EdwinJ85
Re: Setting up HDMI output
Fri Dec 21, 2012 10:52 am
Can we have a little more detail?
The pi should output to hdmi automatically, what device are you trying to connect it to and what resolution is it's screen?
Generally what you will need to do is hook up the pi to your router while it is running via ethernet, SSH into it and run "sudo nano /boot/config.txt" to edit the settings, press ctrl x to save the changes and then call "sudo reboot" to restart the machine.
If you have an SD card reader you can edit the config.txt with a text editor on your lap/desktop computer.
I don't use openelec myself, RASPBMC is far more user friendly imo and has better support. You can also control it with your TV remote which is awesome.
Hello!
7ewis
Wed Dec 26, 2012 12:11 pm
I've had a problem, my desktop doesn't load properly, I just get the wallpaper.
But I have used multiple tv's in my house, and it's the same on all of them even after a reflash?
Raspberry Pi - Model B (512MB)
sansjunk
Sat Dec 29, 2012 5:52 pm
I just posted about an issue I am having trying to get the HDMI to work on my Pi. Please see post here:
http://www.raspberrypi.org/phpBB3/viewt ... 28&t=27485
Help would be truly appreciated :)
Onira
Sun Dec 30, 2012 2:47 pm
My LG IPS236V
still shows black poles on top and bottom of the screen
tried to set HDMI but no results
# tvservice -m CEA
Group CEA has 11 modes:
                     mode 1: 640x480 @ 60Hz, progressive
                     mode 2: 720x480 @ 60Hz, progressive
                     mode 3: 720x480 @ 60Hz, progressive
                     mode 4: 1280x720 @ 60Hz, progressive
                     mode 5: 1920x1080 @ 60Hz, interlaced
        (native) mode 16: 1920x1080 @ 60Hz, progressive
                     mode 17: 720x576 @ 50Hz, progressive
                     mode 18: 720x576 @ 50Hz, progressive
                     mode 19: 1280x720 @ 50Hz, progressive
                     mode 20: 1920x1080 @ 50Hz, interlaced
                     mode 31: 1920x1080 @ 50Hz, progressive
Cogito ergo sum
zproc
Tue Jan 01, 2013 10:36 am
Something weird is going on... maybe?
I received my new 512mb Pi yesterday and was using my 256mb one with a Raspbian SD card on a 1080p TV on HDMI until that, i used that SD card and the 256 Pi for testing a HDMI TO VGA box on a monitor that supports only support 1600Xsomething earlier, and now that I want to use my 512mb with that same SD Raspbian system again on my HDMI TV it only sets the resolution to 1280x720 @ 60hz (was running at 1080p before this / and with the 256mb Pi — i set up again the RAM split just in case and updated Raspi-conf and did an apt-get update+upgrade but the Raspbian was installed only a few days ago)
tvservice - m CEA or DMT returns "Group CEA/DMT has 0 modes:"
tvservice -d something.txt gives me nothing but an empty file...
tvservice -s outputs:
state: HPD high|DVI mode|HDCP off|composite off (0x120016), 1280x720 @ 60 Hz, progressive
Has my Raspbian system somehow memorized the low resolution from when it was connected to the other monitor? Would be weird i guess...
is it something related to some config of the 512mb version? (should have i refrained swapping SD cards between 256mb and 512mb models?)
edit: So i had already tried to turn if off and on again but not fully I guess... unplugging and replugging the HDMI cable on the Pi side (i tried on the TV side) made it be able to detect the CEA/DMT modes... and after a reboot it did set on the good (1080P) resolution. So, i guess everything's okay... (bit weird tho, isn't it?)
migube
Wed Jan 02, 2013 8:57 pm
I managed to add resolutions that my TV is supporting , but the Amplifier edid.dat was not passing through :)
see http://www.raspberrypi.org/phpBB3/viewt ... 21#p248921
Onira
Thu Jan 03, 2013 11:52 am
a resolution different than any of 1920x1080i/p ?
Cogito ergo sum
john999
Sat Jan 19, 2013 10:40 am
This is my first day using the pi, and I am faced with a screen which is almost impossible to read it is about 60 rows x 240 characters. I am now faced with prospect of learning about screen resolutions trying to work out what i should put in the config file. I would not mind learning about this eventually. but within seconds of firing up the Pi.
Do I really need to learn about this on day 1. Surely it would not be to difficult for a Linux whizz kid to write an application called "cycle_through_all_suitable_screen_resolutions", which would allow me to select something I can actually read and then update the config file for me?
zeroos
Sat Jan 19, 2013 10:58 am
Hi
No Audio HDMI output using HDMI cable that came with my Samsung SyncMaster P2570HD.
