pogy
OpenVPN Server stopped working
Fri Sep 06, 2013 12:42 pm
Hi all,
I am having trouble with OpenVPN server on raspbian.
At the moment I just know that the tun interface cannot be created.
Log output:
Fri Sep 6 14:05:02 2013 Linux ifconfig failed: external program exited with error status: 255
Fri Sep 6 14:05:02 2013 Exiting
Fri Sep 6 14:24:35 2013 OpenVPN 2.2.1 arm-linux-gnueabihf [SSL] [LZO2] [EPOLL] [PKCS11] [eurephia] [MH] [PF_INET6] [IPv6 payload 20110424-2 (2.2RC2)] built on Jun 15 2013
Fri Sep 6 14:24:35 2013 NOTE: your local LAN uses the extremely common subnet address 192.168.0.x or 192.168.1.x. Be aware that this might create routing conflicts if you connect to the VPN server from public locations such as internet cafes that use the same subnet.
Fri Sep 6 14:24:35 2013 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
Fri Sep 6 14:24:35 2013 Diffie-Hellman initialized with 1024 bit key
Fri Sep 6 14:24:35 2013 TLS-Auth MTU parms [ L:1574 D:138 EF:38 EB:0 ET:0 EL:0 ]
Fri Sep 6 14:24:35 2013 Socket Buffers: R=[163840->131072] S=[163840->131072]
Fri Sep 6 14:24:35 2013 Note: Cannot open TUN/TAP dev /dev/net/tun: No such device (errno=19)
Fri Sep 6 14:24:35 2013 do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
Fri Sep 6 14:24:35 2013 /sbin/ifconfig 10.8.0.1 netmask 255.255.255.0 mtu 1500 broadcast 10.8.0.255
SIOCSIFADDR: No such device
: ERROR while getting interface flags: No such device
SIOCSIFNETMASK: No such device
SIOCSIFMTU: No such device
SIOCSIFBRDADDR: No such device
Fri Sep 6 14:24:35 2013 Linux ifconfig failed: external program exited with error status: 255
Fri Sep 6 14:24:35 2013 Exiting
ifconfig:
eth0 Link encap:Ethernet HWaddr XX:XX:XX:XX:XX:XX
inet addr:192.168.1.50 Bcast:192.168.1.255 Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:18659 errors:0 dropped:25 overruns:0 frame:0
TX packets:18955 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:1405703 (1.3 MiB) TX bytes:1858179 (1.7 MiB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:722 errors:0 dropped:0 overruns:0 frame:0
TX packets:722 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:41774 (40.7 KiB) TX bytes:41774 (40.7 KiB)
When trying:
modprobe tun
ERROR: could not insert 'tun': Exec format error
Please suggest next steps in troubleshooting.
MattF
Re: OpenVPN Server stopped working
Fri Sep 06, 2013 1:22 pm
What are the outputs of:
uname -a
find /lib/modules/ -name tun.ko
find /lib/modules/`uname -r` -name tun.ko -exec file {} \;
pogy
Fri Sep 06, 2013 1:31 pm
rpi1:/dev/net# uname -a
Linux rpi1 3.6.11+ #494 PREEMPT Fri Jul 5 15:30:31 BST 2013 armv6l GNU/Linux
rpi1:/dev/net# find /lib/modules/ -name tun.ko
/lib/modules/3.6.11+/kernel/drivers/net/tun.ko
rpi1:/dev/net# find /lib/modules/`uname -r` -name tun.ko -exec file {} \;
/lib/modules/3.6.11+/kernel/drivers/net/tun.ko: ELF 32-bit LSB relocatable, ARM, version 1 (SYSV), BuildID[sha1]=0x946acac39a420253907f48915af8b40048059c6b, not stripped
rpi1:/dev/net#
fulton
Sat Sep 07, 2013 12:41 pm
I'm having the same problem, the "tun.ko" module fails to load.
