zanco
Smart meter reading problems
Sat Jul 20, 2013 12:11 pm
Hi All,
I have the Raspberry Pi (model B) connected to a Smart Meter P1 output. I used a ready built cable to USB.
I run the P1uitlezer.py script but it misses a lot of data many times. This script is started once every 5 minutes. I had the script modified to not only save the data to a file P1uitlezer.txt (which is used by another script to create the rrdtools graphs) to also save a P1uitlezer(date/time string).txt to review the file contents. Some of these files contain the correct data, most of them contain too less data or double lines. I will paste two examples below.
After running in this problem I started Minicom with the right settings for the serial data and had it captured to a file. After about one hour I had collected 323 measurements with totally no error. Each measurement was complete and no errors.
What could be the reason that the P1uitlezer.py gives me wrong data (run once every 5 minutes) but the minicom collecting data pushed by the meter every 10 seconds for about one hour gives no errors ?
Thanks in advance for your advice,
Kind regards,
Ben
Good P1 file:
('DSMR P1 uitlezer', '1.0')
Control-C om te stoppen
daldag 01745
piekdag 01819
dalterug 00000
piekterug 00000
afgenomen vermogen 540 W
teruggeleverd vermogen 0 W
Gas 2067927 dm3
Bad P1 file:
daldag 01745
piekdag 01819
piekterug 00000
afgenomen vermogen 420 W
daldag 01745
piekdag 01819
piekterug 00000
P1uitlezer.py with saving to file:
# DSMR P1 uitlezer
# (c) 10-2012 - GJ - gratis te kopieren en te plakken
versie = "1.0"
import sys
import serial
#Error display #
def show_error():
ft = sys.exc_info()[0]
fv = sys.exc_info()[1]
print("Fout type: %s" % ft )
print("Fout waarde: %s" % fv )
return
#Main program
print ("DSMR P1 uitlezer", versie)
print ("Control-C om te stoppen")
#Set COM port config
ser = serial.Serial()
ser.baudrate = 9600
ser.bytesize=serial.SEVENBITS
ser.parity=serial.PARITY_EVEN
ser.stopbits=serial.STOPBITS_ONE
ser.xonxoff=0
ser.rtscts=0
ser.timeout=20
ser.port="/dev/ttyUSB0"
#Open COM port
try:
ser.open()
except:
sys.exit ("Fout bij het openen van %s. Programma afgebroken." % ser.name)
#Initialize
# stack is mijn list met de 20 regeltjes.
p1_teller=0
stack=[]
while p1_teller < 20:
p1_line=''
#Read 1 line
try:
p1_raw = ser.readline()
except:
sys.exit ("Seriele poort %s kan niet gelezen worden. Programma afgebroken." % ser.name )
p1_str=str(p1_raw)
#p1_str=str(p1_raw, "utf-8")
p1_line=p1_str.strip()
stack.append(p1_line)
# als je alles wil zien moet je de volgende line uncommenten
# print (p1_line)
p1_teller = p1_teller +1
#Initialize
# stack_teller is mijn tellertje voor de 20 weer door te lopen. Waarschijnlijk mag ik die p1_teller ook gebruiken
stack_teller=0
while stack_teller < 20:
if stack[stack_teller][0:9] == "1-0:1.8.1":
print "daldag ", stack[stack_teller][10:15]
elif stack[stack_teller][0:9] == "1-0:1.8.2":
print "piekdag ", stack[stack_teller][10:15]
# Daltarief, teruggeleverd vermogen 1-0:2.8.1
elif stack[stack_teller][0:9] == "1-0:2.8.1":
print "dalterug ", stack[stack_teller][10:15]
# Piek tarief, teruggeleverd vermogen 1-0:2.8.2
elif stack[stack_teller][0:9] == "1-0:2.8.2":
print "piekterug ", stack[stack_teller][10:15]
# Huidige stroomafname: 1-0:1.7.0
elif stack[stack_teller][0:9] == "1-0:1.7.0":
print "afgenomen vermogen ", int(float(stack[stack_teller][10:17])*1000), " W"
# Huidig teruggeleverd vermogen: 1-0:1.7.0
elif stack[stack_teller][0:9] == "1-0:2.7.0":
print "teruggeleverd vermogen ", int(float(stack[stack_teller][10:17])*1000), " W"
# Gasmeter: 0-1:24.3.0
elif stack[stack_teller][0:10] == "0-1:24.3.0":
print "Gas ", int(float(stack[stack_teller+1][1:10])*1000), " dm3"
else:
pass
stack_teller = stack_teller +1
#print (stack, "\n")
#Close port and show status
try:
ser.close()
except:
sys.exit ("Oops %s. Programma afgebroken." % ser.name )
Borreltje
Re: Smart meter reading problems
Wed Oct 16, 2013 7:30 am
Hi Zanco,
did you ever resolve this issue? I am having the same problem and get it to work reliable.
If you did solve this, can you post your solutions here please?
regards, Borreltje
zanco
Wed Oct 16, 2013 8:07 pm
somehow I had the problem "solved", at least reduced to minimum holes in my graphs. Sadly after another ethernet breakdown I did reboot my Pi after which the Pi did not reboot properly. I misplaced the SD card when trying to run fsck and I actually managed to break my SD card. No recovery possible, started again from scratch.
So now I have it running but with large and lot of holes. I did change the python script to save the readout in files with date / time stamp for one day and somehow I managed to pull a conclusion out of these results. I have to think very hard what made the difference. I will update this message as soon as my brain tells me how I did fix it.
Kind regards,
Ben
zanco
Sat Oct 19, 2013 6:04 pm
I think I remember.
I suppose I did set ser.xonxoff=0 to ser.xonxoff=1
I did find two messages, one here http://stackoverflow.com/questions/1755 ... range-data and one here http://www.linuxquestions.org/questions ... 175469118/ which both had similair problems and solved it the same way.
Changed it this evening and for the last 1 hour no gaps.
Give it a try !
Kind regards,
Ben
Borreltje
Sat Oct 19, 2013 6:13 pm
Changed that setting just now, script is running, I'm gonna let it run overnight and post back first thing in the morning.
thanks for the tip.
Borreltje
Borreltje
Sun Oct 20, 2013 10:04 am
Hi, it has been running all night without a single drop-out, no more gaps in the line, thanks again for posting that solution, works great!!!
Borreltje.