Mine output s:
[email protected] ~ $ /opt/vc/bin/tvservice -s
state: HPD high|HDMI mode|composite off (0x12000a), 1920x1080 @ 60Hz, progressive
[email protected] ~ $ /opt/vc/bin/tvservice -m CEA
Group CEA has 7 modes:
           mode 34: 1920x1080 @ 30Hz, progressive
[email protected] ~ $ /opt/vc/bin/tvservice -m DMT
Group DMT has 19 modes:
           mode 4: 640x480 @ 60Hz, progressive
           mode 5: 640x480 @ 72Hz, progressive
           mode 6: 640x480 @ 75Hz, progressive
           mode 8: 800x600 @ 56Hz, progressive
           mode 9: 800x600 @ 60Hz, progressive
           mode 10: 800x600 @ 72Hz, progressive
           mode 11: 800x600 @ 75Hz, progressive
           mode 16: 1024x768 @ 60Hz, progressive
           mode 17: 1024x768 @ 70Hz, progressive
           mode 18: 1024x768 @ 75Hz, progressive
           mode 21: 1152x864 @ 75Hz, progressive
           mode 28: 1280x800 @ 60Hz, progressive
           mode 32: 1280x960 @ 60Hz, progressive
           mode 35: 1280x1024 @ 60Hz, progressive
           mode 36: 1280x1024 @ 75Hz, progressive
           mode 47: 1440x900 @ 60Hz, progressive
           mode 48: 1440x900 @ 75Hz, progressive
           mode 51: 1600x1200 @ 60Hz, progressive
           mode 58: 1680x1050 @ 60Hz, progressive
[email protected] ~ $ /opt/vc/bin/tvservice -d edid.dat
Written 256 bytes to edid.dat
[email protected] ~ $ /opt/vc/bin/edidparser edid.dat
Enabling fuzzy format match...
Parsing edid.dat...
HDMI:EDID version 1.3, 1 extensions, screen size 16x9 cm
HDMI:EDID features - videodef 0x80 !standby !suspend !active off; colour encoding:RGB444|YCbCr422; sRGB is not default colourspace; preferred format is native; does not support GTF
HDMI:EDID found monitor range descriptor tag 0xfd
HDMI:EDID monitor range offsets: V min=0, V max=0, H min=0, H max=0
HDMI:EDID monitor range: vertical is 24-75 Hz, horizontal is 26-81 kHz, max pixel clock is 230 MHz
HDMI:EDID monitor range does not support GTF
HDMI:EDID found monitor name descriptor tag 0xfc
HDMI:EDID monitor name is SyncMaster
HDMI:EDID found preferred CEA detail timing format: 1920x1080p @ 60 Hz (16)
HDMI:EDID found CEA detail timing format: 1280x720p @ 60 Hz (4)
HDMI:EDID established timing I/II bytes are BF EF 80
HDMI:EDID found DMT format: code 4, 640x480p @ 60 Hz in established timing I/II
HDMI:EDID found DMT format: code 5, 640x480p @ 72 Hz in established timing I/II
HDMI:EDID found DMT format: code 6, 640x480p @ 75 Hz in established timing I/II
HDMI:EDID found DMT format: code 8, 800x600p @ 56 Hz in established timing I/II
HDMI:EDID found DMT format: code 9, 800x600p @ 60 Hz in established timing I/II
HDMI:EDID found DMT format: code 10, 800x600p @ 72 Hz in established timing I/II
HDMI:EDID found DMT format: code 11, 800x600p @ 75 Hz in established timing I/II
HDMI:EDID found DMT format: code 16, 1024x768p @ 60 Hz in established timing I/II
HDMI:EDID found DMT format: code 17, 1024x768p @ 70 Hz in established timing I/II
HDMI:EDID found DMT format: code 18, 1024x768p @ 75 Hz in established timing I/II
HDMI:EDID found DMT format: code 36, 1280x1024p @ 75 Hz in established timing I/II
HDMI:EDID standard timings block x 8: 0x8100 9500 950F A940 B300 8180 714F 8140
HDMI:EDID found DMT format: code 28, 1280x800p @ 60 Hz (16:10) in standard timing 0
HDMI:EDID found DMT format: code 47, 1440x900p @ 60 Hz (16:10) in standard timing 1
HDMI:EDID found DMT format: code 48, 1440x900p @ 75 Hz (16:10) in standard timing 2
HDMI:EDID found DMT format: code 51, 1600x1200p @ 60 Hz (4:3) in standard timing 3
HDMI:EDID found DMT format: code 58, 1680x1050p @ 60 Hz (16:10) in standard timing 4
HDMI:EDID found DMT format: code 35, 1280x1024p @ 60 Hz (5:4) in standard timing 5
HDMI:EDID found DMT format: code 21, 1152x864p @ 75 Hz (4:3) in standard timing 6
HDMI:EDID found DMT format: code 32, 1280x960p @ 60 Hz (4:3) in standard timing 7
HDMI:EDID parsing v3 CEA extension 0
HDMI:EDID monitor support - underscan IT formats:yes, basic audio:yes, yuv444:yes, yuv422:yes, #native DTD:1
HDMI:EDID found CEA detail timing format: 1920x1080i @ 60 Hz (5)
