amazon83
Re: Dynamode USB Wifi Dongle issues
Tue Feb 10, 2015 1:41 pm
Ghoblin wrote:
alfonder wrote:Here is the driver for kernel 3.18.6+ #753.
How to install
Ssh to your RaspberryPi and enter the following commands (better copy-paste to avoid typos):
cd /tmp
wget https://dl.dropboxusercontent.com/u/67643651/mt7601_3.18.6_753.tar.gz
sudo tar xf mt7601_3.18.6_753.tar.gz -C /
sudo depmod 3.18.6+
sudo reboot
If you want to compile the driver by yourself, you should apply the following compatibility patch https://dl.dropboxusercontent.com/u/676 ... 3.xx.patch
Besides, in the driver I built and posted above there are additional changes:
  • Stripped off debug messages
  • Added device signatures 148f:760b and 148f:761a
Thanks. It works!
I compiled it first with gcc 4.6.3 but it said Ooops on insmod. Then I recompiled with gcc 4.8.2 and it worked! I'm not completely sure about the 4.6.3 being the problem because I had already ran "make" on the sources before patching until the point of
error: incompatible types when assigning to type ‘int’ from type ‘kuid_t’
pOSFSInfo->fsuid = current_fsuid();
I made "make clean". Changed to 4.8.2 and recompiled perfectly (lots of warnings though).
Here's instructions for everybody else how to compile the driver with Rasbian 2015-01-31 (kernel 3.18.5+):
Download the base driver http://www.mediatek.com/en/downloads/mt7610u-usb/
Install and change to gcc 4.8
# be root
sudo su
# install
apt-get install gcc-4.8 g++-4.8
# change the default gcc and g++ version to 4.8
update-alternatives --config gcc
update-alternatives --config g++
Extract and apply the patch:
tar jxvf DPO_MT7601U_LinuxSTA_3.0.0.4_20130913.tar.bz2
cd DPO_MT7601U_LinuxSTA_3.0.0.4_20130913
wget https://dl.dropboxusercontent.com/u/67643651/fix_mt7601_3.xx.patch
patch -p1 < fix_mt7601_3.xx.patch
make
Then try to load the module with insmod:
insmod os/linux/mt7601Usta.ko
If you get lots of text and something about "ooops..." the driver doesn't work. You have to reboot because the driver has failed :P Otherwise the command should not output anything. Then run "lsmod" and verify that you see mt7601Usta on the list.
After that you can install the module to be automatically loaded on boot. This will copy the .ko module file to /lib/modules/3.18.5+/kernel/drivers/net/wireless/. You still probably need /etc/Wireless/RT2870STA/RT2870STA.dat file. Afonder's .tar.gz file contains that also. It's the easiest. Alfonder's compiled module also contain other patches that can be useful for somebody.
make install
After this you still need to figure out how to scan and connect to available network. For me the Raspbian's WLAN wizard doesn't see the WLAN device. I had to do it from command line:
wpa_passphrase MY_WLAN_SSID >> /etc/wpa_supplicant/my-wlan.conf
[ password123 ]
wpa_supplicant -B -D wext -i ra0 -c /etc/wpa_supplicant/my-wlan.conf
Then ask for IP address
dhclient ra0
For future reference, the patch is actually quite easy. In os/linux/rt_linux.c the lines like "pOSFSInfo->fsuid = current_fsuid()" are missing ".val" at the end. So they should be as "pOSFSInfo->fsuid = current_fsuid().val;" and so. Thanks alfonder! :)
It FIXED!!!! wao~
Ghoblin
Tue Feb 10, 2015 2:00 pm
OK. Great.
I updated my post about how to change the default gcc and g++ compilers. First time with --install and later with --config.
Remember everybody. Don't do "make install" until you've verified that the module can be loaded successfully with "insmod". That way you don't have to rescue your non-booting system because the broken driver is there.
alfonder
Tue Feb 10, 2015 8:56 pm
Ghoblin wrote: I compiled it first with gcc 4.6.3 but it said Ooops on insmod. Then I recompiled with gcc 4.8.2 and it worked! I'm not completely sure about the 4.6.3 being the problem
Ghoblin, great job of writing the detailed manual!
Of course, the problem was the compiler version. I used the official cross toolchain, which is 4.8.3. And I didn't know that the other, actually old, version of gcc is supplied on-the-board. Obviously if the kernel is compiled with gcc 4.8.x and a module is compiled with an older gcc version, it causes incompatibility.
