joan
[SOLVED] Wireless no longer working - latest kernel?
Sat Jul 06, 2013 3:36 pm
My wireless connection has never been perfect on the Pi but it has been usable.
It now fails, and stays failed, after about a minute of use.
It may be related to the last one or two rpi-update firmware updates.
Currently on Linux soft 3.6.11+ #494 PREEMPT Fri Jul 5 15:30:31 BST 2013 armv6l GNU/Linux
[  468.968122] usb 1-1.2: Product: 54M.USB.......
[  468.968138] usb 1-1.2: Manufacturer: Ralink
[  469.054423] usb 1-1.2: reset high-speed USB device number 5 using dwc_otg
[  469.500221] ieee80211 phy1: Selected rate control algorithm 'minstrel_ht'
[  469.501568] Registered led device: rt73usb-phy1::radio
[  469.501701] Registered led device: rt73usb-phy1::assoc
[  469.501836] Registered led device: rt73usb-phy1::quality
[  472.518566] wlan0: authenticate with 00:26:44:08:2d:1f
[  472.564931] wlan0: send auth to 00:26:44:08:2d:1f (try 1/3)
[  472.569910] wlan0: authenticated
[  472.571282] rt73usb 1-1.2:1.0: wlan0: disabling HT as WMM/QoS is not supported
[  472.594360] wlan0: associate with 00:26:44:08:2d:1f (try 1/3)
[  472.596857] wlan0: RX AssocResp from 00:26:44:08:2d:1f (capab=0x411 status=0 aid=2)
[  472.610171] wlan0: associated
[  511.999280] ERROR::handle_hc_chhltd_intr_dma:2537: handle_hc_chhltd_intr_dma: Channel 2, DMA Mode -- ChHltd set, but reason for halting is unknown, hcint 0x00000002, intsts 0x04400001
[  511.999280]
[  515.665614] ieee80211 phy1: wlan0: No probe response from AP 00:26:44:08:2d:1f after 500ms, disconnecting.
[  515.681181] cfg80211: Calling CRDA to update world regulatory domain
I don't remember seeing the
message before.
joan
Re: Wireless no longer working - latest kernel?
Sat Jul 06, 2013 4:52 pm
I've reverted to the Jun 29, 2013 firmware and the wireless has been OK for 40 minutes. If it is a firmware problem it was probably introduced in one of the July 2nd commits.
samlu
Sat Jul 06, 2013 7:20 pm
Exactly the same error here, with an Ralink wifi dongle, and same fix (reverting the kernel) worked.
joan
Sat Jul 06, 2013 7:47 pm
It's nice to know it's not just me.
For info, if others have the same problem you can revert to the end of June firmware with
sudo rpi-update 5ea0f44b673eaa52c578fcd6480495f19cd53d97
M33P
Tue Jul 09, 2013 11:18 am
Hi.
@joan and @samlu - this is probably due to the split_fiq implementation which has made its way into the "normal" rpi-updated kernels.
- Please post the complete outputs of lsusb -v and dmesg (enclosed within
 tags)
- What are you doing with the wifi/network link at the time when it stops working? What services/applications are active on the network?
joan, in particular have you seen that specific error message at any time with previous (recent) kernels?
joan
Tue Jul 09, 2013 12:07 pm
M33P wrote: ...
I'm afraid I only look at dmesg when I have problems. My memory is that I first noticed the problem after the initial July updates. I didn't bother to check it out initially as I was happy to plug in a cable. I only looked at dmesg after the July 5th update.
joan
Tue Jul 09, 2013 12:32 pm
M33P wrote: ...
 tags)
[/quote]
dmesg
[code]
[    0.000000] Booting Linux on physical CPU 0
[    0.000000] Initializing cgroup subsys cpu
[    0.000000] Linux version 3.6.11+ ([email protected]) (gcc version 4.7.2 20120731 (prerelease) (crosstool-NG linaro-1.13.1+bzr2458 - Linaro GCC 2012.08) ) #494 PREEMPT Fri Jul 5 15:30:31 BST 2013
[    0.000000] CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
[    0.000000] Machine: BCM2708
[    0.000000] cma: CMA: reserved 16 MiB at 0d000000
[    0.000000] Memory policy: ECC disabled, Data cache writeback
[    0.000000] On node 0 totalpages: 57344
[    0.000000] free_area_init_node: node 0, pgdat c053d894, node_mem_map c05e7000
[    0.000000]   Normal zone: 448 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 56896 pages, LIFO batch:15
[    0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[    0.000000] pcpu-alloc: [0] 0
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 56896
[    0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=280 bcm2708_fb.fbheight=210 bcm2708.boardrev=0x2 bcm2708.serial=0x6bc353e smsc95xx.macaddr=B8:27:EB:BC:35:3E sdhci-bcm2708.emmc_clock_freq=100000000 vc_mem.mem_base=0xec00000 vc_mem.mem_size=0x10000000  dwc_otg.lpm_enable=0 console=ttyAMA0,115200 kgdboc=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline rootwait
[    0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[    0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[    0.000000] Memory: 224MB = 224MB total
[    0.000000] Memory: 204872k/204872k available, 24504k reserved, 0K highmem
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
[    0.000000]     vmalloc : 0xce800000 - 0xff000000   ( 776 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xce000000   ( 224 MB)
[    0.000000]     modules : 0xbf000000 - 0xc0000000   (  16 MB)
[    0.000000]       .text : 0xc0008000 - 0xc04e74d8   (4990 kB)
[    0.000000]       .init : 0xc04e8000 - 0xc0508f44   ( 132 kB)
[    0.000000]       .data : 0xc050a000 - 0xc053e0c0   ( 209 kB)
[    0.000000]        .bss : 0xc053e0e4 - 0xc05e6d18   ( 676 kB)
[    0.000000] NR_IRQS:330
[    0.000000] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 4294967ms
[    0.000000] Console: colour dummy device 80x30
[    0.000000] console [tty1] enabled
[    0.001009] Calibrating delay loop... 697.95 BogoMIPS (lpj=3489792)
[    0.060123] pid_max: default: 32768 minimum: 301
[    0.060450] Mount-cache hash table entries: 512
[    0.061200] Initializing cgroup subsys cpuacct
[    0.061255] Initializing cgroup subsys devices
[    0.061287] Initializing cgroup subsys freezer
[    0.061316] Initializing cgroup subsys blkio
[    0.061416] CPU: Testing write buffer coherency: ok
[    0.061745] hw perfevents: enabled with v6 PMU driver, 3 counters available
[    0.061897] Setting up static identity map for 0x39e578 - 0x39e5d4
[    0.063381] devtmpfs: initialized
[    0.074083] NET: Registered protocol family 16
[    0.080486] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[    0.081569] bcm2708.uart_clock = 0
[    0.082958] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
[    0.083012] hw-breakpoint: maximum watchpoint size is 4 bytes.
[    0.083049] mailbox: Broadcom VideoCore Mailbox driver
[    0.083142] bcm2708_vcio: mailbox at f200b880
[    0.083245] bcm_power: Broadcom power driver
[    0.083284] bcm_power_open() -> 0
[    0.083308] bcm_power_request(0, 8)
[    0.583996] bcm_mailbox_read -> 00000080, 0
[    0.584037] bcm_power_request -> 0
[    0.584063] Serial: AMBA PL011 UART driver
[    0.584204] dev:f1: ttyAMA0 at MMIO 0x20201000 (irq = 83) is a PL011 rev3
[    0.907593] console [ttyAMA0] enabled
[    0.931424] bio: create slab <bio-0> at 0
[    0.936303] SCSI subsystem initialized
[    0.940387] usbcore: registered new interface driver usbfs
[    0.945971] usbcore: registered new interface driver hub
[    0.951563] usbcore: registered new device driver usb
[    0.957907] Switching to clocksource stc
[    0.962144] FS-Cache: Loaded
[    0.965280] CacheFiles: Loaded
[    0.980166] NET: Registered protocol family 2
[    0.985456] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[    0.992806] TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
[    0.999387] TCP: Hash tables configured (established 8192 bind 8192)
[    1.005818] TCP: reno registered
[    1.009071] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    1.014967] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    1.021513] NET: Registered protocol family 1
[    1.026431] RPC: Registered named UNIX socket transport module.
[    1.032472] RPC: Registered udp transport module.
[    1.037193] RPC: Registered tcp transport module.
[    1.041906] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.049043] bcm2708_dma: DMA manager at f2007000
[    1.053831] bcm2708_gpio: bcm2708_gpio_probe c0517d98
[    1.059295] vc-mem: phys_addr:0x00000000 mem_base=0x0ec00000 mem_size:0x10000000(256 MiB)
[    1.068438] audit: initializing netlink socket (disabled)
[    1.074028] type=2000 audit(0.930:1): initialized
[    1.196212] VFS: Disk quotas dquot_6.5.2
[    1.200246] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    1.207309] FS-Cache: Netfs 'nfs' registered for caching
[    1.213064] NFS: Registering the id_resolver key type
[    1.218223] Key type id_resolver registered
[    1.222514] Key type id_legacy registered
[    1.226879] msgmni has been set to 432
[    1.232447] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[    1.240136] io scheduler noop registered
[    1.244172] io scheduler deadline registered (default)
[    1.249357] io scheduler cfq registered
[    1.263772] Console: switching to colour frame buffer device 35x26
[    1.271637] kgdb: Registered I/O driver kgdboc.
[    1.277502] vc-cma: Videocore CMA driver
[    1.282160] vc-cma: vc_cma_base      = 0x00000000
[    1.287533] vc-cma: vc_cma_size      = 0x00000000 (0 MiB)
[    1.293683] vc-cma: vc_cma_initial   = 0x00000000 (0 MiB)
[    1.308649] brd: module loaded
[    1.317010] loop: module loaded
[    1.320942] vchiq: vchiq_init_state: slot_zero = 0xcd000000, is_master = 0
[    1.329673] Loading iSCSI transport class v2.0-870.