HDMI:EDID found CEA detail timing format: 720x480p @ 60 Hz (2)
HDMI:EDID found CEA format: code 16, 1920x1080p @ 60Hz (native)
HDMI:EDID found CEA format: code 5, 1920x1080i @ 60Hz
HDMI:EDID found CEA format: code 34, 1920x1080p @ 30Hz
HDMI:EDID found CEA format: code 4, 1280x720p @ 60Hz
HDMI:EDID found CEA format: code 3, 720x480p @ 60Hz
HDMI:EDID found audio format 2 channels PCM, sample rate: 32|44|48 kHz, sample size: 16|20|24 bits
HDMI:EDID found Video Capability DB length 2
HDMI:EDID video capability: CE:3 IT:3 PT:0 QS:0
HDMI:EDID found HDMI VSDB length 7
HDMI:EDID HDMI VSDB has physical address 1.0.0.0
HDMI:EDID HDMI VSDB supports AI:yes, dual link DVI:no
HDMI:EDID HDMI VSDB deep colour support - 48-bit:no 36-bit:yes 30-bit:yes DC_yuv444:yes
HDMI:EDID HDMI VSDB max TMDS clock 225 MHz
HDMI:EDID HDMI VSDB has no latency information
HDMI:EDID adding mandatory support for CEA (1) 640x480p @ 60Hz
HDMI:EDID filtering formats with pixel clock > 162 MHz or h. blanking > 1023
HDMI:EDID best score mode initialised to CEA (1) 640x480p @ 60 Hz with pixel clock 25 MHz (score 18432)
HDMI:EDID best score mode is now CEA (1) 640x480p @ 60 Hz with pixel clock 25 MHz (score 61864)
HDMI:EDID best score mode is now CEA (2) 720x480p @ 60 Hz with pixel clock 27 MHz (score 3066472)
HDMI:EDID CEA mode (3) 720x480p @ 60 Hz with pixel clock 27 MHz has a score of 66472
HDMI:EDID best score mode is now CEA (4) 1280x720p @ 60 Hz with pixel clock 74 MHz (score 4635592)
HDMI:EDID DMT mode (4) 640x480p @ 60 Hz with pixel clock 25 MHz has a score of 18432
HDMI:EDID CEA mode (5) 1920x1080i @ 60 Hz with pixel clock 74 MHz has a score of 4273832
HDMI:EDID DMT mode (5) 640x480p @ 72 Hz with pixel clock 31 MHz has a score of 22118
HDMI:EDID DMT mode (6) 640x480p @ 75 Hz with pixel clock 31 MHz has a score of 23040
HDMI:EDID DMT mode (8) 800x600p @ 56 Hz with pixel clock 36 MHz has a score of 26880
HDMI:EDID DMT mode (9) 800x600p @ 60 Hz with pixel clock 40 MHz has a score of 28800
HDMI:EDID DMT mode (10) 800x600p @ 72 Hz with pixel clock 50 MHz has a score of 34560
HDMI:EDID DMT mode (11) 800x600p @ 75 Hz with pixel clock 49 MHz has a score of 36000
HDMI:EDID best score mode is now CEA (16) 1920x1080p @ 60 Hz with pixel clock 148 MHz (score 5398248)
HDMI:EDID DMT mode (16) 1024x768p @ 60 Hz with pixel clock 65 MHz has a score of 47185
HDMI:EDID DMT mode (17) 1024x768p @ 70 Hz with pixel clock 75 MHz has a score of 55050
HDMI:EDID DMT mode (18) 1024x768p @ 75 Hz with pixel clock 78 MHz has a score of 58982
HDMI:EDID DMT mode (21) 1152x864p @ 75 Hz with pixel clock 108 MHz has a score of 99649
HDMI:EDID DMT mode (28) 1280x800p @ 60 Hz with pixel clock 83 MHz has a score of 86440
HDMI:EDID DMT mode (32) 1280x960p @ 60 Hz with pixel clock 108 MHz has a score of 98728
HDMI:EDID CEA mode (34) 1920x1080p @ 30 Hz with pixel clock 74 MHz has a score of 149416
HDMI:EDID DMT mode (35) 1280x1024p @ 60 Hz with pixel clock 108 MHz has a score of 103643
HDMI:EDID DMT mode (36) 1280x1024p @ 75 Hz with pixel clock 135 MHz has a score of 98304
HDMI:EDID DMT mode (47) 1440x900p @ 60 Hz with pixel clock 106 MHz has a score of 102760
HDMI:EDID DMT mode (48) 1440x900p @ 75 Hz with pixel clock 136 MHz has a score of 122200
HDMI:EDID DMT mode (51) 1600x1200p @ 60 Hz with pixel clock 162 MHz has a score of 140200
HDMI:EDID DMT mode (58) 1680x1050p @ 60 Hz with pixel clock 146 MHz has a score of 130840
HDMI:EDID preferred mode remained as CEA (16) 1920x1080p @ 60 Hz with pixel clock 148 MHz
HDMI:EDID has HDMI support and audio support
edid_parser exited with code 0
How to get audio to listen?
migube
Sat Jan 19, 2013 11:04 am
Onira wrote:a resolution different than any of 1920x1080i/p ?
it was 1920*1080p, but 24/25/30/50hz, the Amp only showed 60hz
not very good when watching 24p movies ...
Onira
Sat Jan 19, 2013 6:35 pm
well my VGA via DVI goes 1920x1080, 1080p 60Hz and all goes well...
Cogito ergo sum
radiotitoraspi
Sun Jan 20, 2013 11:13 pm
it does not display on HDMI. It workd on RCA video.
What is happening ? It worked on HDMI TV but ionly 2 o 3 times.
I use now the same setup but no HDMI signal
Anyone solved this ?
