rkp4k
Unable to create udev rules for USB NICs
Sat Jul 27, 2013 3:45 pm
I am running "Linux raspberrypi 3.6.11+ #510 PREEMPT Mon Jul 22 21:55:20 BST 2013 arm61 GNU/Linux," and I have installed multiple USB NICs (plugged into a hub). Boths NICs use the AX88772 chipset and work fine. The difficulty I am running into is that /etc/udev/rules.d/75-persistent-net-generator.rules is not being created, so the NICs are not consistently assigned to interfaces across reboots. For example, NIC #1 was assigned to eth1 and NIC#2 was assigned to eth2, but after I rebooted, they swapped.
Based on what I have read, rebooting should generate the rules file, but that has not worked for me. Any ideas of how else I can get this file created? Thanks for the information.
-Ryan
MrEngman
Re: Unable to create udev rules for USB NICs
Sat Jul 27, 2013 4:04 pm
For some reason udev configuration was modified to stop assigning names for eth and wlan when wheezey appeared. Why I don't know.
Can someone else explain why?
MrEngman
rkp4k
Sat Jul 27, 2013 4:16 pm
I think some previous versions had eth included in the device name whitelist in /lib/udev/rules.d/75-persistent-net-generator.rules. However, mine does not:
# device name whitelist
KERNEL!="ath*|msh*|ra*|sta*|ctc*|lcs*|hsi*", \
GOTO="persistent_net_generator_end"
MrEngman
Sat Jul 27, 2013 5:03 pm
rkp4k wrote:I think some previous versions had eth included in the device name whitelist in /lib/udev/rules.d/75-persistent-net-generator.rules. However, mine does not:
You're right. In some versions it looked like
KERNEL!="eth*|ath*|wlan*[0-9]|msh*|ra*|sta*|ctc*|lcs*|hsi*", \
The eth*| section was dropped from most versions originally I think then wlan*[0-9]|
I have added back the wlan*[0-9] section in some of my sd cards as I sometimes have multiple wifi adaptors connected and it makes life easier having the same names assigned on each boot.
Ryan
You could try modifying /lib/udev/rules.d/75-persistent-net-generator.rules and add in the eth*| section to see what happens.
MrEngman
Sat Jul 27, 2013 5:07 pm
You could always just manually add appropriate entries to /etc/udev/rules.d/70-persistent-net.rules instead of letting the auto-generator do it for you.
rkp4k
Sat Jul 27, 2013 9:56 pm
MrEngman, that worked as I now have entries for all of my NICs.
Thanks,
-Ryan
Onira
Sun Oct 20, 2013 6:51 pm
Confirm!
I made my own /etc/udev/rules.d/70-persistent-net.rules file and it works fine :D
Cogito ergo sum
