error message when run rpi_update
Posted: Fri Aug 23, 2013 6:13 pm
by rjobaan
When i run below command i am getting error message? What to do?
root@raspbmc:~# sudo rpi-update
You appear to be trying to update firmware on an incompatible distribution. To force update, run the following:
sudo -E RPI_UPDATE_UNSUPPORTED=0 ./rpi-update
Re: error message when run rpi_update
Posted: Fri Aug 23, 2013 6:33 pm
by dom
rjobaan wrote:When i run below command i am getting error message? What to do?
raspbmc doesn't want rpi-update to be run. Use their own update mechanism. Ask here for more info:
http://forum.stmlabs.com/forumdisplay.php?fid=7
Posted: Fri Mar 11, 2016 8:31 pm
by rjobaan
The links is not working, which code do I need to use now I have same issue
Posted: Fri Mar 11, 2016 10:07 pm
by DougieLawson
Posted: Fri Mar 11, 2016 10:13 pm
by rjobaan
But where can I find the code I need to use?
Posted: Fri Mar 11, 2016 10:20 pm
by DougieLawson
rjobaan wrote:But where can I find the code I need to use?
Post your question on that other forum, where the folks who use and maintain OSMC hang out.
