drdevil44
Re: ALSA drivers?
Fri Apr 20, 2012 12:05 pm
PS vcfiled seems to create some sort of filesystem for message parsing to the GPU and then enter an infinite loop.  It seems mandatory for GPU usage.
I"ve got the disassembly of vcfiled – although cant see a "filesystem" anywhere after execution.  It does appear to use /dev/vchiq
drdevil44
Re: ALSA drivers?
Fri Apr 20, 2012 1:08 pm
In the irq callback, shouldn't these calculations be 'floor()ed' ?
if (alsa_stream->period_size) {
if ((alsa_stream->pos / alsa_stream->period_size) !=
((alsa_stream->pos + consumed) / alsa_stream->period_size))
new_period = 1;
Otherwise if consumed places the pointer half way through the period it'll be rounded up and presumably skip the rest?
Disclaimer: I'm still getting up to scratch it all so my comment is probably invalid.
Re: ALSA drivers?
Fri Apr 20, 2012 1:13 pm
C division is floored as standard.
drdevil44
Re: ALSA drivers?
Fri Apr 20, 2012 1:21 pm
Bugger me I never knew that! In fact, I doubted your statement enough to try it out
Re: ALSA drivers?
Fri Apr 20, 2012 1:32 pm
I hope I was right in your tests.
drdevil44
Re: ALSA drivers?
Fri Apr 20, 2012 1:34 pm
12/10 = [email protected]:~# ./tst 0 10
0/10 = [email protected]:~# ./tst 7 10
7/10 = [email protected]:~# ./tst 9 10
9/10 = [email protected]:~# ./tst 11 10
11/10 = 1
Tavalin
Re: ALSA drivers?
Fri Apr 20, 2012 8:57 pm
drdevil44 said:
Use modprobe rather than insmod – I think it takes care of dependancies.
I too have output from mplayer but it stalls.
The demos in /opt/vc/src work but you first have to run
/opt/vc/sbin/vcfiled
Just trying to get OMX player to compile but its an arse!
This one seems targetted at rasp-pi – should allow high def vid playing – first to get it to compile please upload binaries
https://github.com/huceke/omxplayer
I've managed to get a bit further, the players are starting to play the files (and then stalls after 5-10seconds) but I'm not hearing any sound via the HDMI nor the headphone jack.  Is there a way to find out where the sound is being output or force it to output from a particular one?
Thanks again
dom
Re: ALSA drivers?
Fri Apr 20, 2012 10:27 pm
sudo amixer cset numid=3 x
x=0 automatic
x=1 headphones
x=2 hdmi
auotomatic will be hdmi if the EDID from HMDI says it supports audio, otherwise headphones.
cperrin88
Re: ALSA drivers?
Fri Apr 20, 2012 10:44 pm
I get sound view audiojack but not via HDMI ...
reggie
Re: ALSA drivers?
Wed May 02, 2012 8:35 pm
Hi all, I'm probably a bit late to this party but have any of you jumped onto #alsa-soc on freenode?  Last time I was there a really helpful guy called Broonie helped me with a driver issue, the guy knows his beans!!  Might be worth asking if he'll take a look over the code to see if there's anything glaringly obvious that might've been missed?
Regards,
Reggie.
Mash
Re: ALSA drivers?
Fri May 25, 2012 3:18 am
I'm having the stalling of audio issues as well. I'm using raspbian with pianobar. If I don't do anything on the pi while pianobar is playing it'll be fine. If I open another ssh session and run something it'll cause the audio to stall as well. Running top in another SSH session will usually cause the stall within it's 5th update, 'find /' will cause the stall pretty quickly. I saw these in dmesg tonight and had not seen them previously:
bcm2835 ALSA CARD CREATED!
### BCM2835 ALSA driver init OK ###
snd_bcm2835_playback_open:97 Alsa open (0)
vcos: [2057]: bcm2835_audio_write:778 bcm2835_audio_write: failed on vchi_bulk_queue_transmit (status=-1)
vcos: [2484]: bcm2835_audio_set_ctls_chan:475 bcm2835_audio_set_ctls_chan: failed on waiting for event (status=10)
Failed to set ALSA controls..
vcos: [2485]: bcm2835_audio_set_ctls_chan:475 bcm2835_audio_set_ctls_chan: failed on waiting for event (status=10)
snd_bcm2835_playback_close:167 Alsa close
vcos: [2057]: bcm2835_audio_close:702 bcm2835_audio_close: failed on waiting for event (status=10)
vcos: [2057]: vc_vchi_audio_deinit:309 vc_vchi_audio_deinit: failed to close VCHI service connection (status=1)
vcos: [2521]: bcm2835_audio_set_ctls_chan:475 bcm2835_audio_set_ctls_chan: failed on waiting for event (status=10)
vcos: [2525]: bcm2835_audio_write:778 bcm2835_audio_write: failed on vchi_bulk_queue_transmit (status=-1)
vcos: [2530]: bcm2835_audio_set_ctls_chan:475 bcm2835_audio_set_ctls_chan: failed on waiting for event (status=10)
dom
Re: ALSA drivers?
Fri May 25, 2012 8:56 am
