yumology
Pi boots into emergency kernel and won't boot regular
Sat Jul 20, 2013 4:32 am
I recently tried upgrading the OS on my Pi. I have tried using 2013-02-09-wheezy-raspian and also 2013-05-25-wheezy-raspian. I have tried loading the images using linux or windows. I have tried using a Patriot HC 16GB and DaneElec HC 8GB card. Whatever I try I seem to get the same problem.
The Pi boots into emergency kernel every time. And I simply want to boot it to regular.
What am I doing wrong or need to do to fix this?
No I do not have a jumper between pins 5-6.
Re: Pi boots into emergency kernel and won't boot regular
Sat Jul 20, 2013 4:46 am
This has been happening to a few people and I don't think it has been properly solved yet.
You can prevent booting into emergency kernel by adding
avoid_safe_mode=1
in the config.txt file.
To try and track down why it happens:
Is your Pi a Rev 1 or Rev 2 board?
What is the ouput of
grep Rev /proc/cpuinfo
yumology
Sat Jul 20, 2013 5:17 am
pi@raspberrypi:~$ grep Rev /proc/cpuinfo
Revision : 0002
Thanks! It totally worked to avoid safe mode. Lifesaver!
Sat Jul 20, 2013 5:58 am
yumology wrote:pi@raspberrypi:~$ grep Rev /proc/cpuinfo
Revision : 0002
So, that is saying you have an early (Revision 1) model B Pi. Is that correct?
Differences between Rev 1 and Rev 2:
Rev 2 has two large "mounting" holes in the board, one near the LEDs, one under the raspberry logo.
Rev 2 has 8 small holes for P5 next to P1 connector.
Rev 2 has 2 small holes for P6 next to RG2
Rev 1 has components marked F1 and F2 between the LEDs and the USB.
If you actually have a Rev 2 and it is being detected as Rev 1, then that is probably why it is not working right. Pin 5 on P1 is connected to a different GPIO line on the two revisions, so for Rev 1 the bootcode checks GPIO 1 and Rev 2 it checks GPIO 3. If that is wrong, it can cause it to boot in safe mode.
