micksulley
How to test a Pi
Tue Jul 09, 2013 8:42 am
I have 4 Pi's, 3 revision 1 and 1 revision 2. The old rev 1's work fine but I am havving trouble with the rev 2 crashing.
Are there any tests that I can run to test for a hardware problem with the Pi?
Is there any reason why an SD card from a rev 1 should not work in a rev 2 or vice versa?
piglet
Re: How to test a Pi
Tue Jul 09, 2013 8:47 am
There was a firmware upgrade between release 1 and 2 to cater for the newer memory chips.
Try downloading the latest Raspbian and flashing that to your SD card.
http://www.raspberrypi.org/downloads
meltwater
Tue Jul 09, 2013 8:50 am
piglet wrote:There was a firmware upgrade between release 1 and 2 to cater for the newer memory chips.
Note: that the updated card should work fine with the older boards.
______________
http://www.themagpi.com/
A Magazine for Raspberry Pi Users
Read Online or Download for Free.
My new book: goo.gl/dmVtsc
Meltwater's Pi Hardware - pihardware.com
Like the MagPi? @TheMagP1 @TheMagPiTeam
malakai
Different memory chips could do it. If all are Hynix and one is Samsung an older image might have a problem. http://www.raspberrypi.org/archives/3534
http://www.raspians.com - always looking for content feel free to ask to have it posted. Or sign up and message me to become a contributor to the site. Raspians is not affiliated with the Raspberry Pi Foundation. (RPi's + You = Raspians)
micksulley
Tue Jul 09, 2013 10:14 am
I am using the latest image, downloaded a couple of days ago and installed via NOOBS.
Linux pi-f 3.6.11+ #474 PREEMPT Thu Jun 13 17:14:42 BST 2013 armv6l GNU/Linux
I am assuming that this image should work on any Pi, is that correct?
Davespice
Contact: Twitter
Tue Jul 09, 2013 10:17 am
If you think it might be a power issue you can get a multimeter and go through this procedure;
http://elinux.org/R-Pi_Troubleshooting# ... r_problems
micksulley
Tue Jul 09, 2013 10:42 am
It is a genuine RS recomended power supply, just checked and 4.96 volts, so not a power issue it seems.
Are there any utilities for running memory tests etc?
