solar3000
wayland-weston launch
Fri Jun 21, 2013 4:07 am
OK I give up
I've installed wayland-weston
it runs.
weston-launch starts accelerated gui.
but when I open up the terminal and put in: weston-launch midori
I get:
Date: 2013-06-20 EDT
[23:52:50.081] weston 1.1.0
               http://wayland.freedesktop.org/
               Bug reports to: https://bugs.freedesktop.org/enter_bug.cgi?product=Wayland&component=weston&version=1.1.0
               Build: 1.0.0-448-gcd9b379-dirty Bump version (2013-06-03 14:53:21 +0100)
[23:52:50.083] OS: Linux, 3.6.11+, #474 PREEMPT Thu Jun 13 17:14:42 BST 2013, armv6l
[23:52:50.084] Loading module '/usr/lib/weston/wayland-backend.so'
[23:52:50.085] Failed to load module: /usr/lib/weston/wayland-backend.so: cannot open shared object file: No such file or directory
rmdir: failed to remove `/run/shm/wayland-root-7XqXoX': Directory not empty
Antikythera
Davespice
Contact: Twitter
Re: wayland-weston launch
Fri Jun 21, 2013 3:47 pm
As far as I know this is not yet ready / finished. Correct me if I am wrong though, someone?
So if you install it then it’s probably not going to be in a state where it can be used reliably.
I would expect wayland-weston to be packaged as part of the main Raspbian image, whereupon it will be preconfigured to have an X server in the background that you can use when running X apps etc.
solar3000
Fri Jun 21, 2013 7:24 pm
does this mean x programs like midori and firefox simply won't run under weston/wayland?
Antikythera
pi3g
Authorised Reseller
Authorised Reseller
Wed Jul 03, 2013 10:09 pm
Correctly - to run under Weston / Wayland, X applications need an extension for Wayland, the XWayland server. This extension is not ready / released to the broad public yet.
This XWayland server is a special version of an X Server which ties in with Wayland (it is a client to Wayland, and a server for X applications).
picockpit.com - tools to make your life with the Pi a little bit easier
Joe Schmoe
Wed Jul 03, 2013 10:10 pm
So, ...
What *will* run under W/W ?