[    1.336351] usbcore: registered new interface driver smsc95xx
[    1.343218] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    1.554903] Core Release: 2.80a
[    1.558469] Setting default values for core params
[    1.564088] Finished setting default values for core params
[    1.775468] Using Buffer DMA mode
[    1.779550] Periodic Transfer Interrupt Enhancement - disabled
[    1.786164] Multiprocessor Interrupt Enhancement - disabled
[    1.792518] OTG VER PARAM: 0, OTG VER FLAG: 0
[    1.797624] Dedicated Tx FIFOs mode
[    1.802783] dwc_otg: Microframe scheduler enabled
[    1.803160] dwc_otg bcm2708_usb: DWC OTG Controller
[    1.808916] dwc_otg bcm2708_usb: new USB bus registered, assigned bus number 1
[    1.817419] dwc_otg bcm2708_usb: irq 32, io mem 0x00000000
[    1.823781] Init: Port Power? op_state=1
[    1.828463] Init: Power Port (0)
[    1.832213] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    1.840135] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.848497] usb usb1: Product: DWC OTG Controller
[    1.854057] usb usb1: Manufacturer: Linux 3.6.11+ dwc_otg_hcd
[    1.860575] usb usb1: SerialNumber: bcm2708_usb
[    1.866651] hub 1-0:1.0: USB hub found
[    1.871231] hub 1-0:1.0: 1 port detected
[    1.876309] dwc_otg: FIQ enabled
[    1.876327] dwc_otg: NAK holdoff enabled
[    1.876334] dwc_otg: FIQ split fix enabled
[    1.876353] Module dwc_common_port init
[    1.876574] Initializing USB Mass Storage driver...
[    1.882554] usbcore: registered new interface driver usb-storage
[    1.889366] USB Mass Storage support registered.
[    1.894937] usbcore: registered new interface driver libusual
[    1.901749] mousedev: PS/2 mouse device common for all mice
[    1.908876] bcm2835-cpufreq: min=700000 max=700000 cur=700000
[    1.915571] bcm2835-cpufreq: switching to governor powersave
[    1.922035] bcm2835-cpufreq: switching to governor powersave
[    1.928459] cpuidle: using governor ladder
[    1.933317] cpuidle: using governor menu
[    1.938076] sdhci: Secure Digital Host Controller Interface driver
[    1.945051] sdhci: Copyright(c) Pierre Ossman
[    1.950252] sdhci: Enable low-latency mode
[    1.992194] mmc0: SDHCI controller on BCM2708_Arasan [platform] using platform's DMA
[    2.001188] mmc0: BCM2708 SDHC host at 0x20300000 DMA 2 IRQ 77
[    2.008030] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.020246] usbcore: registered new interface driver usbhid
[    2.028815] usbhid: USB HID core driver
[    2.036169] TCP: cubic registered
[    2.042409] Initializing XFRM netlink socket
[    2.049613] NET: Registered protocol family 17
[    2.057205] Key type dns_resolver registered
[    2.066032] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
[    2.075205] Indeed it is in host mode hprt0 = 00021501
[    2.082036] registered taskstats version 1
[    2.092820] Waiting for root device /dev/mmcblk0p2...
[    2.124210] mmc0: read SD Status register (SSR) after 2 attempts
[    2.143985] mmc0: new high speed SDHC card at address 0002
[    2.162250] mmcblk0: mmc0:0002 N/A   3.75 GiB
[    2.168980]  mmcblk0: p1 p2
[    2.236980] EXT4-fs (mmcblk0p2): warning: mounting fs with errors, running e2fsck is recommended
[    2.252631] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    2.261933] VFS: Mounted root (ext4 filesystem) on device 179:2.
[    2.281724] devtmpfs: mounted
[    2.285622] Freeing init memory: 128K
[    2.302066] usb 1-1: new high-speed USB device number 2 using dwc_otg
[    2.310964] Indeed it is in host mode hprt0 = 00001101
[    2.512666] usb 1-1: New USB device found, idVendor=0424, idProduct=9512
[    2.522126] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    2.533365] hub 1-1:1.0: USB hub found
[    2.538188] hub 1-1:1.0: 3 ports detected
[    2.822354] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[    2.952758] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[    2.961182] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    2.973092] smsc95xx v1.0.4
[    3.036956] smsc95xx 1-1.1:1.0: eth0: register 'smsc95xx' at usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:bc:35:3e
[    3.152286] usb 1-1.2: new high-speed USB device number 4 using dwc_otg
[    3.406388] usb 1-1.2: New USB device found, idVendor=148f, idProduct=2573
[    3.421844] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    3.442103] usb 1-1.2: Product: 54M.USB.......
[    3.447404] usb 1-1.2: Manufacturer: Ralink
[    3.865788] udevd[150]: starting version 175
[    5.130507] Registered led device: led0
[    5.415857] cfg80211: Calling CRDA to update world regulatory domain
[    6.032301] usb 1-1.2: reset high-speed USB device number 4 using dwc_otg
[    6.563508] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[    6.564725] Registered led device: rt73usb-phy0::radio
[    6.564872] Registered led device: rt73usb-phy0::assoc
[    6.565000] Registered led device: rt73usb-phy0::quality
[    6.567363] usbcore: registered new interface driver rt73usb
[   17.245081] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[   17.822164] fuse init (API version 7.20)
[   18.152478] bcm2708_i2c bcm2708_i2c.0: BSC0 Controller at 0x20205000 (irq 79) (baudrate 100k)
[   18.165893] bcm2708_i2c bcm2708_i2c.1: BSC1 Controller at 0x20804000 (irq 79) (baudrate 100k)
[   18.287663] i2c /dev entries driver
[   29.342488] smsc95xx 1-1.1:1.0: eth0: link up, 100Mbps, full-duplex, lpa 0x4DE1
[   29.356352] smsc95xx 1-1.1:1.0: eth0: link down
[   30.825765] wlan0: authenticate with 00:26:44:08:2d:1f
[   30.881367] wlan0: send auth to 00:26:44:08:2d:1f (try 1/3)
[   30.883517] wlan0: authenticated
[   30.884371] rt73usb 1-1.2:1.0: wlan0: disabling HT as WMM/QoS is not supported
[   30.912110] wlan0: associate with 00:26:44:08:2d:1f (try 1/3)
[   30.914731] wlan0: RX AssocResp from 00:26:44:08:2d:1f (capab=0x411 status=0 aid=2)
[   30.930991] wlan0: associated
[   30.940820] smsc95xx 1-1.1:1.0: eth0: link up, 100Mbps, full-duplex, lpa 0x4DE1
[  281.790644] smsc95xx 1-1.1:1.0: eth0: link down
[  302.709941] EXT4-fs (mmcblk0p2): error count: 2
[  302.709972] EXT4-fs (mmcblk0p2): initial error at 1369404309: ext4_put_super:819
[  302.709992] EXT4-fs (mmcblk0p2): last error at 1369404309: ext4_put_super:819
[  303.436210] ERROR::handle_hc_chhltd_intr_dma:2537: handle_hc_chhltd_intr_dma: Channel 5, DMA Mode -- ChHltd set, but reason for halting is unknown, hcint 0x00000002, intsts 0x04400001
[  303.436210]
[  306.650114] ieee80211 phy0: wlan0: No probe response from AP 00:26:44:08:2d:1f after 500ms, disconnecting.
[  306.665752] cfg80211: Calling CRDA to update world regulatory domain
[  369.679196] smsc95xx 1-1.1:1.0: eth0: link up, 100Mbps, full-duplex, lpa 0x4DE1
[  369.690234] smsc95xx 1-1.1:1.0: eth0: link down
[  371.271928] smsc95xx 1-1.1:1.0: eth0: link up, 100Mbps, full-duplex, lpa 0x4DE1
lsusb
Bus 001 Device 002: ID 0424:9512 Standard Microsystems Corp. LAN9500 Ethernet 10/100 Adapter / SMSC9512/9514 Hub
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bDeviceSubClass         0 Unused
  bDeviceProtocol         2 TT per port
  bMaxPacketSize0        64
  idVendor           0x0424 Standard Microsystems Corp.
  idProduct          0x9512 LAN9500 Ethernet 10/100 Adapter / SMSC9512/9514 Hub
  bcdDevice            2.00
  iManufacturer           0
  iProduct                0
  iSerial                 0
  bNumConfigurations      1
  Configuration Descriptor:
    bLength                 9
    bDescriptorType         2
    wTotalLength           41
    bNumInterfaces          1
    bConfigurationValue     1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                2mA
    Interface Descriptor:
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceClass         9 Hub
      bInterfaceSubClass      0 Unused
      bInterfaceProtocol      1 Single TT
      iInterface              0
      Endpoint Descriptor:
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x81  EP 1 IN
        bmAttributes            3
          Transfer Type            Interrupt
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0001  1x 1 bytes
        bInterval              12
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       1
      bNumEndpoints           1
      bInterfaceProtocol      2 TT per port
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bDeviceProtocol         1 Single TT
  bMaxPacketSize0        64
  idVendor           0x1d6b Linux Foundation
  idProduct          0x0002 2.0 root hub
  bcdDevice            3.06
  iManufacturer           3
  iProduct                2
  iSerial                 1
    bLength                 9
    bDescriptorType         2
    wTotalLength           25
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                0mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceProtocol      0 Full speed (or root) hub
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0004  1x 4 bytes
        bInterval              12
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass          255 Vendor Specific Class
  bDeviceSubClass         0
  bDeviceProtocol         1
  bMaxPacketSize0        64
  idProduct          0xec00 SMSC9512/9514 Fast Ethernet Adapter
  bcdDevice            2.00
  iManufacturer           0
  iProduct                0
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength           39
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                2mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           3
      bInterfaceClass       255 Vendor Specific Class
      bInterfaceProtocol    255
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0200  1x 512 bytes
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x02  EP 2 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x83  EP 3 IN
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0010  1x 16 bytes
        bInterval               4
Bus 001 Device 004: ID 148f:2573 Ralink Technology, Corp. RT2501/RT2573 Wireless Adapter
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            0 (Defined at Interface level)
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0        64
  idVendor           0x148f Ralink Technology, Corp.
  idProduct          0x2573 RT2501/RT2573 Wireless Adapter
  bcdDevice            0.01
  iManufacturer           1
  iProduct                2
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength           32
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0x80
      (Bus Powered)
    MaxPower              300mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           2
      bInterfaceSubClass    255 Vendor Specific Subclass
      bInterfaceProtocol    255 Vendor Specific Protocol
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x01  EP 1 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
Usage would be one or two ssh sessions and perhaps a remote ping.
