coolblue2000
HDMI Issue
Fri Oct 25, 2013 8:11 am
I have set my pi up to force hdmi output so that it always turns on properly if the screen was turned on after the pi. However this resulted in it always outputting SD rather than HD.
I now have the following options set
hdmi_force_hotplug=1
hdmi_drive=2
hdmi_ignore_edid=0xa5000080
hdmi_group=1
hdmi_mode=16
Now it works perfectly on my 1080p tv. However if I run it on my 720p tv then obviously it cuts off some of the screen.
Is there a way to force it to output 1080p if the tv supports 1080p or 720p if it does not?
Davespice
Contact: Twitter
Re: HDMI Issue
Fri Oct 25, 2013 10:03 am
Hi there, I’m afraid not. With this config you’re basically saying, ignore everything you detect, I am overriding you with what I want you to output.
