thetimhunt
Re: Setting up HDMI output
Sat Apr 27, 2013 6:17 pm
I am trying to set up for VGA using and HDMI - VGA adapter and I understand I need to change the screen resolution. I am being really thick here but how you access the config.txt file? Mine appears to be locked so I can't change values. How do I unlock it? I am not sure whether I can simply trash it and create a new one with the new values - will that lose all the other settings it controls?
PaulCheffus
Sun Apr 28, 2013 7:42 am
thetimhunt wrote:I am trying to set up for VGA using and HDMI - VGA adapter and I understand I need to change the screen resolution. I am being really thick here but how you access the config.txt file? Mine appears to be locked so I can't change values. How do I unlock it? I am not sure whether I can simply trash it and create a new one with the new values - will that lose all the other settings it controls?
Hi
sudo nano /boot/config.txt
will open the file in a editor. Make your changes then press Ctrl+x to exit and follow the on screen prompts to save your changes.
Cheers
Paul
Procrastination - The Thief of Time.
thetimhunt
Sun Apr 28, 2013 12:06 pm
Thanks Paul. Worked a treat - i was beginning to despair. VgA monitor now running although still fiddling to get resolution to fit ( too big).
SturSteve
Fri May 03, 2013 9:23 pm
I have been struggling with 14" CRT and given up for now.
I have a SHARP HDMI TV model LC-24DV510K which is an improvement - colour and nearly fits.
When I run tvservice -s it says "state 0x12001a, 1920x1080 @ 60Hz, interlaced" this is not one of the HDMI options listed - I don't know whether this is a problem or whether it would be better to change to one of the other options listed.
BUT whatever I set the overscan_left to I still can't see the first letter on the line!! Any advice?
The GUI is ok except crops a little on the right.
TommySan
Fri May 03, 2013 11:45 pm
It aint - I have only just started the RP and I have only got a monitor that says 'No Signal' Can anybody get me out of this situation because I really want to get on and get programing ;D
SturSteve
Sat May 04, 2013 10:25 am
TommySan wrote:It aint - I have only just started the RP and I have only got a monitor that says 'No Signal' Can anybody get me out of this situation because I really want to get on and get programing ;D
You have to say what kind of monitor this is - HDMI or CRT old TV. My 14" CRT TV won't show first 3 or 4 characters in command line which is not too bad as you can guess, but then the GUI is all wrong sizes also - using a 24" HDMI TV which shows nearly all - only missing 1 character each side
PaulCheffus
Sat May 04, 2013 11:39 am
Hi
Have you tried adjusting the screen on the CRT using the manual controls as they usually allow you to stretch and shrink the picture both horizontally and vertically.
Cheers
Paul
breaker
Mon May 06, 2013 8:49 am
Good information, I should have read it earlier for troubleshooting my sound over HDMI issue.
At the start of the thread it was stated not all HDMI modes are supported by the RPi.
Now I know how to find out which modes my television can accept, please point me to the list of which modes the RPi can output, thanks!
abishur
Mon May 06, 2013 1:48 pm
breaker wrote: Now I know how to find out which modes my television can accept, please point me to the list of which modes the RPi can output, thanks!
http://elinux.org/RPiconfig#Video :-)
Dear forum: Play nice ;-)
breaker
Tue May 07, 2013 1:47 am
Thanks! OK, I did see that list, but something made me question for a moment whether it was a master list of all possible HDMI modes that exist, or those RPi support. I suppose the comments reveal the details.
Densely Yours,
breaker
acryliccow
Wed May 08, 2013 11:48 pm
im am currently trying to setup my rasberry on 2 television. I have a working 100ft hdmi cable with a signal booster in the cable. I tried it with my computer and it work great. But when i pug it on my raspberry nothing append. I dont event have the redlight of my signal booster coming up. I have try in the config file the option config_hdmi_boost=7 but still nothing. Is there any way i could beef up the signal ??
Thks !!
dom
Thu May 09, 2013 12:12 am
acryliccow wrote:Hi,
I think the boost goes up to 11...
Cue
Fri May 10, 2013 7:43 pm
I'm using a HDMI to DVI adapter on a Dell 1501FP DVI monitor and can't seem to get the right resolution or aspect ratio. It seems to think I have a 16:9 display and a higher resolution than I actually do and ignores the hdmi_mode I set in config.txt.