$ sudo modprobe tun
$ sudo dmesg
[2048764.664901] tun: disagrees about version of symbol module_layout
It appears that at least a few modules in drivers/net are affected.
Running kernel is 3.6.11+ and raspberrypi-bootloader is 1.20130902-1
pogy
Sun Sep 08, 2013 6:42 pm
same here:
[email protected] ~ $ dmesg | grep tun
[   26.059093] tun: disagrees about version of symbol module_layout
[  183.079981] tun: disagrees about version of symbol module_layout
[50075.397769] tun: disagrees about version of symbol module_layout
[50085.045453] tun: disagrees about version of symbol module_layout
[50243.468688] tun: disagrees about version of symbol module_layout
[51262.594764] tun: disagrees about version of symbol module_layout
[51278.325233] tun: disagrees about version of symbol module_layout
[51900.135440] tun: disagrees about version of symbol module_layout
[51970.499891] tun: disagrees about version of symbol module_layout
[51980.355391] tun: disagrees about version of symbol module_layout
[52440.453929] tun: disagrees about version of symbol module_layout
[52771.155868] tun: disagrees about version of symbol module_layout
[53396.746447] tun: disagrees about version of symbol module_layout
[57186.821899] tun: disagrees about version of symbol module_layout
[60180.410326] tun: disagrees about version of symbol module_layout
[60199.265190] tun: disagrees about version of symbol module_layout
[247169.978501] tun: disagrees about version of symbol module_layout
MattF
Mon Sep 09, 2013 8:52 pm
Hmm,
This does indeed suggest there is a problem with tun.ko - a mismatch of some sort between the running kernel and the module.
I haven't been on the 3.6 branch for ages. Are you fully up to date with rpi-update?
pogy
Tue Sep 10, 2013 7:05 am
Yes, the raspberry is up to date via rpi-update.
fulton
Sun Sep 15, 2013 2:13 pm
FWIW pn my RPi the issue is now resolved after I've removed the SD card to make a backup of the system. (A regular soft boot didn't change anything.)
For the record, this is what I currently have:
$ uname -a
Linux possum 3.6.11+ #538 PREEMPT Fri Aug 30 20:42:08 BST 2013 armv6l GNU/Linux
$ dpkg -l raspberrypi-bootloader
ii  raspberrypi-bootloader   1.20130902-1      armhf             Raspberry Pi bootloader
$ sha256sum /lib/modules/3.6.11+/kernel/drivers/net/tun.ko
9a5bc26b4ff486ae57c62e15708465d9443687445eb3a850737b3cfdc8549c3f  /lib/modules/3.6.11+/kernel/drivers/net/tun.ko
pogy
Sun Sep 15, 2013 7:39 pm
I tried the same, but the issue persists.
uname -a
ii  raspberrypi-bootl 1.20130902-1  armhf         Raspberry Pi bootloader
modprobe tun
cat /var/log/openvpn
Sun Sep 15 21:17:32 2013 OpenVPN 2.2.1 arm-linux-gnueabihf [SSL] [LZO2] [EPOLL] [PKCS11] [eurephia] [MH] [PF_INET6] [IPv6 payload 20110424-2 (2.2RC2)] built on Jun 15 2013
Sun Sep 15 21:17:32 2013 NOTE: your local LAN uses the extremely common subnet address 192.168.0.x or 192.168.1.x.  Be aware that this might create routing conflicts if you connect to the VPN server from public locations such as internet cafes that use the same subnet.