Davespice
Contact: Twitter
Tue Jul 09, 2013 12:50 pm
I've also been having problems in this area. I'll check my syslog later tonight to see if I get the same messages.
madko
Sat Jul 13, 2013 10:42 am
same problem here with firmware version ca0aa2db225d02577fc02e3c576fd2ae9975133b
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Linux version 3.6.11-13-ARCH+ ([email protected]) (gcc version 4.7.2 (GCC) ) #1 PREEMPT Sun Jul 7 12:05:39 CDT 2013
[    0.000000] early_vc_cma_mem(0/[email protected])
[    0.000000]  -> initial 0, size 11800000, base d400000
[    0.000000] cma: CMA: reserved 280 MiB at 0d400000
[    0.000000] cma: CMA: reserved 16 MiB at 0b400000
[    0.000000] On node 0 totalpages: 121856
[    0.000000] free_area_init_node: node 0, pgdat c07dbd08, node_mem_map c08b5000
[    0.000000]   Normal zone: 984 pages used for memmap
[    0.000000]   Normal zone: 120872 pages, LIFO batch:31
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 120872
[    0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708.boardrev=0xf bcm2708.serial=0x497d22b5 smsc95xx.macaddr=B8:27:EB:7D:22:B5 sdhci-bcm2708.emmc_clock_freq=100000000 vc-cma-mem=0/[email protected] [email protected] [email protected] vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000  ipv6.disable=1 selinux=0 plymouth.enable=0 smsc95xx.turbo_mode=N dwc_otg.lpm_enable=0 console=ttyAMA0,115200 kgdboc=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p5 rootfstype=ext4 elevator=noop rootwait
[    0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.000000] allocated 1007616 bytes of page_cgroup
[    0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[    0.000000] Memory: 196MB 280MB = 476MB total
[    0.000000] Memory: 169568k/169568k available, 317856k reserved, 0K highmem
    vmalloc : 0xdf000000 - 0xff000000   ( 512 MB)
    lowmem  : 0xc0000000 - 0xdec00000   ( 492 MB)
      .text : 0xc0008000 - 0xc076559c   (7542 kB)
      .init : 0xc0766000 - 0xc0791384   ( 173 kB)
      .data : 0xc0792000 - 0xc07df310   ( 309 kB)
       .bss : 0xc07df334 - 0xc08b4a14   ( 854 kB)
[    0.000427] Calibrating delay loop... 697.95 BogoMIPS (lpj=3489792)
[    0.060120] pid_max: default: 32768 minimum: 301
[    0.060240] Security Framework initialized
[    0.060282] AppArmor: AppArmor disabled by boot time parameter
[    0.060520] Mount-cache hash table entries: 512
[    0.061351] Initializing cgroup subsys cpuacct
[    0.061380] Initializing cgroup subsys memory
[    0.061438] Initializing cgroup subsys devices
[    0.061454] Initializing cgroup subsys freezer
[    0.061467] Initializing cgroup subsys blkio
[    0.061477] Initializing cgroup subsys perf_event
[    0.061504] Initializing cgroup subsys net_prio
[    0.061606] CPU: Testing write buffer coherency: ok
[    0.061944] hw perfevents: enabled with v6 PMU driver, 3 counters available
[    0.062052] Setting up static identity map for 0x565078 - 0x5650d4
[    0.064238] devtmpfs: initialized
[    0.073754] xor: measuring software checksum speed
[    0.170299]    arm4regs  :   974.400 MB/sec
[    0.270337]    8regs     :   471.200 MB/sec
[    0.370395]    32regs    :   433.600 MB/sec
[    0.370412] xor: using function: arm4regs (974.400 MB/sec)
[    0.405175] NET: Registered protocol family 16
[    0.411893] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[    0.413386] bcm2708.uart_clock = 0
[    0.414882] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
[    0.414903] hw-breakpoint: maximum watchpoint size is 4 bytes.
[    0.414916] mailbox: Broadcom VideoCore Mailbox driver
[    0.415014] bcm2708_vcio: mailbox at f200b880
[    0.415101] bcm_power: Broadcom power driver
[    0.415118] bcm_power_open() -> 0
[    0.415128] bcm_power_request(0, 8)
[    0.915803] bcm_mailbox_read -> 00000080, 0
[    0.915819] bcm_power_request -> 0
[    0.915829] Serial: AMBA PL011 UART driver
[    0.915965] dev:f1: ttyAMA0 at MMIO 0x20201000 (irq = 83) is a PL011 rev3
[    0.916293] console [ttyAMA0] enabled
[    0.939497] bio: create slab <bio-0> at 0
[    1.102318] raid6: int32x1     46 MB/s
[    1.271694] raid6: int32x2     61 MB/s
[    1.442334] raid6: int32x4     64 MB/s
[    1.612416] raid6: int32x8     58 MB/s
[    1.612435] raid6: using algorithm int32x4 (64 MB/s)
[    1.612447] raid6: using intx1 recovery algorithm
[    1.613107] SCSI subsystem initialized
[    1.613348] usbcore: registered new interface driver usbfs
[    1.613438] usbcore: registered new interface driver hub
[    1.613733] usbcore: registered new device driver usb
[    1.616202] Switching to clocksource stc
[    1.646212] FS-Cache: Loaded
[    1.646616] CacheFiles: Loaded
[    1.660247] NET: Registered protocol family 2
[    1.661140] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[    1.661582] TCP bind hash table entries: 16384 (order: 4, 65536 bytes)
[    1.661839] TCP: Hash tables configured (established 16384 bind 16384)
[    1.661886] TCP: reno registered
[    1.661909] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    1.661939] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    1.662260] NET: Registered protocol family 1
[    1.662849] RPC: Registered named UNIX socket transport module.
[    1.662874] RPC: Registered udp transport module.
[    1.662885] RPC: Registered tcp transport module.
[    1.662895] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.664124] bcm2708_dma: DMA manager at f2007000
[    1.664240] bcm2708_gpio: bcm2708_gpio_probe c07a0118
[    1.664676] vc-mem: phys_addr:0x00000000 mem_base=0x1ec00000 mem_size:0x20000000(512 MiB)
[    1.665714] audit: initializing netlink socket (disabled)
[    1.665793] type=2000 audit(1.650:1): initialized
[    1.828187] VFS: Disk quotas dquot_6.5.2
[    1.828289] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    1.828769] FS-Cache: Netfs 'nfs' registered for caching
[    1.829169] NFS: Registering the id_resolver key type
[    1.829276] Key type id_resolver registered
[    1.829293] Key type id_legacy registered
[    1.829689] JFS: nTxBlock = 3692, nTxLock = 29542
[    1.831603] SGI XFS with ACLs, security attributes, realtime, large block/inode numbers, no debug enabled
[    1.832443] msgmni has been set to 923
[    1.834414] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[    1.834719] io scheduler noop registered (default)
[    1.834742] io scheduler deadline registered
[    1.834788] io scheduler cfq registered
[    1.850201] Console: switching to colour frame buffer device 82x26
[    1.852710] kgdb: Registered I/O driver kgdboc.
[    1.853411] vc-cma: Videocore CMA driver
[    1.853433] vc-cma: vc_cma_base      = 0x0d400000
[    1.853445] vc-cma: vc_cma_size      = 0x11800000 (280 MiB)
[    1.853455] vc-cma: vc_cma_initial   = 0x00000000 (0 MiB)
[    1.863253] brd: module loaded
[    1.868788] loop: module loaded
[    1.869181] vchiq: vchiq_init_state: slot_zero = 0xcd400000, is_master = 0
[    1.869999] vchiq_get_state: g_state.remote->initialised != 1 (0)
[    1.870537] vchiq_get_state: g_state.remote->initialised != 1 (0)
[    1.871066] vchiq: vchiq_initialise: videocore initialized after 2 retries
[    1.879140] Loading iSCSI transport class v2.0-870.
[    1.881419] usbcore: registered new interface driver smsc95xx
[    1.881579] usbcore: registered new interface driver cdc_ncm
[    1.881599] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    2.086720] Core Release: 2.80a
[    2.086748] Setting default values for core params
[    2.086791] Finished setting default values for core params
[    2.291930] Using Buffer DMA mode
[    2.291956] Periodic Transfer Interrupt Enhancement - disabled
[    2.291968] Multiprocessor Interrupt Enhancement - disabled
[    2.291980] OTG VER PARAM: 0, OTG VER FLAG: 0
[    2.291996] Dedicated Tx FIFOs mode
[    2.293011] dwc_otg: Microframe scheduler enabled
[    2.293438] dwc_otg bcm2708_usb: DWC OTG Controller
[    2.293508] dwc_otg bcm2708_usb: new USB bus registered, assigned bus number 1
[    2.293577] dwc_otg bcm2708_usb: irq 32, io mem 0x00000000
[    2.293650] Init: Port Power? op_state=1
[    2.293661] Init: Power Port (0)
[    2.293826] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    2.293852] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.293869] usb usb1: Product: DWC OTG Controller
[    2.293885] usb usb1: Manufacturer: Linux 3.6.11-13-ARCH+ dwc_otg_hcd
[    2.293899] usb usb1: SerialNumber: bcm2708_usb
[    2.294708] hub 1-0:1.0: USB hub found
[    2.294756] hub 1-0:1.0: 1 port detected
[    2.295078] dwc_otg: FIQ enabled
[    2.295094] dwc_otg: NAK holdoff enabled
[    2.295103] dwc_otg: FIQ split fix enabled
[    2.295122] Module dwc_common_port init
[    2.295375] Initializing USB Mass Storage driver...
[    2.295579] usbcore: registered new interface driver usb-storage
[    2.295593] USB Mass Storage support registered.
[    2.295730] usbcore: registered new interface driver libusual
[    2.296122] mousedev: PS/2 mouse device common for all mice
[    2.297149] usbcore: registered new interface driver iforce
[    2.298882] md: linear personality registered for level -1
[    2.298906] md: raid0 personality registered for level 0
[    2.298917] md: raid1 personality registered for level 1
[    2.298927] md: raid10 personality registered for level 10
[    2.298937] md: raid6 personality registered for level 6
[    2.298946] md: raid5 personality registered for level 5
[    2.298955] md: raid4 personality registered for level 4
[    2.298964] md: multipath personality registered for level -4
[    2.298974] md: faulty personality registered for level -5
[    2.299034] device-mapper: uevent: version 1.0.3
[    2.299377] device-mapper: ioctl: 4.23.0-ioctl (2012-07-25) initialised: [email protected]
[    2.299797] device-mapper: multipath: version 1.5.0 loaded
[    2.299822] device-mapper: multipath round-robin: version 1.0.0 loaded
[    2.299838] device-mapper: multipath queue-length: version 0.1.0 loaded
[    2.299850] device-mapper: multipath service-time: version 0.2.0 loaded
[    2.300122] bcm2835-cpufreq: min=700000 max=700000 cur=700000
[    2.300229] bcm2835-cpufreq: switching to governor ondemand
[    2.300246] bcm2835-cpufreq: switching to governor ondemand
[    2.300329] cpuidle: using governor ladder
[    2.300344] cpuidle: using governor menu
[    2.300419] sdhci: Secure Digital Host Controller Interface driver
[    2.300432] sdhci: Copyright(c) Pierre Ossman
[    2.300555] sdhci: Enable low-latency mode
[    2.346500] mmc0: SDHCI controller on BCM2708_Arasan [platform] using platform's DMA
[    2.346570] mmc0: BCM2708 SDHC host at 0x20300000 DMA 2 IRQ 77
[    2.346661] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.347263] usbcore: registered new interface driver usbhid
[    2.347282] usbhid: USB HID core driver
[    2.347296] zram: num_devices not specified. Using default: 1
[    2.347306] zram: Creating 1 devices ...