I search in forums and it seems to be a common problem
radiotitoraspi
Mon Jan 21, 2013 4:25 pm
I have tried also to wirte with tvservice -d edid.dat
and I get "Written 0 bytes to edid.dat"
any help ?
johnaaronrose
Wed Jan 30, 2013 6:34 pm
My Pi & LCD TV (model Cello TP-1907D with 16:9 aspect) are driving me crazy. I can see screen display using Composite or HDMI connection with config.txt having hdmi_safe=1. For the HDMI, I'm using a powered hdmi to vga converter. tvservice -m shows CEA but only mode=1 (i.e. VGA). I've run 'tvservice -d filename' followed by 'edidparser filename' and looked at the output. It showed near the end: HDMI:EDID preferred mode remained as CEA (16) 1920x1080p @ 60 Hz with pixel clock 148 MHz. So it looks like tvservice & the edid contradict each other. I've tried changing config.txt to have hdmi_safe=1 commented out and with: hdmi_drive=2,hdmi_force_hotplug=1,hdmi_group=1,hdmi_mode=16. But the display is blank. I've also tried hdmi_drive=2,hdmi_force_hotplug=1,hdmi_group=2,hdmi_mode=16 as the TV makers have told me that its VGA is 1024x768.
dom
Wed Jan 30, 2013 7:32 pm
johnaaronrose wrote:My Pi & LCD TV (model Cello TP-1907D with 16:9 aspect) are driving me crazy. I can see screen display using Composite or HDMI connection with config.txt having hdmi_safe=1. For the HDMI, I'm using a powered hdmi to vga converter. tvservice -m shows CEA but only mode=1 (i.e. VGA). I've run 'tvservice -d filename' followed by 'edidparser filename' and looked at the output. It showed near the end: HDMI:EDID preferred mode remained as CEA (16) 1920x1080p @ 60 Hz with pixel clock 148 MHz. So it looks like tvservice & the edid contradict each other. I've tried changing config.txt to have hdmi_safe=1 commented out and with: hdmi_drive=2,hdmi_force_hotplug=1,hdmi_group=1,hdmi_mode=16. But the display is blank. I've also tried hdmi_drive=2,hdmi_force_hotplug=1,hdmi_group=2,hdmi_mode=16 as the TV makers have told me that its VGA is 1024x768.
HDMI to VGA converters often report garbage in the edid. You may be better off with:
hdmi_ignore_edid=0xa5000080
and you are probably better off removing hdmi_drive=2, and I'd try config_hdmi_boost=4. But without a valid edid (which ideally would report 1024x768 as the preferred mode) you are down to guessing.
JimKnopf
Thu Jan 31, 2013 11:48 am
greetings from Germany.
I've an HP ZR2740W monitor (with a fantastic and brilliant screen) but this device only supports three presets:
Preset, Pixel Format Horizontal Frequency (kHz), Vertical Frequency (Hz)
1, 640 x 480,  31.468, 59.9
2, 1280 x 720,  44.771, 59.8
3, 2560 x 1440, 88.786, 59.9
I connected the monitor using an HDMI-DVI dual cable to my rapsberry pi and really can see from the /op/vc/bin/tvservice using edidparser:
[email protected]:/opt/vc/bin$ sudo tvservice -d myedid.data
Written 128 bytes to myedid.data
[email protected]:/opt/vc/bin$ sudo edidparser myedid.data
Parsing myedid.data...
HDMI:EDID version 1.4, 0 extensions, screen size 60x34 cm
HDMI:EDID features - videodef 0x81 !standby !suspend active off; colour encoding:RGB444; sRGB is not default colourspace; preferred format is native; support discrete frame rate
HDMI:EDID monitor name is HP_ZR2740w
HDMI:EDID found monitor S/N descriptor tag 0xff
HDMI:EDID does not yet know monitor vertical range, setting to default 24 to 120Hz
HDMI:EDID failed to find a matching detail format for 2560x1440p hfp:48 hs:32 hbp:80 vfp:2 vs:34 vbp:5 pixel clock:241 MHz
HDMI:EDID calculated refresh rate is 60 Hz
HDMI:EDID guessing the format to be 2560x1440p @60 Hz
HDMI:EDID found unknown detail timing format: 2560x1440p hfp:48 hs:32 hbp:80 vfp:2 vs:34 vbp:5 pixel clock:241 MHz
HDMI:EDID failed to find a matching detail format for 1280x720p hfp:64 hs:128 hbp:192 vfp:7 vs:5 vbp:16 pixel clock:74 MHz
HDMI:EDID guessing the format to be 1280x720p @60 Hz
HDMI:EDID found preferred CEA detail timing format: 1280x720p @ 60 Hz (4)
HDMI:EDID established timing I/II bytes are 00 00 00
HDMI:EDID standard timings block x 8: 0x0101 0101 0101 0101 0101 0101 0101 0101
HDMI:EDID adding mandatory support for DMT (4) 640x480p @ 60Hz
HDMI:EDID moving support for CEA mode 4 to DMT mode 85 because sink does not support HDMI
HDMI:EDID best score mode initialised to CEA (1) 640x480p @ 60 Hz with pixel clock 25 MHz (score 0)
HDMI:EDID best score mode is now DMT (4) 640x480p @ 60 Hz with pixel clock 25 MHz (score 18432)
HDMI:EDID best score mode is now DMT (85) 1280x720p @ 60 Hz with pixel clock 74 MHz (score 55296)
HDMI:EDID preferred mode is updated to DMT (85) 1280x720p @ 60 Hz with pixel clock 74250000 Hz
HDMI:EDID has only DVI support and no audio support
As you can see with raspbmc and defaults settings in /boot/config.txt I can only use 640x480 and 1280x720 resolution.