What I've tried so far:
Initially I couldn't get any picture at all and the monitor would show "incompatible mode", even with hdmi_safe=1. Strangely what worked was, while hdmi_safe=1 was set, booting the Rpi connected with composite to a TV then switching the connection to the HDMI->DVI Monitor . This was somewhat annoying though because on a reboot it would show "incompatible mode" again and I would have to repeat this every time the Rpi restarted (even when ignoring EDID). At this point I had the following output from the below commands:
[email protected] ~ $ /opt/vc/bin/tvservice -s
state 0x120016 [DVI RGB full 4:3], 640x480 @ 60Hz, progressive
[email protected] ~ $ /opt/vc/bin/tvservice -m CEA
tvservice-client: No supported modes returned for group CEA in [vc_tv_hdmi_get_s upported_modes_new]
Group CEA has 0 modes:
[email protected] ~ $ /opt/vc/bin/tvservice -m DMT
Group DMT has 1 modes:
mode 4: 640x480 @ 60Hz 4:3, clock:25MHz progressive
I then decided to look at my EDID data
[email protected] ~ $ /opt/vc/bin/tvservice -d edid.dat
Written 384 bytes to edid.dat
[email protected] ~ $ /opt/vc/bin/edidparser edid.dat
Enabling fuzzy format match...
Parsing edid.dat...
HDMI:EDID version 1.3, 0 extensions, screen size 30x23 cm
HDMI:EDID features - videodef 0x81 standby suspend active off; colour encoding:RGB444|YCbCr422; sRGB is not default colourspace; preferred format is native; does not support GTF
edid_parser exited with code -1
The parser failed for some reason (guessing it's because of the HDMI to DVI adapter). Nonetheless I kept this edid.dat and set "hdmi_edid_file=1" in config.txt
This fixed my restart problem. I no longer had to connect it to a composite TV on boot. I then tried fixing my resolution. setting hdmi_mode=16 did not work. I decided that it was probably best to connect another PC to the monitor without the HDMI->DVI adapter and get a real dump of the EDID so I did (the results are below)
Parsing edid.dat...
HDMI:EDID found monitor S/N descriptor tag 0xff
HDMI:EDID found monitor name descriptor tag 0xfc
HDMI:EDID monitor name is DELL_1501FP
HDMI:EDID found monitor range descriptor tag 0xfd
HDMI:EDID monitor range offsets: V min=0, V max=0, H min=0, H max=0
HDMI:EDID monitor range: vertical is 56-75 Hz, horizontal is 31-60 kHz, max pixel clock is 80 MHz
HDMI:EDID monitor range does not support GTF
HDMI:EDID found preferred DMT detail timing format: 1024x768p @ 60 Hz (16)
HDMI:EDID established timing I/II bytes are AD CE 00
HDMI:EDID found DMT format: code 4, 640x480p @ 60 Hz in established timing I/II
HDMI:EDID found DMT format: code 5, 640x480p @ 72 Hz in established timing I/II
HDMI:EDID found DMT format: code 6, 640x480p @ 75 Hz in established timing I/II
HDMI:EDID found DMT format: code 9, 800x600p @ 60 Hz in established timing I/II
HDMI:EDID found DMT format: code 10, 800x600p @ 72 Hz in established timing I/II
HDMI:EDID found DMT format: code 11, 800x600p @ 75 Hz in established timing I/II
HDMI:EDID found DMT format: code 16, 1024x768p @ 60 Hz in established timing I/II
HDMI:EDID found DMT format: code 17, 1024x768p @ 70 Hz in established timing I/II
HDMI:EDID found DMT format: code 18, 1024x768p @ 75 Hz in established timing I/II
HDMI:EDID standard timings block x 8: 0x3140 314F 454F 6140 614F 0101 0101 0101
HDMI:EDID found DMT format: code 4, 640x480p @ 60 Hz (4:3) in standard timing 0
HDMI:EDID found DMT format: code 6, 640x480p @ 75 Hz (4:3) in standard timing 1
HDMI:EDID found DMT format: code 11, 800x600p @ 75 Hz (4:3) in standard timing 2
HDMI:EDID found DMT format: code 16, 1024x768p @ 60 Hz (4:3) in standard timing 3
HDMI:EDID found DMT format: code 18, 1024x768p @ 75 Hz (4:3) in standard timing 4
HDMI:EDID filtering formats with pixel clock > 162 MHz or h. blanking > 1023
HDMI:EDID best score mode initialised to DMT (4) 640x480p @ 60 Hz with pixel clock 25 MHz (score 0)
HDMI:EDID best score mode is now DMT (4) 640x480p @ 60 Hz with pixel clock 25 MHz (score 61864)
HDMI:EDID DMT mode (5) 640x480p @ 72 Hz with pixel clock 31 MHz has a score of 44236
HDMI:EDID best score mode is now DMT (6) 640x480p @ 75 Hz with pixel clock 31 MHz (score 71080)
HDMI:EDID DMT mode (9) 800x600p @ 60 Hz with pixel clock 40 MHz has a score of 57600
