psun03
TTYUSB0 - directory not found
Tue Jun 25, 2013 3:19 am
when it comes to linux, i have no real clue on how it all works... i am making a home automation with heyu and a some x10 stuff. I have a CM17A connected to a usb serial adapter to my rasp pi. I need to access the dev/ttyUSB0 directory (?). When I try to check for the ttyUSB0 by typing in
'ls - l /dev/ttyUSB0'
I get cannot access director: No directory exists.
I am not sure how to solve this problem or even know why it doesn't work. I am using a clean install of the lastest wheezy - rasbian.
Anyone can help me in the right direction?
FTrevorGowen
Re: TTYUSB0 - directory not found
Tue Jun 25, 2013 8:09 am
It's been some time since I tried out a USB-serial adapter (FWIW some notes are at http://www.cpmspectrepi.webspace.virgin ... apter.html) and, for me, it "just worked", "hardware-wise", IIRC the main issue I had was finding & installing "GtkTerm" to test it (others have used "minicom"). Since you don't seem to have the "/dev...." entry I suspect you may have an "unrecognised" adapter or it's not "installing" properly.
Can you tell us the make/model etc. (and/or provide a web-link). What does "lsusb" report?
Trev.
pluggy
Tue Jun 25, 2013 11:35 am
You can't use ls on /dev/ttyUSB0 even if it is there, because it isn't a directory - its a device which masquerades as a file.
you could 'ls' the /dev folder which should show the /dev/ttyUSB0 device if it is present.
I'd install and use minicom to access the device.
I must not tread on too many sacred cows......
rpdom
Tue Jun 25, 2013 11:56 am
pluggy wrote:You can't use ls on /dev/ttyUSB0 even if it is there, because it isn't a directory - its a device which masquerades as a file.
Of course you can. It'll just display the name of the file.
pi@raspi:~$ ls /dev/ttyUSB0
/dev/ttyUSB0
pi@raspi:~$
pluggy
Tue Jun 25, 2013 12:02 pm
OK, I had a typo when I tried it on my Pi with an old Arduino connected. :mrgreen:
It will only be there if you have certain types of serial adaptors. My newer Arduinos show as /dev/ttyACMx
Joe Schmoe
Tue Jun 25, 2013 12:52 pm
No, you wouldn't. Minicom sucks. Quite seriously, the only time and the only way that minicom can ever qualify as the best solution is when it is the only solution.
I can't believe people keep giving this crappy advice.
psun03
Tue Jun 25, 2013 1:21 pm
Ok now I get what TTYUSB0 is...
could it be a bad usb cable?
psun03
Tue Jun 25, 2013 1:26 pm
bad usb cable :/ thanks all
pluggy
Tue Jun 25, 2013 1:39 pm
Its what I'm currently using since my preferred 'tail' ing the device in bash wouldn't play.
What would you use ?