May I inspire to support 2560x1440 resolution in future with the RaspBerry Pi as well?
Any suggestion like using any still 'hidden' hdmi_mode etc. are welcome! Thx in advance,
JimKnopf
dom
Thu Jan 31, 2013 2:04 pm
JimKnopf wrote:Hi,
I don't think this will be possible. [email protected] is the maximum we can drive.
Also 2560x1440 is not a standard CEA/DMT resolution.
If you really wanted to hack, you could set
hdmi_pixel_freq_limit=300000000
(effectively allowing overclock - behaviour not guaranteed).
And look here: http://www.raspberrypi.org/phpBB3/viewt ... 29&t=24679
But really without a scope and timing spec of the monitor, I think success is unlikely.
johnaaronrose
Thu Jan 31, 2013 3:21 pm
The Mode=4(i.e. 720p) for Group=1 on the Pi's config.txt did give a better display than using safe=1 (which presumably gives a Mode=1 i.e. VGA of 640x480). So I now have VGA of [email protected]
However, no matter how much I adjust overscan_right, it still leaves a 2cm border on the right. I guess that I'll have to live with that, unless anyone has a solution. Also, the TV speakers make an irritating crackle (like bad VHF radio reception). I 'll try to do some sound stuff to check it out.
JimKnopf
Thu Jan 31, 2013 4:24 pm
Hi, just to share my experience with the HP ZR2740W with 2560x1440 resolution at HDMI-DVI dual link cable:
I tried cusing the custom HDMI mode 87 by appending /boot/config.txt with
#cvt_width=2560 (width in pixels)
#cvt_height=1440 (height in pixel)
#cvt_framerate=60 (framerate in Hz)
#cvt_aspect=3 (aspect ratio 1=4:3, 2=14:9, 3=16:9, 4=5:4, 5=16:10, 6=15:9)
#cvt_margins=0 (0=margins disabled, 1=margins enabled)
#cvt_interlace=0 (0=progressive, 1=interlaced)
#cvt_rb=1 (reduced blanking, only valid for 60 Hz vertical)
hdmi_pixel_freq_limit=350000000
hdmi_cvt 2560 1440 60 3 0 0 0
but the screen gets blank with that.
Although the mode was set correct and was automatically chosen as best value, this seems to overstrain the poor RSP with the huge required pixel frame rate regardless I tried the "reduced blank" option or not:
tvservice output without "reduced blanking":
[email protected]:/opt/vc/bin$ tvservice -m DMT
Group DMT has 3 modes:
           mode 4: 640x480 @ 60Hz 4:3, clock:25MHz progressive
           mode 85: 1280x720 @ 60Hz 16:9, clock:74MHz progressive
           mode 87: 2560x1440 @ 60Hz 16:9, clock:312MHz progressive
tvservice with active "reduced blanking"
           mode 87: 2560x1440 @ 60Hz 16:9, clock:241MHz progressive
So, the HP ZR2740W can only be driven with 1280x720 resolution with the Raspberry Pi ... but that without having any need to adapt something in the /boot/config.txt. Well, I have to look for a Full HD native HDMI television/monitor to get the best out of the RSP and the video material, sigh. ;)
johnaaronrose
Fri Feb 01, 2013 7:11 pm
@dom
The Mode=4 (i.e. 720p which presumably generates 1024x768 or 1280x720 - from looking at the hdmi-vga converter manual) for Group=1 on the Pi's config.txt did give a better display than using safe=1 (which presumably gives a Mode=1 i.e. VGA of 640x480). Would tvservice tell me which it is using?
However, no matter how much I adjust overscan_right, it still leaves a 2cm border on the right. Any ideas?
jesusangel
Sat Feb 23, 2013 11:40 pm
Hi!
I have a 32LG3000 monitor. I can't only get it to work with Raspberry's safe mode.
Could you please help me to get it to work in a better display mode (I want HD 720p)?
This is the output from tvservice:
[email protected] ~ $ tvservice -m cea
tvservice-client: No supported modes returned for group CEA in [vc_tv_hdmi_get_supported_modes_new]
Group CEA has 0 modes:
[email protected] ~ $ tvservice -m dmt
Group DMT has 1 modes:
And this is the parsed EDID data:
Parsing edid.txt...