[    2.348589] TCP: cubic registered
[    2.348615] Initializing XFRM netlink socket
[    2.348654] NET: Registered protocol family 17
[    2.348837] Key type dns_resolver registered
[    2.349542] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
[    2.355907] registered taskstats version 1
[    2.363504] md: Waiting for all devices to be available before autodetect
[    2.363530] md: If you don't use raid, use raid=noautodetect
[    2.368925] md: Autodetecting RAID arrays.
[    2.370106] md: Scanned 0 and added 0 devices.
[    2.370121] md: autorun ...
[    2.370129] md: ... autorun DONE.
[    2.372745] Waiting for root device /dev/mmcblk0p5...
[    2.420229] mmc0: new high speed SDHC card at address e624
[    2.420895] mmcblk0: mmc0:e624 SU04G 3.69 GiB
[    2.425712]  mmcblk0: p1 p2 < p5 >
[    2.486452] Indeed it is in host mode hprt0 = 00021501
[    2.509626] EXT4-fs (mmcblk0p5): mounted filesystem with ordered data mode. Opts: (null)
[    2.509719] VFS: Mounted root (ext4 filesystem) on device 179:5.
[    2.517843] devtmpfs: mounted
[    2.518442] Freeing init memory: 172K
[    2.666421] usb 1-1: new high-speed USB device number 2 using dwc_otg
[    2.666714] Indeed it is in host mode hprt0 = 00001101
[    2.867221] usb 1-1: New USB device found, idVendor=0424, idProduct=9512
[    2.867257] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    2.868441] hub 1-1:1.0: USB hub found
[    2.868640] hub 1-1:1.0: 3 ports detected
[    2.893182] systemd[1]: systemd 204 running in system mode. (+PAM -LIBWRAP -AUDIT -SELINUX -IMA -SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ)
[    3.000703] IPv6: Loaded, but administratively disabled, reboot required to enable
[    3.001479] systemd[1]: Inserted module 'ipv6'
[    3.003839] systemd[1]: Set hostname to <pi>.
[    3.146646] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[    3.247102] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[    3.247136] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    3.250178] smsc95xx v1.0.4
[    3.313184] smsc95xx 1-1.1:1.0: eth0: register 'smsc95xx' at usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:7d:22:b5
[    3.358089] systemd[1]: Cannot add dependency job for unit display-manager.service, ignoring: Unit display-manager.service failed to load: No such file or directory. See system logs and 'systemctl status display-manager.service' for details.
[    3.368912] systemd[1]: Starting Replay Read-Ahead Data...
[    3.374391] systemd[1]: Starting Collect Read-Ahead Data...
[    3.396082] systemd-readahead[57]: Bumped block_nr parameter of 179:0 to 20480. This is a temporary hack and should be removed one day.
[    3.398336] systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
[    3.399533] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    3.399855] systemd[1]: Expecting device dev-ttyAMA0.device...
[    3.400640] systemd[1]: Expecting device sys-subsystem-net-devices-wlan0-BZH.device...
[    3.401454] systemd[1]: Expecting device sys-subsystem-net-devices-wlan0.device...
[    3.402268] systemd[1]: Starting Syslog Socket.
[    3.403490] systemd[1]: Listening on Syslog Socket.
[    3.403759] systemd[1]: Starting Remote File Systems.
[    3.404551] systemd[1]: Reached target Remote File Systems.
[    3.404743] systemd[1]: Expecting device sys-subsystem-net-devices-eth0.device...
[    3.405498] systemd[1]: Starting Device-mapper event daemon FIFOs.
[    3.406628] usb 1-1.3: new high-speed USB device number 4 using dwc_otg
[    3.416550] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[    3.416764] systemd[1]: Starting LVM2 metadata daemon socket.
[    3.417925] systemd[1]: Listening on LVM2 metadata daemon socket.
[    3.418119] systemd[1]: Starting /dev/initctl Compatibility Named Pipe.
[    3.419129] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[    3.419319] systemd[1]: Starting Delayed Shutdown Socket.
[    3.420322] systemd[1]: Listening on Delayed Shutdown Socket.
[    3.420587] systemd[1]: Starting Dispatch Password Requests to Console Directory Watch.
[    3.421165] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[    3.421341] systemd[1]: Starting Paths.
[    3.422095] systemd[1]: Reached target Paths.
[    3.422613] systemd[1]: Starting Arbitrary Executable File Formats File System Automount Point.
[    3.424308] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    3.425140] systemd[1]: Starting udev Kernel Socket.
[    3.428042] systemd[1]: Listening on udev Kernel Socket.
[    3.428853] systemd[1]: Starting udev Control Socket.
[    3.432213] systemd[1]: Listening on udev Control Socket.
[    3.432491] systemd[1]: Starting Journal Socket.
[    3.436906] systemd[1]: Listening on Journal Socket.
[    3.437406] systemd[1]: Mounted Huge Pages File System.
[    3.437645] systemd[1]: Mounting Debug File System...
[    3.449227] systemd[1]: Starting udev Coldplug all Devices...
[    3.464489] systemd[1]: Mounting POSIX Message Queue File System...
[    3.473872] systemd[1]: Starting Create static device nodes in /dev...
[    3.496867] systemd[1]: Starting Journal Service...
[    3.514009] systemd[1]: Started Journal Service.
[    3.514445] systemd[1]: Starting Encrypted Volumes.
[    3.516937] systemd[1]: Reached target Encrypted Volumes.
[    3.517133] systemd[1]: Starting Swap.
[    3.524726] systemd[1]: Reached target Swap.
[    3.525006] systemd[1]: Mounting Temporary Directory...
[    3.532621] systemd[1]: Expecting device dev-mmcblk0p1.device...
[    3.552516] systemd[1]: Started Replay Read-Ahead Data.
[    3.559632] systemd[1]: Started Collect Read-Ahead Data.
[    3.560152] systemd[1]: Started File System Check on Root Device.
[    3.560609] systemd[1]: Starting Remount Root and Kernel File Systems...
[    3.600289] systemd[1]: Starting Apply Kernel Variables...
[    3.619378] systemd[1]: Started Set Up Additional Binary Formats.
[    3.624738] systemd[1]: Starting Load Kernel Modules...
[    3.641578] systemd[1]: Starting Setup Virtual Console...
[    3.677330] usb 1-1.3: New USB device found, idVendor=148f, idProduct=2573
[    3.677365] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    3.677384] usb 1-1.3: Product: 54M.USB.......
[    3.677400] usb 1-1.3: Manufacturer: Ralink
[    3.677414] usb 1-1.3: SerialNumber: 12345
[    3.942204] bcm2708_rng_init=df292000
[    4.278708] systemd-udevd[80]: starting version 204
[    4.352292] systemd-modules-load[67]: Inserted module 'snd_bcm2835'
[    5.395675] cfg80211: Calling CRDA to update world regulatory domain
[    5.632318] bcm2708_i2c bcm2708_i2c.0: BSC0 Controller at 0x20205000 (irq 79) (baudrate 100k)
[    5.693657] bcm2708_i2c bcm2708_i2c.1: BSC1 Controller at 0x20804000 (irq 79) (baudrate 100k)
[    5.699997] bcm2708_spi bcm2708_spi.0: master is unqueued, this is deprecated
[    5.700266] bcm2708_spi bcm2708_spi.0: SPI Controller at 0x20204000 (irq 80)
[    5.770317] Registered led device: led0
[    5.951241] usb 1-1.3: reset high-speed USB device number 4 using dwc_otg
[    6.410332] cfg80211: Updating information on frequency 2412 MHz for a 20 MHz width channel with regulatory rule:
[    6.410366] cfg80211: 2402000 KHz - 2472000 KHz @ 40000 KHz), (600 mBi, 2000 mBm)
[    6.410382] cfg80211: Updating information on frequency 2417 MHz for a 20 MHz width channel with regulatory rule:
[    6.410396] cfg80211: 2402000 KHz - 2472000 KHz @ 40000 KHz), (600 mBi, 2000 mBm)
[    6.410409] cfg80211: Updating information on frequency 2422 MHz for a 20 MHz width channel with regulatory rule:
[    6.410422] cfg80211: 2402000 KHz - 2472000 KHz @ 40000 KHz), (600 mBi, 2000 mBm)
[    6.410434] cfg80211: Updating information on frequency 2427 MHz for a 20 MHz width channel with regulatory rule:
[    6.410447] cfg80211: 2402000 KHz - 2472000 KHz @ 40000 KHz), (600 mBi, 2000 mBm)
[    6.410459] cfg80211: Updating information on frequency 2432 MHz for a 20 MHz width channel with regulatory rule:
[    6.410472] cfg80211: 2402000 KHz - 2472000 KHz @ 40000 KHz), (600 mBi, 2000 mBm)
[    6.410486] cfg80211: Updating information on frequency 2437 MHz for a 20 MHz width channel with regulatory rule:
[    6.410500] cfg80211: 2402000 KHz - 2472000 KHz @ 40000 KHz), (600 mBi, 2000 mBm)
[    6.410512] cfg80211: Updating information on frequency 2442 MHz for a 20 MHz width channel with regulatory rule:
[    6.410525] cfg80211: 2402000 KHz - 2472000 KHz @ 40000 KHz), (600 mBi, 2000 mBm)
[    6.410538] cfg80211: Updating information on frequency 2447 MHz for a 20 MHz width channel with regulatory rule:
[    6.410551] cfg80211: 2402000 KHz - 2472000 KHz @ 40000 KHz), (600 mBi, 2000 mBm)
[    6.410563] cfg80211: Updating information on frequency 2452 MHz for a 20 MHz width channel with regulatory rule:
[    6.410576] cfg80211: 2402000 KHz - 2472000 KHz @ 40000 KHz), (600 mBi, 2000 mBm)
[    6.410589] cfg80211: Updating information on frequency 2457 MHz for a 20 MHz width channel with regulatory rule:
[    6.410603] cfg80211: 2402000 KHz - 2472000 KHz @ 40000 KHz), (600 mBi, 2000 mBm)
[    6.410616] cfg80211: Updating information on frequency 2462 MHz for a 20 MHz width channel with regulatory rule:
[    6.410630] cfg80211: 2402000 KHz - 2472000 KHz @ 40000 KHz), (600 mBi, 2000 mBm)
[    6.410642] cfg80211: Updating information on frequency 2467 MHz for a 20 MHz width channel with regulatory rule:
[    6.410655] cfg80211: 2457000 KHz - 2482000 KHz @ 40000 KHz), (600 mBi, 2000 mBm)
[    6.410668] cfg80211: Updating information on frequency 2472 MHz for a 20 MHz width channel with regulatory rule:
[    6.410681] cfg80211: 2457000 KHz - 2482000 KHz @ 40000 KHz), (600 mBi, 2000 mBm)
[    6.410694] cfg80211: Updating information on frequency 2484 MHz for a 20 MHz width channel with regulatory rule:
[    6.410706] cfg80211: 2474000 KHz - 2494000 KHz @ 20000 KHz), (600 mBi, 2000 mBm)
[    6.520025] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[    6.521308] Registered led device: rt73usb-phy0::radio
[    6.521453] Registered led device: rt73usb-phy0::assoc
[    6.521588] Registered led device: rt73usb-phy0::quality
[    6.522547] usbcore: registered new interface driver rt73usb
[    9.969254] smsc95xx 1-1.1:1.0: eth0: link up, 100Mbps, full-duplex, lpa 0xCDE1
[   10.809428] wlan0: authenticate with 74:44:01:84:a6:fd
[   10.905943] wlan0: send auth to 74:44:01:84:a6:fd (try 1/3)
[   10.908124] wlan0: authenticated
[   10.910170] rt73usb 1-1.3:1.0: wlan0: disabling HT as WMM/QoS is not supported
[   10.976416] wlan0: associate with 74:44:01:84:a6:fd (try 1/3)
[   10.983592] wlan0: RX AssocResp from 74:44:01:84:a6:fd (capab=0x411 status=0 aid=2)
[   11.002777] wlan0: associated
[   11.003046] cfg80211: Pending regulatory request, waiting for it to be processed...
