dr_d_gee
No sound after upgrade
Sun Nov 17, 2013 6:53 pm
Earlier today updated Raspbian using sudo apt-get update and then sudo apt-get update: the first time since May. However sound no longer works—on checking the alsaguimixer one of the volume settings was zero, set it to maximum but made no difference.
The Pi's sound hardware is fine because sound still works on RISCOS.
elatllat
Re: No sound after upgrade
Sun Nov 17, 2013 8:16 pm
If you can try a fresh img and isolate which package upgrade breaks the sound (and which firmware version if it's the firmware package) that might help. (don't have a spare pi at the moment to test myself)
SBC with 32GB RAM: https://hardkernel.com
FAQ : https://raspberrypi.stackexchange.com
Unanswered: https://www.raspberrypi.org/forums/search.php?search_id=unanswered