HDMI:EDID version 1.3, 1 extensions, screen size 70x39 cm
HDMI:EDID features - videodef 0x80 standby suspend active off; colour encoding:RGB444|YCbCr422; sRGB is not default colourspace; preferred format is native; does not support GTF
HDMI:EDID monitor name is 32LG3000
HDMI:EDID monitor range: vertical is 50-75 Hz, horizontal is 28-67 kHz, max pixel clock is 150 MHz
HDMI:EDID failed to find a matching detail format for 1360x768p hfp:72 hs:136 hbp:208 vfp:3 vs:5 vbp:22 pixel clock:84 MHz
HDMI:EDID guessing the format to be 1360x768p @60 Hz
HDMI:EDID found preferred DMT detail timing format: 1360x768p @ 60 Hz (39)
HDMI:EDID found CEA detail timing format: 1920x1080p @ 60 Hz (16)
HDMI:EDID established timing I/II bytes are A5 6E 00
HDMI:EDID standard timings block x 8: 0x3140 4540 6140 8180 D1C0 0101 0101 0101
HDMI:EDID found DMT format: code 4, 640x480p @ 60 Hz (4:3) in standard timing 0
HDMI:EDID found DMT format: code 9, 800x600p @ 60 Hz (4:3) in standard timing 1
HDMI:EDID found DMT format: code 16, 1024x768p @ 60 Hz (4:3) in standard timing 2
HDMI:EDID found DMT format: code 35, 1280x1024p @ 60 Hz (5:4) in standard timing 3
HDMI:EDID found DMT format: code 82, 1920x1080p @ 60 Hz (16:9) in standard timing 4
HDMI:EDID failed to find a matching detail format for 1280x720p hfp:64 hs:128 hbp:192 vfp:3 vs:5 vbp:20 pixel clock:74 MHz
HDMI:EDID found CEA detail timing format: 1920x1080i @ 50 Hz (20)
HDMI:EDID found CEA detail timing format: 720x576p @ 50 Hz (17)
HDMI:EDID found DMT detail timing format: 1280x768p @ 60 Hz (23)
HDMI:EDID found CEA format: code 7, 1440x480i @ 60Hz
HDMI:EDID found CEA format: code 1, 640x480p @ 60Hz
HDMI:EDID found CEA format: code 22, 1440x576i @ 50Hz
HDMI:EDID found CEA format: code 2, 720x480p @ 60Hz
HDMI:EDID found CEA format: code 17, 720x576p @ 50Hz
HDMI:EDID found CEA format: code 18, 720x576p @ 50Hz
HDMI:EDID found CEA format: code 19, 1280x720p @ 50Hz
HDMI:EDID found CEA format: code 20, 1920x1080i @ 50Hz
HDMI:EDID found CEA format: code 5, 1920x1080i @ 60Hz (native)
HDMI:EDID found CEA format: code 32, 1920x1080p @ 24Hz
HDMI:EDID found CEA format: code 33, 1920x1080p @ 25Hz
HDMI:EDID found CEA format: code 31, 1920x1080p @ 50Hz
HDMI:EDID HDMI VSDB has physical address 3.0.0.0
HDMI:EDID best score mode initialised to DMT (4) 640x480p @ 60 Hz with pixel clock 25 MHz (score 0)
HDMI:EDID best score mode is now CEA (1) 640x480p @ 60 Hz with pixel clock 25 MHz (score 43432)
HDMI:EDID best score mode is now CEA (2) 720x480p @ 60 Hz with pixel clock 27 MHz (score 3545736)
HDMI:EDID CEA mode (3) 720x480p @ 60 Hz with pixel clock 27 MHz has a score of 45736
HDMI:EDID best score mode is now CEA (4) 1280x720p @ 60 Hz with pixel clock 74 MHz (score 4080296)
HDMI:EDID DMT mode (4) 640x480p @ 60 Hz with pixel clock 25 MHz has a score of 61864
HDMI:EDID CEA mode (5) 1920x1080i @ 60 Hz with pixel clock 74 MHz has a score of 118312
HDMI:EDID DMT mode (6) 640x480p @ 75 Hz with pixel clock 31 MHz has a score of 46080
HDMI:EDID CEA mode (7) 1440x480i @ 60 Hz with pixel clock 27 MHz has a score of 35368
HDMI:EDID DMT mode (9) 800x600p @ 60 Hz with pixel clock 40 MHz has a score of 82600
HDMI:EDID DMT mode (11) 800x600p @ 75 Hz with pixel clock 49 MHz has a score of 72000
HDMI:EDID best score mode is now CEA (16) 1920x1080p @ 60 Hz with pixel clock 148 MHz (score 4649416)
HDMI:EDID DMT mode (16) 1024x768p @ 60 Hz with pixel clock 65 MHz has a score of 119370
HDMI:EDID CEA mode (17) 720x576p @ 50 Hz with pixel clock 27 MHz has a score of 2545736
HDMI:EDID DMT mode (17) 1024x768p @ 70 Hz with pixel clock 75 MHz has a score of 110100
HDMI:EDID CEA mode (18) 720x576p @ 50 Hz with pixel clock 27 MHz has a score of 45736
HDMI:EDID DMT mode (18) 1024x768p @ 75 Hz with pixel clock 78 MHz has a score of 117964
HDMI:EDID CEA mode (19) 1280x720p @ 50 Hz with pixel clock 74 MHz has a score of 71080
HDMI:EDID CEA mode (20) 1920x1080i @ 50 Hz with pixel clock 74 MHz has a score of 3128680
HDMI:EDID CEA mode (22) 1440x576i @ 50 Hz with pixel clock 27 MHz has a score of 35368
HDMI:EDID DMT mode (23) 1280x768p @ 60 Hz with pixel clock 79 MHz has a score of 2117964
