thin client LTSP
Posted: Thu Sep 26, 2013 10:41 pm
As i have mentioned in my previous posts, I am a newbie with the Pi. I am working on a big project, where I have to experiment with the Pi. So among other things, I have proposed to do a thin client with the raspberry, which I saw is included in the Berryboot pack. I installed it on the Pi, installed Edubuntu on an old netbook that I use for testing, and since I dont have a computer with 2 ethernet ports as recommended in posts I found on my research, I used an ethernet switch, and put on the raspberry, the netbook and a 3rd cable that goes to my router. At first, I couln't even get to the login screen on the raspberry pi. After many hours of searching the internet, I saw someone proposed to just connect the client and server without the internet cable. It worked and I finally saw the LTSP client login screen. I typed username and password (by the way, I am not sure if I have to put the server login info or something else) and I keep getting the message "no response from server" and it restarts. After a few hours again, I saw a post from someone with the same problem and he made it work with setting server=1.2.3.4 on a file in the sd card (cmd something, I don't remember right now), but that did nothing for me. All I want is to be able to log so I can make some screenshots for the project. Any help is much appreciated. Thanks in advance.