Sun Sep 15 21:17:32 2013 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
Sun Sep 15 21:17:32 2013 Diffie-Hellman initialized with 1024 bit key
Sun Sep 15 21:17:32 2013 TLS-Auth MTU parms [ L:1574 D:138 EF:38 EB:0 ET:0 EL:0 ]
Sun Sep 15 21:17:32 2013 Socket Buffers: R=[163840->131072] S=[163840->131072]
Sun Sep 15 21:17:32 2013 Note: Cannot open TUN/TAP dev /dev/net/tun: No such file or directory (errno=2)
Sun Sep 15 21:17:32 2013 do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
Sun Sep 15 21:17:32 2013 /sbin/ifconfig  10.8.0.1 netmask 255.255.255.0 mtu 1500 broadcast 10.8.0.255
Sun Sep 15 21:17:32 2013 Linux ifconfig failed: external program exited with error status: 255
Sun Sep 15 21:17:32 2013 Exiting
dmesg
[ 1141.685159] tun: disagrees about version of symbol module_layout
[ 1673.383066] Loading kernel module for a network device with CAP_SYS_MODULE (deprecated).  Use CAP_NET_ADMIN and alias netdev- instead.
[ 1673.409191] Loading kernel module for a network device with CAP_SYS_MODULE (deprecated).  Use CAP_NET_ADMIN and alias netdev- instead.
[ 1673.435235] Loading kernel module for a network device with CAP_SYS_MODULE (deprecated).  Use CAP_NET_ADMIN and alias netdev- instead.
[ 1673.461092] Loading kernel module for a network device with CAP_SYS_MODULE (deprecated).  Use CAP_NET_ADMIN and alias netdev- instead.
[ 1673.486948] Loading kernel module for a network device with CAP_SYS_MODULE (deprecated).  Use CAP_NET_ADMIN and alias netdev- instead.
[ 1673.513160] Loading kernel module for a network device with CAP_SYS_MODULE (deprecated).  Use CAP_NET_ADMIN and alias netdev- instead.
[ 2668.536321] tun: disagrees about version of symbol module_layout
boombata
Wed Nov 20, 2013 10:45 am
copied back tun.ko from previous version, it now works.
Julien.
shaan_raspberrypi
Wed Dec 11, 2013 5:54 am
Hi ,
I am also having same problem with tun.ko....(/lib/modules/3.6.11+/kernel/drivers/net/tun.ko
****************Note: Cannot open TUN/TAP dev /dev/net/tun: No such device (errno=19) *****************
Could you please let me know from where did you find the old version for tun.ko ?
atmosx
Thu Dec 19, 2013 5:15 pm
Same problem here after upgrade, but here is a clear version miss-match. Theoretically re-compiling the kernel with tun/tap support would add this at kernel level avoiding headaches. Didn't try it yet but will soon and let you know.
Thu Dec 19, 2013 7:03 pm
Can you post the output from
/usr/sbin/openvpn --config ./server.conf
on your system.
I've just tried it on my system running
[email protected] /etc/openvpn # vcgencmd version
Dec  9 2013 21:24:40
Copyright (c) 2012 Broadcom
version c7215df85576f3e72f9c390db9bc2da642453b10 (clean) (release)
[email protected] /etc/openvpn # uname -a
Linux pi 3.10.24+ #610 PREEMPT Thu Dec 12 13:12:09 GMT 2013 armv6l GNU/Linux
That was installed ten days ago with sudo rpi-update.
And it worked fine. Created the tun device with no problems.
My config looks like
port 1194
proto udp
dev tun
#tun-ipv6
ca ca.crt
cert server.crt
key server.key  # This file should be kept secret
dh dh1024.pem
server 192.168.50.0 255.255.255.0
ifconfig-pool-persist ipp.txt
keepalive 10 120
comp-lzo
user openvpn
group openvpn
persist-key
persist-tun
status openvpn-status.log
verb 3
#tun-ipv6
#ifconfig-ipv6  2001:xxxx:xxxx:xxxx:a::1 2001:xxxx:xxxx:xxxx:a::2
#ifconfig-ipv6-pool 2001:xxxx:xxxx:xxxx:b::7/64
#route-ipv6 2001:xxxx:xxxx:xxxx:b::7
#push "route-ipv6 ::/0"
This is a doctor free zone.
