Takenover83
XBMC not honoring overscan settings (/boot/config.txt)?
Sun Sep 08, 2013 5:50 pm
I started my XBEAN install from scratch. Previously, my "boot/config.txt" settings were applying just fine on the old install. Now they are not being applied to XBMC. If I drop back to command line (cli) I can see the overscan settings of "/boot/config.txt" are being honored. Just not in XBMC, which makes no sense to me, seeing at the "/boot/config.txt" should apply to any app that uses the framebuffer? I have resorted to using XBMC's video calibration for now to fix the problem. Can anyone tell me what I am missing? Here is my current config.txt.
/boot/config.txt
initramfs initramfs.gz  0x00a00000
arm_freq=840
core_freq=275
gpu_mem_256=128
gpu_mem_512=128
sdram_freq=400
over_voltage=0
disable_overscan=0
disable_splash=1
overscan_left=50
overscan_right=50
overscan_top=10
overscan_bottom=10
Edit: I think I figured out why. I had to add
overscan_scale=1
More info here.
http://www.raspberrypi.org/phpBB3/viewt ... 67&t=15700