Easy-to-patch but not that easy to find. I wonder how it happens that MediaTek hasn't adopted their driver to 3.x kernels.
To support me, register Dropbox account via invitation https://db.tt/xrV5BqTf
amazon83
Wed Feb 11, 2015 2:56 am
I wonder why Raspberry pi kernel 3.18.x the gcc don't upgrade to latest? if their kernel compile using 4.8.
Ghoblin
Wed Feb 11, 2015 8:00 am
Thanks for feedback! :D
The GCC version is a bit problematic.
I'm using rpi-source [ https://github.com/notro/rpi-source/wiki ] to download and prepare the kernel files on Raspberry itself. Rpi-source is good tool that downloads exactly the same kernel source files that the current Raspbian has been built with. However, it warns about the GCC compiler mismatch in the beginning. The default gcc for Raspbian 2015-01-31 is "gcc-4.6 (Debian 4.6.3-14+rpi1) 4.6" and the kernel has been built with "gcc version 4.8.3 20140303 (prerelease) (crosstool-NG linaro-1.13.1+bzr2650 - Linaro GCC 2014.03)" as seen from /proc/version. The 4.8 version on Raspbian repo is "gcc-4.8 (Raspbian 4.8.2-21~rpi3rpi1) 4.8.2". Note that it's indeed 4.6.3 by default, 4.8.2 on gcc-4.8 package and 4.8.3 on toolchain.
On the first time running rpi-source, you have to have the default gcc 4.6.3. You have to also specify --skip-gcc so that rpi-source doesn't care about the different gcc in use and what's been used to build the default kernel. If you run rpi-source with 4.8.2 as the default gcc, you'll end up getting message like this during the kernel preparation (make prepare?) phase:
  CC      arch/arm/kernel/asm-offsets.s
arch/arm/kernel/asm-offsets.c:53:2: error: #error Your compiler is too buggy; it is known to miscompile kernels
arch/arm/kernel/asm-offsets.c:54:2: error: #error and result in filesystem corruption and oopses.
After that rpi-source exits and the kernel files have not been prepared enough to be able to build working kernel modules.
That's why you have to first run rpi-source with the default gcc 4.6.3 with --skip-gcc parameter. After rpi-source gets all done, you have to change to gcc 4.8.2. The kernel doesn't let you compile the kernel itself, but you can compile compatible modules for it. It's bit tricky :(. It would be great if the default Raspbian gcc would compile compatible modules. Maybe gcc 4.8.3 would not complain about the kernel miscompile problem?
Of course it's not good idea to compile whole new kernels or anything like that on Raspberry device - because it's so slow - but sometimes you need to do some small stuff like compile WLAN driver module ;)
MrEngman
Wed Feb 11, 2015 10:43 am
Hi Ghoblin,
Regarding gcc-4.8.3, you might find this useful, https://github.com/raspberrypi/linux/is ... t-68550215, especially the link popcornmix posted.
MrEngman
Ghoblin
Wed Feb 11, 2015 11:43 am
Thanks for reply.
I'm not sure if the "jessie" release makes any difference. We still end up with different gcc than what has been used to build the kernel.
Currently Raspbian's repos contain these gcc versions.
[email protected] ~ $ apt-cache search gcc-4.
gcc-4.4 - GNU C compiler
gcc-4.5 - The GNU C compiler
gcc-4.6 - GNU C compiler
gcc-4.7 - GNU C compiler
gcc-4.8 - GNU C compiler
It's possible to install 4.8 by:
There is no need to edit sources.list or anything special. Maybe the repo didn't contain 4.8 at some point in time. Now the repo contains gcc-4.8. The instructions can be from the time when it wasn't possible to install it out-of-the-box.
The repo where the 4.8 comes is:
[email protected]:/home/pi# cat /etc/apt/sources.list.d/raspi.list
deb http://archive.raspberrypi.org/debian/ wheezy main
MrEngman
Wed Feb 11, 2015 1:35 pm
Ghoblin wrote:Thanks for reply.
Only gcc-4.6 was included in the standard raspbian image. I have installed gcc-4.7 and gcc-4.8. I used apt-get install gcc-4.8, using the standard release without the Jessie mod, some time back to load gcc-4.8 and it installed gcc-4.8.2 (Raspbian 4.8.2-21~rpi3rpi1). When I tried compiling the kernel using gcc 4.8.2 the compile failed. I haven't tried recently so whether it compiles ok now I don't know. Loading the latest raspbian image ,2015-01-31, and I still see only gcc-4.6 installed, not very helpful.
