mistakent
Ethernet doesn't fit?
Sun Sep 08, 2013 12:07 am
I have an older white ethernet cable that doesn't fit into the pi's ethernet port for some odd reason. It's a CAT5 but would that prevent it from inserting properly? The blue ethernet fits and it's a CAT5e. Thanks for any help
wirelessmonk
Re: Ethernet doesn't fit?
Sun Sep 08, 2013 1:03 am
I guess I'll be the one.
It's a standard. The cable terminations should be dimensionally identical within a fraction of a millimeter. Make sure the port on the RPi is not damaged, obstructed, and that the cables are oriented correctly.
Best of luck.
mistakent
Sun Sep 08, 2013 6:46 am
Ah ok finally was able to jam it in. Very scary work though. I thought I was going to break something..
pluggy
Sun Sep 08, 2013 4:53 pm
I'd have chucked it in the bin and used another, they aren't expensive and it isn't worth wrecking the socket for.
