I'm able to get my WiFi working using the wpa_gui...
Here's my /etc/network/interfaces:
pi@raspberrypi ~ $ more /etc/network/interfaces
auto lo
iface lo inet loopback
iface eth0 inet dhcp
allow-hotplug wlan0
auto wlan0
iface wlan0 inet manual
wpa-roam /etc/wpa_supplicant/wpa_supplicant.conf
iface default inet dhcp
pi@raspberrypi ~ $ more /etc/wpa_supplicant/wpa_supplicant.conf
update_config=1
network={
ssid="TRENDnet"
scan_ssid=1
psk="passphrase"
proto=RSN
key_mgmt=WPA-PSK
pairwise=TKIP
group=TKIP
sudo wpa_supplicant -c/etc/wpa_supplicant/wpa_supplicant.conf -iwlan0 -d
wpa_supplicant v1.0
random: Trying to read entropy from /dev/random
Initializing interface 'wlan0' conf '/etc/wpa_supplicant/wpa_supplicant.conf' driver 'default' ctrl_interface 'N/A' bridge 'N/A'
Configuration file '/etc/wpa_supplicant/wpa_supplicant.conf' -> '/etc/wpa_supplicant/wpa_supplicant.conf'
Reading configuration file '/etc/wpa_supplicant/wpa_supplicant.conf'
ctrl_interface='DIR=/var/run/wpa_supplicant GROUP=netdev'
update_config=1
Priority group 0
id=0 ssid='TRENDnet'
rfkill: Cannot open RFKILL control device
WEXT: RFKILL status not available
SIOCGIWRANGE: WE(compiled)=22 WE(source)=16 enc_capa=0xf
capabilities: key_mgmt 0xf enc 0xf flags 0x0
ioctl[SIOCSIWAP]: Operation not permitted
WEXT: Failed to clear BSSID selection on disconnect
netlink: Operstate: linkmode=1, operstate=5
wlan0: Own MAC address: 64:70:02:09:4c:e6
wpa_driver_wext_set_key: alg=0 key_idx=0 set_tx=0 seq_len=0 key_len=0
wpa_driver_wext_set_key: alg=0 key_idx=1 set_tx=0 seq_len=0 key_len=0
wpa_driver_wext_set_key: alg=0 key_idx=2 set_tx=0 seq_len=0 key_len=0
wpa_driver_wext_set_key: alg=0 key_idx=3 set_tx=0 seq_len=0 key_len=0
wpa_driver_wext_set_key: alg=0 key_idx=4 set_tx=0 seq_len=0 key_len=0
ioctl[SIOCSIWENCODEEXT]: Invalid argument
Driver did not support SIOCSIWENCODEEXT
wpa_driver_wext_set_key: alg=0 key_idx=5 set_tx=0 seq_len=0 key_len=0
wpa_driver_wext_set_countermeasures
wlan0: RSN: flushing PMKID list in the driver
wlan0: Setting scan request: 0 sec 100000 usec
WPS: Set UUID for interface wlan0
WPS: UUID based on MAC address - hexdump(len=16): f0 c9 9c 58 55 2d 5a 1a 9f 7a 56 1d 7a 8a 03 ab
EAPOL: SUPP_PAE entering state DISCONNECTED
EAPOL: Supplicant port status: Unauthorized
EAPOL: KEY_RX entering state NO_KEY_RECEIVE
EAPOL: SUPP_BE entering state INITIALIZE
EAP: EAP entering state DISABLED
Using existing control interface directory.
ctrl_interface_group=105 (from group name 'netdev')
ctrl_iface bind(PF_UNIX) failed: Address already in use
ctrl_iface exists and seems to be in use - cannot override it
Delete '/var/run/wpa_supplicant/wlan0' manually if it is not used anymore
Failed to initialize control interface 'DIR=/var/run/wpa_supplicant GROUP=netdev'.
You may have another wpa_supplicant process already running or the file was
left by an unclean termination of wpa_supplicant in which case you will need
to manually remove this file before starting wpa_supplicant again.
Failed to add interface wlan0
wlan0: No keys have been configured - skip key clearing
wlan0: State: DISCONNECTED -> DISCONNECTED
wpa_driver_wext_set_operstate: operstate 0->0 (DORMANT)
netlink: Operstate: linkmode=-1, operstate=5
EAPOL: External notification - portEnabled=0
EAPOL: External notification - portValid=0
wlan0: Cancelling scan request
wlan0: Cancelling authentication timeout
netlink: Operstate: linkmode=0, operstate=6
