yvonnezoe
I/O error and Logitech USB Optical Mouse error
Fri Oct 11, 2013 7:30 am
My R-Pi was OK when i first start up but after i did the initial configuration and reboot, all the I/O errors just appear endlessly. :o
The keyboard and mouse works fine though but i keep seeing
 input: Logitech USB Optical mouse as /devices/platform/bcm2708_usb/usb1/1-1/1-1.2/1-1.2:1.0/input/input X
although I am using Acer keyboard and Acer mouse. It keeps running for different inputs X. How long must I wait?
Is it because I expanded filesystem? (i am using 16Gb SD card).
Also I see error message like the following when doing the configuration.
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
    LANGUAGE = (unset),
    LC_ALL = (unset),
    LC_CTYPE = "UTF-8",
    LANG = "en_GB.UTF-8"
    are supported and installed on your system.
perl: warning: Falling back to the standard locale ("C").
locale: Cannot set LC_CTYPE to default locale: No such file or directory
locale: Cannot set LC_ALL to default locale: No such file or directory
Just started my Raspberry Pi journey >> http://yvonnezoe.wordpress.com
Davespice
Re: I/O error and Logitech USB Optical Mouse error
Fri Oct 11, 2013 12:58 pm
Hmm, I've never seen those errors before. It looks like it's complaining about the locale setting you're using.
You might want to run this command and set it again.
sudo raspi-config
Go to Internationalisation Options and set it there. The Pi will then reboot.
Also... do you still get these erros with say just the keyboard or just the mouse? I am wondering if this could also be a power consumption issue. The Pi can only supply a certain amount of current to USB devices and if they don’t get the power they need weird behaviour starts occurring.
You can check that out by going through this procedure;
http://elinux.org/R-Pi_Troubleshooting# ... r_problems
yvonnezoe
Fri Oct 11, 2013 5:17 pm
Davespice wrote:Hmm, I've never seen those errors before. It looks like it's complaining about the locale setting you're using.
sudo raspi-config
Hello! Thank you for your reply. There is no way that I can fix the locale problem now because R-Pi keep stuck at the booting part. :( I have a screenshot of it but i can't seem to attach it here. :/
 Information: The image file you tried to attach is invalid.
the Pi works fine at first. But after I'm done with all the configuration and do a reboot, it kept on loading forever...
Who is online
Users browsing this forum: klricks and 52 guests
