HDMI audio not woking
Posted: Fri Oct 11, 2013 8:38 pm
by farmazon3000
I have setup video playing with audio perfectly working via HDMI (I used both "bare metal" video playing with omxplayer and specialized application for raspberry called Screenly for digital signage). Both worked OK.
All of the sudden audio via HDMI stopped working. Video worked OK. Panic :?
After about an hour I've switched SD cards, started hello_audio.bin both to analog and hdmi output - it worked OK.
Then started playing videos again and audio via HDMI started working.
WTF happened?
Re: suddenly HDMI audio stopped woking
Posted: Tue Oct 22, 2013 8:24 pm
by farmazon3000
the problem has occured again when I use different TV and different instance of Raspberry pi hardware
Posted: Tue Oct 22, 2013 8:34 pm
by farmazon3000
the solution is here:
http://raspberrypi.stackexchange.com/qu ... ot-working
set
hdmi_drive=2
Posted: Thu Oct 24, 2013 6:02 am
by farmazon3000
However still sometimes after reboot there's no audio via HDMI. I have to reboot again and then it works.
Really weird.
EDIT: see this http://www.raspberrypi.org/phpBB3/viewtopic.php?t=5851
