801 Sunplus Technology Co., Ltd
Bus 001 Device 007: ID 046d:c315 Logitech, Inc. Classic New Touch Keyboard
ifconfig & iwconfig
lsmod
I've already try to reinstall drivers as a last time - this time it didn't help
wpa_supplicant.conf
What else I need to do?
Can anyone help to fix my wlan0 interface
apt-get update && upgradeuname -a
Linux pi.local 3.6.11+ #538 PREEMPT Fri Aug 30 20:42:08 BST 2013 armv6l GNU/LinuxBus 001 Device 002: ID 0424:9512 Standard Microsystems Corp.
ifconfig & iwconfig
ifconfig
eth0 Link encap:Ethernet HWaddr b8:27:eb:52:db:e1
inet addr:192.168.0.182 Bcast:192.168.0.255 Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:13098 errors:0 dropped:0 overruns:0 frame:0
TX packets:10478 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:8288713 (7.9 MiB) TX bytes:4455841 (4.2 MiB)
iwconfig
lo no wireless extensions.
eth0 no wireless extensions.
Module Size Used by
xt_multiport 1582 8
iptable_filter 1493 1
ip_tables 11490 1 iptable_filter
x_tables 16962 3 ip_tables,xt_multiport,iptable_filter
snd_bcm2835 16432 0
snd_pcm 77728 1 snd_bcm2835
snd_seq 53482 0
snd_timer 20110 2 snd_pcm,snd_seq
snd_seq_device 6462 1 snd_seq
snd 58744 5 snd_bcm2835,snd_timer,snd_pcm,snd_seq,snd_seq_device
snd_page_alloc 5169 1 snd_pcm
crc_ccitt 1530 0
rt2x00usb 11240 0
rt2x00lib 42342 1 rt2x00usb
mac80211 273979 2 rt2x00lib,rt2x00usb
cfg80211 184390 2 mac80211,rt2x00lib
rfkill 18298 1 cfg80211
leds_gpio 2243 0
led_class 3570 2 leds_gpio,rt2x00lib
evdev 9450 2
joydev 9356 0 and finallypi@pi / $ cat /etc/network/interfaces
auto lo
iface lo inet loopback
iface eth0 inet dhcp
allow-hotplug wlan0
iface wlan0 inet manual
wpa-roam /etc/wpa_supplicant/wpa_supplicant.conf
iface default inet dhcp
wpa_supplicant.conf
Please note that above # are as I've try 1st and 2nd configuration and any of them didn't work.sudo cat /etc/wpa_supplicant/wpa_supplicant.conf
update_config=1
#network={
# ssid="SKYA767C"
# psk="House!-01"
# proto=RSN
# key_mgmt=WPA-PSK
# group=CCMP TKIP
network={
ssid="SKYA767C"
psk="House!-01"
proto=WPA
key_mgmt=WPA-PSK
pairwise=TKIP
auth_alg=OPEN