[  393.571652] ieee80211 phy0: wlan0: No probe response from AP 74:44:01:84:a6:fd after 500ms, disconnecting.
[  393.601287] cfg80211: All devices are disconnected, going to restore regulatory settings
[  393.601325] cfg80211: Restoring regulatory settings
[  393.601356] cfg80211: Calling CRDA for country: FR
[  395.034390] wlan0: authenticate with 74:44:01:84:a6:fd
[  395.087765] wlan0: send auth to 74:44:01:84:a6:fd (try 1/3)
[  395.090818] wlan0: authenticated
[  395.091464] rt73usb 1-1.3:1.0: wlan0: disabling HT as WMM/QoS is not supported
[  395.121731] wlan0: associate with 74:44:01:84:a6:fd (try 1/3)
[  395.124906] wlan0: RX AssocResp from 74:44:01:84:a6:fd (capab=0x411 status=0 aid=2)
[  395.142485] wlan0: associated
[  960.823582] ERROR::handle_hc_chhltd_intr_dma:2537: handle_hc_chhltd_intr_dma: Channel 1, DMA Mode -- ChHltd set, but reason for halting is unknown, hcint 0x00000002, intsts 0x04000001
[  964.560840] ieee80211 phy0: wlan0: No probe response from AP 74:44:01:84:a6:fd after 500ms, disconnecting.
[  964.586666] cfg80211: All devices are disconnected, going to restore regulatory settings
[  964.586780] cfg80211: Restoring regulatory settings
[  964.586814] cfg80211: Calling CRDA to update world regulatory domain
[  965.933427] wlan0: authenticate with 74:44:01:84:a6:fd
[  965.984143] wlan0: send auth to 74:44:01:84:a6:fd (try 1/3)
[  966.190899] wlan0: send auth to 74:44:01:84:a6:fd (try 2/3)
[  966.400910] wlan0: send auth to 74:44:01:84:a6:fd (try 3/3)
[  966.610909] wlan0: authentication with 74:44:01:84:a6:fd timed out
[ 2057.208401] netlink: 20 bytes leftover after parsing attributes.
[ 2057.208438] netlink: 20 bytes leftover after parsing attributes.
[ 2057.208657] netlink: 20 bytes leftover after parsing attributes.
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0        64
  bcdDevice            0.01
  iManufacturer           1 Ralink
  iProduct                2 54M.USB.......
  iSerial                 3 12345
    bLength                 9
    bDescriptorType         2
    wTotalLength           32
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0x80
      (Bus Powered)
    MaxPower              300mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           2
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
Device Qualifier (for other device speed):
  bLength                10
  bDescriptorType         6
  bcdUSB               2.00
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0        64
Device Status:     0x0000
  (Bus Powered)
MrEngman
Sat Jul 13, 2013 2:23 pm
I've seen the same thing http://www.raspberrypi.org/phpBB3/viewt ... 03#p386803
Really annoying. I hadn't notice a problem until I updated with rpi-update to the latest #496 and the Pi started behaving a little strangely. I nearly always run rpi-update when I find an update available and I was running #494 and that didn't seem to have problems but checking I found the DMA errors there as well.
MrEngman
MrEngman
Sat Jul 13, 2013 5:10 pm
I've been hunting this down and the DMA errors appear to start with #488 PREEMPT Tue Jul 2 16:37:47 BST 2013.
.firmware_revision 44dc4f093c9ec075e6704965665311a94f6371aa
I've found an easy way to create this error is to hotplug a wifi adaptor. One or more often several errors occur when you plug it in.
MrEngman
jdb
Sun Jul 14, 2013 1:43 pm
I can reproduce this locally.
Proposed fix is now on https://github.com/P33M - if you are savvy with compiling your own kernels then please do give it a try and report back. If not then PM me and I can get a binary to you.
Rockets are loud.
https://astro-pi.org
joan
Sun Jul 14, 2013 2:05 pm
I'm not familiar with the git process. Is there a file or files I need to replace in the kernel source tree?
edited to add: okay, I need to replace drivers/usb/host/dwc_otg/dwc_otg_hcd_intr.c with your proposed version.
jackokring
Contact: ICQ
Sun Jul 14, 2013 2:06 pm
http://modarchive.org/index.php for your listening pleasure, just need a pi mod player ... mikmod? A full kernel recompile is too much for today. Is there a no pressure ETA on the roll-out?
Pi[NFA]=B256R0USB CL4SD8GB Raspbian Stock.
Pi[Work]=A+256 CL4SD8GB Raspbian Stock.
My favourite constant 1.65056745028
joan
Sun Jul 14, 2013 4:37 pm
I replaced drivers/usb/host/dwc_otg/dwc_otg_hcd_intr.c with the proposed version and downloaded the rebuilt kernel to the Pi.
Wifi has been OK for 55 minutes and there are no errors in dmesg.
MrEngman
Sun Jul 14, 2013 5:09 pm
joan wrote:I replaced drivers/usb/host/dwc_otg/dwc_otg_hcd_intr.c with the proposed version and downloaded the rebuilt kernel to the Pi.
Hi Joan,
Is there any chance you can post the update somewhere where I can download it to try. Or I can PM an address to email it too if that's alright. I've been in touch with jdb but haven't heard back.
MrEngman
MrEngman
Sun Jul 14, 2013 5:28 pm
Thanks very much, Joan.
MrEngman
jdb
Sun Jul 14, 2013 6:31 pm
jackokring wrote:http://modarchive.org/index.php for your listening pleasure, just need a pi mod player ... mikmod? A full kernel recompile is too much for today. Is there a no pressure ETA on the roll-out?
The roll-out has to take into consideration ~1x10^6 Pi users with all manner of uses of their hardware.
If we get an issue, reproduced by several people with different hardware (this is the "best" kind of bug - it means there is a vanishingly small chance of a coincidence), then it follows to let people experiencing the issue test with the proposed fix before rolling it out globally.
Once those people test and verify that their particular problem is now resolved, or at least better, then we can consider releasing it unto the world.
Rockets are loud.
joan
Sun Jul 14, 2013 7:15 pm
Just noticed this in dmesg.
 SysRq : HELP : loglevel(0-9) reBoot Crash terminate-all-tasks(E) memory-full-oom-kill(F) debug(G) kill-all-tasks(I) thaw-filesystems(J) saK show-memory-usage(M) nice-all-RT-tasks(N) powerOff show-registers(P) show-all-timers(Q) unRaw Sync show-task-states(T) Unmount show-blocked-tasks(W)
[    0.000000] Linux version 3.6.11+ ([email protected]) (gcc version 4.4.6 (Debian 4.4.6-14) ) #6 PREEMPT Sun Jul 14 16:19:35 BST 2013
[    0.000000] free_area_init_node: node 0, pgdat c054d9e4, node_mem_map c05f7000
[    0.000000] Memory: 204808k/204808k available, 24568k reserved, 0K highmem
[    0.000000]       .text : 0xc0008000 - 0xc04f7868   (5055 kB)
[    0.000000]       .init : 0xc04f8000 - 0xc0519584   ( 134 kB)
[    0.000000]       .data : 0xc051a000 - 0xc054e200   ( 209 kB)
[    0.000000]        .bss : 0xc054e224 - 0xc05f6db8   ( 675 kB)
[    0.001005] Calibrating delay loop... 697.95 BogoMIPS (lpj=3489792)
[    0.060136] pid_max: default: 32768 minimum: 301
[    0.060466] Mount-cache hash table entries: 512
[    0.061215] Initializing cgroup subsys cpuacct
[    0.061271] Initializing cgroup subsys devices
[    0.061302] Initializing cgroup subsys freezer
[    0.061330] Initializing cgroup subsys blkio
[    0.061420] CPU: Testing write buffer coherency: ok
[    0.061760] hw perfevents: enabled with v6 PMU driver, 3 counters available
[    0.061906] Setting up static identity map for 0x3b4368 - 0x3b43c4
[    0.063432] devtmpfs: initialized
[    0.073780] NET: Registered protocol family 16
[    0.080061] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[    0.081202] bcm2708.uart_clock = 0
[    0.082580] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
[    0.082640] hw-breakpoint: maximum watchpoint size is 4 bytes.