HDMI:EDID DMT mode (10) 800x600p @ 72 Hz with pixel clock 50 MHz has a score of 69120
HDMI:EDID best score mode is now DMT (11) 800x600p @ 75 Hz with pixel clock 49 MHz (score 97000)
HDMI:EDID best score mode is now DMT (16) 1024x768p @ 60 Hz with pixel clock 65 MHz (score 5166555)
HDMI:EDID DMT mode (17) 1024x768p @ 70 Hz with pixel clock 75 MHz has a score of 110100
HDMI:EDID DMT mode (18) 1024x768p @ 75 Hz with pixel clock 78 MHz has a score of 142964
HDMI:EDID preferred mode remained as DMT (16) 1024x768p @ 60 Hz with pixel clock 65 MHz
HDMI:EDID has only DVI support and no audio support
edid_parser exited with code 0
I then transferred this edid.dat to the RPi and connected it to my monitor again with the HDMI to DVI adapter. Now my screen was showing a higher resolution but higher than my monitor is capable of and the aspect ratio was wrong, it thought the display is 16:9. a segment at the bottom of the screen was showing the top (where the raspberry logo is) and the right was cut off because it was showing a 16:9 image on a 4:3 monitor. the output of "tvservice -s" was now
[email protected] ~ $/opt/vc/bin/tvservice -s
state 0x120005 [DVI RGB lim 16:9], 1280x720 @ 60Hz, progressive
what can I do to get my monitors native resolution and aspect ratio of 1024x768p @ 60 Hz (4:3)?
klein5366
Wed May 15, 2013 1:28 pm
hdmi to vga set-up dell
hi
i'm new to rpi and am having some trouble understanding and setting up a vga monitor, i have three monitors one microtek and two dells, i'm trying to get one of the two dells working. the microtek works right off the bat with no configuration well it works in low resolution.
i have one dell:
edid:
edid: 1 3
eisa: DELa00b
serial: 3754414c
manufacture: 25 2005
input: sync on green, analog signal.
screensize: 34 27
gamma: 2.200000
dpms: RGB, active off, suspend, standby
timing: [email protected] Hz (VGA 640x400, IBM)
timing: [email protected] Hz (VGA)
timing: [email protected] Hz (VESA)
timing: [email protected] Hz Interlaced (8514A)
ctiming: [email protected]
dtiming: [email protected]
monitorrange: 31-80, 56-75
monitorserial: D542856B7TAL
monitorname: DELL E173FP
and the other dell:
edid:
edid: 1 3
eisa: DELa006
serial: 30464555
manufacture: 17 2003
screensize: 34 27
gamma: 2.200000
monitorserial: 5W54034O0FEU
monitorname: DELL E171FPb
when i turn on the monitor the power light is orange, when i power my rpi on the power light turns green and i can see the back light on the screen no nothing else just a blank black screen , the rpi yellow light blinks for a good bit so i'm sure it is to the setup page.
i tryed configuring the /boot/config.text and i tryed editing the config.text in the boot partion
hdmi_safe=1
hdmi_force_hotplug=1
hdmi_group=2
hdmi_mode=16 1024x768 60Hz
hdmi_drive=2
config_hdmi_boost=7
i haven't been to the confederating page yet so the /boot/config.text isn't helping
maybe some one with a little more understanding of this can help me out.
klein5366
Sat May 18, 2013 1:02 am
this worked for me all i needed to change three lines :
# uncomment if hdmi display is not detected and composite is being output
# uncomment to force a specific HDMI mode (this will force VGA)
hdmi_group=2
#hdmi_mode=16 #works 1024x768 60Hz
#hdmi_mode=21 #works 1152x864 75Hz
hdmi_mode=36 #works 1280x1024 75Hz
# uncomment to force a HDMI mode rather than DVI. This can make audio work in
# DMT (computer monitor) modes
hdmi_drive=2
fullma
Mon May 20, 2013 6:13 pm
Hello
i have a problem.
when in plug mi rasp with a hdmi-dvi adapter i have a black screen. if i force to ignore edid the monitor show me a message saying no input.
i try in mi pc to get the edid data and the terminal freeze in linux so i guess that the monitor dont send the edid data.
the monitor its a lg e1940t
pd sorry for my english
pyroshroom
Mon May 27, 2013 6:58 am
So, I am trying to set up HDMI on a Toshiba 19LV505C and I am getting no signal from the TV even with the config.txt having:
config_hdmi_boost=4
hdmi_group=1
hdmi_mode=4
hdmi_drive=2
The pi works through the composite on the Toshiba 19LV505C, and through the HDMI using the default config.txt on another TV. I have no idea what else I could do to get the HDMI to work on the Toshiba 19LV505C. Here is the EDID if anyone can help.
