Hi all,
I am fooling around with my Pi (model B) for some time now. It has been running debian with RTL-SDR tcp/ip server for some months, has been running XBMC for a week or two and now I am using the same Pi as smart meter reader.
What never happened before now does happen, every now and then (sometimes after 2 days, sometimes after 4 days) the Pi justs stops doing it's work. The smart meter data is being produced with the rrdtool, which graphs are being displayed by use of the apache webserver. The Pi is connectable by SSH, has no local monitor or keyboard. Suddenly the webpage with the graphs can not be reached, and the Pi can not be connected by SSH or reached by Ping anymore. Led's on the Pi are the same as when it's running normally, sometimes the network led blinks, power is on, but the unit is unreachable. After disconnecting the power supply and re-connecting the Pi comes back to live again, after which I can see on the graphs at what time it got offline.
What would be the proper (log) file to view to get a clue why the Pi is suddenly stopping it's work ? Is there a possibillity to add a (hardware) button so gently reboot the Pi making the risk of damaging the filesystem as small as possible ?
I am running the latest Pisces image, with update, upgrade and manually installed Apache and Python. If any other info is required please let me know. I understand that the fault is quite vague but I hope someone can point me into the right direction.
Any help would be greatly appreciated,
Thanks,
Ben