HDMI:EDID CEA mode (31) 1920x1080p @ 50 Hz with pixel clock 148 MHz has a score of 128680
HDMI:EDID CEA mode (32) 1920x1080p @ 24 Hz with pixel clock 74 MHz has a score of 74766
HDMI:EDID CEA mode (33) 1920x1080p @ 25 Hz with pixel clock 74 MHz has a score of 76840
HDMI:EDID CEA mode (34) 1920x1080p @ 30 Hz with pixel clock 74 MHz has a score of 87208
HDMI:EDID DMT mode (35) 1280x1024p @ 60 Hz with pixel clock 108 MHz has a score of 182286
HDMI:EDID best score mode is now DMT (39) 1360x768p @ 60 Hz with pixel clock 85 MHz (score 5188004)
HDMI:EDID DMT mode (82) 1920x1080p @ 60 Hz with pixel clock 148 MHz has a score of 273832
HDMI:EDID preferred mode remained as DMT (39) 1360x768p @ 60 Hz with pixel clock 85 MHz
This is my /boot/config.txt file right now:
# uncomment if you get no picture on HDMI for a default "safe" mode
hdmi_safe=1
disable_overscan=1
# uncomment the following to adjust overscan. Use positive numbers if console
# goes off screen, and negative if there is too much border
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# uncomment to force a console size. By default it will be display's size minus
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
#hdmi_force_hotplug=1
# uncomment to force a specific HDMI mode (this will force VGA)
hdmi_group=2
hdmi_mode=4
# uncomment to force a HDMI mode rather than DVI. This can make audio work in
# DMT (computer monitor) modes
hdmi_drive=2
# uncomment to increase signal to HDMI, if you have interference, blanking, or
# no display
config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#uncomment to overclock the arm. 700 MHz is the default.
#arm_freq=800
# for more options see http://elinux.org/RPi_config.txt
dom
Sun Feb 24, 2013 11:45 am
jesusangel wrote: I have a 32LG3000 monitor. I can't only get it to work with Raspberry's safe mode.
Remove hdmi_safe as that forces it to VGA.
Options are here:
hdmi_group=2
hdmi_mode=4
is VGA. You probably want:
hdmi_group=1
hdmi_mode=4
for [email protected]
khingcat
Tue Apr 02, 2013 4:45 am
Hi, I'm from Indonesia, I've got my RasPi on Dec last year and I love it. First time I run it up I'm using my conventional CRT TV. Now I connect it to my 17" flat CRT monitor using a HDMI to VGA converter that I've just bought it on eBay. When I run it using Raspbian Wheezy, it's start to booting up but the monitor shows nothing except blinking indicator LED. When I reboot it (using Ctrl-Alt-Del), it rebooted and the monitor working well. I didn't find this when I run it using another SD card with Xbian, it's booting up normally.
Can anybody help me what should I do to fix it?
stealthdeath
Mon Apr 15, 2013 9:52 pm
I am not sure if this has been brought up through this thread but I don't want to create a new one either. The current setup I have currently is:
RPi - > Yamaha RX-Z7 - > Panasonic Plasma 1080p TV
My question is, when I run all the commands to find supported modes, is this for the TV or the receiver? Here is my output from all three:
[email protected] ~ $ tvservice -m CEA
Group CEA has 15 modes:
           mode 1: 640x480 @ 60Hz 4:3, clock:25MHz progressive
  (native) mode 2: 720x480 @ 60Hz 4:3, clock:27MHz progressive
           mode 3: 720x480 @ 60Hz 16:9, clock:27MHz progressive
           mode 4: 1280x720 @ 60Hz 16:9, clock:74MHz progressive
           mode 5: 1920x1080 @ 60Hz 16:9, clock:74MHz interlaced
           mode 6: 720x480 @ 60Hz 4:3, clock:27MHz x2 interlaced
           mode 7: 720x480 @ 60Hz 16:9, clock:27MHz x2 interlaced
           mode 10: 720x480 @ 60Hz 4:3, clock:54MHz x4 interlaced
           mode 11: 720x480 @ 60Hz 16:9, clock:54MHz x4 interlaced
           mode 14: 720x480 @ 60Hz 4:3, clock:54MHz x2 progressive
           mode 15: 720x480 @ 60Hz 16:9, clock:54MHz x2 progressive
  (native) mode 16: 1920x1080 @ 60Hz 16:9, clock:148MHz progressive
           mode 32: 1920x1080 @ 24Hz 16:9, clock:74MHz progressive
           mode 35: 720x480 @ 60Hz 4:3, clock:108MHz x4 progressive
           mode 36: 720x480 @ 60Hz 16:9, clock:108MHz x4 progressive
Parsing edid.dat...