Using the Jessie update gcc-4.8 installed was version (Raspbian 4.8.3-13) and the kernel compiled OK, and the kernel in the raspbian image is also compiled with 4.8.3, so the same version. I don't often compile the kernel, only if I want to compile a special version for some reason, but I do it on the Pi although of course it does take time. I've even reverted to gcc-4.4 to compile stuff for adafruit images as they compiled their kernel with gcc-4.4.
Compiling the kernel on the Pi takes time, however, the new Pi B 2 may make a big difference with more memory and multiple cores. Must try it some time to see.
MrEngman
alfonder
Thu Feb 12, 2015 8:12 am
MrEngman, Ghoblin, I appreciate your discovering. And I remember that Raspberry Pi is promoted as "credit card size computer". But it is actually an embedded device. An embedded device isn't supposed to compile objects on itself. I think this is the main cause why the appropriate compiler is not included.
I can give you an example, that a certain gcc instances exist even for iPhone and Android handhelds. But nobody uses them for real projects.
The cross toolchain installing is very easy. No need in onboard native compiler.
Hope I'm convincing enough.
aalaap
Thu Feb 12, 2015 1:51 pm
I followed nearly every step on each page of this thread to no avail, till I spotted one line on the earlier page that mentioned that this doesn't work on the Raspberry Pi 2.
:oops:
I've got 3.18.6+ #754 and nope. Nothing works.
alfonder
Thu Feb 12, 2015 5:35 pm
aalaap wrote:I followed nearly every step on each page of this thread to no avail, till I spotted one line on the earlier page that mentioned that this doesn't work on the Raspberry Pi 2.
:oops:
I've already written about it. Just post here "/proc/config.gz" file from your pi2 and I will make module for you.
aalaap
Fri Feb 13, 2015 7:30 am
alfonder wrote:I've already written about it. Just post here "/proc/config.gz" file from your pi2 and I will make module for you.
Sorry for having missed that. That's awfully nice of you. Here is a link to my /proc/config.gz: https://mega.co.nz/#!48BTEbCb!j9SH290sL ... 9tCCMUFImo
FYI:
  • I've run rpi-update
  • I've done a complete apt-get update and upgrade
  • I've got gcc 4.8 installed (but my default is still 4.6)
If you could also put in some instructions on what I should do next, that'll be great!
Thanks!
demonx42
Fri Feb 13, 2015 10:44 am
Hi
I also have problem with my USB Wifi (ID: 148f:7601 Ralink Technology, Corp. MT7601U Wireless Adapter).
My uname -a return :
Linux raspberrypi 3.18.7-v7+ #755 SMP PREEMT Thu Feb 12 17:20:48 GMT 2015 armv7l GNU/Linex
(It's a Raspberry Pi 2, B)
Is that possible to make me a module ?
My "/proc/config.gz" : https://mega.co.nz/#!wQwwWLRa!Fq5J-fudK ... 2tZJ2CVmeI
Thanx !
Valvert
Fri Feb 13, 2015 12:58 pm
When I try to 'make', I have this result :
make -C tools
make[1]: Entering directory '/tmp/mt7610u_wifi_sta_v3002_dpo_20130916/tools'
gcc -g bin2h.c -o bin2h
make[1]: Leaving directory '/tmp/mt7610u_wifi_sta_v3002_dpo_20130916/tools'
/tmp/mt7610u_wifi_sta_v3002_dpo_20130916/tools/bin2h
chipset = mt7650u
chipset = mt7630u
chipset = mt7610u
cp -f os/linux/Makefile.6 /tmp/mt7610u_wifi_sta_v3002_dpo_20130916/os/linux/Makefile
make -C /lib/modules/3.18.7-v7+/build SUBDIRS=/tmp/mt7610u_wifi_sta_v3002_dpo_20130916/os/linux modules
make[1]: Entering directory '/lib/modules/3.18.7-v7+/build'
make[1]: *** No rule to make target 'modules'.  Stop.
make[1]: Leaving directory '/lib/modules/3.18.7-v7+/build'
Makefile:393: recipe for target 'LINUX' failed
make: *** [LINUX] Error 2
I don't know what to do and I don't want to wait each time I do an update/upgrade to ask someone else to recompile the driver for me :-)
TIA,
Valvert
MrEngman
Fri Feb 13, 2015 5:37 pm
Valvert wrote:Hello,
TIA,
Valvert
Make expects a link to the Linux source directory. So /lib/modules/3.18.7-v7+/build should be a symbolic link to the Linux source directory which can be made using a command something like
sudo ln -s /home/pi/src/linux /lib/modules/$(uname -r)/build
where /home/pi/src/linux would need to be changed to point to where your Linux source directory is.
