lucasmun09
Usb Wifi Dongle Not working?
Wed Jul 17, 2013 4:08 am
So I bought this cheapo-kind generic wifi usb dongle. Apperantly, it uses rt2870 chipset from Ralink...... So I got it working on my Window computers but just could not on my raspberry pi.
From the directions here,http://ubunturt2870.pbworks.com/w/page/ ... /FrontPage, step 6, I should do command 'sudo make' and 'sudo make install'.
This is what I got....
pi@raspberrypi ~/Desktop/wifidriver/official driver $ sudo make
make -C tools
make[1]: Entering directory `/home/pi/Desktop/wifidriver/official driver/tools'
gcc -g bin2h.c -o bin2h
make[1]: Leaving directory `/home/pi/Desktop/wifidriver/official driver/tools'
/home/pi/Desktop/wifidriver/official driver/tools/bin2h
make: /home/pi/Desktop/wifidriver/official: Command not found
make: *** [build_tools] Error 127
pi@raspberrypi ~/Desktop/wifidriver/official driver $ sudo make install
make -C /home/pi/Desktop/wifidriver/official driver/os/linux -f Makefile.6 install
make: *** /home/pi/Desktop/wifidriver/official: No such file or directory.  Stop.
make: *** [install] Error 2
fyi, I am kinda noobie at linux...... Thanks for looking!
pichicken
Re: Usb Wifi Dongle Not working?
Wed Jul 17, 2013 5:43 pm
It seems that the make process has got problems handling the space in the name of the "official driver" folder.
Try renaming it so that it contains no spaces.
The knowledge gained from a failure is more valuable than an immediate success.
lucasmun09
Wed Jul 17, 2013 7:49 pm
pichicken wrote:It seems that the make process has got problems handling the space in the name of the "official driver" folder.
So I did what you said...... Same error, build:no such file or directory. Stop. I don't think the name is the problem......
When you do command : 'build' , what does it exactly do?
FTrevorGowen
Wed Jul 17, 2013 8:26 pm
lucasmun09 wrote: ...
Having looking at the link above it appears that the source code etc. referred to there is for i386 or amd64 m/c's (ie. not arm... which the Pi is) - hence it is quite likely that the compile etc. will fail. Just in case it can cope with the Pi's architecture you could try this:
./configure
make
and, only if the above works,
sudo make install
NB: if there's no "configure" file in the top-level directory then they're using a different "build" process to what I'm used to (eg. cmake perhaps?).
Trev.
Trev
Still running Raspbian Jessie or Stretch on some older Pi's (an A, B1, 2xB2, B+, P2B, 3xP0, P0W, 2xP3A+, P3B+, P3B, B+, and a A+) but Buster on the P4B's & P400. See: https://www.cpmspectrepi.uk/raspberry_pi/raspiidx.htm
lucasmun09
Wed Jul 17, 2013 9:46 pm
./configure
make
sudo make install
Trev.
Trev
So as you predicted, there is no configure file. From What I have researched and learned,
Maybe this the problem?
