Page 1 of 2
Noobs error resizing existing fat partition
Posted: Fri Oct 11, 2013 2:04 pm
by mirojr
Hi
After great help from Davespice my raspbian download booting is now wonderfully, I am now trying to boot my Noobs download.
Problem is after formatting my SD card twice and copying over the extracted Noobs files, I get the boot screen and an error message: error resizing existing fat partition
I can close this dialogue box and see the list of OS's, but each one I select then gives a notification that I haven't enough space on my card.
Is this a common solvable issue?
Thanks.
Re: Noobs error resizing existing fat partition
Posted: Fri Oct 11, 2013 2:07 pm
by rdb
Your SD card hasnt been formatted correctly. Try following the steps given in the quick start guide.
Posted: Thu Oct 17, 2013 2:09 pm
by mirojr
Hi
Yes I did follow this quick start guide and used the formatting tool with correct options, I have done it a couple of times and still have the same issue. My sd card is branded 8gb Kingston
the raspbian os works fine, just the noobs that's a problem
Posted: Thu Oct 17, 2013 2:12 pm
by rdb
Could you provide a list of the files that you have in the FAT partition?
Posted: Sun Nov 24, 2013 6:22 am
by digable1
I'm having the exact same issue as duxbuz.
My list of files on SD card FAT partition (formatted with resize option, full overwrite, using the SDFormatter):
11/02/2013 02:21 AM 17,824 bootcode.bin
11/02/2013 02:21 AM 268 BUILD-DATA
11/02/2013 02:21 AM 2,249 INSTRUCTIONS-README.txt
11/02/2013 02:21 AM 71 recovery.cmdline
11/02/2013 02:21 AM 471,736 recovery.elf
11/02/2013 02:21 AM 2,093,824 recovery.img
11/02/2013 02:21 AM 20,579,519 recovery.rfs
11/02/2013 02:21 AM 0 RECOVERY_FILES_DO_NOT_EDIT
11/02/2013 02:21 AM 9,728 riscos-boot.bin
09/27/2013 05:41 AM <DIR> defaults
10/13/2013 07:47 AM <DIR> os
Posted: Sun Nov 24, 2013 9:43 am
by DeeJay
It sounds as though you are doing things right, and the list of files looks correct. The final answer has to be the one from @rdb Fri Oct 11, 2013 2:07 pm
One tiny detail to check:
After formatting the SD card with SDFormatter, are you 'safely-removing' the SD card from the system and re-inserting it prior to copying the files across?
Posted: Sun Nov 24, 2013 10:44 pm
by digable1
Well, I thought I was (I was trying to keep that issue in mind). However, the way you phrased the question, maybe not.
What I did:
1. Formatted
2. Copied the files.
3. Slight bugaboo here: My win7 box wouldn't let me safely eject - said another application was using it although I couldn't see what it was. So I rebooted the machine, and when the machine was off, removed the SD card.
So: I will try doing the reboot between above step 1 and 2 as well as step 3.
Posted: Sun Nov 24, 2013 11:31 pm
by digable1
No joy.
I did the steps as described in my previous post (two reboots of my box - as it would not let me eject the sd card).
And I omitted stating clearly that "FORMAT SIZE ADJUSTMENT ON" was displayed in SDFormatter each time I've tried this.
You probably already know the Error window, but just in case I wonder if the following information helps (it seems like it's acting like format size adjustment was off after all during formatting in spite of setting it to the contrary and checking what it said afterwards):
"WARNING: you are attempting to use /usr/sbin/parted to operate on (resize) a file system. /usr/sbin/parted's file system manipulation code is not as robust as what you'll find in dedicated file-system-specific packages like e2fsprogs. We recommend you to use /usr/sbin/parted only to manipulate partition tables, whever possible. Support for performing most operations on most types of file systems will be removed in an upcoming release. Error: Can't have a partition outside the disk!"
Furthermore, there is a "progress window" that indicates it's trying to re-size before this error window comes up. That progress window says "removing 2, 3, 4" before it goes away and the error window comes up.
So, since this appears to be a recent update to noobs, did something get out of sync introduced by this change?
Posted: Mon Nov 25, 2013 8:28 am
by DeeJay
The Error Window is 'generic': it is the specific error reported at the end that is of interest. In this case -
That takes us back to "@rdb: Your SD card hasnt been formatted correctly."
My suggestion to safely-eject was intended to go between steps 1 and 2 in your list.
The fact that the OS thinks a process is using the card may be relevant - perhaps this is preventing the writes to the card fully completing and leaving an unusable partition table?
I assume you are using an SD card reader slot built into the Windows machine? Is it truly SDHC compatible? Some are not. A cheap usb SD card 'dongle' might be worth a try.
The re-sizing operation is a normal part of NOOBS at first-boot.
Posted: Tue Nov 26, 2013 4:04 am
by digable1
Yup - did two reboots: Between step 1 and 2 as suggested and also at the original place.
I thought the fact it wouldn't let me eject was relevant as well. Which is why I did the full reboot in both places, as I figured that would be one way to get the OS to flush everything to the card as it was time to close it.
It is indeed a card-reader built into the laptop - but it was a high end enough machine at the time to where it should be good (2 years old). And if it didn't format, I shouldn't be able to access it for copying the files over to it without a hitch (as well as SDFormatter not noticing anything). Plus there's enough boot-strap information for the rPi to at least start up - so I was presuming enough was working to where this is strange (yes, could easily be presuming wrong).
