NikEy
Edimax Wifi Dongle + RPi
Thu Jun 27, 2013 3:41 am
Hi all,
I have encountered a weird problem. So far I had no problems in using the Edimax Wifi Dongle in combination with my raspberry pi. However, today it wouldn't connect to my network anymore after I accidentally stuck it in a ping loop (I wanted to create a script that checks if my network connection is down). The odd thing is that now (after rebooting numerous times) the attached keyboard is not working anymore either whenever the wifi-dongle is connected. On its own the keyboard works on the RPi... I figured the dongle must be broken - but it works flawlessly when attaching it to my windows PC. I then came to the conclusion that I must have somehow corrupted the system, so I flashed the drive with the latest wheezy version. Unfortunately the result is the same - whenever the dongle is connected, I can't even use the keyboard.
Anyone had this before? How can I fix this?
Davespice
Contact: Twitter
Re: Edimax Wifi Dongle + RPi
Thu Jun 27, 2013 9:40 am
Sounds like it might be an ampage issue. Have a look at the sticker on the bottom of your keyboard, you should see a power rating saying something like 5V == 100 mA. If the mA value is higher than 100 then you will probably have a problem. The Pi can only supply 100 mA of current to each USB device. So the same rule applies for the Wifi dongle, one definite solution is to run them through a powered USB hub.
Killasin
Thu Jun 27, 2013 2:09 pm
Funny thing is, I have the same WiFi dongle. I got a USB hub for my pi to power the dongle and have slots for keyboard+mouse. The weird thing for me is that the dongle works perfectly with my USB hub, but my hub doesn't support any other devices. I plugged my keyboard and mouse into the hub, the blue light for their ports flicker a little, and then it goes off, not supporting the devices. Even when the dongle is removed from the hub, the other devices don't work.
pluggy
Thu Jun 27, 2013 2:31 pm
Depends a lot on the exact operating system, and how up to date it is and what you have plugged into the USB as well as the power supply. I use generic Realtek RTL8188CUS adapators (the same chipset as the Edimax) directly plugged into the Pi without issues. I don't take anything relating to USB for granted on the Pi, its way too tetchy for that. My Wifi adaptors use about 35mA in normal use (I measured them).
I must not tread on too many sacred cows......