[    0.082674] mailbox: Broadcom VideoCore Mailbox driver
[    0.082768] bcm2708_vcio: mailbox at f200b880
[    0.082868] bcm_power: Broadcom power driver
[    0.082905] bcm_power_open() -> 0
[    0.082929] bcm_power_request(0, 8)
[    0.583620] bcm_mailbox_read -> 00000080, 0
[    0.583662] bcm_power_request -> 0
[    0.583686] Serial: AMBA PL011 UART driver
[    0.583833] dev:f1: ttyAMA0 at MMIO 0x20201000 (irq = 83) is a PL011 rev3
[    0.901626] console [ttyAMA0] enabled
[    0.924734] bio: create slab <bio-0> at 0
[    0.929624] SCSI subsystem initialized
[    0.933719] usbcore: registered new interface driver usbfs
[    0.939304] usbcore: registered new interface driver hub
[    0.944917] usbcore: registered new device driver usb
[    0.951218] Switching to clocksource stc
[    0.955464] FS-Cache: Loaded
[    0.958609] CacheFiles: Loaded
[    0.973633] NET: Registered protocol family 2
[    0.978906] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[    0.986267] TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
[    0.992850] TCP: Hash tables configured (established 8192 bind 8192)
[    0.999286] TCP: reno registered
[    1.002537] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    1.008434] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    1.014965] NET: Registered protocol family 1
[    1.019895] RPC: Registered named UNIX socket transport module.
[    1.025945] RPC: Registered udp transport module.
[    1.030667] RPC: Registered tcp transport module.
[    1.035411] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.042478] bcm2708_dma: DMA manager at f2007000
[    1.047277] bcm2708_gpio: bcm2708_gpio_probe c0527db8
[    1.052730] vc-mem: phys_addr:0x00000000 mem_base=0x0ec00000 mem_size:0x10000000(256 MiB)
[    1.061870] audit: initializing netlink socket (disabled)
[    1.067473] type=2000 audit(0.930:1): initialized
[    1.189460] VFS: Disk quotas dquot_6.5.2
[    1.193492] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    1.200557] FS-Cache: Netfs 'nfs' registered for caching
[    1.206319] NFS: Registering the id_resolver key type
[    1.211497] Key type id_resolver registered
[    1.215793] Key type id_legacy registered
[    1.220163] msgmni has been set to 432
[    1.225788] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[    1.233494] io scheduler noop registered
[    1.237533] io scheduler deadline registered (default)
[    1.242712] io scheduler cfq registered
[    1.257403] Console: switching to colour frame buffer device 35x26
[    1.265241] kgdb: Registered I/O driver kgdboc.
[    1.271109] vc-cma: Videocore CMA driver
[    1.275749] vc-cma: vc_cma_base      = 0x00000000
[    1.281101] vc-cma: vc_cma_size      = 0x00000000 (0 MiB)
[    1.287230] vc-cma: vc_cma_initial   = 0x00000000 (0 MiB)
[    1.302149] brd: module loaded
[    1.310430] loop: module loaded
[    1.314354] vchiq: vchiq_init_state: slot_zero = 0xcd000000, is_master = 0
[    1.323115] Loading iSCSI transport class v2.0-870.
[    1.329809] usbcore: registered new interface driver smsc95xx
[    1.336700] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    1.548378] Core Release: 2.80a
[    1.551929] Setting default values for core params
[    1.557528] Finished setting default values for core params
[    1.768877] Using Buffer DMA mode
[    1.772931] Periodic Transfer Interrupt Enhancement - disabled
[    1.779519] Multiprocessor Interrupt Enhancement - disabled
[    1.785848] OTG VER PARAM: 0, OTG VER FLAG: 0
[    1.790931] Dedicated Tx FIFOs mode
[    1.796095] dwc_otg: Microframe scheduler enabled
[    1.796467] dwc_otg bcm2708_usb: DWC OTG Controller
[    1.802195] dwc_otg bcm2708_usb: new USB bus registered, assigned bus number 1
[    1.810673] dwc_otg bcm2708_usb: irq 32, io mem 0x00000000
[    1.817016] Init: Port Power? op_state=1
[    1.821672] Init: Power Port (0)
[    1.825416] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    1.833298] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.841620] usb usb1: Product: DWC OTG Controller
[    1.847157] usb usb1: Manufacturer: Linux 3.6.11+ dwc_otg_hcd
[    1.853649] usb usb1: SerialNumber: bcm2708_usb
[    1.859705] hub 1-0:1.0: USB hub found
[    1.864256] hub 1-0:1.0: 1 port detected
[    1.869312] dwc_otg: FIQ enabled
[    1.869329] dwc_otg: NAK holdoff enabled
[    1.869337] dwc_otg: FIQ split fix enabled
[    1.869356] Module dwc_common_port init
[    1.869587] Initializing USB Mass Storage driver...
[    1.875545] usbcore: registered new interface driver usb-storage
[    1.882320] USB Mass Storage support registered.
[    1.887854] usbcore: registered new interface driver libusual
[    1.894635] mousedev: PS/2 mouse device common for all mice
[    1.901767] bcm2835-cpufreq: min=700000 max=700000 cur=700000
[    1.908434] bcm2835-cpufreq: switching to governor powersave
[    1.914832] bcm2835-cpufreq: switching to governor powersave
[    1.921253] cpuidle: using governor ladder
[    1.926096] cpuidle: using governor menu
[    1.930825] sdhci: Secure Digital Host Controller Interface driver
[    1.937776] sdhci: Copyright(c) Pierre Ossman
[    1.942952] sdhci: Enable low-latency mode
[    1.985521] mmc0: SDHCI controller on BCM2708_Arasan [platform] using platform's DMA
[    1.994464] mmc0: BCM2708 SDHC host at 0x20300000 DMA 2 IRQ 77
[    2.001287] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.013467] usbcore: registered new interface driver usbhid
[    2.022012] usbhid: USB HID core driver
[    2.029342] TCP: cubic registered
[    2.035563] Initializing XFRM netlink socket
[    2.042737] NET: Registered protocol family 17
[    2.050315] Key type dns_resolver registered
[    2.056965] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
[    2.068164] Indeed it is in host mode hprt0 = 00021501
[    2.075014] registered taskstats version 1
[    2.086428] Waiting for root device /dev/mmcblk0p2...
[    2.137528] mmc0: read SD Status register (SSR) after 3 attempts
[    2.157317] mmc0: new high speed SDHC card at address 0002
[    2.175696] mmcblk0: mmc0:0002 N/A   3.75 GiB
[    2.182412]  mmcblk0: p1 p2
[    2.305401] usb 1-1: new high-speed USB device number 2 using dwc_otg
[    2.315043] Indeed it is in host mode hprt0 = 00001101
[    2.545938] usb 1-1: New USB device found, idVendor=0424, idProduct=9512
[    2.553851] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    2.565962] hub 1-1:1.0: USB hub found
[    2.573215] hub 1-1:1.0: 3 ports detected
[    2.865585] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[    2.986130] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[    2.994195] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    3.005630] smsc95xx v1.0.4
[    3.072448] smsc95xx 1-1.1:1.0: eth0: register 'smsc95xx' at usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:bc:35:3e
[    3.165483] usb 1-1.3: new high-speed USB device number 4 using dwc_otg
[    3.429063] usb 1-1.3: New USB device found, idVendor=148f, idProduct=2573
[    3.437111] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    3.445598] usb 1-1.3: Product: 54M.USB.......
[    3.450781] usb 1-1.3: Manufacturer: Ralink
[   15.889032] EXT4-fs (mmcblk0p2): warning: mounting fs with errors, running e2fsck is recommended
[   17.232520] EXT4-fs (mmcblk0p2): recovery complete
[   17.243363] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[   17.252815] VFS: Mounted root (ext4 filesystem) on device 179:2.
[   17.272404] devtmpfs: mounted
[   17.276314] Freeing init memory: 132K
[   18.676914] udevd[151]: starting version 175
[   19.941518] Registered led device: led0
[   20.132714] cfg80211: Calling CRDA to update world regulatory domain
[   20.885778] usb 1-1.3: reset high-speed USB device number 4 using dwc_otg
[   21.415106] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[   21.416396] Registered led device: rt73usb-phy0::radio
[   21.416544] Registered led device: rt73usb-phy0::assoc
[   21.416669] Registered led device: rt73usb-phy0::quality
[   21.418266] usbcore: registered new interface driver rt73usb
[   31.187282] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[   31.775457] fuse init (API version 7.20)
[   32.143508] bcm2708_i2c bcm2708_i2c.0: BSC0 Controller at 0x20205000 (irq 79) (baudrate 100k)
[   32.161105] bcm2708_i2c bcm2708_i2c.1: BSC1 Controller at 0x20804000 (irq 79) (baudrate 100k)
[   32.263295] i2c /dev entries driver
[   50.259683] wlan0: authenticate with 00:26:44:08:2d:1f
[   50.307953] wlan0: send auth to 00:26:44:08:2d:1f (try 1/3)
[   50.310102] wlan0: authenticated
[   50.311411] rt73usb 1-1.3:1.0: wlan0: disabling HT as WMM/QoS is not supported
[   50.335473] wlan0: associate with 00:26:44:08:2d:1f (try 1/3)
[   50.338015] wlan0: RX AssocResp from 00:26:44:08:2d:1f (capab=0x411 status=0 aid=2)
[   50.352929] wlan0: associated
[  318.063360] EXT4-fs (mmcblk0p2): error count: 2
[  318.063390] EXT4-fs (mmcblk0p2): initial error at 1369404309: ext4_put_super:819
[  318.063411] EXT4-fs (mmcblk0p2): last error at 1369404309: ext4_put_super:819
[ 4764.284863] phy0 -> rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x30c0 with error -71.
[ 4764.313993] phy0 -> rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x30c4 with error -71.
[ 4765.285252] phy0 -> rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x30c0 with error -71.
[ 4765.315003] phy0 -> rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x30c4 with error -71.
[ 4765.343571] phy0 -> rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x308c with error -71.
[ 4765.373128] phy0 -> rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x308c with error -71.
[ 4765.402627] phy0 -> rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x308c with error -71.
[ 4765.432061] phy0 -> rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x308c with error -71.
[ 4765.461396] phy0 -> rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x308c with error -71.
[ 4765.490438] phy0 -> rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x308c with error -71.
[ 4765.520324] phy0 -> rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x308c with error -71.
[ 4765.549662] phy0 -> rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x308c with error -71.
[ 4765.579234] phy0 -> rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x308c with error -71.
[ 4765.608197] phy0 -> rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x308c with error -71.
[ 4765.636794] phy0 -> rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x308c with error -71.
[ 4765.665834] phy0 -> rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x308c with error -71.
[ 4765.695438] phy0 -> rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x308c with error -71.
