wenfi
Raspberry and power usb suply
Wed Sep 18, 2013 8:54 pm
ih,
i have a power usb problem:
my configuration: raspberry, power supply AC 1A, hd 2,5" external usb self-powered, wi-pi wireless adapter.
i can connect both usb device and start raspberry as usually. but after a couple of hours raspberry became unreachable in ssh and if i power on the monitor it show a black screen. i think it's a power supply problem (wi-pi + usb hd). i read in this forum that can be some solution by means of some mods on cmdline.txt
can you tell me more so i can solve this problem and use both wi-pi and usb hd?
thanks so much in advance.
klricks
Re: Raspberry and power usb suply
Thu Sep 19, 2013 12:37 am
The external USB drive must have it's own power supply OR you must use a powered USB HUB. There is no other way to run a USB hard disk on the RPi.
There is nothing in any config files that will fix power issues... perhaps you were confusing the no display symptom?
rurwin
Thu Sep 19, 2013 9:43 am
You are almost certainly pulling too much power through the input fuse. Because you are only pulling a bit too much, the fuse takes an hour or two to trigger.
Both of the devices that you have plugged in to the USB are fairly power-hungry, especially the hard-disk. The RaspPi only has 200mA budgeted for both of them, whereas they could each expect to be able to use 500mA.
wenfi
Thu Sep 19, 2013 10:53 am
Yes, so i think i need a usb with its power supply.
thanks so much for your support, do you have some special model to tell me about?
did you yet use someone?
thanks
Oakham
Thu Sep 19, 2013 11:55 am
http://elinux.org/RPi_Powered_USB_Hubs
'Belkin Hi-Speed USB 2.0 4-Port Hub F5U234 Revision 3 2.6A Power Supply' very stable !
(I us the Brlkin to power the Pi with a "USB Hub to micro-USB Cable", which leaves the other 3 ports for WiFi, Bluetooth and Keyboard RF Sender..)
Searching is easy, most questions have been asked before !
AndrewS
Thu Sep 19, 2013 2:04 pm
wenfi
Thu Sep 19, 2013 9:13 pm
what about this?
http://www.amazon.it/dp/B00DYOQKW6
that's ok?
wenfi
Tue Oct 01, 2013 3:35 pm
hi,
i buyed this http://www.oxgadgets.com/2013/09/review ... -port.html
but the raspberry still crash randomly if is connected to internet by wi-pi module so wifi connection :(
can you please help me to understand why it happens?
thanks so much,
my best,
Giorgio