And the SD card is the PNY SDHC P-SDHC8G10-GE (8G, class 10) - specifically called out as being good in
http://elinux.org/RPi_SD_cards if you're not on a Mac.
I guess it's time to try a CentOS 6 VM via virtual box thtat's on this machine and see if "dd" will work (or get a USB reader on a dongle).
And since I'm not the originator of this thread, there appear to be 2 of us with this issue. Yeah I know, not enough for significance.
Posted: Tue Nov 26, 2013 4:18 am
by Phill Rymer
try formatting in windows as restore defaults then format again with sd set to full size on load image and try again when ive had problems that's normally solved them it was originally suggested for flashing android but works on raspberry as well windows should safe eject doing that
Posted: Tue Nov 26, 2013 12:00 pm
by gsh
Try again, then when you get the error:
Press Ctrl-Alt-F2 and log in username: root password: raspberry
The command line to parted should be there, can you paste that?
Also do
$ parted /dev/mmcblk0
(parted) unit s
(parted) p
And paste the result (or take photos)
This should tell us if the problem is with parted or NOOBS and how we can reproduce it to fix the problem
Gordon
Posted: Tue Nov 26, 2013 12:07 pm
by RaTTuS
digable1 wrote:Well, I thought I was (I was trying to keep that issue in mind). However, the way you phrased the question, maybe not.
What I did:
1. Formatted
this is probably the problem
windows is telling you that either it is still writing to the SD card or that you have it open [both will give the error]
if you reboot or anything you are likely to fail to get a good image
wait for it to finish
or
make sure that windows does not have any explorer window open on the drive
or it may be that your SD card reader is not SDHC and only SD
Posted: Tue Nov 26, 2013 3:03 pm
by digable1
The parted invocation: "/usr/sbin/parted --script /dev/mmcblk0 resize 1 8192s 1286M"
Now for the errors:
mount: mounting /dev/mmcblk0p3 on /settings failed: No such file or directory
(you might now expect this one) mount: mounting rw on /settings failed: Invalid argument
can't find /settings in /proc/mounts
Note: /proc has mmcblk0 and mmcblk0p1 (indeed, no mmcblk0p3).
Posted: Tue Nov 26, 2013 4:54 pm
by gsh
Did you run parted?
Gordon
Posted: Thu Nov 28, 2013 7:08 am
by digable1
You mean run parted manually? Yes. Same error. Used the same invocation as listed in the debug file (reported in last email).
Posted: Thu Nov 28, 2013 9:00 am
by gsh
No I mean like a asked you in the previous post:
(parted) unit s
(parted) p
Posted: Sat Nov 30, 2013 8:10 pm
by digable1
Sorry, missed that request.
When I tried the third one, 'p', it said "Error: Can't have a partition outside the disk!" (the first two were silent).
Posted: Sun Dec 01, 2013 8:24 pm
by gsh
That's not a very useful error from parted!!!
What I'm trying to find out is the actual size of the SDCard in sectors (which isn't pre-determined). I think it's probably available somewhere in
/proc/bus/mmc/mmc???/
There are a number of bits of information there! Might be worth searching around a bit...
Gordon
Posted: Sun Dec 01, 2013 8:41 pm
by jojanonone
digable1 wrote:1. Formatted
I had the exact same problem, could not safely eject and I think a reboot is not good enough. Here's how I solved it:
- Rebooted my Win 7 with the middle choice in msconfig (Diagnostikstart in Swedish)
- Formatted my SD card
- Safely ejected, no problem now
- Copied the files
- Safe eject
- No problem when booting NOOB in the RaspberryPi
Hope this will help you as well.
Posted: Mon Jan 06, 2014 1:38 pm
by dokken
I had the same problem and finally got it working with the msconfig solution. Thanks, jojanonone.
Posted: Thu Jan 09, 2014 8:51 pm
by ndebras
I had the same problem and solved it this way :
1) The SD formatter created me a partition that occupied the whole SD card space (16Gb), so I resized it to 1.5Gb using a gparted under ubuntu linux
2) I added a new FAT32 on the remaining space
It then booted like a charm
Posted: Fri Jan 10, 2014 12:14 pm
by AndrewS
I once saw a similar error on a particular 4GB SDcard when I formatted it as FAT16 instead of FAT32. If I switched to FAT32, or if I tried using other 4GB SDcards formatted to FAT16, it always worked fine. See also
https://github.com/raspberrypi/noobs/issues/121
I haven't investigated it fully, but I
believe that the partition-check that parted is running before doing the resize operation is being overly-strict, and sometimes complaining about a partitioning layout that it thinks is invalid (even though other tools think it's okay), and then refusing to go any further
Posted: Fri Feb 07, 2014 5:17 pm
by mstarnes
I was experiencing this problem, too. Turns out my Toshiba Tecra R940 could not format my card properly but my HP 8440p could.
Posted: Tue Jun 02, 2015 7:40 pm
by worldofchris
Thanks for sharing your experience.
My son and I just had the exact same problem. We solved it with the suggestion above of using a SDHC compliant USB card reader instead of the internal reader on my olde ThinkPad X60s.