Parsing edid.dat...
HDMI:EDID version 1.3, 1 extensions, screen size 16x9 cm
HDMI:EDID features - videodef 0x80 !standby !suspend !active off; colour encodin        g:RGB444|YCbCr422; sRGB is not default colourspace; preferred format is native;        does not support GTF
HDMI:EDID monitor name is TOSHIBA-TV
HDMI:EDID monitor range: vertical is 59-61 Hz, horizontal is 15-46 kHz, max pixe        l clock is 80 MHz
HDMI:EDID found preferred CEA detail timing format: 1280x720p @ 60 Hz (4)
HDMI:EDID found CEA detail timing format: 1920x1080i @ 60 Hz (5)
HDMI:EDID established timing I/II bytes are 00 00 00
HDMI:EDID standard timings block x 8: 0x0101 0101 0101 0101 0101 0101 0101 0101
HDMI:EDID parsing v3 CEA extension 0
HDMI:EDID monitor support - underscan IT formats:no, basic audio:yes, yuv444:yes        , yuv422:yes, #native DTD:1
HDMI:EDID found CEA detail timing format: 720x480p @ 60 Hz (2)
HDMI:EDID found CEA format: code 4, 1280x720p @ 60Hz (native)
HDMI:EDID found CEA format: code 5, 1920x1080i @ 60Hz
HDMI:EDID found CEA format: code 3, 720x480p @ 60Hz
HDMI:EDID found CEA format: code 2, 720x480p @ 60Hz
HDMI:EDID found CEA format: code 1, 640x480p @ 60Hz
HDMI:EDID found CEA format: code 7, 1440x480i @ 60Hz
HDMI:EDID found CEA format: code 6, 1440x480i @ 60Hz
HDMI:EDID found audio format 2 channels PCM, sample rate: 32|44|48 kHz, sample s        ize: 16 bits
HDMI:EDID found HDMI VSDB length 8
HDMI:EDID HDMI VSDB has physical address 1.0.0.0
HDMI:EDID HDMI VSDB supports AI:yes, dual link DVI:no
HDMI:EDID HDMI VSDB deep colour support - 48-bit:no 36-bit:no 30-bit:no DC_yuv44        4:no
HDMI:EDID HDMI VSDB max TMDS clock 75 MHz
HDMI:EDID HDMI VSDB does not support content type
HDMI:EDID adding mandatory support for DMT (4) 640x480p @ 60Hz
HDMI:EDID best score mode initialised to CEA (1) 640x480p @ 60 Hz with pixel clo        ck 25 MHz (score 0)
HDMI:EDID best score mode is now CEA (1) 640x480p @ 60 Hz with pixel clock 25 MH        z (score 61864)
HDMI:EDID best score mode is now CEA (2) 720x480p @ 60 Hz with pixel clock 27 MH        z (score 4066472)
HDMI:EDID CEA mode (3) 720x480p @ 60 Hz with pixel clock 27 MHz has a score of 6        6472
HDMI:EDID best score mode is now CEA (4) 1280x720p @ 60 Hz with pixel clock 74 M        Hz (score 5190888)
HDMI:EDID DMT mode (4) 640x480p @ 60 Hz with pixel clock 25 MHz has a score of 1        8432
HDMI:EDID CEA mode (5) 1920x1080i @ 60 Hz with pixel clock 74 MHz has a score of        4773832
HDMI:EDID CEA mode (6) 1440x480i @ 60 Hz with pixel clock 27 MHz has a score of        45736
HDMI:EDID CEA mode (7) 1440x480i @ 60 Hz with pixel clock 27 MHz has a score of        45736
HDMI:EDID preferred mode remained as CEA (4) 1280x720p @ 60 Hz with pixel clock        74 MHz
HDMI:EDID has HDMI support and audio support
scottnla
Thu May 30, 2013 3:03 pm
I'm trying to get my raspberry pi to send video to a square monitor (http://www.samsung.com/us/business/comm ... UDBPLBB/ZA); my eventual goal is to use a network of raspberry pis to drive a video wall.
The monitor has the rather unusual resolution of 960 x 960. This doesn't correspond to any of the options that are already built in to /boot/config.txt, so I tried to manually change the resolution in this file. However, this doesn't work :(
Here's my edid file to help sort out why this happening:
Parsing edidfile...
