davidjw79
4G Dongle - Alcatel L800Z - use as a modem?
Fri Aug 09, 2013 9:02 pm
I have been given a new modem dongle and I would like if possible to get it work with my pi.
It is an Alcatel OneTouch L800Z. Like most of these it first shows on a Windows machine as a USB CD, then once the software is installed it becomes an ethernet port.
Having searched I think I need usb_modeswitch to change it over in Wheezy and as such I have apt-get usb_modeswitch.
I am now stuck as I can't find the ID's it needs (or what to with them when I know what they are :) ).
The last message that widows event log has for this is
Driver Management has concluded the process to add Service usb_rndisx for Device Instance ID USB\VID_1BBB&PID_0195&MI_00\7&1BA77EA6&0&0000 with the following status: 0.
When doing a lsusb it shows as 1bbb:0195. I also see it as /dev/sda
I can see in ifconfig that therer is a usb0 and the first 3 pairs of the mac are registed to alcatel but it doesnt have the 192.168.1.1 it normally gets in windows
Any help very welcome, thanks
davidjw79
Re: 4G Dongle - Alcatel L800Z - use as a modem?
Mon Aug 12, 2013 12:32 am
Still not working but an update.
Added usb0 inet dhcp to /etc/network/interfaces
This has given usb0 an ip address of 192.168.1.x and the gateway 192.168.1.1 is ping-able.
I can also see in route : default 192.168.1.
but I still can't connect to the internet.
Suggestions welcome, thank you.
goci
Thu Apr 17, 2014 7:59 pm
Is it connected to 2 networks perhaps?
If you're ssh-ing via the ethernet port (i.e. the pi connected to another network) that network may be conflicting.