[ 4765.724803] phy0 -> rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x308c with error -71.
[ 4765.754561] phy0 -> rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x308c with error -71.
[ 4765.783548] phy0 -> rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x308c with error -71.
[ 4765.813425] phy0 -> rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x308c with error -71.
[ 4765.842680] phy0 -> rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x308c with error -71.
[ 4765.871865] phy0 -> rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x308c with error -71.
[ 4765.901211] phy0 -> rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x308c with error -71.
[ 4765.930215] phy0 -> rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x308c with error -71.
[ 4765.959569] phy0 -> rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x308c with error -71.
[ 4793.289678] phy0 -> rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x30c0 with error -71.
[ 4793.323763] phy0 -> rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x30c4 with error -71.
[ 4798.289725] phy0 -> rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x30c0 with error -71.
[ 4798.321242] phy0 -> rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x30c4 with error -71.
[ 4799.290855] phy0 -> rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x30c0 with error -71.
[ 4799.324427] phy0 -> rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x30c4 with error -71.
[ 4799.356996] phy0 -> rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x308c with error -71.
[ 4799.390127] phy0 -> rt2x00usb_vendor_request: Error - Vendor Request 0x06 failed for offset 0x308c with error -71.
[ 4799.422807] phy0 -> rt2x00usb_vendor_request: Error - Vendor Request 0x0a failed for offset 0x0000 with error -71.
[ 4800.302294] phy0 -> rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x30c0 with error -71.
[ 4800.335802] phy0 -> rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x30c4 with error -71.
[ 4800.368636] phy0 -> rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x308c with error -71.
[ 4800.402334] phy0 -> rt2x00usb_vendor_request: Error - Vendor Request 0x06 failed for offset 0x308c with error -71.
[ 4801.300829] phy0 -> rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x30c0 with error -71.
[ 4801.333896] phy0 -> rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x30c4 with error -71.
[ 4801.366193] phy0 -> rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x308c with error -71.
[ 4801.398825] phy0 -> rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x308c with error -71.
[ 4801.433023] phy0 -> rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x308c with error -71.
[ 4801.465910] phy0 -> rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x308c with error -71.
[ 4801.498877] phy0 -> rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x308c with error -71.
[ 4801.532301] phy0 -> rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x308c with error -71.
[ 4801.565428] phy0 -> rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x308c with error -71.
[ 4801.599807] phy0 -> rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x308c with error -71.
[ 4801.633501] phy0 -> rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x308c with error -71.
[ 4801.668644] phy0 -> rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x308c with error -71.
[ 4801.701647] phy0 -> rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x308c with error -71.
[ 4801.734324] phy0 -> rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x308c with error -71.
[ 4825.290398] phy0 -> rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x30c0 with error -71.
[ 4885.306346] phy0 -> rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x30c0 with error -71.
[ 5143.297976] phy0 -> rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x30c0 with error -71.
[ 5143.330969] phy0 -> rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x30c4 with error -71.
[ 5153.938568] SysRq : HELP : loglevel(0-9) reBoot Crash terminate-all-tasks(E) memory-full-oom-kill(F) debug(G) kill-all-tasks(I) thaw-filesystems(J) saK show-memory-usage(M) nice-all-RT-tasks(N) powerOff show-registers(P) show-all-timers(Q) unRaw Sync show-task-states(T) Unmount show-blocked-tasks(W)
[ 5154.050476] SysRq : HELP : loglevel(0-9) reBoot Crash terminate-all-tasks(E) memory-full-oom-kill(F) debug(G) kill-all-tasks(I) thaw-filesystems(J) saK show-memory-usage(M) nice-all-RT-tasks(N) powerOff show-registers(P) show-all-timers(Q) unRaw Sync show-task-states(T) Unmount show-blocked-tasks(W)
[ 5154.190735] SysRq : Show Regs
[ 5154.194191]
[ 5154.194212] Pid: 3971, comm:          kworker/u:1
[ 5154.194227] CPU: 0    Not tainted  (3.6.11+ #6)
[ 5154.194279] PC is at rt2x00usb_interrupt_rxdone+0x3c/0x88 [rt2x00usb]
[ 5154.194307] LR is at rt2x00usb_interrupt_rxdone+0x3c/0x88 [rt2x00usb]
[ 5154.194323] pc : [<bf0b8a60>]    lr : [<bf0b8a60>]    psr: 40000113
[ 5154.194323] sp : cc83de80  ip : 00076810  fp : c056f7e0
[ 5154.194337] r10: c056f800  r9 : 00000102  r8 : c052c114
[ 5154.194348] r7 : cc9eb4a0  r6 : ccb03040  r5 : cc9eb4a0  r4 : cbaaf198
[ 5154.194359] r3 : 00000000  r2 : 00000102  r1 : 00000001  r0 : cbaaf198
[ 5154.194371] Flags: nZcv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment kernel
[ 5154.194382] Control: 00c5387d  Table: 08c00008  DAC: 00000017
[ 5154.194444] [<c0014b0c>] (unwind_backtrace+0x0/0xf4) from [<c022e128>] (sysrq_handle_showregs+0x18/0x24)
[ 5154.194477] [<c022e128>] (sysrq_handle_showregs+0x18/0x24) from [<c022e434>] (__handle_sysrq+0x114/0x198)
[ 5154.194518] [<c022e434>] (__handle_sysrq+0x114/0x198) from [<c0240934>] (pl011_int+0x234/0x490)
[ 5154.194563] [<c0240934>] (pl011_int+0x234/0x490) from [<c007b534>] (handle_irq_event_percpu+0x50/0x1b0)
[ 5154.194593] [<c007b534>] (handle_irq_event_percpu+0x50/0x1b0) from [<c007b6e8>] (handle_irq_event+0x54/0x84)
[ 5154.194624] [<c007b6e8>] (handle_irq_event+0x54/0x84) from [<c007dd9c>] (handle_level_irq+0x98/0x138)
[ 5154.194651] [<c007dd9c>] (handle_level_irq+0x98/0x138) from [<c007b07c>] (generic_handle_irq+0x38/0x48)
[ 5154.194688] [<c007b07c>] (generic_handle_irq+0x38/0x48) from [<c000ef5c>] (handle_IRQ+0x30/0x84)
[ 5154.194717] [<c000ef5c>] (handle_IRQ+0x30/0x84) from [<c03b0914>] (__irq_svc+0x34/0xc8)
[ 5154.194759] [<c03b0914>] (__irq_svc+0x34/0xc8) from [<bf0b8a60>] (rt2x00usb_interrupt_rxdone+0x3c/0x88 [rt2x00usb])
[ 5154.194816] [<bf0b8a60>] (rt2x00usb_interrupt_rxdone+0x3c/0x88 [rt2x00usb]) from [<c0284e14>] (usb_hcd_giveback_urb+0x64/0xf8)
[ 5154.194868] [<c0284e14>] (usb_hcd_giveback_urb+0x64/0xf8) from [<c02ac370>] (completion_tasklet_func+0x60/0x8c)
[ 5154.194908] [<c02ac370>] (completion_tasklet_func+0x60/0x8c) from [<c02b4888>] (tasklet_callback+0x14/0x18)
[ 5154.194950] [<c02b4888>] (tasklet_callback+0x14/0x18) from [<c0026d40>] (tasklet_hi_action+0xa0/0xb4)
[ 5154.194979] [<c0026d40>] (tasklet_hi_action+0xa0/0xb4) from [<c0027058>] (__do_softirq+0xa0/0x14c)
[ 5154.195007] [<c0027058>] (__do_softirq+0xa0/0x14c) from [<c00272ec>] (irq_exit+0x8c/0x94)
[ 5154.195034] [<c00272ec>] (irq_exit+0x8c/0x94) from [<c000ef60>] (handle_IRQ+0x34/0x84)
[ 5154.195062] [<c000ef60>] (handle_IRQ+0x34/0x84) from [<c03b0914>] (__irq_svc+0x34/0xc8)
[ 5154.195088] [<c03b0914>] (__irq_svc+0x34/0xc8) from [<c00366ec>] (worker_thread+0x1c0/0x568)
[ 5154.195122] [<c00366ec>] (worker_thread+0x1c0/0x568) from [<c003d058>] (kthread+0x88/0x94)
[ 5154.195150] [<c003d058>] (kthread+0x88/0x94) from [<c000f038>] (kernel_thread_exit+0x0/0x8)
[ 5154.195163] SysRq : HELP : loglevel(0-9) reBoot Crash terminate-all-tasks(E) memory-full-oom-kill(F) debug(G) kill-all-tasks(I) thaw-filesystems(J) saK show-memory-usage(M) nice-all-RT-tasks(N) powerOff show-registers(P) show-all-timers(Q) unRaw Sync show-task-states(T) Unmount show-blocked-tasks(W)
[ 5154.233287] SysRq : HELP : loglevel(0-9) reBoot Crash terminate-all-tasks(E) memory-full-oom-kill(F) debug(G) kill-all-tasks(I) thaw-filesystems(J) saK show-memory-usage(M) nice-all-RT-tasks(N) powerOff show-registers(P) show-all-timers(Q) unRaw Sync show-task-states(T) Unmount show-blocked-tasks(W)
[ 5154.298517] phy0 -> rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x30c0 with error -71.
[ 5154.298816] SysRq : HELP : loglevel(0-9) reBoot Crash terminate-all-tasks(E) memory-full-oom-kill(F) debug(G) kill-all-tasks(I) thaw-filesystems(J) saK show-memory-usage(M) nice-all-RT-tasks(N) powerOff show-registers(P) show-all-timers(Q) unRaw Sync show-task-states(T) Unmount show-blocked-tasks(W)
[ 5154.329103] SysRq : HELP : loglevel(0-9) reBoot Crash terminate-all-tasks(E) memory-full-oom-kill(F) debug(G) kill-all-tasks(I) thaw-filesystems(J) saK show-memory-usage(M) nice-all-RT-tasks(N) powerOff show-registers(P) show-all-timers(Q) unRaw Sync show-task-states(T) Unmount show-blocked-tasks(W)
[ 5154.397032] phy0 -> rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x30c4 with error -71.