HDMI:EDID version 1.3, 1 extensions, screen size 39x39 cm
HDMI:EDID features - videodef 0x80 !standby !suspend !active off; colour encoding:RGB444|YCbCr422; sRGB is not default colourspace; preferred format is native; does not support GTF
HDMI:EDID monitor range: vertical is 24-75 Hz, horizontal is 26-81 kHz, max pixel clock is 170 MHz
HDMI:EDID monitor name is UD22B
HDMI:EDID failed to find a matching detail format for 960x960p hfp:56 hs:96 hbp:152 vfp:3 vs:10 vbp:23 pixel clock:75 MHz
HDMI:EDID calculated refresh rate is 60 Hz
HDMI:EDID guessing the format to be 960x960p @60 Hz
HDMI:EDID found unknown detail timing format: 960x960p hfp:56 hs:96 hbp:152 vfp:3 vs:10 vbp:23 pixel clock:75 MHz
HDMI:EDID found preferred DMT detail timing format: 1366x768p @ 60 Hz (81)
HDMI:EDID established timing I/II bytes are BF EF 80
HDMI:EDID found DMT format: code 8, 800x600p @ 56 Hz in established timing I/II
HDMI:EDID found DMT format: code 36, 1280x1024p @ 75 Hz in established timing I/II
HDMI:EDID standard timings block x 8: 0x8180 A9C0 714F B300 8100 9500 81C0 D1C0
HDMI:EDID found DMT format: code 35, 1280x1024p @ 60 Hz (5:4) in standard timing 0
HDMI:EDID found DMT format: code 83, 1600x900p @ 60 Hz (16:9) in standard timing 1
HDMI:EDID found DMT format: code 21, 1152x864p @ 75 Hz (4:3) in standard timing 2
HDMI:EDID found DMT format: code 58, 1680x1050p @ 60 Hz (16:10) in standard timing 3
HDMI:EDID found DMT format: code 28, 1280x800p @ 60 Hz (16:10) in standard timing 4
HDMI:EDID found DMT format: code 47, 1440x900p @ 60 Hz (16:10) in standard timing 5
HDMI:EDID found DMT format: code 85, 1280x720p @ 60 Hz (16:9) in standard timing 6
HDMI:EDID found DMT format: code 82, 1920x1080p @ 60 Hz (16:9) in standard timing 7
HDMI:EDID monitor support - underscan IT formats:yes, basic audio:yes, yuv444:yes, yuv422:yes, #native DTD:1
HDMI:EDID found CEA detail timing format: 1920x1080i @ 50 Hz (20)
HDMI:EDID found CEA detail timing format: 1280x720p @ 50 Hz (19)
HDMI:EDID found CEA detail timing format: 1280x720p @ 60 Hz (4)
HDMI:EDID found CEA format: code 16, 1920x1080p @ 60Hz (native)
HDMI:EDID found CEA format: code 31, 1920x1080p @ 50Hz
HDMI:EDID found CEA format: code 19, 1280x720p @ 50Hz
HDMI:EDID found CEA format: code 20, 1920x1080i @ 50Hz
HDMI:EDID found CEA format: code 18, 720x576p @ 50Hz
HDMI:EDID found audio format 2 channels PCM, sample rate: 32|44|48 kHz, sample size: 16|20|24 bits
HDMI:EDID found HDMI VSDB length 6
HDMI:EDID HDMI VSDB deep colour support - 48-bit:no 36-bit:no 30-bit:no DC_yuv444:no
HDMI:EDID HDMI VSDB has no latency information
HDMI:EDID adding mandatory support for CEA (1) 640x480p @ 60Hz
HDMI:EDID adding mandatory support for CEA (2) 720x480p @ 60Hz
HDMI:EDID adding mandatory support for CEA (17) 720x576p @ 50Hz
HDMI:EDID best score mode is now CEA (1) 640x480p @ 60 Hz with pixel clock 25 MHz (score 43432)
HDMI:EDID best score mode is now CEA (2) 720x480p @ 60 Hz with pixel clock 27 MHz (score 45736)
HDMI:EDID CEA mode (3) 720x480p @ 60 Hz with pixel clock 27 MHz has a score of 45736
HDMI:EDID best score mode is now CEA (4) 1280x720p @ 60 Hz with pixel clock 74 MHz (score 2580296)
HDMI:EDID DMT mode (4) 640x480p @ 60 Hz with pixel clock 25 MHz has a score of 36864
HDMI:EDID best score mode is now CEA (5) 1920x1080i @ 60 Hz with pixel clock 74 MHz (score 4649416)
HDMI:EDID DMT mode (6) 640x480p @ 75 Hz with pixel clock 31 MHz has a score of 46080