I am able to generate the same error you have if I make directory /lib/modules/3.18.7-v7+/build using
sudo mkdir /lib/modules/3.18.7-v7+/build
and build directory is empty, or if I generate the symbolic link using the command sudo ln -s ... as above but then the Linux directory is empty or does not include the necessary data required for the compile.
MrEngman
alfonder
Fri Feb 13, 2015 8:29 pm
aalaap, meet the module for you.
Here is the driver for kernel 3.18.6-v7+ (for Raspberry Pi 2).
How to install
cd /tmp
wget https://dl.dropboxusercontent.com/u/67643651/mt7601_3.18.6-v7.tar.gz
sudo tar xf mt7601_3.18.6-v7.tar.gz -C /
sudo depmod 3.18.6-v7+
sudo reboot
alfonder
Fri Feb 13, 2015 8:54 pm
demonx42, meet the driver for you.
Here is the driver for kernel 3.18.7-v7+ (for Raspberry Pi 2).
How to install
cd /tmp
wget https://dl.dropboxusercontent.com/u/67643651/mt7601_3.18.7-v7.tar.gz
sudo tar xf mt7601_3.18.7-v7.tar.gz -C /
sudo depmod 3.18.7-v7+
sudo reboot
Valvert
Fri Feb 13, 2015 9:06 pm
Amazing!
alfonder you rock.
Thank you very much.
Valvert
Fri Feb 13, 2015 9:09 pm
Thank you MrEngman for your answer, I quit.
I'm not a Linux expert, I'm always getting errors.
amazon83
Fri Feb 13, 2015 11:33 pm
alfonder wrote:demonx42, meet the driver for you.
How to install
cd /tmp
sudo reboot
alfonder,can input this ID?
{USB_DEVICE(0x2717,0x4106)}, /* Xiaomi Wi
so that in future I can use yr link, I'm lazy to compile :P
aalaap
Sat Feb 14, 2015 4:39 am
How to install
cd /tmp
sudo reboot
I ended up doing a dist-upgrade, which bumped me up from v6 to v7, so I used this code instead of the one you gave specifically for me. After rebooting, I got an ra0 entry with lots of details after running iwconfig, but wpa_supplicant still wasn't able to do anything with it. Even auto ra0 didn't seem to do anything.
I swapped my Ralink for an RTL8188CUS with a friend and it works like a charm. I'm giving up on the MT7601. It's just not worth the time and effort. Even if I did get it to work eventually, one dist-upgrade or rpi-update would throw me back offline anyway.
Thank you, alfonder. Your help is very much appreciated!
alfonder
Sat Feb 14, 2015 8:44 am
amazon83 wrote: alfonder,can input this ID?
You haven't answered if the module, which was compiled for you with your ID, works (https://dl.dropboxusercontent.com/u/676 ... 601Usta.ko).
And secondly, you have Raspberry Pi or Pi 2?
alfonder
Sat Feb 14, 2015 10:12 am
aalaap wrote: I ended up doing a dist-upgrade, which bumped me up from v6 to v7,
I think you mean "from .6 to .7", because v6 and v7 are for different processors.
It should be configured according to Pi's FAQ ("/etc/wpa_supplicant/wpa_supplicant.conf: network={}" method) and not by "auto ra0" method.
Unfortunately, this is almost true, unless MediaTek GPL'ed their driver and then it included in a package. But there is a workaround. After "rpi-update" don't reboot immediately, but at first install posted here driver for the new kernel version, and only after that reboot device. Then your device will not lose connectivity.
demonx42
Sat Feb 14, 2015 11:38 am
How to install
cd /tmp
sudo reboot
Waoh ! Thanx you very much alfonder ! It work !!
I just have a little question: How do you do to "create" the Driver?
Do you have information, website, etc. ?
Thank you again !
ginner159
Sat Feb 14, 2015 12:53 pm
@Alfonda
Just a big thank you for this! please keep up the great work your doing have you sent your patches to the ras pi people so that it can be compiled into the main kernel for future updates?
so yeah big kudos to you!