[ 5154.467702] SysRq : HELP : loglevel(0-9) reBoot Crash terminate-all-tasks(E) memory-full-oom-kill(F) debug(G) kill-all-tasks(I) thaw-filesystems(J) saK show-memory-usage(M) nice-all-RT-tasks(N) powerOff show-registers(P) show-all-timers(Q) unRaw Sync show-task-states(T) Unmount show-blocked-tasks(W)
[ 5154.512257] SysRq : HELP : loglevel(0-9) reBoot Crash terminate-all-tasks(E) memory-full-oom-kill(F) debug(G) kill-all-tasks(I) thaw-filesystems(J) saK show-memory-usage(M) nice-all-RT-tasks(N) powerOff show-registers(P) show-all-timers(Q) unRaw Sync show-task-states(T) Unmount show-blocked-tasks(W)
[ 5154.560088] SysRq : HELP : loglevel(0-9) reBoot Crash terminate-all-tasks(E) memory-full-oom-kill(F) debug(G) kill-all-tasks(I) thaw-filesystems(J) saK show-memory-usage(M) nice-all-RT-tasks(N) powerOff show-registers(P) show-all-timers(Q) unRaw Sync show-task-states(T) Unmount show-blocked-tasks(W)
[ 5154.862622] SysRq : HELP : loglevel(0-9) reBoot Crash terminate-all-tasks(E) memory-full-oom-kill(F) debug(G) kill-all-tasks(I) thaw-filesystems(J) saK show-memory-usage(M) nice-all-RT-tasks(N) powerOff show-registers(P) show-all-timers(Q) unRaw Sync show-task-states(T) Unmount show-blocked-tasks(W)
[ 5154.915902] SysRq : HELP : loglevel(0-9) reBoot Crash terminate-all-tasks(E) memory-full-oom-kill(F) debug(G) kill-all-tasks(I) thaw-filesystems(J) saK show-memory-usage(M) nice-all-RT-tasks(N) powerOff show-registers(P) show-all-timers(Q) unRaw Sync show-task-states(T) Unmount show-blocked-tasks(W)
[ 5155.054699] SysRq : HELP : loglevel(0-9) reBoot Crash terminate-all-tasks(E) memory-full-oom-kill(F) debug(G) kill-all-tasks(I) thaw-filesystems(J) saK show-memory-usage(M) nice-all-RT-tasks(N) powerOff show-registers(P) show-all-timers(Q) unRaw Sync show-task-states(T) Unmount show-blocked-tasks(W)
[ 5155.166649] SysRq : HELP : loglevel(0-9) reBoot Crash terminate-all-tasks(E) memory-full-oom-kill(F) debug(G) kill-all-tasks(I) thaw-filesystems(J) saK show-memory-usage(M) nice-all-RT-tasks(N) powerOff show-registers(P) show-all-timers(Q) unRaw Sync show-task-states(T) Unmount show-blocked-tasks(W)
[ 5155.315113] phy0 -> rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x30c0 with error -71.
[ 5155.350159] phy0 -> rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x30c4 with error -71.
[ 5155.384242] phy0 -> rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x308c with error -71.
[ 5155.419328] phy0 -> rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x308c with error -71.
[ 5155.453633] phy0 -> rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x308c with error -71.
[ 5155.489586] phy0 -> rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x308c with error -71.
[ 5155.523556] phy0 -> rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x308c with error -71.
[ 5155.558188] phy0 -> rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x308c with error -71.
[ 5155.592683] phy0 -> rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x308c with error -71.
[ 5155.627655] phy0 -> rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x308c with error -71.
[ 5155.661376] phy0 -> rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x308c with error -71.
[ 5155.694346] phy0 -> rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x308c with error -71.
[ 5155.728277] phy0 -> rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x308c with error -71.
[ 5155.763761] phy0 -> rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x308c with error -71.
[ 5155.829531] phy0 -> rt2x00usb_vendor_request: Error - Vendor Request 0x06 failed for offset 0x308c with error -71.
[ 5155.861921] phy0 -> rt2x00usb_vendor_request: Error - Vendor Request 0x0a failed for offset 0x0000 with error -71.
[ 5156.149934] SysRq : HELP : loglevel(0-9) reBoot Crash terminate-all-tasks(E) memory-full-oom-kill(F) debug(G) kill-all-tasks(I) thaw-filesystems(J) saK show-memory-usage(M) nice-all-RT-tasks(N) powerOff show-registers(P) show-all-timers(Q) unRaw Sync show-task-states(T) Unmount show-blocked-tasks(W)
[ 5156.285444] SysRq : HELP : loglevel(0-9) reBoot Crash terminate-all-tasks(E) memory-full-oom-kill(F) debug(G) kill-all-tasks(I) thaw-filesystems(J) saK show-memory-usage(M) nice-all-RT-tasks(N) powerOff show-registers(P) show-all-timers(Q) unRaw Sync show-task-states(T) Unmount show-blocked-tasks(W)
[ 5156.416119] SysRq : HELP : loglevel(0-9) reBoot Crash terminate-all-tasks(E) memory-full-oom-kill(F) debug(G) kill-all-tasks(I) thaw-filesystems(J) saK show-memory-usage(M) nice-all-RT-tasks(N) powerOff show-registers(P) show-all-timers(Q) unRaw Sync show-task-states(T) Unmount show-blocked-tasks(W)
[ 5156.996424] SysRq : HELP : loglevel(0-9) reBoot Crash terminate-all-tasks(E) memory-full-oom-kill(F) debug(G) kill-all-tasks(I) thaw-filesystems(J) saK show-memory-usage(M) nice-all-RT-tasks(N) powerOff show-registers(P) show-all-timers(Q) unRaw Sync show-task-states(T) Unmount show-blocked-tasks(W)
[ 5157.145950] SysRq : HELP : loglevel(0-9) reBoot Crash terminate-all-tasks(E) memory-full-oom-kill(F) debug(G) kill-all-tasks(I) thaw-filesystems(J) saK show-memory-usage(M) nice-all-RT-tasks(N) powerOff show-registers(P) show-all-timers(Q) unRaw Sync show-task-states(T) Unmount show-blocked-tasks(W)
[ 5157.411129] SysRq : HELP : loglevel(0-9) reBoot Crash terminate-all-tasks(E) memory-full-oom-kill(F) debug(G) kill-all-tasks(I) thaw-filesystems(J) saK show-memory-usage(M) nice-all-RT-tasks(N) powerOff show-registers(P) show-all-timers(Q) unRaw Sync show-task-states(T) Unmount show-blocked-tasks(W)
[ 5157.813019] SysRq : HELP : loglevel(0-9) reBoot Crash terminate-all-tasks(E) memory-full-oom-kill(F) debug(G) kill-all-tasks(I) thaw-filesystems(J) saK show-memory-usage(M) nice-all-RT-tasks(N) powerOff show-registers(P) show-all-timers(Q) unRaw Sync show-task-states(T) Unmount show-blocked-tasks(W)
[ 5157.929030] SysRq : HELP : loglevel(0-9) reBoot Crash terminate-all-tasks(E) memory-full-oom-kill(F) debug(G) kill-all-tasks(I) thaw-filesystems(J) saK show-memory-usage(M) nice-all-RT-tasks(N) powerOff show-registers(P) show-all-timers(Q) unRaw Sync show-task-states(T) Unmount show-blocked-tasks(W)
[ 5157.963054] SysRq : HELP : loglevel(0-9) reBoot Crash terminate-all-tasks(E) memory-full-oom-kill(F) debug(G) kill-all-tasks(I) thaw-filesystems(J) saK show-memory-usage(M) nice-all-RT-tasks(N) powerOff show-registers(P) show-all-timers(Q) unRaw Sync show-task-states(T) Unmount show-blocked-tasks(W)
[ 5157.993337] SysRq : HELP : loglevel(0-9) reBoot Crash terminate-all-tasks(E) memory-full-oom-kill(F) debug(G) kill-all-tasks(I) thaw-filesystems(J) saK show-memory-usage(M) nice-all-RT-tasks(N) powerOff show-registers(P) show-all-timers(Q) unRaw Sync show-task-states(T) Unmount show-blocked-tasks(W)
[ 5158.278245] SysRq : HELP : loglevel(0-9) reBoot Crash terminate-all-tasks(E) memory-full-oom-kill(F) debug(G) kill-all-tasks(I) thaw-filesystems(J) saK show-memory-usage(M) nice-all-RT-tasks(N) powerOff show-registers(P) show-all-timers(Q) unRaw Sync show-task-states(T) Unmount show-blocked-tasks(W)
[ 5158.765936] SysRq : HELP : loglevel(0-9) reBoot Crash terminate-all-tasks(E) memory-full-oom-kill(F) debug(G) kill-all-tasks(I) thaw-filesystems(J) saK show-memory-usage(M) nice-all-RT-tasks(N) powerOff show-registers(P) show-all-timers(Q) unRaw Sync show-task-states(T) Unmount show-blocked-tasks(W)
[ 5159.289869] SysRq : HELP : loglevel(0-9) reBoot Crash terminate-all-tasks(E) memory-full-oom-kill(F) debug(G) kill-all-tasks(I) thaw-filesystems(J) saK show-memory-usage(M) nice-all-RT-tasks(N) powerOff show-registers(P) show-all-timers(Q) unRaw Sync show-task-states(T) Unmount show-blocked-tasks(W)
jdb
Re: Wireless no longer working - latest kernel?
Mon Jul 15, 2013 12:10 pm
What are the associated symptoms? Wireless stops working, I assume. Are you pressing alt-sysrq locally?
Both these things are indicative of "better" - USB itself is not broken, and is responding correctly to failed transfers to a device.
Once the wifi dongle enters that error state, does a replug result in it working again?
Rockets are loud.
joan
Mon Jul 15, 2013 2:39 pm
There were no immediate problems after those messages were logged. The Pi stopped working afterwards (perhaps 10 minutes or so). I wasn't knowingly pressing any keys, not to say I wasn't leaning on the keyboard.
I loaded up the kernel I compiled again and this time it failed within a few minutes without anything in dmesg (it was in a loop doing dmesg every 30 seconds).
Of course I may have screwed up the kernel compile.
MrEngman
Mon Jul 15, 2013 2:55 pm
joan wrote:There were no immediate problems after those messages were logged. The Pi stopped working afterwards (perhaps 10 minutes or so). I wasn't knowingly pressing any keys, not to say I wasn't leaning on the keyboard.
Hi Joan,
Your kernel update seemed to have fixed the issues I was having. The Pi is running smoothly again and no DMA errors. I've been unplugging and plugging wifi adaptors every so often which was the thing that seemed to cause most DMA errors and I've seen none.
MrEngman
joan
Mon Jul 15, 2013 3:06 pm
@MrEngman
That's good. I've abused my Pi so much I'm sometimes surprised it works at all.
jdb
Mon Jul 15, 2013 4:22 pm
@joan
So have you seen any further instances of the error message ERROR::handle_hc_chhltd_intr_dma:2537:etc etc?
Rockets are loud.