HDMI:EDID DMT mode (8) 800x600p @ 56 Hz with pixel clock 36 MHz has a score of 53760
HDMI:EDID DMT mode (11) 800x600p @ 75 Hz with pixel clock 49 MHz has a score of 72000
HDMI:EDID CEA mode (16) 1920x1080p @ 60 Hz with pixel clock 148 MHz has a score of 211624
HDMI:EDID DMT mode (16) 1024x768p @ 60 Hz with pixel clock 65 MHz has a score of 94370
HDMI:EDID CEA mode (17) 720x576p @ 50 Hz with pixel clock 27 MHz has a score of 45736
HDMI:EDID CEA mode (18) 720x576p @ 50 Hz with pixel clock 27 MHz has a score of 45736
HDMI:EDID DMT mode (18) 1024x768p @ 75 Hz with pixel clock 78 MHz has a score of 117964
HDMI:EDID CEA mode (19) 1280x720p @ 50 Hz with pixel clock 74 MHz has a score of 3071080
HDMI:EDID CEA mode (20) 1920x1080i @ 50 Hz with pixel clock 74 MHz has a score of 4128680
HDMI:EDID DMT mode (21) 1152x864p @ 75 Hz with pixel clock 108 MHz has a score of 174298
HDMI:EDID DMT mode (28) 1280x800p @ 60 Hz with pixel clock 83 MHz has a score of 147880
HDMI:EDID CEA mode (31) 1920x1080p @ 50 Hz with pixel clock 148 MHz has a score of 128680
HDMI:EDID DMT mode (35) 1280x1024p @ 60 Hz with pixel clock 108 MHz has a score of 182286
HDMI:EDID DMT mode (36) 1280x1024p @ 75 Hz with pixel clock 135 MHz has a score of 196608
HDMI:EDID DMT mode (47) 1440x900p @ 60 Hz with pixel clock 106 MHz has a score of 180520
HDMI:EDID DMT mode (58) 1680x1050p @ 60 Hz with pixel clock 146 MHz has a score of 236680
HDMI:EDID best score mode is now DMT (81) 1366x768p @ 60 Hz with pixel clock 85 MHz (score 5188835)
HDMI:EDID DMT mode (82) 1920x1080p @ 60 Hz with pixel clock 148 MHz has a score of 273832
HDMI:EDID DMT mode (83) 1600x900p @ 60 Hz with pixel clock 108 MHz has a score of 197800
HDMI:EDID DMT mode (85) 1280x720p @ 60 Hz with pixel clock 74 MHz has a score of 135592
HDMI:EDID preferred mode remained as DMT (81) 1366x768p @ 60 Hz with pixel clock 85 MHz
thanks for your help! looking forward to making awesome art with the help of the pi :)
JeremyF
Fri May 31, 2013 10:26 pm
scottnla wrote:I'm trying to get my raspberry pi to send video to a square monitor (http://www.samsung.com/us/business/comm ... UDBPLBB/ZA); my eventual goal is to use a network of raspberry pis to drive a video wall.
Parsing edidfile...
http://www.raspberrypi.org/phpBB3/viewt ... 29&t=24679 may help with the custom resolutions
{sig} Setup: Original version Raspberry Pi (B, rev1, 256MB), Dell 2001FP monitor (1600x1200), 8GB Class 4 SD Card with Raspbian and XBMC, DD-WRT wireless bridge
scottnla
Tue Jun 11, 2013 3:56 pm
Awesome! This seems to have corrected my screen resolution problem. I added the line:
hdmi_cvt=960 960 60
to my config.txt and my raspberry pi boots up in the right resolution. I cropped a video to 960 x 960 to play with omxplayer (which seems the right resolution when I play it on another computer); however, when I play it with omxplayer on my raspberry pi, it's highly distorted. Perhaps something like 960 px tall x 320 px wide.
Any thoughts on why it is so highly distorted?
nathan
chesterweirdo
Sat Jun 29, 2013 7:53 am
Just starting to get the hang of the PI but strugling to get the HDMI output correct.
What ever I do I can not get the resolution correct on my Sony 32" TV.
Below is my EDID but I am not sure what I should set it to from that info. I want to be able to display a image full screen at 1920x1080 and for it to look crisp.
Is this even possible.
Parsing edid...
