Back Feeding Power
Posted: Thu Sep 12, 2013 5:23 pm
by ChrisMayhew
Hello
I realise this has probably been posted to death but I am getting mixed information from Googling this issue.
Basically I got a USB hub today off eBay, I plugged it into the Pi and noticed the Pi suddenly powered on without my power plug plugged in..
It seems that the powered USB hub is back feeding power into the Pi through the standard USB slots.
Is this safe? I read somewhere that it isn't because it could potentially fry the Pi?
My Pi is a Model B if that's any help.
Thanks!
Chris
Re: Back Feeding Power
Posted: Thu Sep 12, 2013 7:06 pm
by FTrevorGowen
This happens with about 50% of low-to-medium-cost hubs. As long as the hub's PSU is "of good quality" (ie. produces a clean. stable, 5V) then you're unlikely to "fry your Pi". However you're by-passing the Pi's polyfuse and over-voltage protection circuits so there is an "increased risk", but many forum members do use this "USB hub feature" (which, strictly speaking, is "against the USB specs.").
Trev.
Posted: Thu Sep 12, 2013 7:09 pm
by ChrisMayhew
FTrevorGowen wrote:This happens with about 50% of low-to-medium-cost hubs. As long as the hub's PSU is "of good quality" (ie. produces a clean. stable, 5V) then you're unlikely to "fry your Pi". However you're by-passing the Pi's polyfuse and over-voltage protection circuits so there is an "increased risk", but many forum members do use this "USB hub feature" (which, strictly speaking, is "against the USB specs.").
Trev.
Thanks for the reply.
Well I am not taking the risk, I've just ripped open the cable and cut the red cable and it's no longer powering the Pi now!
I assume I only needed to cut the red to stop all power backfeeding?
I've tried a USB keyboard and it still works
Posted: Thu Sep 12, 2013 7:18 pm
by FTrevorGowen
Fair enough. I'm not a fan of doing it either. Cutting just the red cables fine, and others have chose to do similar. As part of my testing of USB hubs I made an "Isolating and Back-power Indicating Adapter" as shown here**:
http://www.cpmspectrepi.webspace.virgin ... esChk.html .
Trev.
**towards the end of the webpage.
Posted: Thu Sep 12, 2013 8:05 pm
by ChrisMayhew
Trev.
Thanks mate, Looks like a good little device.
I'll see how the modified cable goes but it seems to be okay so far
