tom66
Re: Using with 720p display
Thu May 03, 2012 9:52 pm
I have a rather old 720p LCD TV for use with the Pi (LG 42LC46) – it"s a TV I got with bad caps and fixed, so I have no intention (or money!) to upgrade soon.
Anyway, the Pi boots fine on the TV and as expected the image is scaled (looks a little blocky) – but unfortunately it"s cropped at the edges. The TV seems to do this on all 1080p sources; I"ve only really used it with 720p, so is it possible to get the Pi to output 720p on the HDMI, or alternatively scale down the video so there"s a 30 or so pixel border around it (making it a weird resolution like 1860 x 1020)?
It does this in both console and LXDE when using the default Debian build.
Thu May 03, 2012 9:59 pm
Search the troubleshooting section for overscan, and likewise check the Wiki for more information.
“My wife said to me `...you’re not even listening`.
I thought, that’s an odd way to start a conversation.."
JeremyF
Thu May 03, 2012 10:14 pm
http://elinux.org/RPi_config.txt
Read this...and things I would try first would be:
hdmi_mode=4 (720p/60Hz)
hdmi_mode=47 (720p/120Hz)
disable_overscan=1
You can also play around with overscan_left, overscan_right, overscan_top, and of overscan_bottom with the corresponding number of pixels to skip.
{sig} Setup: Original version Raspberry Pi (B, rev1, 256MB), Dell 2001FP monitor (1600x1200), 8GB Class 4 SD Card with Raspbian and XBMC, DD-WRT wireless bridge