HDMI:EDID version 1.3, 1 extensions, screen size 160x90 cm
HDMI:EDID features - videodef 0x80 !standby !suspend !active off; colour encoding:RGB444|YCbCr422; sRGB is not default colourspace; preferred$
HDMI:EDID monitor name is SONY_TV
HDMI:EDID monitor range: vertical is 48-62 Hz, horizontal is 14-48 kHz, max pixel clock is 90 MHz
HDMI:EDID found preferred DMT detail timing format: 1360x768p @ 60 Hz (39)
HDMI:EDID established timing I/II bytes are 21 08 00
HDMI:EDID monitor support - underscan IT formats:no, basic audio:yes, yuv444:yes, yuv422:yes, #native DTD:0
HDMI:EDID found CEA detail timing format: 720x576p @ 50 Hz (17)
HDMI:EDID found CEA format: code 17, 720x576p @ 50Hz
HDMI:EDID found CEA format: code 22, 1440x576i @ 50Hz
HDMI:EDID found CEA format: code 21, 1440x576i @ 50Hz
HDMI:EDID HDMI VSDB has physical address 3.0.0.0
HDMI:EDID best score mode is now CEA (4) 1280x720p @ 60 Hz with pixel clock 74 MHz (score 4580296)
HDMI:EDID CEA mode (5) 1920x1080i @ 60 Hz with pixel clock 74 MHz has a score of 3649416
HDMI:EDID CEA mode (6) 1440x480i @ 60 Hz with pixel clock 27 MHz has a score of 35368
HDMI:EDID CEA mode (7) 1440x480i @ 60 Hz with pixel clock 27 MHz has a score of 35368
HDMI:EDID CEA mode (17) 720x576p @ 50 Hz with pixel clock 27 MHz has a score of 2045736
HDMI:EDID CEA mode (21) 1440x576i @ 50 Hz with pixel clock 27 MHz has a score of 35368
HDMI:EDID CEA mode (22) 1440x576i @ 50 Hz with pixel clock 27 MHz has a score of 35368
HDMI:EDID best score mode is now DMT (39) 1360x768p @ 60 Hz with pixel clock 85 MHz (score 5188004)
HDMI:EDID preferred mode remained as DMT (39) 1360x768p @ 60 Hz with pixel clock 85 MHz
spiderbrigade
Mon Jul 01, 2013 9:29 pm
Is there a set of circumstances in which the settings in config.txt will be ignored on boot?
I have the Pi set up as a kiosk, using an older Dell monitor via HDMI-VGA converter. I have confirmed that the following settings work:
hdmi_group=2
hdmi_mode=16
I know these work because if I configure the pi this way on another monitor via direct HDMI, then swap cables, the display works correctly. At this point I can reboot and all will work well. Running edid confims that the VGA monitor will support DMT mode 16 just as it is set in the config.txt.
However as soon as I do a full halt or the system loses power, on a fresh boot the display does not work. If I swap cables back to the HDMI monitor, I can see via /tvservice -s that the display is set to CEA mode 4 despite the settings in config.txt.
I have tried various options such as hdmi_ignore_edid, hdmi_edid_file, avoid_safe_mode etc. thinking that for some reason the monitor isn't reporting correctly at startup, to no avail. Is there some other reason for the explicit settings in config.txt would be ignored? Or am I making some other simple mistake that causes the monitor not to work?
JedAil
Mon Jul 15, 2013 9:13 am
I connect my Raspberry to a 7" monitor LCD via composite.
I changed my config.txt to configurer the ouput .
My config is:
disable_overscan = 1
framebuffer_width = 480
framebuffer_height = 234
Will these parametres be used if I connect my Raspberry on another monitor via HDMI?
Are parametres HDMI and composite independent ?
ricgal
Tue Jul 16, 2013 6:55 pm
By looking through this, I found a link to http://elinux.org/RPi_config.txt where the discussion of modifying the file /boot/config.txt was referenced. If you are having problems with hdmi sound, this is where you will find the answer.
I bought my raspberry pi model a from element 14 at the end of May 2013. (It is now mid-july and the camera module just arrived). My preconfigured sd card came with the the hdmi drive setting commented out. So I was not getting sound coming out, and I was getting frustrated. Reading the elinux wiki answered that problem.
matzehali
Wed Jul 17, 2013 9:53 pm
Hi there,
I'm trying to connect an Atomos Ninja as HDMI-output device. I was not able to get a picture, even though the edid-extraction showed, that it was supporting a lot of modes:
edidparser /home/pi/ninja.edid
Parsing /home/pi/ninja.edid...