HDMI:EDID version 1.3, 1 extensions, unknown aspect ratio
HDMI:EDID monitor name is Panasonic-TV
HDMI:EDID monitor range: vertical is 23-61 Hz, horizontal is 15-68 kHz, max pixel clock is 150 MHz
HDMI:EDID found preferred CEA detail timing format: 720x480p @ 60 Hz (2)
HDMI:EDID monitor support - underscan IT formats:no, basic audio:yes, yuv444:yes, yuv422:yes, #native DTD:4
HDMI:EDID found CEA detail timing format: 1920x1080p @ 24 Hz (32)
HDMI:EDID found CEA format: code 6, 1440x480i @ 60Hz
HDMI:EDID found CEA format: code 14, 1440x480p @ 60Hz
HDMI:EDID found CEA format: code 15, 1440x480p @ 60Hz
HDMI:EDID found CEA format: code 10, 2880x480i @ 60Hz
HDMI:EDID found CEA format: code 11, 2880x480i @ 60Hz
HDMI:EDID found CEA format: code 35, 2880x480p @ 60Hz
HDMI:EDID found CEA format: code 36, 2880x480p @ 60Hz
HDMI:EDID found audio format 2 channels PCM, sample rate: 32|44|48|88|96|176|192 kHz, sample size: 16|20|24 bits
HDMI:EDID found audio format 8 channels PCM, sample rate: 32|44|48|88|96|176|192 kHz, sample size: 16|20|24 bits
HDMI:EDID found audio format 6 channels AC3, sample rate: 32|44|48 kHz, bitrate: 640 kbps
HDMI:EDID found audio format 7 channels DTS, sample rate: 32|44|48|88|96 kHz, bitrate: 1536 kbps
HDMI:EDID found audio format 6 channels One Bit Audio, sample rate: 44 kHz, codec define: 0
HDMI:EDID found audio format 8 channels Dobly Digital+, sample rate: 44|48 kHz, codec define: 0
HDMI:EDID found audio format 8 channels MLP, sample rate: 48|96|192 kHz, codec define: 0
HDMI:EDID found audio format 8 channels DTS-HD, sample rate: 48|96|192 kHz, codec define: 1
HDMI:EDID found HDMI VSDB length 8
HDMI:EDID HDMI VSDB has physical address 1.4.0.0
HDMI:EDID HDMI VSDB does not support content type
HDMI:EDID extended data block tag 0x05 length 3 not supported
HDMI:EDID best score mode is now CEA (2) 720x480p @ 60 Hz with pixel clock 27 MHz (score 5087208)
HDMI:EDID CEA mode (4) 1280x720p @ 60 Hz with pixel clock 74 MHz has a score of 4135592
HDMI:EDID CEA mode (5) 1920x1080i @ 60 Hz with pixel clock 74 MHz has a score of 4773832
HDMI:EDID CEA mode (6) 1440x480i @ 60 Hz with pixel clock 27 MHz has a score of 45736
HDMI:EDID CEA mode (7) 1440x480i @ 60 Hz with pixel clock 27 MHz has a score of 45736
HDMI:EDID CEA mode (10) 2880x480i @ 60 Hz with pixel clock 54 MHz has a score of 45736
HDMI:EDID CEA mode (11) 2880x480i @ 60 Hz with pixel clock 54 MHz has a score of 45736
HDMI:EDID CEA mode (14) 1440x480p @ 60 Hz with pixel clock 54 MHz has a score of 66472
HDMI:EDID CEA mode (15) 1440x480p @ 60 Hz with pixel clock 54 MHz has a score of 66472
HDMI:EDID CEA mode (16) 1920x1080p @ 60 Hz with pixel clock 148 MHz has a score of 3898248
HDMI:EDID CEA mode (32) 1920x1080p @ 24 Hz with pixel clock 74 MHz has a score of 3124532
HDMI:EDID CEA mode (35) 2880x480p @ 60 Hz with pixel clock 108 MHz has a score of 66472
HDMI:EDID CEA mode (36) 2880x480p @ 60 Hz with pixel clock 108 MHz has a score of 66472
HDMI:EDID preferred mode remained as CEA (2) 720x480p @ 60 Hz with pixel clock 27 MHz
Not sure why the preferred mode is CEA 2 though? Any thoughts why it would show that?
Cheers
dom
Wed Apr 17, 2013 1:23 pm
@stealthdeath
From the EDID spec: VESA ENHANCED EXTENDED DISPLAY IDENTIFICATION DATA STANDARD (Defines EDID Structure Version 1, Revision 4):
The display EDID data shall be defined with the understanding that the host shall evaluate and support the timing modes in the following order:
1 The ‘Preferred Timing Mode’ as defined in BASE EDID. See Note 2.
2 Other ‘Detailed Timing Modes’ in the order listed in BASE EDID. See Note 3.
3 Any additional ‘Detailed Timing Modes’ (priority is in the order listed) in optional EXTENSION Blocks to the BASE EDID --- See Note 4.
4 Any optional 3 Byte CVT Codes (defined in optional Display Descriptors) listed in BASE EDID or an optional Extension Block. See Note 5.
5 ‘Standard Timings’ listed in BASE EDID and in optional EXTENSION Blocks. See Note 6.
6 Additional Timing Mode Information: Established Timings I, II & III, Default GTF, GTF Secondary Curve & CVT. See Note 7.
7 BASE VIDEO MODE (Default VGA). See Note 8.
And your edid contains:
Which we are supposed to interpret as 720x480p @ 60 Hz is the preferred resolution of the monitor.
Your preferred resolution is presumably [email protected]0, but that only comes third on the "preferred" list.
I believe we are doing the right thing, but your TV has a poorly defined EDID.
