How to test a Pi
Posted: Tue Jul 09, 2013 8:42 am
by micksulley
I have 4 Pi's, 3 revision 1 and 1 revision 2. The old rev 1's work fine but I am havving trouble with the rev 2 crashing.
Are there any tests that I can run to test for a hardware problem with the Pi?
Is there any reason why an SD card from a rev 1 should not work in a rev 2 or vice versa?
Re: How to test a Pi
Posted: Tue Jul 09, 2013 8:47 am
by piglet
There was a firmware upgrade between release 1 and 2 to cater for the newer memory chips.
Try downloading the latest Raspbian and flashing that to your SD card.
http://www.raspberrypi.org/downloads
Posted: Tue Jul 09, 2013 8:50 am
by meltwater
piglet wrote:There was a firmware upgrade between release 1 and 2 to cater for the newer memory chips.
Note: that the updated card should work fine with the older boards.
by malakai
Different memory chips could do it. If all are Hynix and one is Samsung an older image might have a problem. http://www.raspberrypi.org/archives/3534
Posted: Tue Jul 09, 2013 10:14 am
by micksulley
I am using the latest image, downloaded a couple of days ago and installed via NOOBS.
Linux pi-f 3.6.11+ #474 PREEMPT Thu Jun 13 17:14:42 BST 2013 armv6l GNU/Linux
I am assuming that this image should work on any Pi, is that correct?
Posted: Tue Jul 09, 2013 10:17 am
by Davespice
If you think it might be a power issue you can get a multimeter and go through this procedure;
http://elinux.org/R-Pi_Troubleshooting# ... r_problems
Posted: Tue Jul 09, 2013 10:42 am
by micksulley
It is a genuine RS recomended power supply, just checked and 4.96 volts, so not a power issue it seems.
Are there any utilities for running memory tests etc?