HDMI:EDID version 1.3, 1 extensions, screen size 71x40 cm
HDMI:EDID monitor name is ATOMOS_NINJA_~
HDMI:EDID monitor range: vertical is 59-61 Hz, horizontal is 15-46 kHz, max pixel clock is 80 MHz
HDMI:EDID found preferred CEA detail timing format: 1440x480i @ 60 Hz (6)
HDMI:EDID monitor support - underscan IT formats:no, basic audio:yes, yuv444:yes, yuv422:yes, #native DTD:8
HDMI:EDID found CEA detail timing format: 1440x576i @ 50 Hz (21)
HDMI:EDID found CEA detail timing format: 640x480p @ 60 Hz (1)
HDMI:EDID found CEA format: code 1, 640x480p @ 60Hz (native)
HDMI:EDID found CEA format: code 2, 720x480p @ 60Hz (native)
HDMI:EDID found CEA format: code 5, 1920x1080i @ 60Hz (native)
HDMI:EDID found CEA format: code 6, 1440x480i @ 60Hz (native)
HDMI:EDID found CEA format: code 17, 720x576p @ 50Hz (native)
HDMI:EDID found CEA format: code 19, 1280x720p @ 50Hz (native)
HDMI:EDID found CEA format: code 20, 1920x1080i @ 50Hz (native)
HDMI:EDID found CEA format: code 21, 1440x576i @ 50Hz (native)
HDMI:EDID found CEA format: code 32, 1920x1080p @ 24Hz (native)
HDMI:EDID found CEA format: code 33, 1920x1080p @ 25Hz (native)
HDMI:EDID found CEA format: code 34, 1920x1080p @ 30Hz (native)
HDMI:EDID found audio format 2 channels PCM, sample rate: 48 kHz, sample size: 16|20|24 bits
HDMI:EDID HDMI VSDB has physical address 0.0.0.0
HDMI:EDID HDMI VSDB supports AI:no, dual link DVI:no
HDMI:EDID adding mandatory support for CEA (3) 720x480p @ 60Hz
HDMI:EDID adding mandatory support for CEA (18) 720x576p @ 50Hz
HDMI:EDID best score mode initialised to CEA (1) 640x480p @ 60 Hz with pixel clock 25 MHz (score 0)
HDMI:EDID best score mode is now CEA (1) 640x480p @ 60 Hz with pixel clock 25 MHz (score 2080296)
HDMI:EDID CEA mode (2) 720x480p @ 60 Hz with pixel clock 27 MHz has a score of 87208
HDMI:EDID CEA mode (3) 720x480p @ 60 Hz with pixel clock 27 MHz has a score of 66472
HDMI:EDID best score mode is now CEA (4) 1280x720p @ 60 Hz with pixel clock 74 MHz (score 4190888)
HDMI:EDID DMT mode (4) 640x480p @ 60 Hz with pixel clock 25 MHz has a score of 18432
HDMI:EDID best score mode is now CEA (5) 1920x1080i @ 60 Hz with pixel clock 74 MHz (score 4898248)
HDMI:EDID best score mode is now CEA (6) 1440x480i @ 60 Hz with pixel clock 27 MHz (score 5087208)
HDMI:EDID CEA mode (17) 720x576p @ 50 Hz with pixel clock 27 MHz has a score of 87208
HDMI:EDID CEA mode (18) 720x576p @ 50 Hz with pixel clock 27 MHz has a score of 66472
HDMI:EDID CEA mode (19) 1280x720p @ 50 Hz with pixel clock 74 MHz has a score of 2663240
HDMI:EDID CEA mode (20) 1920x1080i @ 50 Hz with pixel clock 74 MHz has a score of 3336040
HDMI:EDID CEA mode (21) 1440x576i @ 50 Hz with pixel clock 27 MHz has a score of 3587208
HDMI:EDID CEA mode (32) 1920x1080p @ 24 Hz with pixel clock 74 MHz has a score of 174298
HDMI:EDID CEA mode (33) 1920x1080p @ 25 Hz with pixel clock 74 MHz has a score of 180520
HDMI:EDID CEA mode (34) 1920x1080p @ 30 Hz with pixel clock 74 MHz has a score of 211624
HDMI:EDID preferred mode remained as CEA (6) 1440x480i @ 60 Hz with pixel clock 27 MHz
Did anyone ever had success with an Ninja connected to a RaspberryPi?
Any ideas what I'm doing wrong?
Here's my config.txt:
# uncomment if you get no picture on HDMI for a default "safe" mode
# hdmi_safe=1
# uncomment this if your display has a black border of unused pixels visible
# and your display can output without overscan
disable_overscan=1
# uncomment the following to adjust overscan. Use positive numbers if console
# goes off screen, and negative if there is too much border
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# uncomment to force a console size. By default it will be display's size minus
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
# hdmi_ignore_hotplug=1
hdmi_ignore_cec=1
hdmi_pixel_encoding=1
hdmi_mode=20
hdmi_ignore_edid=0xa5000080
hdmi_group=2
hdmi_drive=2
# uncomment to increase signal to HDMI, if you have interference, blanking, or
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#uncomment to overclock the arm. 700 MHz is the default.
#arm_freq=800
# for more options see http://elinux.org/RPi_config.txt
start_x=1
gpu_mem=128
# disable_camera_led=1
Thanks for your help,
much appreciated,
MatzeHali
SOLVED: hdmi_drive was obviously wrong, so setting it to one made the picture appear no the Ninja, hurray!
