alex347
Re: Arch Linux - no HDMI output
Fri May 11, 2012 9:03 am
I am using Arch Linux version 29-04-2012. It seems like it boots fine, because it responds on ping command. However no output to HDMI. Haven't tried other video output. I have been using two different SD cards - Sandisk 4gb class 6 and Transcend 4gb (recommended by RS Components).
Debian, OpenELEC and Fedora don't have this problem.
theunit
Fri May 11, 2012 9:26 am
I have the same problem. Check out this thread for a solution:
http://www.raspberrypi.org/for.....reen-blank
Basically you need to delete/rename the /boot/config.txt file.
mrevergreen
Fri May 11, 2012 9:35 am
Having the same issue: can anyone explain how to access/edit/delete the config.txt file?
(Ideally from Windows)
djhuk
Sat May 26, 2012 8:05 pm
mrevergreen wrote:Having the same issue: can anyone explain how to access/edit/delete the config.txt file?
Plug in your SD card into your computer and delete the config.txt file :)
mikerr
Sun Jun 24, 2012 1:19 pm
Yep, had to do this on mine too with the latest archlinuxarm-29-04-2012 version.
I just put the SD card back on (windows) PC and deleted the config.txt file.
Put back in Pi, booted and HDMI came on fine.
